path: root/arch/powerpc/configs/prpmc2800_defconfig
2014-03-07powerpc: Delete old PrPMC 280/2800 supportPaul Gortmaker
This processor/memory module was mostly used on ATCA blades and before that, on cPCI blades. It wasn't really user friendly, with custom non u-boot bootloaders (powerboot/motload) and no real way to recover corrupted boot flash (which was a common problem). As such, it had its day back before the big ppc --> powerpc move to device trees, and that was largely through commercial BSPs that started to dry up around 2007. Systems using one were largely in a "deploy and sustain" mode, so interest in upgrading to new kernels in the field was nil. Also, requiring 50A, 48V power supplies and a 2'x2'x2' ATCA chassis largely rules out any hobbyist/enthusiast interest. The point of all this, is that we might as well delete the in kernel files relating to this platform. No point in continuing to build it via walking the defconfigs or via linux-next testing. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-03-07powerpc: : Kill CONFIG_MTD_PARTITIONS송은봉
This patch removes CONFIG_MTD_PARTITIONS in config files for powerpc. Because CONFIG_MTD_PARTITIONS was removed by commit 6a8a98b22b10f1560d5f90aded4a54234b9b2724. Signed-off-by: Eunbong Song <eunb.song@samsung.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-09powerpc: Trim defconfigsBenjamin Herrenschmidt
This trims all our defconfigs using make savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-15powerpc: Disable CONFIG_SYSFS_DEPRECATEDGrant Likely
Acked-by: Grant Likely <grant.likely@secretlab.ca> On 5 May 2010 21:33, "Anton Blanchard" <anton@samba.org> wrote: CONFIG_SYSFS_DEPRECATED can cause issues with newer distros and should not be required for any distro in the last 3 or 4 years, so disable it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-19powerpc: 2.6.34 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2010-01-06powerpc: 2.6.33 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2009-11-05powerpc: 2.6.32 update of defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
Updated mpc85xx_{smp_}defconfig to enable: * XES_MPC85xx board * PCI MSI * RapidIO Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc: Update defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
2009-05-13powerpc/embedded6xx: Update defconfigsKumar Gala
2009-01-28Merge commit 'kumar/kumar-merge' into mergeBenjamin Herrenschmidt
2009-01-26powerpc/embedded6xx: Update defconfigsKumar Gala
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-11-08powerpc: Updated Freescale PPC related defconfigsKumar Gala
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable ISDN drivers which seem to be the only place we are using pci_find_device Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21powerpc: Update defconfigs for FSL PPC boardsKumar Gala
Since we are updated defconfigs I went ahead and moved the asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under 85xx/ as that is where they should have been to start with. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09[POWERPC] Updated Freescale PPC defconfigsKumar Gala
2008-03-31[POWERPC] Fix defconfigs so we dont set both GENRTC and RTCLIBKumar Gala
The new rtc subsystem conflicts with genrtc so don't enable GENRTC if RTCLIB is enabled. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-24[POWERPC] Update some defconfigsKumar Gala
2007-12-06[POWERPC] Update defconfigsPaul Mackerras
This updates all the defconfigs in arch/powerpc/configs except iseries and ps3, which were updated by the preceding commits. This mostly takes the defaults, except that I turned on tickless idle and high-resolution timers for everything, and turned off instrumentation support and "Fair group CPU scheduler" for the smaller/embedded platforms. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-29[POWERPC] Update defconfigsKumar Gala
2007-07-22[POWERPC] Fix misspelled "CONFIG_CHECK_CACHE_COHERENCY" Kconfig option.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-05-12[POWERPC] Add arch/powerpc support for the Motorola PrPMC2800Dale Farnsworth
This finally adds the PPC_PRPMC2800 Kconfig option, the board setup code (the setup and reset functions) and the defconfig, to support the Motorola PrPMC2800 platform. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
