In commit 73d8ef76006b ("Input: mousedev - stop offering PS/2 to
userspace by default") the symbol INPUT_MOUSEDEV went from being
'default y' to 'default n' (implied).
That means we no longer need to explicitly disable it in our
defconfigs.
Since commit 401e4238f35c ("crypto: rng - Make DRBG the default RNG") we no longer need to set CONFIG_CRYPTO_ANSI_CPRNG in our defconfigs.
Update defconfigs for symbols that have moved around, without their
value changing.
Update defconfigs to remove old symbols and comments referencing old
symbols.
Dropped:
* AVERAGE
* INET_LRO
* EXT3_DEFAULTS_TO_ORDERED
* EXT3_FS_XATTR
* I2O
* INFINIBAND_AMSO1100
* INFINIBAND_EHCA
* IP1000
Replaced:
* BLK_DEV_XIP -> BLK_DEV_RAM_DAX
* CLK_PPC_CORENET -> CLK_QORIQ
* EXT2_FS_XIP -> FS_DAX
* EXT3_FS* -> EXT4_FS*
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
It looks like it's ~4 years since we updated some of these, so do a bulk
update.
Verified that the before and after generated configs are exactly the
same.
Which begs the question why update them? The answer is that it can be
confusing when the stored defconfig drifts too far from the generated
result.
This patch removes CONFIG_MTD_PARTITIONS in config files for powerpc.
Because CONFIG_MTD_PARTITIONS was removed by commit 6a8a98b22b10f1560d5f90aded4a54234b9b2724.
Signed-off-by: Eunbong Song <eunb.song@samsung.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This trims all our defconfigs using make savedefconfig
a recent fc11 udev update on an 83xx board made root console login
disappear:
Updating : udev-141-8.fc11.ppc 32/83
udev: starting version 141
udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED;
some udev features will not work correctly
and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable
ISDN drivers which seem to be the only place we are using pci_find_device
Since we are updated defconfigs I went ahead and moved the
asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under
85xx/ as that is where they should have been to start with.
Board specific defconfigs are useful, however with the ability to do
multi-board defconfigs they aren't needed in the top level configs directory
Move the 83xx/85xx board specific defconfigs to individual directories under
arch/powerpc/configs.
