path: root/arch/powerpc/include/asm/kvm_host.h
2011-07-12KVM: PPC: book3s_hv: Add support for PPC970-family processorsPaul Mackerras
This adds support for running KVM guests in supervisor mode on those PPC970 processors that have a usable hypervisor mode. Unfortunately, Apple G5 machines have supervisor mode disabled (MSR[HV] is forced to 1), but the YDL PowerStation does have a usable hypervisor mode. There are several differences between the PPC970 and POWER7 in how guests are managed. These differences are accommodated using the CPU_FTR_ARCH_201 (PPC970) and CPU_FTR_ARCH_206 (POWER7) CPU feature bits. Notably, on PPC970: * The LPCR, LPID or RMOR registers don't exist, and the functions of those registers are provided by bits in HID4 and one bit in HID0. * External interrupts can be directed to the hypervisor, but unlike POWER7 they are masked by MSR[EE] in non-hypervisor modes and use SRR0/1 not HSRR0/1. * There is no virtual RMA (VRMA) mode; the guest must use an RMO (real mode offset) area. * The TLB entries are not tagged with the LPID, so it is necessary to flush the whole TLB on partition switch. Furthermore, when switching partitions we have to ensure that no other CPU is executing the tlbie or tlbsync instructions in either the old or the new partition, otherwise undefined behaviour can occur. * The PMU has 8 counters (PMC registers) rather than 6. * The DSCR, PURR, SPURR, AMR, AMOR, UAMOR registers don't exist. * The SLB has 64 entries rather than 32. * There is no mediated external interrupt facility, so if we switch to a guest that has a virtual external interrupt pending but the guest has MSR[EE] = 0, we have to arrange to have an interrupt pending for it so that we can get control back once it re-enables interrupts. We do that by sending ourselves an IPI with smp_send_reschedule after hard-disabling interrupts. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Allocate RMAs (Real Mode Areas) at boot for use by guestsPaul Mackerras
This adds infrastructure which will be needed to allow book3s_hv KVM to run on older POWER processors, including PPC970, which don't support the Virtual Real Mode Area (VRMA) facility, but only the Real Mode Offset (RMO) facility. These processors require a physically contiguous, aligned area of memory for each guest. When the guest does an access in real mode (MMU off), the address is compared against a limit value, and if it is lower, the address is ORed with an offset value (from the Real Mode Offset Register (RMOR)) and the result becomes the real address for the access. The size of the RMA has to be one of a set of supported values, which usually includes 64MB, 128MB, 256MB and some larger powers of 2. Since we are unlikely to be able to allocate 64MB or more of physically contiguous memory after the kernel has been running for a while, we allocate a pool of RMAs at boot time using the bootmem allocator. The size and number of the RMAs can be set using the kvm_rma_size=xx and kvm_rma_count=xx kernel command line options. KVM exports a new capability, KVM_CAP_PPC_RMA, to signal the availability of the pool of preallocated RMAs. The capability value is 1 if the processor can use an RMA but doesn't require one (because it supports the VRMA facility), or 2 if the processor requires an RMA for each guest. This adds a new ioctl, KVM_ALLOCATE_RMA, which allocates an RMA from the pool and returns a file descriptor which can be used to map the RMA. It also returns the size of the RMA in the argument structure. Having an RMA means we will get multiple KMV_SET_USER_MEMORY_REGION ioctl calls from userspace. To cope with this, we now preallocate the kvm->arch.ram_pginfo array when the VM is created with a size sufficient for up to 64GB of guest memory. Subsequently we will get rid of this array and use memory associated with each memslot instead. This moves most of the code that translates the user addresses into host pfns (page frame numbers) out of kvmppc_prepare_vrma up one level to kvmppc_core_prepare_memory_region. Also, instead of having to look up the VMA for each page in order to check the page size, we now check that the pages we get are compound pages of 16MB. However, if we are adding memory that is mapped to an RMA, we don't bother with calling get_user_pages_fast and instead just offset from the base pfn for the RMA. Typically the RMA gets added after vcpus are created, which makes it inconvenient to have the LPCR (logical partition control register) value in the vcpu->arch struct, since the LPCR controls whether the processor uses RMA or VRMA for the guest. This moves the LPCR value into the kvm->arch struct and arranges for the MER (mediated external request) bit, which is the only bit that varies between vcpus, to be set in assembly code when going into the guest if there is a pending external interrupt request. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Allow book3s_hv guests to use SMT processor modesPaul Mackerras
