Currently, cpu_online_cores_map returns a mask, which for every core with
at least one online thread, has the bit for thread 0 of the core set to 1,
and the bits for all other threads of the core set to 0. But thread 0 of
the core itself may not be online always. In such cases, if the returned
mask is used for IPI, then it'll cause IPIs to be skipped on cores where
the first thread is offline, because the IPI code refuses to send IPIs to
offline threads.
Fix this by setting the bit of the first online thread in the core.
This is done by fixing this in the underlying function
cpu_thread_mask_to_cores.
The result has the property that for all cores with online threads, there
is one bit set in the returned map. And further, all bits that are set in
the returned map correspond to online threads.
Signed-off-by: Shreyas B. Prabhu <shreyas@linux.vnet.ibm.com>
Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
[ Changelog from Michael Ellerman <mpe@ellerman.id.au> ]
Reviewed-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
Space allocated for paca is based off nr_cpu_ids,
but pnv_alloc_idle_core_states() iterates paca with
cpu_nr_cores()*threads_per_core, which is using NR_CPUS.
This causes pnv_alloc_idle_core_states() to write over memory,
which is outside of paca array and may later lead to various panics.
Fixes: 7cba160ad789 (powernv/cpuidle: Redesign idle states management)
Signed-off-by: Jan Stancek <jstancek@redhat.com>
On POWER8 we have a new concept of a subcore. This is what happens when
you take a regular core and split it. A subcore is a grouping of two or
four SMT threads, as well as a handfull of SPRs which allows the subcore
to appear as if it were a core from the point of view of a guest.
Unlike threads_per_core which is fixed at boot, threads_per_subcore can
change while the system is running. Most code will not want to use
threads_per_subcore.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Adapt new API.
Almost change is trivial. Most important change is the below line
because we plan to change task->cpus_allowed implementation.
- ctx->cpus_allowed = current->cpus_allowed;
These APIs take logical cpu number as input
Change cpu_first_thread_in_core() to cpu_first_thread_sibling()
Change cpu_last_thread_in_core() to cpu_last_thread_sibling()
These APIs convert core number (index) to logical cpu/thread numbers
Add cpu_first_thread_of_core(int core)
Changed cpu_thread_to_core() to cpu_core_index_of_thread(int cpu)
The goal is to make 'threads_per_core' accessible to the
pseries_energy module. Instead of making an API to read
threads_per_core, this is a higher level wrapper function to
convert from logical cpu number to core number.
The current APIs cpu_first_thread_in_core() and
cpu_last_thread_in_core() returns logical CPU number while
cpu_thread_to_core() returns core number or index which is
not a logical CPU number. The new APIs are now clearly named to
distinguish 'core number' versus first and last 'logical cpu
number' in that core.
The new APIs cpu_{first,last}_thread_sibling() work on
logical cpu numbers. While cpu_first_thread_of_core() and
cpu_core_index_of_thread() work on core index.
Example usage: (4 threads per core system)
cpu_first_thread_sibling(5) = 4
cpu_last_thread_sibling(5) = 7
cpu_core_index_of_thread(5) = 1
cpu_first_thread_of_core(1) = 4
cpu_core_index_of_thread() is used in cpu_to_drc_index() in the
module and cpu_first_thread_of_core() is used in
drc_index_to_cpu() in the module.
Make API changes to few callers. Export symbols for use in modules.
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
The current "no hash" MMU context management code is written with
the assumption that one CPU == one TLB. This is not the case on
implementations that support HW multithreading, where several
linux CPUs can share the same TLB.
This adds some basic support for this to our context management
and our TLB flushing code.
It also cleans up the optional debugging output a bit
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
