Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
We look at both the segment base page size and actual page size and store
the pte-lp-encodings in an array per base page size.
We also update all relevant functions to take actual page size argument
so that we can use the correct PTE LP encoding in HPTE. This should also
get the basic Multiple Page Size per Segment (MPSS) support. This is needed
to enable THP on ppc64.
[Fixed PR KVM build --BenH]
Acked-by: Paul Mackerras <paulus@samba.org>
We allocate one page for the last level of linux page table. With THP and
large page size of 16MB, that would mean we are wasting large part
of that page. To map 16MB area, we only need a PTE space of 2K with 64K
page size. This patch reduce the space wastage by sharing the page
allocated for the last level of linux page table with multiple pmd
entries. We call these smaller chunks PTE page fragments and allocated
page, PTE page.
In order to support systems which doesn't have 64K HPTE support, we also
add another 2K to PTE page fragment. The second half of the PTE fragments
is used for storing slot and secondary bit information of an HPTE. With this
we now have a 4K PTE fragment.
We use a simple approach to share the PTE page. On allocation, we bump the
PTE page refcount to 16 and share the PTE page with the next 16 pte alloc
request. This should help in the node locality of the PTE page fragment,
assuming that the immediate pte alloc request will mostly come from the
same NUMA node. We don't try to reuse the freed PTE page fragment. Hence
we could be waisting some space.
Change the hugepage directory format so that we can have leaf ptes directly
at page directory avoiding the allocation of hugepage directory.
With the new table format we have 3 cases for pgds and pmds:
(1) invalid (all zeroes)
(2) pointer to next table, as normal; bottom 6 bits == 0
(4) hugepd pointer, bottom two bits == 00, next 4 bits indicate size of table
Instead of storing shift value in hugepd pointer we use mmu_psize_def index
so that we can fit all the supported hugepage size in 4 bits
Now we use ESID_BITS of kernel address to build proto vsid. So rename
USER_ESIT_BITS to ESID_BITS
CC: <stable@vger.kernel.org> [v3.8]
This patch change the kernel VSID range so that we limit VSID_BITS to 37.
This enables us to support 64TB with 65 bit VA (37+28). Without this patch
we have boot hangs on platforms that only support 65 bit VA.
With this patch we now have proto vsid generated as below:
We first generate a 37-bit "proto-VSID". Proto-VSIDs are generated
from mmu context id and effective segment id of the address.
For user processes max context id is limited to ((1ul << 19) - 5)
for kernel space, we use the top 4 context ids to map address as below
0x7fffc - [ 0xc000000000000000 - 0xc0003fffffffffff ]
0x7fffd - [ 0xd000000000000000 - 0xd0003fffffffffff ]
0x7fffe - [ 0xe000000000000000 - 0xe0003fffffffffff ]
0x7ffff - [ 0xf000000000000000 - 0xf0003fffffffffff ]
Tested-by: Geoff Levand <geoff@infradead.org>
VSID_BITS and VSID_BITS_1T depends on the context bits and user esid
bits. Make the dependency explicit
panicking
Currently, if a machine check interrupt happens while we are in the
guest, we exit the guest and call the host's machine check handler,
which tends to cause the host to panic. Some machine checks can be
triggered by the guest; for example, if the guest creates two entries
in the SLB that map the same effective address, and then accesses that
effective address, the CPU will take a machine check interrupt.
To handle this better, when a machine check happens inside the guest,
we call a new function, kvmppc_realmode_machine_check(), while still in
real mode before exiting the guest. On POWER7, it handles the cases
that the guest can trigger, either by flushing and reloading the SLB,
or by flushing the TLB, and then it delivers the machine check interrupt
directly to the guest without going back to the host. On POWER7, the
OPAL firmware patches the machine check interrupt vector so that it
gets control first, and it leaves behind its analysis of the situation
in a structure pointed to by the opal_mc_evt field of the paca. The
kvmppc_realmode_machine_check() function looks at this, and if OPAL
reports that there was no error, or that it has handled the error, we
also go straight back to the guest with a machine check. We have to
deliver a machine check to the guest since the machine check interrupt
might have trashed valid values in SRR0/1.