This lifts the restriction that book3s_hv guests can only run one hardware thread per core, and allows them to use up to 4 threads per core on POWER7. The host still has to run single-threaded. This capability is advertised to qemu through a new KVM_CAP_PPC_SMT capability. The return value of the ioctl querying this capability is the number of vcpus per virtual CPU core (vcore), currently 4. To use this, the host kernel should be booted with all threads active, and then all the secondary threads should be offlined. This will put the secondary threads into nap mode. KVM will then wake them from nap mode and use them for running guest code (while they are still offline). To wake the secondary threads, we send them an IPI using a new xics_wake_cpu() function, implemented in arch/powerpc/sysdev/xics/icp-native.c. In other words, at this stage we assume that the platform has a XICS interrupt controller and we are using icp-native.c to drive it. Since the woken thread will need to acknowledge and clear the IPI, we also export the base physical address of the XICS registers using kvmppc_set_xics_phys() for use in the low-level KVM book3s code. When a vcpu is created, it is assigned to a virtual CPU core. The vcore number is obtained by dividing the vcpu number by the number of threads per core in the host. This number is exported to userspace via the KVM_CAP_PPC_SMT capability. If qemu wishes to run the guest in single-threaded mode, it should make all vcpu numbers be multiples of the number of threads per core. We distinguish three states of a vcpu: runnable (i.e., ready to execute the guest), blocked (that is, idle), and busy in host. We currently implement a policy that the vcore can run only when all its threads are runnable or blocked. This way, if a vcpu needs to execute elsewhere in the kernel or in qemu, it can do so without being starved of CPU by the other vcpus. When a vcore starts to run, it executes in the context of one of the vcpu threads. The other vcpu threads all go to sleep and stay asleep until something happens requiring the vcpu thread to return to qemu, or to wake up to run the vcore (this can happen when another vcpu thread goes from busy in host state to blocked). It can happen that a vcpu goes from blocked to runnable state (e.g. because of an interrupt), and the vcore it belongs to is already running. In that case it can start to run immediately as long as the none of the vcpus in the vcore have started to exit the guest. We send the next free thread in the vcore an IPI to get it to start to execute the guest. It synchronizes with the other threads via the vcore->entry_exit_count field to make sure that it doesn't go into the guest if the other vcpus are exiting by the time that it is ready to actually enter the guest. Note that there is no fixed relationship between the hardware thread number and the vcpu number. Hardware threads are assigned to vcpus as they become runnable, so we will always use the lower-numbered hardware threads in preference to higher-numbered threads if not all the vcpus in the vcore are runnable, regardless of which vcpus are runnable. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Accelerate H_PUT_TCE by implementing it in real modeDavid Gibson
This improves I/O performance for guests using the PAPR paravirtualization interface by making the H_PUT_TCE hcall faster, by implementing it in real mode. H_PUT_TCE is used for updating virtual IOMMU tables, and is used both for virtual I/O and for real I/O in the PAPR interface. Since this moves the IOMMU tables into the kernel, we define a new KVM_CREATE_SPAPR_TCE ioctl to allow qemu to create the tables. The ioctl returns a file descriptor which can be used to mmap the newly created table. The qemu driver models use them in the same way as userspace managed tables, but they can be updated directly by the guest with a real-mode H_PUT_TCE implementation, reducing the number of host/guest context switches during guest IO. There are certain circumstances where it is useful for userland qemu to write to the TCE table even if the kernel H_PUT_TCE path is used most of the time. Specifically, allowing this will avoid awkwardness when we need to reset the table. More importantly, we will in the future need to write the table in order to restore its state after a checkpoint resume or migration. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Handle some PAPR hcalls in the kernelPaul Mackerras
This adds the infrastructure for handling PAPR hcalls in the kernel, either early in the guest exit path while we are still in real mode, or later once the MMU has been turned back on and we are in the full kernel context. The advantage of handling hcalls in real mode if possible is that we avoid two partition switches -- and this will become more important when we support SMT4 guests, since a partition switch means we have to pull all of the threads in the core out of the guest. The disadvantage is that we can only access the kernel linear mapping, not anything vmalloced or ioremapped, since the MMU is off. This also adds code to handle the following hcalls in real mode: H_ENTER Add an HPTE to the hashed page table H_REMOVE Remove an HPTE from the hashed page table H_READ Read HPTEs from the hashed page table H_PROTECT Change the protection bits in an HPTE H_BULK_REMOVE Remove up to 4 HPTEs from the hashed page table H_SET_DABR Set the data address breakpoint register Plus code to handle the following hcalls in the kernel: H_CEDE Idle the vcpu until an interrupt or H_PROD hcall arrives H_PROD Wake up a ceded vcpu H_REGISTER_VPA Register a virtual processor area (VPA) The code that runs in real mode has to be in the base kernel, not in the module, if KVM is compiled as a module. The real-mode code can only access the kernel linear mapping, not vmalloc or ioremap space. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Add support for Book3S processors in hypervisor modePaul Mackerras
