path: root/arch/powerpc/configs/pasemi_defconfig
2016-07-08powerpc/configs: Remove old symbols from defconfigsAndrew Donnellan
Update defconfigs to remove old symbols and comments referencing old symbols. Dropped: * AVERAGE * INET_LRO * EXT3_DEFAULTS_TO_ORDERED * EXT3_FS_XATTR * I2O * INFINIBAND_AMSO1100 * INFINIBAND_EHCA * IP1000 Replaced: * BLK_DEV_XIP -> BLK_DEV_RAM_DAX * CLK_PPC_CORENET -> CLK_QORIQ * EXT2_FS_XIP -> FS_DAX * EXT3_FS* -> EXT4_FS* Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-01-20powerpc: Update all configs using savedefconfigMichael Ellerman
It looks like it's ~4 years since we updated some of these, so do a bulk update. Verified that the before and after generated configs are exactly the same. Which begs the question why update them? The answer is that it can be confusing when the stored defconfig drifts too far from the generated result. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-03powerpc: Don't build powernv for other platform defconfigsMichael Ellerman
Because powernv arrived after these other platforms, the defconfigs didn't have PPC_POWERNV disabled, and being default y it gets turned on. If we're going to bother having defconfigs for the specific platforms then they should only build the code required for those platforms. The grab bag of everything config is ppc64_defconfig. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-09-09powerpc: Make CONFIG_FHANDLE=y for all 64 bit powerpc defconfigsCyril Bur
CONFIG_FHANDLE is a requirement for systemd and with the increasing uptake of systemd within distros it makes sense for 64 bit defconfigs to include it. Signed-off-by: Cyril Bur <cyril.bur@au1.ibm.com>
2013-12-10powerpc/pasemi: Turn on devtmpfs in defconfigOlof Johansson
At least some distros expect it these days; turn it on. Also, random churn from doing a savedefconfig for the first time in a year or so. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-10powerpc/pasemi: Enable PRINTK_TIME in defconfigOlof Johansson
Enable PRINTK_TIME in pasemi_defconfig. Also regenerate it, it seems that a lot of options have moved around since last time savedefconfig was ran on it. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc: Remove CONFIG_POWER4_ONLYAnton Blanchard
Remove CONFIG_POWER4_ONLY, the option is badly named and only does two things: - It wraps the MMU segment table code. With feature fixups there is little downside to compiling this in. - It uses the newer mtocrf instruction in various assembly functions. Instead of making this a compile option just do it at runtime via a feature fixup. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc: Restore some misc devices to our configsStephen Rothwell
Uwe Kleine-König reported: while working on an defconfig (arm/mx27) I noticed that just updating it[1] results in removing CONFIG_EEPROM_AT24=y. The reason is that since commit v2.6.36-5965-g5f2365d (misc devices: do not enable by default) MISC_DEVICES isn't enabled anymore by default. So all defconfigs that have CONFIG_SOME_SYMBOL=y (or =m) (with SOME_SYMBOL depending on MISC_DEVICES) but not CONFIG_MISC_DEVICES=y suffer from the same problem. This restores those misc devices to the powerpc defconfigs. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Uwe Kleine-König Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-09powerpc: Trim defconfigsBenjamin Herrenschmidt
This trims all our defconfigs using make savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-15powerpc: Disable CONFIG_SYSFS_DEPRECATEDGrant Likely
Acked-by: Grant Likely <grant.likely@secretlab.ca> On 5 May 2010 21:33, "Anton Blanchard" <anton@samba.org> wrote: CONFIG_SYSFS_DEPRECATED can cause issues with newer distros and should not be required for any distro in the last 3 or 4 years, so disable it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-11powerpc: pasemi_defconfig updateOlof Johansson
pasemi_defconfig hasn't been updated for a year. Mostly a refresh of defaults, but this also disables 64K pages. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-05-27[POWERPC] pasemi: update pasemi_defconfig, enable electra_cfOlof Johansson
Refresh pasemi_defconfig and enable ELECTRA_CF=y. Signed-off-by: Olof Johansson <olof@lixom.net>
2008-03-25[POWERPC] update pasemi_defconfigOlof Johansson
Disable GEN_RTC since it conflicts with the i2c rtc drivers registering, besides that keep most of the new defaults. Signed-off-by: Olof Johansson <olof@lixom.net>
2008-01-15[POWERPC] pasemi: Move electra-ide to pata_of_platformOlof Johansson
Move electra-ide glue over to the new pata_of_platform framework, and add the quirks needed to that driver. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-28[POWERPC] Enable CONFIG_PCI_MSI and CONFIG_MD in pasemi_defconfigOlof Johansson
Enable MSI now that we have an implementation, and enable CONFIG_MD and the raid options by default as well. Signed-off-by: Olof Johansson <olof@lixom.net>
2007-12-06[POWERPC] Update defconfigsPaul Mackerras
This updates all the defconfigs in arch/powerpc/configs except iseries and ps3, which were updated by the preceding commits. This mostly takes the defaults, except that I turned on tickless idle and high-resolution timers for everything, and turned off instrumentation support and "Fair group CPU scheduler" for the smaller/embedded platforms. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-08[POWERPC] pasemi: Update defconfigOlof Johansson
Update pasemi_defconfig. Add a few missing options for default devices on electra boards, enable tickless and hrtimers, etc, etc. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-30[POWERPC] Update defconfigsPaul Mackerras
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-05-17[POWERPC] Update pasemi_defconfigOlof Johansson
Update pasemi_defconfig, add new relevant drivers. Take out CONFIG_PPC_PSERIES, it should't have been enabled in the first place. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] pasemi: defconfigOlof Johansson
Base pasemi defconfig. Nothing special, just the native drivers plus common PCI-express/PCI cards. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