If the machine check is one we can't handle in real mode, and one that
OPAL hasn't already handled, or on PPC970, we exit the guest and call
the host's machine check handler. We do this by jumping to the
machine_check_fwnmi label, rather than absolute address 0x200, because
we don't want to re-execute OPAL's handler on POWER7. On PPC970, the
two are equivalent because address 0x200 just contains a branch.
Then, if the host machine check handler decides that the system can
continue executing, kvmppc_handle_exit() delivers a machine check
interrupt to the guest -- once again to let the guest know that SRR0/1
have been modified.
[agraf: fix checkpatch warnings]
slice array size and slice mask size depend on PGTABLE_RANGE.
Reviewed-by: Paul Mackerras <paulus@samba.org>
This update the proto-VSID and VSID scramble related information
to be more generic by using names instead of current values.
Increase max addressable range to 64TB. This is not tested on
real hardware yet.
This patch makes the high psizes mask as an unsigned char array
so that we can have more than 16TB. Currently we support upto
64TB
This patch convert different functions to take virtual page number
instead of virtual address. Virtual page number is virtual address
shifted right by VPN_SHIFT (12) bits. This enable us to have an
address range of upto 76 bits.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull a few more things for powerpc by Benjamin Herrenschmidt:
- Anton's did some recent improvements to EPOW event reporting on
pSeries (power supply failures and such). The patches are self
contained enough and replace really nasty code so I felt it should
still go in
- I did the vio driver registration change Greg requested, I don't see
the point of leaving that til the next merge window
- The remaining EEH changes I said were still pending to get rid of the
EEH references from the generic struct device_node
- A few more iSeries removal bits
- A perf bug fix on 970
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/perf: Fix instruction address sampling on 970 and Power4
powerpc+sparc/vio: Modernize driver registration
powerpc: Random little legacy iSeries removal tidy ups
powerpc: Remove NO_IRQ_IGNORE
powerpc/pseries: Cut down on enthusiastic use of defines in RAS code
powerpc/pseries: Clean up ras_error_interrupt code
powerpc/pseries: Remove RTAS_POWERMGM_EVENTS
powerpc/pseries: Use rtas_get_sensor in RAS code
powerpc/pseries: Parse and handle EPOW interrupts
powerpc: Make function that parses RTAS error logs global
powerpc/eeh: Retrieve PHB from global list
powerpc/eeh: Remove eeh information from pci_dn
powerpc/eeh: Remove eeh device from OF node
This provides the low-level support for MMIO emulation in Book3S HV
guests. When the guest tries to map a page which is not covered by
any memslot, that page is taken to be an MMIO emulation page. Instead
of inserting a valid HPTE, we insert an HPTE that has the valid bit
clear but another hypervisor software-use bit set, which we call
HPTE_V_ABSENT, to indicate that this is an absent page. An
absent page is treated much like a valid page as far as guest hcalls
(H_ENTER, H_REMOVE, H_READ etc.) are concerned, except of course that
an absent HPTE doesn't need to be invalidated with tlbie since it
was never valid as far as the hardware is concerned.
When the guest accesses a page for which there is an absent HPTE, it
will take a hypervisor data storage interrupt (HDSI) since we now set
the VPM1 bit in the LPCR. Our HDSI handler for HPTE-not-present faults
looks up the hash table and if it finds an absent HPTE mapping the
requested virtual address, will switch to kernel mode and handle the
fault in kvmppc_book3s_hv_page_fault(), which at present just calls
kvmppc_hv_emulate_mmio() to set up the MMIO emulation.
This is based on an earlier patch by Benjamin Herrenschmidt, but since
heavily reworked.
