path: root/arch/powerpc/include/asm/dcr-mmio.h
2014-05-23of: Stop naming platform_device using dcr addressGrant Likely
There is now a way to ensure all platform devices get a unique name when populated from the device tree, and the DCR_NATIVE code path is broken anyway. PowerPC Cell (PS3) is the only platform that actually uses this path. Most likely nobody will notice if it is killed. Remove the code and associated ugly #ifdef. The user-visible impact of this patch is that any DCR device on Cell will get a new name in the /sys/devices hierarchy. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