This adds support for KVM running on 64-bit Book 3S processors, specifically POWER7, in hypervisor mode. Using hypervisor mode means that the guest can use the processor's supervisor mode. That means that the guest can execute privileged instructions and access privileged registers itself without trapping to the host. This gives excellent performance, but does mean that KVM cannot emulate a processor architecture other than the one that the hardware implements. This code assumes that the guest is running paravirtualized using the PAPR (Power Architecture Platform Requirements) interface, which is the interface that IBM's PowerVM hypervisor uses. That means that existing Linux distributions that run on IBM pSeries machines will also run under KVM without modification. In order to communicate the PAPR hypercalls to qemu, this adds a new KVM_EXIT_PAPR_HCALL exit code to include/linux/kvm.h. Currently the choice between book3s_hv support and book3s_pr support (i.e. the existing code, which runs the guest in user mode) has to be made at kernel configuration time, so a given kernel binary can only do one or the other. This new book3s_hv code doesn't support MMIO emulation at present. Since we are running paravirtualized guests, this isn't a serious restriction. With the guest running in supervisor mode, most exceptions go straight to the guest. We will never get data or instruction storage or segment interrupts, alignment interrupts, decrementer interrupts, program interrupts, single-step interrupts, etc., coming to the hypervisor from the guest. Therefore this introduces a new KVMTEST_NONHV macro for the exception entry path so that we don't have to do the KVM test on entry to those exception handlers. We do however get hypervisor decrementer, hypervisor data storage, hypervisor instruction storage, and hypervisor emulation assist interrupts, so we have to handle those. In hypervisor mode, real-mode accesses can access all of RAM, not just a limited amount. Therefore we put all the guest state in the vcpu.arch and use the shadow_vcpu in the PACA only for temporary scratch space. We allocate the vcpu with kzalloc rather than vzalloc, and we don't use anything in the kvmppc_vcpu_book3s struct, so we don't allocate it. We don't have a shared page with the guest, but we still need a kvm_vcpu_arch_shared struct to store the values of various registers, so we include one in the vcpu_arch struct. The POWER7 processor has a restriction that all threads in a core have to be in the same partition. MMU-on kernel code counts as a partition (partition 0), so we have to do a partition switch on every entry to and exit from the guest. At present we require the host and guest to run in single-thread mode because of this hardware restriction. This code allocates a hashed page table for the guest and initializes it with HPTEs for the guest's Virtual Real Memory Area (VRMA). We require that the guest memory is allocated using 16MB huge pages, in order to simplify the low-level memory management. This also means that we can get away without tracking paging activity in the host for now, since huge pages can't be paged or swapped. This also adds a few new exports needed by the book3s_hv code. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Move fields between struct kvm_vcpu_arch and kvmppc_vcpu_book3sPaul Mackerras
This moves the slb field, which represents the state of the emulated SLB, from the kvmppc_vcpu_book3s struct to the kvm_vcpu_arch, and the hpte_hash_[v]pte[_long] fields from kvm_vcpu_arch to kvmppc_vcpu_book3s. This is in accord with the principle that the kvm_vcpu_arch struct represents the state of the emulated CPU, and the kvmppc_vcpu_book3s struct holds the auxiliary data structures used in the emulation. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: e500: Add shadow PID supportLiu Yu
Dynamically assign host PIDs to guest PIDs, splitting each guest PID into multiple host (shadow) PIDs based on kernel/user and MSR[IS/DS]. Use both PID0 and PID1 so that the shadow PIDs for the right mode can be selected, that correspond both to guest TID = zero and guest TID = guest PID. This allows us to significantly reduce the frequency of needing to invalidate the entire TLB. When the guest mode or PID changes, we just update the host PID0/PID1. And since the allocation of shadow PIDs is global, multiple guests can share the TLB without conflict. Note that KVM does not yet support the guest setting PID1 or PID2 to a value other than zero. This will need to be fixed for nested KVM to work. Until then, we enforce the requirement for guest PID1/PID2 to stay zero by failing the emulation if the guest tries to set them to something else. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: e500: Save/restore SPE stateScott Wood