Signed-off-by: Avi Kivity <avi@redhat.com>
We support 16TB of user address space and half a million contexts
so update the comment to reflect this.
Enable hugepages on Freescale BookE processors. This allows the kernel to
use huge TLB entries to map pages, which can greatly reduce the number of
TLB misses and the amount of TLB thrashing experienced by applications with
large memory footprints. Care should be taken when using this on FSL
processors, as the number of large TLB entries supported by the core is low
(16-64) on current processors.
The supported set of hugepage sizes include 4m, 16m, 64m, 256m, and 1g.
Page sizes larger than the max zone size are called "gigantic" pages and
must be allocated on the command line (and cannot be deallocated).
This is currently only fully implemented for Freescale 32-bit BookE
processors, but there is some infrastructure in the code for
64-bit BooKE.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
This adds support for KVM running on 64-bit Book 3S processors,
specifically POWER7, in hypervisor mode. Using hypervisor mode means
that the guest can use the processor's supervisor mode. That means
that the guest can execute privileged instructions and access privileged
registers itself without trapping to the host. This gives excellent
performance, but does mean that KVM cannot emulate a processor
architecture other than the one that the hardware implements.
This code assumes that the guest is running paravirtualized using the
PAPR (Power Architecture Platform Requirements) interface, which is the
interface that IBM's PowerVM hypervisor uses. That means that existing
Linux distributions that run on IBM pSeries machines will also run
under KVM without modification. In order to communicate the PAPR
hypercalls to qemu, this adds a new KVM_EXIT_PAPR_HCALL exit code
to include/linux/kvm.h.
Currently the choice between book3s_hv support and book3s_pr support
(i.e. the existing code, which runs the guest in user mode) has to be
made at kernel configuration time, so a given kernel binary can only
do one or the other.
This new book3s_hv code doesn't support MMIO emulation at present.
Since we are running paravirtualized guests, this isn't a serious
restriction.
With the guest running in supervisor mode, most exceptions go straight
to the guest. We will never get data or instruction storage or segment
interrupts, alignment interrupts, decrementer interrupts, program
interrupts, single-step interrupts, etc., coming to the hypervisor from
the guest. Therefore this introduces a new KVMTEST_NONHV macro for the
exception entry path so that we don't have to do the KVM test on entry
to those exception handlers.
We do however get hypervisor decrementer, hypervisor data storage,
hypervisor instruction storage, and hypervisor emulation assist
interrupts, so we have to handle those.
In hypervisor mode, real-mode accesses can access all of RAM, not just
a limited amount. Therefore we put all the guest state in the vcpu.arch
and use the shadow_vcpu in the PACA only for temporary scratch space.
We allocate the vcpu with kzalloc rather than vzalloc, and we don't use
anything in the kvmppc_vcpu_book3s struct, so we don't allocate it.
We don't have a shared page with the guest, but we still need a
kvm_vcpu_arch_shared struct to store the values of various registers,
so we include one in the vcpu_arch struct.
The POWER7 processor has a restriction that all threads in a core have
to be in the same partition. MMU-on kernel code counts as a partition
(partition 0), so we have to do a partition switch on every entry to and
exit from the guest. At present we require the host and guest to run
in single-thread mode because of this hardware restriction.
This code allocates a hashed page table for the guest and initializes
it with HPTEs for the guest's Virtual Real Memory Area (VRMA). We
require that the guest memory is allocated using 16MB huge pages, in
order to simplify the low-level memory management. This also means that
we can get away without tracking paging activity in the host for now,
since huge pages can't be paged or swapped.
This also adds a few new exports needed by the book3s_hv code.
Icswx is a PowerPC instruction to send data to a co-processor. On Book-S
processors the LPAR_ID and process ID (PID) of the owning process are
registered in the window context of the co-processor at initialization
time. When the icswx instruction is executed the L2 generates a cop-reg
transaction on PowerBus. The transaction has no address and the
processor does not perform an MMU access to authenticate the transaction.
