Here are the powerpc bits to remove TIF_ABI_PENDING now that
set_personality() is called at the appropriate place in exec.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Currently all architectures but microblaze unconditionally define
USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so
let's kill this ifdef and make sure we are the same everywhere.
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: <linux-arch@vger.kernel.org>
Cc: Michal Simek <michal.simek@petalogix.com>
We believe if a toolchain supports PT_GNU_STACK that it sets the proper
PHDR permissions. Therefor elf_read_implies_exec() should only be true
if we don't see PT_GNU_STACK set.
On ppc64 we implemented elf_read_implies_exec() for 32-bit binaries
because old toolchains had bugs where they didn't mark program
segments executable that needed to be. For some reason we didn't do
this on ppc32 builds. This hadn't been an issue until commit 8d30c14c
("powerpc/mm: Rework I$/D$ coherency (v3)"), which had as a side
effect that we are now enforcing execute permissions to some extent on
32-bit 4xx and Book E processors.
This fixes it by defining elf_read_implies_exec on 32-bit to turn on
the read-implies-exec behaviour on programs that are sufficiently old
that they don't have a PT_GNU_STACK program header.
Now that ppc32 implements address randomization it also wants to inherit
personality flags like ADDR_NO_RANDOMIZE across exec, for things like
`setarch ppc -R' to work. But the ppc32 version of SET_PERSONALITY
forcefully sets PER_LINUX, clearing all personality flags. So be
careful about preserving the flags.
Randomise ELF_ET_DYN_BASE, which is used when loading position independent
executables.
Randomize the heap.
before:
tundro2:~ # sleep 1 & cat /proc/${!}/maps | grep heap
10017000-10118000 rw-p 10017000 00:00 0 [heap]
after
19419000-1951a000 rw-p 19419000 00:00 0 [heap]
325ff000-32700000 rw-p 325ff000 00:00 0 [heap]
1a97c000-1aa7d000 rw-p 1a97c000 00:00 0 [heap]
1cc60000-1cd61000 rw-p 1cc60000 00:00 0 [heap]
1afa9000-1b0aa000 rw-p 1afa9000 00:00 0 [heap]
At the moment we randomise the stack by 8MB on 32bit and 64bit tasks. Since we
have a lot more address space to play with on 64bit, lets do what x86 does and
increase that randomisation to 1GB:
before:
# for i in seq `1 10` ; do sleep 1 & cat /proc/${!}/maps | grep stack; done
fffffebc000-fffffed1000 rw-p ffffffeb000 00:00 0 [stack]
ffffff5a000-ffffff6f000 rw-p ffffffeb000 00:00 0 [stack]
fffffdb2000-fffffdc7000 rw-p ffffffeb000 00:00 0 [stack]
fffffd3e000-fffffd53000 rw-p ffffffeb000 00:00 0 [stack]
fffffad9000-fffffaee000 rw-p ffffffeb000 00:00 0 [stack]
after:
ffff5c27000-ffff5c3c000 rw-p ffffffeb000 00:00 0 [stack]
fffebe5e000-fffebe73000 rw-p ffffffeb000 00:00 0 [stack]
fffcb298000-fffcb2ad000 rw-p ffffffeb000 00:00 0 [stack]
fffc719d000-fffc71b2000 rw-p ffffffeb000 00:00 0 [stack]
fffe01af000-fffe01c4000 rw-p ffffffeb000 00:00 0 [stack]
include/asm/bootx.h:12: include of <linux/types.h> is preferred over <asm/types.h>
include/asm/bootx.h:57: found __[us]{8,16,32,64} type without #include <linux/types.h>
include/asm/elf.h:5: include of <linux/types.h> is preferred over <asm/types.h>
include/asm/kvm.h:23: include of <linux/types.h> is preferred over <asm/types.h>
include/asm/kvm.h:26: found __[us]{8,16,32,64} type without #include <linux/types.h>
include/asm/ps3fb.h:33: found __[us]{8,16,32,64} type without #include <linux/types.h>
include/asm/spu_info.h:27: found __[us]{8,16,32,64} type without #include <linux/types.h>
include/asm/swab.h:11: include of <linux/types.h> is preferred over <asm/types.h>
arch_setup_additional_pages currently gets two arguments, the binary
format descripton and an indication if the process uses an executable
stack or not. The second argument is not used by anybody, it could
be removed without replacement.
What actually does make sense is to pass an indication if the process
uses the elf interpreter or not. The glibc code will not use anything
from the vdso if the process does not use the dynamic linker, so for
statically linked binaries the architecture backend can choose not
to map the vdso.
The SET_PERSONALITY macro is always called with a second argument of 0.
Remove the ibcs argument and the various tests to set the PER_SVR4
personality.
Commit deac93df26b20cf8438339b5935b5f5643bc30c9 ("lib: Correct printk
%pF to work on all architectures") broke the non modular builds by
moving an essential function into modules.c. Fix this by moving it
out again and into asm/sections.h as an inline. To do this, the
definition of struct ppc64_opd_entry has been lifted out of modules.c
and put in asm/elf.h where it belongs.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
