path: root/arch/powerpc/configs/mpc8272_ads_defconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09powerpc: Trim defconfigsBenjamin Herrenschmidt
This trims all our defconfigs using make savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-19powerpc: 2.6.34 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2010-04-19powerpc/mpc8xxx defconfigs - turn off SYSFS_DEPRECATEDKim Phillips
a recent fc11 udev update on an 83xx board made root console login disappear: Updating : udev-141-8.fc11.ppc 32/83 udev: starting version 141 udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED; some udev features will not work correctly and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-06powerpc: 2.6.33 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2009-11-05powerpc: 2.6.32 update of defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
Updated mpc85xx_{smp_}defconfig to enable: * XES_MPC85xx board * PCI MSI * RapidIO Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc: Update defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
2009-05-13powerpc/embedded6xx: Update defconfigsKumar Gala
2009-01-26powerpc/embedded6xx: Update defconfigsKumar Gala
2008-11-08powerpc: Updated Freescale PPC related defconfigsKumar Gala
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable ISDN drivers which seem to be the only place we are using pci_find_device Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-13powerpc: disable CHRP and PMAC support in various defconfigsTimur Tabi
Because CHRP and PMAC are by default enabled, several non-CHRP and non-PMAC PowerPC defconfigs will have these Kconfig options set erroneously. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-07powerpc: Remove CHRP and PMAC support from FSL defconfigsTimur Tabi
Fix various defconfigs for Freescale chip based boards to remove CONFIG_PPC_PMAC or CONFIG_PPC_CHRP which crept in due to those being default y Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-08-21powerpc: Update defconfigs for FSL PPC boardsKumar Gala
Since we are updated defconfigs I went ahead and moved the asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under 85xx/ as that is where they should have been to start with. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09[POWERPC] Updated Freescale PPC defconfigsKumar Gala
2008-03-24[POWERPC] Update some defconfigsKumar Gala
2007-12-13[POWERPC] 82xx: mpc8272ads, pq2fads: Update defconfig with ↵Scott Wood
CONFIG_FS_ENET_MDIO_FCC This was recently made configurable, and needs to be set for these boards. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-06[POWERPC] Update defconfigsPaul Mackerras
This updates all the defconfigs in arch/powerpc/configs except iseries and ps3, which were updated by the preceding commits. This mostly takes the defaults, except that I turned on tickless idle and high-resolution timers for everything, and turned off instrumentation support and "Fair group CPU scheduler" for the smaller/embedded platforms. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-04[POWERPC] mpc82xx: Update mpc8272ads, and factor out PCI and reset.Scott Wood
1. PCI and reset are factored out into pq2.c. I renamed them from m82xx to pq2 because they won't work on the Integrated Host Processor line of 82xx chips (i.e. 8240, 8245, and such). 2. The PCI PIC, which is nominally board-specific, is used on multiple boards, and thus is used into pq2ads-pci-pic.c. 3. The new CPM binding is used. 4. General cleanup. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-29[POWERPC] Update defconfigsKumar Gala
2007-07-02[POWERPC] Update defconfigsKumar Gala
2007-02-07[POWERPC] mpc8272ads: defconfigVitaly Bordug
Default config file for mpc8272ads (powerpc port).Though relevant bits went in, it is required to keep proper default configuration for the target, which seems to be missed initially. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
