This will remove some build warnings and doesn't stop us building any
drivers that we were building previously with these configs.
This updates all the defconfigs in arch/powerpc/configs except iseries
and ps3, which were updated by the preceding commits.
This mostly takes the defaults, except that I turned on tickless idle
and high-resolution timers for everything, and turned off instrumentation
support and "Fair group CPU scheduler" for the smaller/embedded platforms.
Refresh ppc64_defconfig, add PPC_PASEMI and various options that the
common boards there need:
* Chip drivers (iommu, ethernet, IDE, CF, EDAC, MDIO/PHY)
* PCMCIA
* PATA_PCMCIA
* RTC_CLASS
* SATA_MV
* SATA_SIL24
* IP_PNP + NFS_ROOT for diskless booting
+ possibly some other things I might have missed to list
In pre-cgroup cpusets, a few config files enabled cpusets by default.
Signed-off-by: Paul Jackson <pj@sgi.com>
Cc: Paul Menage <menage@google.com>
Enable NO_HZ and high res timers for the ppc64 and pseries defconfigs.
When checking out the new NO_HZ support in powerpc, I noticed we never
slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu
timer that causes this.
After switching to SLUB I see some nice 4 second sleeps which is the
limit on this POWER6 box (the decrementer ticks at 512MHz):
slept 4.19 sec
slept 4.19 sec
slept 4.19 sec
slept 4.19 sec
slept 3.96 sec
slept 3.80 sec
slept 2.99 sec
Since SLUB is now the default and some powerpc defconfigs already enable
it, lets enable SLUB across the board for consistency. While doing this
I also noticed that the maple defconfig has SLAB debugging enabled which
is sure to make your box nice and slow. Fix that too.
Rename MPIC_BROKEN_U3 to something a little more descriptive. Its
effect is to enable support for HT irqs behind the PCI-X/HT bridge on
U3/U4 (aka. CPC9x5) parts.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Change the default for the built-in IDE on p610/p615/p630 from
ide to libata. libata has better error handling and the drive can
recover when hald does its CD media polling.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Mostly took the defaults, except tried to get the netfilter options
more or less as they were before.
Since we can now boot legacy iSeries and other machines with the same
config, enable legacy iSeries in ppc64_defconfig.
Enabled new netfilter stuff corresponding to what was enabled before
under different names, and turned on the gxt4500 video driver;
otherwise just took the defaults.
Defconfig ppc64 kernels running under late-model distros
may hang in the automounter rc.d script, which seems to be
expecting autofs version 4. This patch uses the newer autofs.
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
Update defconfig files after libata .config breakage
sed -i 's/CONFIG_SCSI_SATA_/CONFIG_SATA_/;s/CONFIG_SCSI_SATA/CONFIG_ATA/' arch/powerpc/configs/*g
Enable the onboard IDE driver for p610, p615 and p630.
They have the CD connected to this card. All other RS/6000 systems with this
controller have no connectors and dont need this option.
Signed-off-by: Olaf Hering <olh@suse.de>
Update defconfigs for g5, pseries and generic ppc64. Default choices
for everything, with the following exceptions:
* Enable WINDFARM_PM112 on g5 and ppc64.
* Increase CONFIG_NR_CPUS to 4 in g5_defconfig
* CONFIG_TIGON3=y instead of =m in g5_defconfig
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option.
Signed-off-by: John Ronciak <john.ronciak@intel.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Enable the RTC driver.
Changes to the serial driver to remove flip buffers have broken the serial
jsm driver. It doesn't even compile anymore. The jsm driver was enabled
in only one defconfig - ppc64. In order to keep defconfigs building,
disable CONFIG_SERIAL_JSM for the time being.
make defconfig will now use arch/powerpc/configs/ppc64_defconfig
if running on a ppc64 system. I need to add an
arch/powerpc/configs/ppc_defconfig sometime.