This is done lazily. The SPE save will be done only if the guest has used SPE since the last preemption or heavyweight exit. Restore will be done only on demand, when enabling MSR_SPE in the shadow MSR, in response to an SPE fault or mtmsr emulation. For SPEFSCR, Linux already switches it on context switch (non-lazily), so the only remaining bit is to save it between qemu and the guest. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: booke: use shadow_msrScott Wood
Keep the guest MSR and the guest-mode true MSR separate, rather than modifying the guest MSR on each guest entry to produce a true MSR. Any bits which should be modified based on guest MSR must be explicitly propagated from vcpu->arch.shared->msr to vcpu->arch.shadow_msr in kvmppc_set_msr(). While we're modifying the guest entry code, reorder a few instructions to bury some load latencies. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-22KVM: PPC: booke: add sregs supportScott Wood
2011-05-22KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0)Scott Wood
Linux doesn't use USPRG0 (now renamed VRSAVE in the architecture, even when Altivec isn't involved), but a guest might. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-05-11KVM: PPC: Fix issue clearing exit timing countersBharat Bhushan
Following dump is observed on host when clearing the exit timing counters [root@p1021mds kvm]# echo -n 'c' > vm1200_vcpu0_timing INFO: task echo:1276 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. echo D 0ff5bf94 0 1276 1190 0x00000000 Call Trace: [c2157e40] [c0007908] __switch_to+0x9c/0xc4 [c2157e50] [c040293c] schedule+0x1b4/0x3bc [c2157e90] [c04032dc] __mutex_lock_slowpath+0x74/0xc0 [c2157ec0] [c00369e4] kvmppc_init_timing_stats+0x20/0xb8 [c2157ed0] [c0036b00] kvmppc_exit_timing_write+0x84/0x98 [c2157ef0] [c00b9f90] vfs_write+0xc0/0x16c [c2157f10] [c00ba284] sys_write+0x4c/0x90 [c2157f40] [c000e320] ret_from_syscall+0x0/0x3c The vcpu->mutex is used by kvm_ioctl_* (KVM_RUN etc) and same was used when clearing the stats (in kvmppc_init_timing_stats()). What happens is that when the guest is idle then it held the vcpu->mutx. While the exiting timing process waits for guest to release the vcpu->mutex and a hang state is reached. Now using seprate lock for exit timing stats. Signed-off-by: Bharat Bhushan <Bharat.Bhushan@freescale.com> Acked-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Add book3s_32 tlbie flush accelerationAlexander Graf
On Book3s_32 the tlbie instruction flushed effective addresses by the mask 0x0ffff000. This is pretty hard to reflect with a hash that hashes ~0xfff, so to speed up that target we should also keep a special hash around for it. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: RCU'ify the Book3s MMUAlexander Graf
So far we've been running all code without locking of any sort. This wasn't really an issue because I didn't see any parallel access to the shadow MMU code coming. But then I started to implement dirty bitmapping to MOL which has the video code in its own thread, so suddenly we had the dirty bitmap code run in parallel to the shadow mmu code. And with that came trouble. So I went ahead and made the MMU modifying functions as parallelizable as I could think of. I hope I didn't screw up too much RCU logic :-). If you know your way around RCU and locking and what needs to be done when, please take a look at this patch. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: First magic page stepsAlexander Graf
We will be introducing a method to project the shared page in guest context. As soon as we're talking about this coupling, the shared page is colled magic page. This patch introduces simple defines, so the follow-up patches are easier to read. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Make PAM a defineAlexander Graf
On PowerPC it's very normal to not support all of the physical RAM in real mode. To check if we're matching on the shared page or not, we need to know the limits so we can restrain ourselves to that range. So let's make it a define instead of open-coding it. And while at it, let's also increase it. Signed-off-by: Alexander Graf <agraf@suse.de> v2 -> v3: - RMO -> PAM (non-magic page) Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Convert SPRG[0-4] to shared pageAlexander Graf
When in kernel mode there are 4 additional registers available that are simple data storage. Instead of exiting to the hypervisor to read and write those, we can just share them with the guest using the page. This patch converts all users of the current field to the shared page. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Convert SRR0 and SRR1 to shared pageAlexander Graf
The SRR0 and SRR1 registers contain cached values of the PC and MSR respectively. They get written to by the hypervisor when an interrupt occurs or directly by the kernel. They are also used to tell the rfi(d) instruction where to jump to. Because it only gets touched on defined events that, it's very simple to share with the guest. Hypervisor and guest both have full r/w access. This patch converts all users of the current field to the shared page. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Convert DAR to shared page.Alexander Graf
