Pull KVM bugfixes from Marcelo Tosatti.
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: use dynamic percpu allocations for shared msrs area
KVM: PPC: Book3S HV: Fix compilation without CONFIG_PPC_POWERNV
powerpc: Corrected include header path in kvm_para.h
Add rcu user eqs exception hooks for async page fault
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"A few new features this merge-window. The most important one is
probably, that dma-debug now warns if a dma-handle is not checked with
dma_mapping_error by the device driver. This requires minor changes
to some architectures which make use of dma-debug. Most of these
changes have the respective Acks by the Arch-Maintainers.
Besides that there are updates to the AMD IOMMU driver for refactor
the IOMMU-Groups support and to make sure it does not trigger a
hardware erratum.
The OMAP changes (for which I pulled in a branch from Tony Lindgren's
tree) have a conflict in linux-next with the arm-soc tree. The
conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is
deleted in the arm-soc tree. It is safe to delete the file too so
solve the conflict. Similar changes are done in the arm-soc tree in
the common clock framework migration. A missing hunk from the patch
in the IOMMU tree will be submitted as a seperate patch when the
merge-window is closed."
* tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits)
ARM: dma-mapping: support debug_dma_mapping_error
ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks
iommu/omap: Adapt to runtime pm
iommu/omap: Migrate to hwmod framework
iommu/omap: Keep mmu enabled when requested
iommu/omap: Remove redundant clock handling on ISR
iommu/amd: Remove obsolete comment
iommu/amd: Don't use 512GB pages
iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch
iommu/tegra: gart: Move bus_set_iommu after probe for multi arch
iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all
tile: dma_debug: add debug_dma_mapping_error support
sh: dma_debug: add debug_dma_mapping_error support
powerpc: dma_debug: add debug_dma_mapping_error support
mips: dma_debug: add debug_dma_mapping_error support
microblaze: dma-mapping: support debug_dma_mapping_error
ia64: dma_debug: add debug_dma_mapping_error support
c6x: dma_debug: add debug_dma_mapping_error support
ARM64: dma_debug: add debug_dma_mapping_error support
intel-iommu: Prevent devices with RMRRs from being placed into SI Domain
The include/uapi/asm/kvm_para.h includes
<include/uapi/asm/epapr_hcalls.h> but the correct reference
should be <include/asm/epapr_hcalls.h> as this is the place
where make install_header installs the header files for
userspace.
Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com>
CC: stable@vger.kernel.org
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing all that exciting; a new module-from-fd syscall for those who
want to verify the source of the module (ChromeOS) and/or use standard
IMA on it or other security hooks."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Fix kbuild output when using default extra_certificates
MODSIGN: Avoid using .incbin in C source
modules: don't hand 0 to vmalloc.
module: Remove a extra null character at the top of module->strtab.
ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants
ASN.1: Define indefinite length marker constant
moduleparam: use __UNIQUE_ID()
__UNIQUE_ID()
MODSIGN: Add modules_sign make target
powerpc: add finit_module syscall.
ima: support new kernel module syscall
add finit_module syscall to asm-generic
ARM: add finit_module syscall to ARM
security: introduce kernel_module_from_file hook
module: add flags arg to sys_finit_module()
module: add syscall to load module from fd
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlight is probably some base POWER8 support. There's more
to come such as transactional memory support but that will wait for
the next one.
Overall it's pretty quiet, or rather I've been pretty poor at picking
things up from patchwork and reviewing them this time around and Kumar
no better on the FSL side it seems..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits)
powerpc+of: Rename and fix OF reconfig notifier error inject module
powerpc: mpc5200: Add a3m071 board support
powerpc/512x: don't compile any platform DIU code if the DIU is not enabled
powerpc/mpc52xx: use module_platform_driver macro
powerpc+of: Export of_reconfig_notifier_[register,unregister]
powerpc/dma/raidengine: add raidengine device
powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct
powerpc/mpc85xx: Change spin table to cached memory
powerpc/fsl-pci: Add PCI controller ATMU PM support
powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI
drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS]
powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers
powerpc: Disable relocation on exceptions when kexecing
powerpc: Enable relocation on during exceptions at boot
powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function
powerpc: Add wrappers to enable/disable relocation on exceptions
powerpc: Add set_mode hcall
powerpc: Setup relocation on exceptions for bare metal systems
powerpc: Move initial mfspr LPCR out of __init_LPCR
powerpc: Add relocation on exception vector handlers
This function is used by sparc, powerpc tile and arm64 for compat support.
The patch adds a generic implementation with a wrapper for PowerPC to do
the u32->int sign extension.
