path: root/arch/powerpc/include/asm/elf.h
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-02powerpc: Use is_32bit_task() helper to test 32-bit binaryDenis Kirjanov
This patch removes all explicit tests for the TIF_32BIT flag Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-01powerpc: TIF_ABI_PENDING bit removalAndreas Schwab
Here are the powerpc bits to remove TIF_ABI_PENDING now that set_personality() is called at the appropriate place in exec. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-21powerpc: Fix up elf_read_implies_exec() usageKumar Gala
We believe if a toolchain supports PT_GNU_STACK that it sets the proper PHDR permissions. Therefor elf_read_implies_exec() should only be true if we don't see PT_GNU_STACK set. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-28powerpc: ppc32 needs elf_read_implies_exec()Kumar Gala
On ppc64 we implemented elf_read_implies_exec() for 32-bit binaries because old toolchains had bugs where they didn't mark program segments executable that needed to be. For some reason we didn't do this on ppc32 builds. This hadn't been an issue until commit 8d30c14c ("powerpc/mm: Rework I$/D$ coherency (v3)"), which had as a side effect that we are now enforcing execute permissions to some extent on 32-bit 4xx and Book E processors. This fixes it by defining elf_read_implies_exec on 32-bit to turn on the read-implies-exec behaviour on programs that are sufficiently old that they don't have a PT_GNU_STACK program header. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-22powerpc/32: Don't clobber personality flags on execAndreas Schwab
Now that ppc32 implements address randomization it also wants to inherit personality flags like ADDR_NO_RANDOMIZE across exec, for things like `setarch ppc -R' to work. But the ppc32 version of SET_PERSONALITY forcefully sets PER_LINUX, clearing all personality flags. So be careful about preserving the flags. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-02-23powerpc: Randomise PIEsAnton Blanchard
Randomise ELF_ET_DYN_BASE, which is used when loading position independent executables. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc: Randomise the brk regionAnton Blanchard
Randomize the heap. before: tundro2:~ # sleep 1 & cat /proc/${!}/maps | grep heap 10017000-10118000 rw-p 10017000 00:00 0 [heap] 10017000-10118000 rw-p 10017000 00:00 0 [heap] 10017000-10118000 rw-p 10017000 00:00 0 [heap] 10017000-10118000 rw-p 10017000 00:00 0 [heap] 10017000-10118000 rw-p 10017000 00:00 0 [heap] after tundro2:~ # sleep 1 & cat /proc/${!}/maps | grep heap 19419000-1951a000 rw-p 19419000 00:00 0 [heap] 325ff000-32700000 rw-p 325ff000 00:00 0 [heap] 1a97c000-1aa7d000 rw-p 1a97c000 00:00 0 [heap] 1cc60000-1cd61000 rw-p 1cc60000 00:00 0 [heap] 1afa9000-1b0aa000 rw-p 1afa9000 00:00 0 [heap] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc: More stack randomisation for 64bit binariesAnton Blanchard
At the moment we randomise the stack by 8MB on 32bit and 64bit tasks. Since we have a lot more address space to play with on 64bit, lets do what x86 does and increase that randomisation to 1GB: before: # for i in seq `1 10` ; do sleep 1 & cat /proc/${!}/maps | grep stack; done fffffebc000-fffffed1000 rw-p ffffffeb000 00:00 0 [stack] ffffff5a000-ffffff6f000 rw-p ffffffeb000 00:00 0 [stack] fffffdb2000-fffffdc7000 rw-p ffffffeb000 00:00 0 [stack] fffffd3e000-fffffd53000 rw-p ffffffeb000 00:00 0 [stack] fffffad9000-fffffaee000 rw-p ffffffeb000 00:00 0 [stack] after: # for i in seq `1 10` ; do sleep 1 & cat /proc/${!}/maps | grep stack; done ffff5c27000-ffff5c3c000 rw-p ffffffeb000 00:00 0 [stack] fffebe5e000-fffebe73000 rw-p ffffffeb000 00:00 0 [stack] fffcb298000-fffcb2ad000 rw-p ffffffeb000 00:00 0 [stack] fffc719d000-fffc71b2000 rw-p ffffffeb000 00:00 0 [stack] fffe01af000-fffe01c4000 rw-p ffffffeb000 00:00 0 [stack] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc: Fix warnings from make headers_checkKumar Gala
include/asm/bootx.h:12: include of <linux/types.h> is preferred over <asm/types.h> include/asm/bootx.h:57: found __[us]{8,16,32,64} type without #include <linux/types.h> include/asm/elf.h:5: include of <linux/types.h> is preferred over <asm/types.h> include/asm/kvm.h:23: include of <linux/types.h> is preferred over <asm/types.h> include/asm/kvm.h:26: found __[us]{8,16,32,64} type without #include <linux/types.h> include/asm/ps3fb.h:33: found __[us]{8,16,32,64} type without #include <linux/types.h> include/asm/spu_info.h:27: found __[us]{8,16,32,64} type without #include <linux/types.h> include/asm/swab.h:11: include of <linux/types.h> is preferred over <asm/types.h> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-25[S390] arch_setup_additional_pages argumentsMartin Schwidefsky
arch_setup_additional_pages currently gets two arguments, the binary format descripton and an indication if the process uses an executable stack or not. The second argument is not used by anybody, it could be removed without replacement. What actually does make sense is to pass an indication if the process uses the elf interpreter or not. The glibc code will not use anything from the vdso if the process does not use the dynamic linker, so for statically linked binaries the architecture backend can choose not to map the vdso. Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-16[PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITYMartin Schwidefsky
The SET_PERSONALITY macro is always called with a second argument of 0. Remove the ibcs argument and the various tests to set the PER_SVR4 personality. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-17Fix compile failure with non modular buildsJames Bottomley
Commit deac93df26b20cf8438339b5935b5f5643bc30c9 ("lib: Correct printk %pF to work on all architectures") broke the non modular builds by moving an essential function into modules.c. Fix this by moving it out again and into asm/sections.h as an inline. To do this, the definition of struct ppc64_opd_entry has been lifted out of modules.c and put in asm/elf.h where it belongs. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