The co-processor compares the LPAR_ID and the PID included in the
transaction and the LPAR_ID and PID held in the window context to
determine if the process is authorized to generate the transaction.
The OS needs to assign a 16-bit PID for the process. This cop-PID needs
to be updated during context switch. The cop-PID needs to be destroyed
when the context is destroyed.
Signed-off-by: Sonny Rao <sonnyrao@linux.vnet.ibm.com>
Signed-off-by: Tseng-Hui (Frank) Lin <thlin@linux.vnet.ibm.com>
Recent upstream builds with allmodconfig fail due to lack of space
between 0x3000 and 0x6000. We have a hard block at 0x7000 but we can
spare a page by moving the STAB0 from 0x6000 to 0x8000.
The code is wrapped in an #if 0, but it's wrong so we may as well fix it.
This adds some debug output to our MMU hash code to print out some
useful debug data if the hypervisor refuses the insertion (which
should normally never happen).
Commit a0668cdc154e54bf0c85182e0535eea237d53146 cleans up the handling
of kmem_caches for allocating various levels of pagetables.
Unfortunately, it conflicts badly with CONFIG_PPC_SUBPAGE_PROT, due to
the latter's cleverly hidden technique of adding some extra allocation
space to the top level page directory to store the extra information
it needs.
Since that extra allocation really doesn't fit into the cleaned up
page directory allocating scheme, this patch alters
CONFIG_PPC_SUBPAGE_PROT to instead allocate its struct
subpage_prot_table as part of the mm_context_t.
CONFIG_PPC_SUBPAGE_PROT"
This reverts commit c045256d146800ea1d741a8e9e377dada6b7e195.
It breaks build when CONFIG_PPC_SUBPAGE_PROT is not set. I will
commit a fixed version separately
it needs.
accessors
The hugepage arch code provides a number of hook functions/macros
which mirror the functionality of various normal page pte access
functions. Various changes in the normal page accessors (in
particular BenH's recent changes to the handling of lazy icache
flushing and PAGE_EXEC) have caused the hugepage versions to get out
of sync with the originals. In some cases, this is a bug, at least on
some MMU types.
One of the reasons that some hooks were not identical to the normal
page versions, is that the fact we're dealing with a hugepage needed
to be passed down do use the correct dcache-icache flush function.
This patch makes the main flush_dcache_icache_page() function hugepage
aware (by checking for the PageCompound flag). That in turn means we
can make set_huge_pte_at() just a call to set_pte_at() bringing it
back into sync. As a bonus, this lets us remove the
hash_huge_page_do_lazy_icache() function, replacing it with a call to
the hash_page_do_lazy_icache() function it was based on.
Some other hugepage pte access hooks - huge_ptep_get_and_clear() and
huge_ptep_clear_flush() - are not so easily unified, but this patch at
least brings them back into sync with the current versions of the
corresponding normal page functions.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
Currently each available hugepage size uses a slightly different
pagetable layout: that is, the bottem level table of pointers to
hugepages is a different size, and may branch off from the normal page
tables at a different level. Every hugepage aware path that needs to
walk the pagetables must therefore look up the hugepage size from the
slice info first, and work out the correct way to walk the pagetables
accordingly. Future hardware is likely to add more possible hugepage
sizes, more layout options and more mess.
This patch, therefore reworks the handling of hugepage pagetables to
reduce this complexity. In the new scheme, instead of having to
consult the slice mask, pagetable walking code can check a flag in the
PGD/PUD/PMD entries to see where to branch off to hugepage pagetables,
and the entry also contains the information (eseentially hugepage
shift) necessary to then interpret that table without recourse to the
slice mask. This scheme can be extended neatly to handle multiple
levels of self-describing "special" hugepage pagetables, although for
now we assume only one level exists.
This approach means that only the pagetable allocation path needs to
know how the pagetables should be set out. All other (hugepage)
pagetable walking paths can just interpret the structure as they go.