The reason for a single patch covering powerpc, tile, sparc and arm64 is
to keep it bisectable, otherwise kernel building may fail with mismatched
function declarations.
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile]
Currently the __define_initcall() macro takes three arguments, fn, id and
level. The level argument is exactly the same as the id argument but
wrapped in quotes. To overcome this need to specify three arguments to
the __define_initcall macro, where one argument is the stringification of
another, we can just use the stringification macro instead.
Signed-off-by: Matthew Leach <matthew@mattleach.net>
(This is just for Acks: this won't work without the actual syscall patches,
sitting in my tree for -next at the moment).
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Pull KVM updates from Marcelo Tosatti:
"Considerable KVM/PPC work, x86 kvmclock vsyscall support,
IA32_TSC_ADJUST MSR emulation, amongst others."
Fix up trivial conflict in kernel/sched/core.c due to cross-cpu
migration notifier added next to rq migration call-back.
* tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits)
KVM: emulator: fix real mode segment checks in address linearization
VMX: remove unneeded enable_unrestricted_guest check
KVM: VMX: fix DPL during entry to protected mode
x86/kexec: crash_vmclear_local_vmcss needs __rcu
kvm: Fix irqfd resampler list walk
KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump
x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary
KVM: MMU: optimize for set_spte
KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface
KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation
KVM: PPC: bookehv: Add guest computation mode for irq delivery
KVM: PPC: Make EPCR a valid field for booke64 and bookehv
KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit
KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation
KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation
KVM: PPC: e500: Add emulation helper for getting instruction ea
KVM: PPC: bookehv64: Add support for interrupt handling
KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler
KVM: PPC: booke: Fix get_tb() compile error on 64-bit
KVM: PPC: e500: Silence bogus GCC warning in tlb code
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
Pull networking changes from David Miller:
1) Allow to dump, monitor, and change the bridge multicast database
using netlink. From Cong Wang.
2) RFC 5961 TCP blind data injection attack mitigation, from Eric
Dumazet.
3) Networking user namespace support from Eric W. Biederman.
4) tuntap/virtio-net multiqueue support by Jason Wang.
5) Support for checksum offload of encapsulated packets (basically,
tunneled traffic can still be checksummed by HW). From Joseph
Gasparakis.
6) Allow BPF filter access to VLAN tags, from Eric Dumazet and
Daniel Borkmann.
7) Bridge port parameters over netlink and BPDU blocking support
from Stephen Hemminger.
8) Improve data access patterns during inet socket demux by rearranging
socket layout, from Eric Dumazet.
9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and
Jon Maloy.
10) Update TCP socket hash sizing to be more in line with current day
realities. The existing heurstics were choosen a decade ago.
From Eric Dumazet.
11) Fix races, queue bloat, and excessive wakeups in ATM and
associated drivers, from Krzysztof Mazur and David Woodhouse.
12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions
in VXLAN driver, from David Stevens.
13) Add "oops_only" mode to netconsole, from Amerigo Wang.
14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also
allow DCB netlink to work on namespaces other than the initial
namespace. From John Fastabend.
15) Support PTP in the Tigon3 driver, from Matt Carlson.
16) tun/vhost zero copy fixes and improvements, plus turn it on
by default, from Michael S. Tsirkin.
17) Support per-association statistics in SCTP, from Michele
Baldessari.
And many, many, driver updates, cleanups, and improvements. Too
numerous to mention individually.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
net/mlx4_en: Add support for destination MAC in steering rules
net/mlx4_en: Use generic etherdevice.h functions.
net: ethtool: Add destination MAC address to flow steering API
bridge: add support of adding and deleting mdb entries
bridge: notify mdb changes via netlink
ndisc: Unexport ndisc_{build,send}_skb().
uapi: add missing netconf.h to export list
pkt_sched: avoid requeues if possible
solos-pci: fix double-free of TX skb in DMA mode
bnx2: Fix accidental reversions.
bna: Driver Version Updated to 3.1.2.1
bna: Firmware update
bna: Add RX State
bna: Rx Page Based Allocation
bna: TX Intr Coalescing Fix
bna: Tx and Rx Optimizations
bna: Code Cleanup and Enhancements
ath9k: check pdata variable before dereferencing it
ath5k: RX timestamp is reported at end of frame
ath9k_htc: RX timestamp is reported at end of frame
Pull big execve/kernel_thread/fork unification series from Al Viro:
"All architectures are converted to new model. Quite a bit of that
stuff is actually shared with architecture trees; in such cases it's
literally shared branch pulled by both, not a cherry-pick.
