It looks like it's ~4 years since we updated some of these, so do a bulk
update.
Verified that the before and after generated configs are exactly the
same.
Which begs the question why update them? The answer is that it can be
confusing when the stored defconfig drifts too far from the generated
result.
This board has soldered on flash, and a SODIMM flash module.
Both can be used for booting, via switching JP12 and SW2.8
and using the sbc8548-altflash.dts when booting from SODIMM.
Here we enable MTD in kernel so that we can see the bootloader
(and other flash sectors) from linux.
Normal configuration:
root@sbc8548:~# cat /proc/mtd
dev: size erasesize name
mtd0: 007a0000 00020000 "space"
mtd1: 00060000 00020000 "bootloader"
mtd2: 03f00000 00080000 "space"
mtd3: 00100000 00080000 "bootloader"
root@sbc8548:~# dd if=/dev/mtd1 count=1 bs=48|hexdump -C
1+0 records in
1+0 records out
00000000 27 05 19 56 55 2d 42 6f 6f 74 20 32 30 31 32 2e |'..VU-Boot 2012.|
00000010 31 30 2d 64 69 72 74 79 20 28 4a 61 6e 20 31 39 |10-dirty (Jan 19|
00000020 20 32 30 31 33 20 2d 20 31 39 3a 34 30 3a 31 31 | 2013 - 19:40:11|
00000030
root@sbc8548:~# dd if=/dev/mtd3 count=1 bs=48|hexdump -C
1+0 records in
1+0 records out
00000010 31 30 2d 64 69 72 74 79 20 28 44 65 63 20 31 33 |10-dirty (Dec 13|
00000020 20 32 30 31 32 20 2d 20 31 35 3a 30 30 3a 30 37 | 2012 - 15:00:07|
00000030
root@sbc8548:~#
Alternate configuration, with sbc8548-altflash.dts:
mtd0: 03f00000 00080000 "space"
mtd1: 00100000 00080000 "bootloader"
mtd2: 007a0000 00020000 "space"
mtd3: 00060000 00020000 "bootloader"
1+0 records in
1+0 records out
00000030
1+0 records in
1+0 records out
00000030
root@sbc8548:~#
Note that in the latter, the larger SODIMM device appears 1st,
as mtd0 and mtd1, as indicated in the sizes, and in the date
of the u-boot image.
The kernel configuration is the same in both cases; only the dtb
needs to be changed in accordance with the JP12/SW2.8 settings.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This trims all our defconfigs using make savedefconfig
a recent fc11 udev update on an 83xx board made root console login
disappear:
Updating : udev-141-8.fc11.ppc 32/83
udev: starting version 141
udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED;
some udev features will not work correctly
and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable
ISDN drivers which seem to be the only place we are using pci_find_device
Since we are updated defconfigs I went ahead and moved the
asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under
85xx/ as that is where they should have been to start with.
Board specific defconfigs are useful, however with the ability to do
multi-board defconfigs they aren't needed in the top level configs directory
Move the 83xx/85xx board specific defconfigs to individual directories under
arch/powerpc/configs.
