path: root/arch/powerpc/include/asm/atomic.h
2010-02-17powerpc: Rename LWSYNC_ON_SMP to PPC_RELEASE_BARRIER, ISYNC_ON_SMP to ↵Anton Blanchard
PPC_ACQUIRE_BARRIER For performance reasons we are about to change ISYNC_ON_SMP to sometimes be lwsync. Now that the macro name doesn't make sense, change it and LWSYNC_ON_SMP to better explain what the barriers are doing. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15powerpc: Use generic atomic64_t implementation on 32-bit processorsPaul Mackerras
This makes 32-bit powerpc use the generic atomic64_t implementation. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-01-06atomic_t: unify all arch definitionsMatthew Wilcox
The atomic_t type cannot currently be used in some header files because it would create an include loop with asm/atomic.h. Move the type definition to linux/types.h to break the loop. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19powerpc: Tell gcc when we clobber the carry in inline asmPaul Mackerras
We have several instances of inline assembly code that use the addic or addic. instructions, but don't include XER in the list of clobbers. The addic and addic. instructions affect the carry bit, which is in the XER register. This adds "xer" to the list of clobbers for those inline asm statements that use addic or addic. and didn't already have it. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