A lot of ugliness and black magic is gone (-3KLoC total in this one):
- kernel_thread()/kernel_execve()/sys_execve() redesign.
We don't do syscalls from kernel anymore for either kernel_thread()
or kernel_execve():
kernel_thread() is essentially clone(2) with callback run before we
return to userland, the callbacks either never return or do
successful do_execve() before returning.
kernel_execve() is a wrapper for do_execve() - it doesn't need to
do transition to user mode anymore.
As a result kernel_thread() and kernel_execve() are
arch-independent now - they live in kernel/fork.c and fs/exec.c
resp. sys_execve() is also in fs/exec.c and it's completely
architecture-independent.
- daemonize() is gone, along with its parts in fs/*.c
- struct pt_regs * is no longer passed to do_fork/copy_process/
copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump.
- sys_fork()/sys_vfork()/sys_clone() unified; some architectures
still need wrappers (ones with callee-saved registers not saved in
pt_regs on syscall entry), but the main part of those suckers is in
kernel/fork.c now."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits)
do_coredump(): get rid of pt_regs argument
print_fatal_signal(): get rid of pt_regs argument
ptrace_signal(): get rid of unused arguments
get rid of ptrace_signal_deliver() arguments
new helper: signal_pt_regs()
unify default ptrace_signal_deliver
flagday: kill pt_regs argument of do_fork()
death to idle_regs()
don't pass regs to copy_process()
flagday: don't pass regs to copy_thread()
bfin: switch to generic vfork, get rid of pointless wrappers
xtensa: switch to generic clone()
openrisc: switch to use of generic fork and clone
unicore32: switch to generic clone(2)
score: switch to generic fork/vfork/clone
c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone()
take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h
mn10300: switch to generic fork/vfork/clone
h8300: switch to generic fork/vfork/clone
tile: switch to generic clone()
arch/microblaze/include/asm/Kbuild
Pull scheduler updates from Ingo Molnar:
"The biggest change affects group scheduling: we now track the runnable
average on a per-task entity basis, allowing a smoother, exponential
decay average based load/weight estimation instead of the previous
binary on-the-runqueue/off-the-runqueue load weight method.
This will inevitably disturb workloads that were in some sort of
borderline balancing state or unstable equilibrium, so an eye has to
be kept on regressions.
For that reason the new load average is only limited to group
scheduling (shares distribution) at the moment (which was also hurting
the most from the prior, crude weight calculation and whose scheduling
quality wins most from this change) - but we plan to extend this to
regular SMP balancing as well in the future, which will simplify and
speed up things a bit.
Other changes involve ongoing preparatory work to extend NOHZ to the
scheduler as well, eventually allowing completely irq-free user-space
execution."
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
Revert "sched/autogroup: Fix crash on reboot when autogroup is disabled"
cputime: Comment cputime's adjusting code
cputime: Consolidate cputime adjustment code
cputime: Rename thread_group_times to thread_group_cputime_adjusted
cputime: Move thread_group_cputime() to sched code
vtime: Warn if irqs aren't disabled on system time accounting APIs
vtime: No need to disable irqs on vtime_account()
vtime: Consolidate a bit the ctx switch code
vtime: Explicitly account pending user time on process tick
vtime: Remove the underscore prefix invasion
cputime: Separate irqtime accounting from generic vtime
cputime: Specialize irq vtime hooks
kvm: Directly account vtime to system on guest switch
vtime: Make vtime_account_system() irqsafe
vtime: Gather vtime declarations to their own header file
sched: Describe CFS load-balancer
sched: Introduce temporary FAIR_GROUP_SCHED dependency for load-tracking
sched: Make __update_entity_runnable_avg() fast
sched: Update_cfs_shares at period edge
Pull perf updates from Ingo Molnar:
"Lots of activity:
211 files changed, 8328 insertions(+), 4116 deletions(-)
most of it on the tooling side.
Main changes:
* ftrace enhancements and fixes from Steve Rostedt.
* uprobes fixes, cleanups and preparation for the ARM port from Oleg
Nesterov.
* UAPI fixes, from David Howels - prepares the arch/x86 UAPI
transition
* Separate perf tests into multiple objects, one per test, from Jiri
Olsa.
* Make hardware event translations available in sysfs, from Jiri
Olsa.
* Fixes to /proc/pid/maps parsing, preparatory to supporting data
maps, from Namhyung Kim
* Implement ui_progress for GTK, from Namhyung Kim
* Add framework for automated perf_event_attr tests, where tools with
different command line options will be run from a 'perf test', via
python glue, and the perf syscall will be intercepted to verify
that the perf_event_attr fields set by the tool are those expected,
from Jiri Olsa
* Add a 'link' method for hists, so that we can have the leader with
buckets for all the entries in all the hists. This new method is
now used in the default 'diff' output, making the sum of the
'baseline' column be 100%, eliminating blind spots.
