path: root/arch/powerpc/configs/iseries_defconfig
2008-05-20[POWERPC] Update defconfigs for desktop/server systemsPaul Mackerras
2008-04-07[POWERPC] Remove CONFIG_PCI_LEGACY from some configsStephen Rothwell
This will remove some build warnings and doesn't stop us building any drivers that we were building previously with these configs. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-20[POWERPC] Update some defconfigsPaul Mackerras
2007-12-06[POWERPC] Update iseries_defconfigStephen Rothwell
The notable changes here are the enabling of NO_HZ and HIGH_RES_TIMERS. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-30[POWERPC] Update defconfigsPaul Mackerras
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-05-17[POWERPC] Update iseries_defconfigStephen Rothwell
2007-01-22[POWERPC] Update defconfigsPaul Mackerras
Mostly took the defaults, except tried to get the netfilter options more or less as they were before. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-07[POWERPC] Update iseries_defconfigStephen Rothwell
This make sure that an iseries_defconfig does not inlude other platforms. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-26[POWERPC] update powerpc defconfig files after libata kconfig breakageOlaf Hering
Update defconfig files after libata .config breakage sed -i 's/CONFIG_SCSI_SATA_/CONFIG_SATA_/;s/CONFIG_SCSI_SATA/CONFIG_ATA/' arch/powerpc/configs/*g Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-10[POWERPC] Update defconfigsPaul Mackerras
2006-08-17[POWERPC] update {g5,iseries,pseries}_defconfigsWill Schmidt
Updating the defconfigs for iseries, pseries, and G5. Sticking with the defaults, with the following exceptions: I've turned off HW_RANDOM for all three configs. For G5, I've enabled SND_AOA and friends as modules; this includes the FABRIC_LAYOUT, ONYX, TAS, TOONIE and SOUNDBUS* config options. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-21[PATCH] powerpc: update {g5,iseries,pseries}_defconfigsWill Schmidt
Default choices for all. Signed-off-by: Will Schmidt <willschm@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-16powerpc: update defconfigsPaul Mackerras
2006-01-18[PATCH] e1000: Added disable packet split capabilityJesse Brandeburg
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: John Ronciak <john.ronciak@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-20powerpc: update defconfigsPaul Mackerras
2005-11-16[PATCH] powerpc: update defconfigsBenjamin Herrenschmidt
My patch moving ppc64 RTC to genrtc was supposed to update all defconfigs, but for some reason, the patch actually posted only had the pseries one... ouch. This patch properly updates all defconfigs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-03powerpc: Copy default configs into arch/powerpc/configsMichael Ellerman
Copy default configs into arch/powerpc/configs, rename bpa_defconfig to cell_defconfig while we're at it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
