path: root/arch/powerpc/include/asm/time.h
2010-09-02powerpc: Account time using timebase rather than PURRPaul Mackerras
Currently, when CONFIG_VIRT_CPU_ACCOUNTING is enabled, we use the PURR register for measuring the user and system time used by processes, as well as other related times such as hardirq and softirq times. This turns out to be quite confusing for users because it means that a program will often be measured as taking less time when run on a multi-threaded processor (SMT2 or SMT4 mode) than it does when run on a single-threaded processor (ST mode), even though the program takes longer to finish. The discrepancy is accounted for as stolen time, which is also confusing, particularly when there are no other partitions running. This changes the accounting to use the timebase instead, meaning that the reported user and system times are the actual number of real-time seconds that the program was executing on the processor thread, regardless of which SMT mode the processor is in. Thus a program will generally show greater user and system times when run on a multi-threaded processor than on a single-threaded processor. On pSeries systems on POWER5 or later processors, we measure the stolen time (time when this partition wasn't running) using the hypervisor dispatch trace log. We check for new entries in the log on every entry from user mode and on every transition from kernel process context to soft or hard IRQ context (i.e. when account_system_vtime() gets called). So that we can correctly distinguish time stolen from user time and time stolen from system time, without having to check the log on every exit to user mode, we store separate timestamps for exit to user mode and entry from user mode. On systems that have a SPURR (POWER6 and POWER7), we read the SPURR in account_system_vtime() (as before), and then apportion the SPURR ticks since the last time we read it between scaled user time and scaled system time according to the relative proportions of user time and system time over the same interval. This avoids having to read the SPURR on every kernel entry and exit. On systems that have PURR but not SPURR (i.e., POWER5), we do the same using the PURR rather than the SPURR. This disables the DTL user interface in /sys/debug/kernel/powerpc/dtl for now since it conflicts with the use of the dispatch trace log by the time accounting code. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-09powerpc: Clean up obsolete code relating to decrementer and timebasePaul Mackerras
Since the decrementer and timekeeping code was moved over to using the generic clockevents and timekeeping infrastructure, several variables and functions have been obsolete and effectively unused. This deletes them. In particular, wakeup_decrementer() is no longer needed since the generic code reprograms the decrementer as part of the process of resuming the timekeeping code, which happens during sysdev resume. Thus the wakeup_decrementer calls in the suspend_enter methods for 52xx platforms have been removed. The call in the powermac cpu frequency change code has been replaced by set_dec(1), which will cause a timer interrupt as soon as interrupts are enabled, and the generic code will then reprogram the decrementer with the correct value. This also simplifies the generic_suspend_en/disable_irqs functions and makes them static since they are not referenced outside time.c. The preempt_enable/disable calls are removed because the generic code has disabled all but the boot cpu at the point where these functions are called, so we can't be moved to another cpu. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-11-06powerpc: Eliminate unused do_gtod variablePaul Mackerras
Since we started using the generic timekeeping code, we haven't had a powerpc-specific version of do_gettimeofday, and hence there is now nothing that reads the do_gtod variable in arch/powerpc/kernel/time.c. This therefore removes it and the code that sets it. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