* libtraceevent fixes for compiler warnings trying to make perf it
build on some distros, like fedora 14, 32-bit, some of the warnings
really pointed to real bugs.
* Add a browser for 'perf script' and make it available from the
report and annotate browsers. It does filtering to find the
scripts that handle events found in the perf.data file used. From
Feng Tang
* perf inject changes to allow showing where a task sleeps, from
Andrew Vagin.
* Makefile improvements from Namhyung Kim.
* Add --pre and --post command hooks in 'stat', from Peter Zijlstra.
* Don't stop synthesizing threads when one vanishes, this is for the
existing threads when we start a tool like trace.
* Use sched:sched_stat_runtime to provide a thread summary, this
produces the same output as the 'trace summary' subcommand of
tglx's original "trace" tool.
* Support interrupted syscalls in 'trace'
* Add an event duration column and filter in 'trace'.
* There are references to the man pages in some tools, so try to
build Documentation when installing, warning the user if that is
not possible, from Borislav Petkov.
* Give user better message if precise is not supported, from David
Ahern.
* Try to find cross-built objdump path by using the session
environment information in the perf.data file header, from Irina
Tirdea, original patch and idea by Namhyung Kim.
* Diplays more output on features check for make V=1, so that one can
figure out what is happening by looking at gcc output, etc. From
Jiri Olsa.
* Add on_exit implementation for systems without one, e.g. Android,
from Bernhard Rosenkraenzer.
* Only process events for vcpus of interest, helps handling large
number of events, from David Ahern.
* Cross compilation fixes for Android, from Irina Tirdea.
* Add documentation on compiling for Android, from Irina Tirdea.
* perf diff improvements from Jiri Olsa.
* Target (task/user/cpu/syswide) handling improvements, from Namhyung
Kim.
* Add support in 'trace' for tracing workload given by command line,
from Namhyung Kim.
* ... and much more."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (194 commits)
uprobes: Use percpu_rw_semaphore to fix register/unregister vs dup_mmap() race
perf evsel: Introduce is_group_member method
perf powerpc: Use uapi/unistd.h to fix build error
tools: Pass the target in descend
tools: Honour the O= flag when tool build called from a higher Makefile
tools: Define a Makefile function to do subdir processing
perf ui: Always compile browser setup code
perf ui: Add ui_progress__finish()
perf ui gtk: Implement ui_progress functions
perf ui: Introduce generic ui_progress helper
perf ui tui: Move progress.c under ui/tui directory
perf tools: Add basic event modifier sanity check
perf tools: Omit group members from perf_evlist__disable/enable
perf tools: Ensure single disable call per event in record comand
perf tools: Fix 'disabled' attribute config for record command
perf tools: Fix attributes for '{}' defined event groups
perf tools: Use sscanf for parsing /proc/pid/maps
perf tools: Add gtk.<command> config option for launching GTK browser
perf tools: Fix compile error on NO_NEWT=1 build
perf hists: Initialize all of he->stat with zeroes
Implement ONE_REG interface for EPCR register adding KVM_REG_PPC_EPCR to
the list of ONE_REG PPC supported registers.
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
[agraf: remove HV dependency, use get/put_user]
In BookE, EPCR is defined and valid when either the HV or the 64bit
category are implemented. Reflect this in the field definition.
Today the only KVM target on 64bit is HV enabled, so there is no
change in actual source code, but this keeps the code closer to the
spec and doesn't build up artificial road blocks for a PR KVM
on 64bit.
Extend MAS2 EPN mask to retain most significant bits on 64-bit hosts.
Use this mask in tlb effective address accessor.
Mask high 32 bits of effective address in emulation layer for guests running
in 32-bit mode.
[agraf: fix indent]
Add emulation helper for getting instruction ea and refactor tlb instruction
emulation to use it.
[agraf: keep rt variable around]
Add interrupt handling support for 64-bit bookehv hosts. Unify 32 and 64 bit
implementations using a common stack layout and a common execution flow starting
from kvm_handler_common macro. Update documentation for 64-bit input register
values. This patch only address the bolted TLB miss exception handlers version.
panicking
Currently, if a machine check interrupt happens while we are in the
guest, we exit the guest and call the host's machine check handler,
which tends to cause the host to panic. Some machine checks can be
triggered by the guest; for example, if the guest creates two entries
in the SLB that map the same effective address, and then accesses that
effective address, the CPU will take a machine check interrupt.