The DAR register contains the address a data page fault occured at. This register behaves pretty much like a simple data storage register that gets written to on data faults. There is no hypervisor interaction required on read or write. This patch converts all users of the current field to the shared page. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Convert MSR to shared pageAlexander Graf
One of the most obvious registers to share with the guest directly is the MSR. The MSR contains the "interrupts enabled" flag which the guest has to toggle in critical sections. So in order to bring the overhead of interrupt en- and disabling down, let's put msr into the shared page. Keep in mind that even though you can fully read its contents, writing to it doesn't always update all state. There are a few safe fields that don't require hypervisor interaction. See the documentation for a list of MSR bits that are safe to be set from inside the guest. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Introduce shared pageAlexander Graf
For transparent variable sharing between the hypervisor and guest, I introduce a shared page. This shared page will contain all the registers the guest can read and write safely without exiting guest context. This patch only implements the stubs required for the basic structure of the shared page. The actual register moving follows. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Remove unnecessary divide operationsJoerg Roedel
This patch converts unnecessary divide and modulo operations in the KVM large page related code into logical operations. This allows to convert gfn_t to u64 while not breaking 32 bit builds. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: PPC: Make use of hash based Shadow MMUAlexander Graf
We just introduced generic functions to handle shadow pages on PPC. This patch makes the respective backends make use of them, getting rid of a lot of duplicate code along the way. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: PPC: Convert u64 -> ulongAlexander Graf
There are some pieces in the code that I overlooked that still use u64s instead of longs. This slows down 32 bit hosts unnecessarily, so let's just move them to ulong. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Use now shadowed vcpu fieldsAlexander Graf
The shadow vcpu now contains some fields we don't use from the vcpu anymore. Access to them happens using inline functions that happily use the shadow vcpu fields. So let's now ifdef them out to booke only and add asm-offsets. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Use CONFIG_PPC_BOOK3S defineAlexander Graf
Upstream recently added a new name for PPC64: Book3S_64. So instead of using CONFIG_PPC64 we should use CONFIG_PPC_BOOK3S consotently. That makes understanding the code easier (I hope). Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Make bools bitfieldsAlexander Graf
Bool defaults to at least byte width. We usually only want to waste a single bit on this. So let's move all the bool values to bitfields, potentially saving memory. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Add OSI hypercall interfaceAlexander Graf
MOL uses its own hypercall interface to call back into userspace when the guest wants to do something. So let's implement that as an exit reason, specify it with a CAP and only really use it when userspace wants us to. The only user of it so far is MOL. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Make DSISR 32 bits wideAlexander Graf
DSISR is only defined as 32 bits wide. So let's reflect that in the structs too. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: PPC: Teach MMIO SignednessAlexander Graf
The guest I was trying to get to run uses the LHA and LHAU instructions. Those instructions basically do a load, but also sign extend the result. Since we need to fill our registers by hand when doing MMIO, we also need to sign extend manually. This patch implements sign extended MMIO and the LHA(U) instructions. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: PPC: Make fpscr 64-bitAlexander Graf
Modern PowerPCs have a 64 bit wide FPSCR register. Let's accomodate for that and make it 64 bits in our vcpu struct too. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: PPC: Add QPR registersAlexander Graf
The Gekko has GPRs, SPRs and FPRs like normal PowerPC codes, but it also has QPRs which are basically single precision only FPU registers that get used when in paired single mode. The following patches depend on them being around, so let's add the definitions early. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: ppc/booke: Set ESR and DEAR when inject interrupt to guestLiu Yu
Old method prematurely sets ESR and DEAR. Move this part after we decide to inject interrupt, which is more like hardware behave. Signed-off-by: Liu Yu <yu.liu@freescale.com> Acked-by: Hollis Blanchard <hollis@penguinppc.org> Acked-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: PPC: Keep SRR1 flags around in shadow_msrAlexander Graf
