path: root/arch/powerpc/configs/ppc64_defconfig
2008-05-20[POWERPC] Update defconfigs for desktop/server systemsPaul Mackerras
2008-04-07[POWERPC] Remove CONFIG_PCI_LEGACY from some configsStephen Rothwell
This will remove some build warnings and doesn't stop us building any drivers that we were building previously with these configs. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-20[POWERPC] Update some defconfigsPaul Mackerras
2007-12-21[POWERPC] Add EHEA and EHCA as modules in the ppc64_defconfigStephen Rothwell
2007-12-06[POWERPC] Update defconfigsPaul Mackerras
This updates all the defconfigs in arch/powerpc/configs except iseries and ps3, which were updated by the preceding commits. This mostly takes the defaults, except that I turned on tickless idle and high-resolution timers for everything, and turned off instrumentation support and "Fair group CPU scheduler" for the smaller/embedded platforms. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-08[POWERPC] Refresh ppc64_defconfig and enable pasemi-related optionsOlof Johansson
Refresh ppc64_defconfig, add PPC_PASEMI and various options that the common boards there need: * Chip drivers (iommu, ethernet, IDE, CF, EDAC, MDIO/PHY) * PCMCIA * PATA_PCMCIA * RTC_CLASS * SATA_MV * SATA_SIL24 * IP_PNP + NFS_ROOT for diskless booting + possibly some other things I might have missed to list Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-19task cgroups: enable cgroups by default in some configsPaul Jackson
In pre-cgroup cpusets, a few config files enabled cpusets by default. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17[POWERPC] Enable NO_HZ and high res timers for pseries and ppc64 configsAnton Blanchard
Enable NO_HZ and high res timers for the ppc64 and pseries defconfigs. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-30[POWERPC] Update defconfigsPaul Mackerras
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-04-24[POWERPC] Rename MPIC_BROKEN_U3 to MPIC_U3_HT_IRQSMichael Ellerman
Rename MPIC_BROKEN_U3 to something a little more descriptive. Its effect is to enable support for HT irqs behind the PCI-X/HT bridge on U3/U4 (aka. CPC9x5) parts. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-17[POWERPC] use winbond libata instead of ide driver for pseries CD drivesOlaf Hering
Change the default for the built-in IDE on p610/p615/p630 from ide to libata. libata has better error handling and the drive can recover when hald does its CD media polling. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-22[POWERPC] Update defconfigsPaul Mackerras
Mostly took the defaults, except tried to get the netfilter options more or less as they were before. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-09[POWERPC] Add legacy iSeries to ppc64_defconfigStephen Rothwell
Since we can now boot legacy iSeries and other machines with the same config, enable legacy iSeries in ppc64_defconfig. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-09[POWERPC] Update ppc64_defconfigStephen Rothwell
Enabled new netfilter stuff corresponding to what was enabled before under different names, and turned on the gxt4500 video driver; otherwise just took the defaults. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Change ppc64_defconfig to use AUTOFS_V4 not V3Linas Vepstas
Defconfig ppc64 kernels running under late-model distros may hang in the automounter rc.d script, which seems to be expecting autofs version 4. This patch uses the newer autofs. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-26[POWERPC] update powerpc defconfig files after libata kconfig breakageOlaf Hering
Update defconfig files after libata .config breakage sed -i 's/CONFIG_SCSI_SATA_/CONFIG_SATA_/;s/CONFIG_SCSI_SATA/CONFIG_ATA/' arch/powerpc/configs/*g Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-10[POWERPC] Update defconfigsPaul Mackerras
2006-03-16[PATCH] powerpc/64: enable CONFIG_BLK_DEV_SL82C105Olaf Hering
Enable the onboard IDE driver for p610, p615 and p630. They have the CD connected to this card. All other RS/6000 systems with this controller have no connectors and dont need this option. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc: Update {g5,pseries,ppc64}_defconfigOlof Johansson
Update defconfigs for g5, pseries and generic ppc64. Default choices for everything, with the following exceptions: * Enable WINDFARM_PM112 on g5 and ppc64. * Increase CONFIG_NR_CPUS to 4 in g5_defconfig * CONFIG_TIGON3=y instead of =m in g5_defconfig Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-18[PATCH] e1000: Added disable packet split capabilityJesse Brandeburg
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: John Ronciak <john.ronciak@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-11[PATCH] enable the RTC driver in ppc64_defconfigOlaf Hering
Enable the RTC driver. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-10[PATCH] Serial: disable jsm in ppc64 defconfigPaul Jackson
Changes to the serial driver to remove flip buffers have broken the serial jsm driver. It doesn't even compile anymore. The jsm driver was enabled in only one defconfig - ppc64. In order to keep defconfigs building, disable CONFIG_SERIAL_JSM for the time being. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-20powerpc: update defconfigsPaul Mackerras
2005-11-18powerpc: Move defconfig over and remove remaining arch/ppc64 filesPaul Mackerras
make defconfig will now use arch/powerpc/configs/ppc64_defconfig if running on a ppc64 system. I need to add an arch/powerpc/configs/ppc_defconfig sometime. Signed-off-by: Paul Mackerras <paulus@samba.org>
