path: root/arch/powerpc/include/asm/trace.h
2009-10-28powerpc: tracing: Give hypervisor call tracepoints access to argumentsAnton Blanchard
While most users of the hcall tracepoints will only want the opcode and return code, some will want all the arguments. To avoid the complexity of using varargs we pass a pointer to the register save area, which contains all the arguments. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-10-28powerpc: tracing: Add hypervisor call tracepointsAnton Blanchard
Add hcall_entry and hcall_exit tracepoints. This replaces the inline assembly HCALL_STATS code and converts it to use the new tracepoints. To keep the disabled case as quick as possible, we embed a status word in the TOC so we can get at it with a single load. By doing so we keep the overhead at a minimum. Time taken for a null hcall: No tracepoint code: 135.79 cycles Disabled tracepoints: 137.95 cycles For reference, before this patch enabling HCALL_STATS resulted in a null hcall of 201.44 cycles! Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-10-28powerpc: tracing: Add powerpc tracepoints for timer entry and exitAnton Blanchard
We can monitor the effectiveness of our power management of both the kernel and hypervisor by probing the timer interrupt. For example, on this box we see 10.37s timer interrupts on an idle core: <idle>-0 [010] 3900.671297: timer_interrupt_entry: pt_regs=c0000000ce1e7b10 <idle>-0 [010] 3900.671302: timer_interrupt_exit: pt_regs=c0000000ce1e7b10 <idle>-0 [010] 3911.042963: timer_interrupt_entry: pt_regs=c0000000ce1e7b10 <idle>-0 [010] 3911.042968: timer_interrupt_exit: pt_regs=c0000000ce1e7b10 <idle>-0 [010] 3921.414630: timer_interrupt_entry: pt_regs=c0000000ce1e7b10 <idle>-0 [010] 3921.414635: timer_interrupt_exit: pt_regs=c0000000ce1e7b10 Since we have a 207MHz decrementer it will go negative and fire every 10.37s even if Linux is completely idle. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-10-28powerpc: tracing: Add powerpc tracepoints for interrupt entry and exitAnton Blanchard
This adds powerpc-specific tracepoints for interrupt entry and exit. While we already have generic irq_handler_entry and irq_handler_exit tracepoints there are cases on our virtualised powerpc machines where an interrupt is presented to the OS, but subsequently handled by the hypervisor. This means no OS interrupt handler is invoked. Here is an example on a POWER6 machine with the patch below applied: <idle>-0 [006] 3243.949840744: irq_entry: pt_regs=c0000000ce31fb10 <idle>-0 [006] 3243.949850520: irq_exit: pt_regs=c0000000ce31fb10 <idle>-0 [007] 3243.950218208: irq_entry: pt_regs=c0000000ce323b10 <idle>-0 [007] 3243.950224080: irq_exit: pt_regs=c0000000ce323b10 <idle>-0 [000] 3244.021879320: irq_entry: pt_regs=c000000000a63aa0 <idle>-0 [000] 3244.021883616: irq_handler_entry: irq=87 handler=eth0 <idle>-0 [000] 3244.021887328: irq_handler_exit: irq=87 return=handled <idle>-0 [000] 3244.021897408: irq_exit: pt_regs=c000000000a63aa0 Here we see two phantom interrupts (no handler was invoked), followed by a real interrupt for eth0. Without the tracepoints in this patch we would have missed the phantom interrupts. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