There already was a flag bit in PGD/PUD/PMD entries for hugepage
directory pointers, but it was only used for debug. We alter that
flag bit to instead be a 0 in the MSB to indicate a hugepage pagetable
pointer (normally it would be 1 since the pointer lies in the linear
mapping). This means that asm pagetable walking can test for (and
punt on) hugepage pointers with the same test that checks for
unpopulated page directory entries (beq becomes bge), since hugepage
pointers will always be positive, and normal pointers always negative.
While we're at it, we get rid of the confusing (and grep defeating)
#defining of hugepte_shift to be the same thing as mmu_huge_psizes.
The SLB can change sizes across a live migration, which was not
being handled, resulting in possible machine crashes during
migration if migrating to a machine which has a smaller max SLB
size than the source machine. Fix this by first reducing the
SLB size to the minimum possible value, which is 32, prior to
migration. Then during the device tree update which occurs after
migration, we make the call to ensure the SLB gets updated. Also
add the slb_size to the lparcfg output so that the migration
tools can check to make sure the kernel has this capability
before allowing migration in scenarios where the SLB size will change.
BenH: Fixed #include <asm/mmu-hash64.h> -> <asm/mmu.h> to avoid
breaking ppc32 build
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
This adds the PTE and pgtable format definitions, along with changes
to the kernel memory map and other definitions related to implementing
support for 64-bit Book3E. This also shields some asm-offset bits that
are currently only relevant on 32-bit
We also move the definition of the "linux" page size constants to
the common mmu.h file and add a few sizes that are relevant to
embedded processors.
This moves some MMU related init code out of setup_64.c into hash_utils_64.c
and calls it early_init_mmu() and early_init_mmu_secondary(). This will
make it easier to plug in a new MMU type.
called only from __init, calls __init. Incidentally, it ought to be static
in file.
This implements CONFIG_RELOCATABLE for 64-bit by making the kernel as
a position-independent executable (PIE) when it is set. This involves
processing the dynamic relocations in the image in the early stages of
booting, even if the kernel is being run at the address it is linked at,
since the linker does not necessarily fill in words in the image for
which there are dynamic relocations. (In fact the linker does fill in
such words for 64-bit executables, though not for 32-bit executables,
so in principle we could avoid calling relocate() entirely when we're
running a 64-bit kernel at the linked address.)
The dynamic relocations are processed by a new function relocate(addr),
where the addr parameter is the virtual address where the image will be
run. In fact we call it twice; once before calling prom_init, and again
when starting the main kernel. This means that reloc_offset() returns
0 in prom_init (since it has been relocated to the address it is running
at), which necessitated a few adjustments.
This also changes __va and __pa to use an equivalent definition that is
simpler. With the relocatable kernel, PAGE_OFFSET and MEMORY_START are
constants (for 64-bit) whereas PHYSICAL_START is a variable (and
KERNELBASE ideally should be too, but isn't yet).
With this, relocatable kernels still copy themselves down to physical
address 0 and run there.
The function htab_bolt_mapping() is used to create permanent
mappings in the MMU hash table, for example, in order to create
the linear mapping of vmemmap. It's also used by early boot
ioremap (before mem_init_done).
However, the way ioremap uses it is incorrect as it passes it the
protection flags in the "linux PTE" form while htab_bolt_mapping()
expects them in the hash table format. This is made more confusing by
the fact that some of those flags are actually in the same position in
both cases.
This fixes it all by making htab_bolt_mapping() take normal linux
protection flags instead, and use a little helper to convert them to
htab flags. Callers can now use the usual PAGE_* definitions safely.
arch/powerpc/include/asm/mmu-hash64.h | 2 -
arch/powerpc/mm/hash_utils_64.c | 65 ++++++++++++++++++++--------------
arch/powerpc/mm/init_64.c | 9 +---
3 files changed, 44 insertions(+), 32 deletions(-)
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
