Update defconfigs to remove old symbols and comments referencing old
symbols.
Dropped:
* AVERAGE
* INET_LRO
* EXT3_DEFAULTS_TO_ORDERED
* EXT3_FS_XATTR
* I2O
* INFINIBAND_AMSO1100
* INFINIBAND_EHCA
* IP1000
Replaced:
* BLK_DEV_XIP -> BLK_DEV_RAM_DAX
* CLK_PPC_CORENET -> CLK_QORIQ
* EXT2_FS_XIP -> FS_DAX
* EXT3_FS* -> EXT4_FS*
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
This patch disables deprecated IDE subsystem in mpc834x_itx_defconfig
(no IDE host drivers are selected in this config so there is no valid
reason to enable IDE subsystem itself).
Cc: Scott Wood <oss@buserror.net>
Cc: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Scott Wood <oss@buserror.net>
It looks like it's ~4 years since we updated some of these, so do a bulk
update.
Verified that the before and after generated configs are exactly the
same.
Which begs the question why update them? The answer is that it can be
confusing when the stored defconfig drifts too far from the generated
result.
It no longer occurs in Kconfig.
USB: remove CONFIG_USB_DEVICEFS(fb28d58b) leaked remove defconfig.
Signed-off-by: Naoki MATSUMOTO <nekomatu+linux@gmail.com>
This patch removes CONFIG_MTD_PARTITIONS in config files for powerpc.
Because CONFIG_MTD_PARTITIONS was removed by commit 6a8a98b22b10f1560d5f90aded4a54234b9b2724.
Signed-off-by: Eunbong Song <eunb.song@samsung.com>
Synchronize this defconfig with latest kernel version.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
CONFIG_MTD_NAND_VERIFY_WRITE was killed recently, so remove it from
defconfigs as well.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Switch on UBIFS, HOTPLUG and TIPC and update the config to
the latest kernel version.
cc: Heiko Schocher <hs@denx.de>
This debug option has no overhead other than a slight increase in
kernel size, and makes bug reports more useful. While some end users
may prefer to save the space, as a default on a kernel config aimed
primarily at development on reference boards, it should be enabled.
Beside the MPC 8360 based board kmeter1 other km83xx boards
from keymile will follow. Therefore the board specific naming
kmeter1 for functions and files were replaced with km83xx.
Additionally some updates were made:
- update defconfig for 2.6.38
- rework flash partitioning in dts file
- add gpio controller for qe_pio_c in dts
Acked-by: Heiko Schocher <hs@denx.de>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Heiko Schocher <hs@denx.de>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This trims all our defconfigs using make savedefconfig
a recent fc11 udev update on an 83xx board made root console login
disappear:
Updating : udev-141-8.fc11.ppc 32/83
udev: starting version 141
udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED;
some udev features will not work correctly
and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back.
83xx users looking to run apache will experience this error:
/var/log/apache2/error.log:
[emerg] (38)Function not implemented: Couldn't create pollset in child; check system or user limits
enabling CONFIG_EPOLL in kernel config fixes this so apache can run.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
With flash partition entries in the DTS file, MTD might as well
be enabled in the defconfig. In a similar vein, enable USB and
enough related options (SCSI/ext2/ext3) so that a user can read
and write to a generic USB flash drive as well.
Also, this board only has the two default SOC UARTs, so adjust the
UART config accordingly.
The following series implements basic board support for
the kmeter1 board from keymile, based on a MPC8360.
This series provides the following functionality:
- The board can boot with a serial console on UART1
- Ethernet:
UCC1 in RGMII mode
UCC2 in RGMII mode
UCC4 in RMII mode
UCC5 in RMII mode
UCC6 in RMII mode
UCC7 in RMII mode
UCC8 in RMII mode
following patch is necessary for working UCC in RMII mode:
http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-April/070804.html
- Flash accessed via MTD layer
On this hardware there is an Intel P30 flash, following patch
series is necessary for working with this hardware:
http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-April/070624.html
- I2C using I2C Bus 1 from the MPC8360 cpu
TSEC0 is connected to Vitesse 7385 5-port switch. The switch
isn't connected to any mdio bus, the link to the switch is fixed
to Full-duplex 1000 Mb/s (no pause).
This patch fixes following failure during bootup:
mdio@24520:01 not found
eth0: Could not attach to PHY
IP-Config: Failed to open eth0
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
This is needed so that Vitesse 7385 5-port switch could work on
MPC8349E-mITX boards.
Acked-by: Timur Tabi <timur@freescale.com>
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable
ISDN drivers which seem to be the only place we are using pci_find_device
Because CHRP and PMAC are by default enabled, several non-CHRP and non-PMAC
PowerPC defconfigs will have these Kconfig options set erroneously.
Fix various defconfigs for Freescale chip based boards to remove
CONFIG_PPC_PMAC or CONFIG_PPC_CHRP which crept in due to those
being default y
This patch adds the localbus node, moves the bcsr node into the
localbus node, and adds the flash node.
Also enable MTD support in the defconfig.
Since we are updated defconfigs I went ahead and moved the
asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under
85xx/ as that is where they should have been to start with.
This is patch adds board file, device tree, and defconfig for the new
board, made by Freescale Semiconductor Inc. and Logic Product Development.
Currently supported:
1. UEC{1,2,7,4};
2. I2C;
3. SPI;
4. NS16550 serial;
5. PCI and miniPCI;
6. Intel NOR StrataFlash X16 64Mbit PC28F640P30T85;
7. Graphics controller, Fujitsu MB86277.
Not supported in this patch:
1. StMICRO NAND512W3A2BN6E, 512 Mbit (supported with FSL UPM NAND driver);
2. FHCI USB (supported with FHCI driver).
3. QE Serial UCCs (tested to not work with ucc_uart driver, reason
unknown, yet);
4. ADC AD7843 (tested to work, but support via device tree depends on
major SPI rework, GPIO API, etc);
MDIO-less PHYs should use CONFIG_FIXED_PHY driver and appropriate
fixed-link property in the device tree.
If not, ethernet will not work:
e0024520:03 not found
eth1: Could not attach to PHY
IP-Config: Failed to open eth1
Board specific defconfigs are useful, however with the ability to do
multi-board defconfigs they aren't needed in the top level configs directory
Move the 83xx/85xx board specific defconfigs to individual directories under
arch/powerpc/configs.
