Update defconfigs to remove old symbols and comments referencing old
symbols.
Dropped:
* AVERAGE
* INET_LRO
* EXT3_DEFAULTS_TO_ORDERED
* EXT3_FS_XATTR
* I2O
* INFINIBAND_AMSO1100
* INFINIBAND_EHCA
* IP1000
Replaced:
* BLK_DEV_XIP -> BLK_DEV_RAM_DAX
* CLK_PPC_CORENET -> CLK_QORIQ
* EXT2_FS_XIP -> FS_DAX
* EXT3_FS* -> EXT4_FS*
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
It looks like it's ~4 years since we updated some of these, so do a bulk
update.
Verified that the before and after generated configs are exactly the
same.
Which begs the question why update them? The answer is that it can be
confusing when the stored defconfig drifts too far from the generated
result.
by 8 on Powerpc 8xx.
On PPC_8xx, CRC32_SLICEBY4 is more efficient (almost twice) than CRC32_SLICEBY8,
as shown below:
With CRC32_SLICEBY8:
[ 1.109204] crc32: CRC_LE_BITS = 64, CRC_BE BITS = 64
[ 1.114401] crc32: self tests passed, processed 225944 bytes in 15118910 nsec
[ 1.130655] crc32c: CRC_LE_BITS = 64
[ 1.134235] crc32c: self tests passed, processed 225944 bytes in 4479879 nsec
With CRC32_SLICEBY4:
[ 1.097129] crc32: CRC_LE_BITS = 32, CRC_BE BITS = 32
[ 1.101878] crc32: self tests passed, processed 225944 bytes in 8616242 nsec
[ 1.116298] crc32c: CRC_LE_BITS = 32
[ 1.119607] crc32c: self tests passed, processed 225944 bytes in 3289576 nsec
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This trims all our defconfigs using make savedefconfig
On 5 May 2010 21:33, "Anton Blanchard" <anton@samba.org> wrote:
CONFIG_SYSFS_DEPRECATED can cause issues with newer distros and should not
be required for any distro in the last 3 or 4 years, so disable it.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable
ISDN drivers which seem to be the only place we are using pci_find_device
Since we are updated defconfigs I went ahead and moved the
asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under
85xx/ as that is where they should have been to start with.
This updates all the defconfigs in arch/powerpc/configs except iseries
and ps3, which were updated by the preceding commits.
This mostly takes the defaults, except that I turned on tickless idle
and high-resolution timers for everything, and turned off instrumentation
support and "Fair group CPU scheduler" for the smaller/embedded platforms.
This board is also resold by Freescale under the names
"QUICCStart MPC885 Evaluation System" and "CWH-PPC-885XN-VE".
