Enable I2C char dev interface for user space testing of I2C controler.
Enable the I2C driver on 64-bit builds (corenet64_smp_defconfig) as it
was missing.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Remove the "select PHYS_64BIT" from the Kconfig entry for the P1022DS,
so that large physical address support is a selectable option for non-CoreNet
reference boards.
The option is enabled in mpc85xx_[smp_]defconfig so that the default is
unchanged. However, now it can be deselected.
The P1022DS had this option defined because the default device tree for
this board uses 36-bit addresses. This had the side-effect of forcing
this option on for all boards that use mpc85xx_[smp_]defconfig. Some
users may want to disable this feature to create an optimized configuration
for boards with <= 2GB of RAM.
corenet64_smp_defconfig:
- enabled rapidio
corenet32_smp_defconfig:
- enabled hugetlbfs, rapidio
mpc85xx_smp_defconfig:
- enabled P1010RDB, hugetlbfs, SPI, SDHC, Crypto/CAAM
- enabled hugetlbfs, SPI, SDHC, Crypto/CAAM
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Results from updates via make savedefconfig.
Move the driver to the place where it is expected to be nowadays. Also
rename its CONFIG-name to match the rest and adapt the defconfigs.
Finally, move selection of REQUIRE_GPIOLIB or WANTS_OPTIONAL_GPIOLIB to
the platforms, because this option is per-platform and not per-driver.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Enable the audio drivers in the non-corenet 85xx defconfigs so that audio
is enabled on the Freescale P1022DS reference board.
P1010RDB Overview
1Gbyte DDR3 (on board DDR)
32Mbyte 16bit NOR flash
32Mbyte SLC NAND Flash
256 Kbit M24256 I2C EEPROM
128 Mbit SPI Flash memory
I2C Board 128x8 bit memory
SD/MMC connector to interface with the SD memory card
2 SATA interface
1 internal SATA connect to 2.5. 160G SATA2 HDD
1 eSATA connector to rear panel
USB 2.0
x1 USB 2.0 port: connected via a UTMI PHY to Mini-AB interface.
x1 USB 2.0 port: directly connected to Mini-AB interface Ethernet
eTSEC1: Connected to RGMII PHY VSC8641XKO
eTSEC2: Connected to SGMII PHY VSC8221
eTSEC3: Connected to SGMII PHY VSC8221 eCAN
Two DB-9 female connectors for Field bus interface UART
DUART interface: supports two UARTs up to 115200 bps for console display
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Enable framebuffer console support by default in the defconfigs for the
Freescale 85xx-based reference board. This allows the boot messages to
be shown on the video display on the P1022DS.
The P1023 processor is an e500v2 based SoC that utilizes the DPAA
networking architecture. This adds basic board support for non-DPAA
functionality (device tree, board file, etc).
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
This debug option has no overhead other than a slight increase in
kernel size, and makes bug reports more useful. While some end users
may prefer to save the space, as a default on a kernel config aimed
primarily at development on reference boards, it should be enabled.
Uwe Kleine-König reported:
while working on an defconfig (arm/mx27) I noticed that just updating
it[1] results in removing CONFIG_EEPROM_AT24=y. The reason is that
since commit
v2.6.36-5965-g5f2365d (misc devices: do not enable by default)
MISC_DEVICES isn't enabled anymore by default. So all defconfigs that
have CONFIG_SOME_SYMBOL=y (or =m) (with SOME_SYMBOL depending on
MISC_DEVICES) but not CONFIG_MISC_DEVICES=y suffer from the same
problem.
This restores those misc devices to the powerpc defconfigs.
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de
Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Acked-by: Uwe Kleine-König
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
The Freescale P1022DS has an on-chip video controller called the DIU, and a
driver for this device already exists. Update the platform file for the
P1022DS reference board to enable the driver, and update the defconfig for
Freescale MPC85xx boards to add the driver.
[Edited to resolve header add/add conflict and drop #define DEBUG.
-- broonie]
Acked-by: Kumar Gala <kumar.gala@freescale.com>
This trims all our defconfigs using make savedefconfig
Introduce basic support for the Freescale P1022DS reference board, based on the
Freescale BSP for this board. This patch excludes the DIU, SSI, and MMC/SD
drivers. Only a 36-bit DTS is provided.
Update mpc86xx_smp_defconfig and mpc85xx_defconfig to support the P1022DS.
This means enabling 64-bit physical address support, increasing the maximum
zone order to 12 (to allow the DIU driver to allocate large chunks), and
clean up the audio options to disable the deprecated OSS support.
a recent fc11 udev update on an 83xx board made root console login
disappear:
Updating : udev-141-8.fc11.ppc 32/83
udev: starting version 141
udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED;
some udev features will not work correctly
and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
Add support for the P2020RDB reference board from Freescale.
Overview of P2020RDB platform
- DDR
DDR2 1G
- NOR Flash
16MByte
- NAND Flash
32MByte
- 3 Ethernet interfaces
1) etSEC1
- RGMII
- connected to a 5 port Vitesse Switch(VSC7385)
- Switch is memory mapped through eLBC interface(CS#2)
- IRQ1
2) etSEC2
- SGMII
- connected to VSC8221
- IRQ2
3) etSEC3
- RGMII
- connected to VSC8641
- IRQ3
- 2 1X PCIe interfaces
- SD/MMC ,USB
- SPI EEPROM
- Serial I2C EEPROM
* Add new 85xx boards
* Added QE/FSL gpio
* Enabled PHY drivers that exist on various boards
* Enabled FS_ENET & UCC ethernet drivers (CPM2 & QE)
* FSL HW Crypto Engine
* CPM I2C
* QE Serial
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable
ISDN drivers which seem to be the only place we are using pci_find_device
Since we are updated defconfigs I went ahead and moved the
asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under
85xx/ as that is where they should have been to start with.
The defconfigs for Freescale 85xx and 86xx SOCs had bad choices for some
audio related options. In particular, OSS emulation should be enabled,
and the old ALSA API should be disabled.
The new rtc subsystem conflicts with genrtc so don't enable GENRTC
if RTCLIB is enabled.
* Allow multiple boards to be selected in a single build
* Removed Kconfig option '85xx' which existed only for compat with arch/ppc
* Added a multiplatform 85xx defconfig (mpc85xx_defconfig). This builds
all 85xx boards except sbc8560 and stx_gp3 since these to boards have
board specific ifdef in driver code that may break all other boards