SRR1 stores more information that just the MSR value. It also stores valuable information about the type of interrupt we received, for example whether the storage interrupt we just got was because of a missing htab entry or not. We use that information to speed up the exit path. Now if we get preempted before we can interpret the shadow_msr values, we get into vcpu_put which then calls the MSR handler, which then sets all the SRR1 information bits in shadow_msr to 0. Great. So let's preserve the SRR1 specific bits in shadow_msr whenever we set the MSR. They don't hurt. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: PPC: Add support for FPU/Altivec/VSXAlexander Graf
When our guest starts using either the FPU, Altivec or VSX we need to make sure Linux knows about it and sneak into its process switching code accordingly. This patch makes accesses to the above parts of the system work inside the VM. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: PPC: Call SLB patching code in interrupt safe mannerAlexander Graf
Currently we're racy when doing the transition from IR=1 to IR=0, from the module memory entry code to the real mode SLB switching code. To work around that I took a look at the RTAS entry code which is faced with a similar problem and did the same thing: A small helper in linear mapped memory that does mtmsr with IR=0 and then RFIs info the actual handler. Thanks to that trick we can safely take page faults in the entry code and only need to be really wary of what to do as of the SLB switching part. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: PPC: Use PACA backed shadow vcpuAlexander Graf
We're being horribly racy right now. All the entry and exit code hijacks random fields from the PACA that could easily be used by different code in case we get interrupted, for example by a #MC or even page fault. After discussing this with Ben, we figured it's best to reserve some more space in the PACA and just shove off some vcpu state to there. That way we can drastically improve the readability of the code, make it less racy and less complex. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-11-05Use hrtimers for the decrementerAlexander Graf
Following S390's good example we should use hrtimers for the decrementer too! This patch converts the timer from the old mechanism to hrtimers. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-05Add Book3s fields to vcpu structsAlexander Graf
We need to store more information than we currently have for vcpus when running on Book3s. So let's extend the internal struct definitions. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-10KVM: Prepare memslot data structures for multiple hugepage sizesJoerg Roedel
[avi: fix build on non-x86] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: ppc: e500: Directly pass pvr to guestLiu Yu
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-08-05KVM: Make KVM_HPAGES_PER_HPAGE unsigned long to avoid build error on powerpcStephen Rothwell
Eliminates this compiler warning: arch/powerpc/kvm/../../../virt/kvm/kvm_main.c:1178: error: integer overflow in expression Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: ppc: remove debug support broken by KVM debug rewriteHollis Blanchard
After the rewrite of KVM's debug support, this code doesn't even build any more. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: ppc: Add extra E500 exceptionsHollis Blanchard
e500 has additional interrupt vectors (and corresponding IVORs) for SPE and performance monitoring interrupts. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: ppc: Add dbsr in kvm_vcpu_archHollis Blanchard
Kernel for E500 need clear dbsr when startup. So add dbsr register in kvm_vcpu_arch for BOOKE. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: ppc: move struct kvmppc_44x_tlbe into 44x-specific headerHollis Blanchard
2009-03-24KVM: Remove old kvm_guest_debug structsJan Kiszka
Remove the remaining arch fragments of the old guest debug interface that now break non-x86 builds. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: ppc: mostly cosmetic updates to the exit timing accounting codeHollis Blanchard
The only significant changes were to kvmppc_exit_timing_write() and kvmppc_exit_timing_show(), both of which were dramatically simplified. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: ppc: Implement in-kernel exit timing statisticsHollis Blanchard
Existing KVM statistics are either just counters (kvm_stat) reported for KVM generally or trace based aproaches like kvm_trace. For KVM on powerpc we had the need to track the timings of the different exit types. While this could be achieved parsing data created with a kvm_trace extension this adds too much overhead (at least on embedded PowerPC) slowing down the workloads we wanted to measure. Therefore this patch adds a in-kernel exit timing statistic to the powerpc kvm code. These statistic is available per vm&vcpu under the kvm debugfs directory. As this statistic is low, but still some overhead it can be enabled via a .config entry and should be off by default. Since this patch touched all powerpc kvm_stat code anyway this code is now merged and simplified together with the exit timing statistic code (still working with exit timing disabled in .config). Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