To handle this better, when a machine check happens inside the guest,
we call a new function, kvmppc_realmode_machine_check(), while still in
real mode before exiting the guest. On POWER7, it handles the cases
that the guest can trigger, either by flushing and reloading the SLB,
or by flushing the TLB, and then it delivers the machine check interrupt
directly to the guest without going back to the host. On POWER7, the
OPAL firmware patches the machine check interrupt vector so that it
gets control first, and it leaves behind its analysis of the situation
in a structure pointed to by the opal_mc_evt field of the paca. The
kvmppc_realmode_machine_check() function looks at this, and if OPAL
reports that there was no error, or that it has handled the error, we
also go straight back to the guest with a machine check. We have to
deliver a machine check to the guest since the machine check interrupt
might have trashed valid values in SRR0/1.
If the machine check is one we can't handle in real mode, and one that
OPAL hasn't already handled, or on PPC970, we exit the guest and call
the host's machine check handler. We do this by jumping to the
machine_check_fwnmi label, rather than absolute address 0x200, because
we don't want to re-execute OPAL's handler on POWER7. On PPC970, the
two are equivalent because address 0x200 just contains a branch.
Then, if the host machine check handler decides that the system can
continue executing, kvmppc_handle_exit() delivers a machine check
interrupt to the guest -- once again to let the guest know that SRR0/1
have been modified.
[agraf: fix checkpatch warnings]
When we change or remove a HPT (hashed page table) entry, we can do
either a global TLB invalidation (tlbie) that works across the whole
machine, or a local invalidation (tlbiel) that only affects this core.
Currently we do local invalidations if the VM has only one vcpu or if
the guest requests it with the H_LOCAL flag, though the guest Linux
kernel currently doesn't ever use H_LOCAL. Then, to cope with the
possibility that vcpus moving around to different physical cores might
expose stale TLB entries, there is some code in kvmppc_hv_entry to
flush the whole TLB of entries for this VM if either this vcpu is now
running on a different physical core from where it last ran, or if this
physical core last ran a different vcpu.
There are a number of problems on POWER7 with this as it stands:
- The TLB invalidation is done per thread, whereas it only needs to be
done per core, since the TLB is shared between the threads.
- With the possibility of the host paging out guest pages, the use of
H_LOCAL by an SMP guest is dangerous since the guest could possibly
retain and use a stale TLB entry pointing to a page that had been
removed from the guest.
- The TLB invalidations that we do when a vcpu moves from one physical
core to another are unnecessary in the case of an SMP guest that isn't
using H_LOCAL.
- The optimization of using local invalidations rather than global should
apply to guests with one virtual core, not just one vcpu.
(None of this applies on PPC970, since there we always have to
invalidate the whole TLB when entering and leaving the guest, and we
can't support paging out guest memory.)
To fix these problems and simplify the code, we now maintain a simple
cpumask of which cpus need to flush the TLB on entry to the guest.
(This is indexed by cpu, though we only ever use the bits for thread
0 of each core.) Whenever we do a local TLB invalidation, we set the
bits for every cpu except the bit for thread 0 of the core that we're
currently running on. Whenever we enter a guest, we test and clear the
bit for our core, and flush the TLB if it was set.
On initial startup of the VM, and when resetting the HPT, we set all the
bits in the need_tlb_flush cpumask, since any core could potentially have
stale TLB entries from the previous VM to use the same LPID, or the
previous contents of the HPT.
Then, we maintain a count of the number of online virtual cores, and use
that when deciding whether to use a local invalidation rather than the
number of online vcpus. The code to make that decision is extracted out
into a new function, global_invalidates(). For multi-core guests on
POWER7 (i.e. when we are using mmu notifiers), we now never do local
invalidations regardless of the H_LOCAL flag.
This fixes various issues in how we were handling the VSX registers
that exist on POWER7 machines. First, we were running off the end
of the current->thread.fpr[] array. Ultimately this was because the
vcpu->arch.vsr[] array is sized to be able to store both the FP
registers and the extra VSX registers (i.e. 64 entries), but PR KVM
only uses it for the extra VSX registers (i.e. 32 entries).
Secondly, calling load_up_vsx() from C code is a really bad idea,
because it jumps to fast_exception_return at the end, rather than
returning with a blr instruction. This was causing it to jump off
to a random location with random register contents, since it was using
the largely uninitialized stack frame created by kvmppc_load_up_vsx.
In fact, it isn't necessary to call either __giveup_vsx or load_up_vsx,
since giveup_fpu and load_up_fpu handle the extra VSX registers as well
as the standard FP registers on machines with VSX. Also, since VSX
instructions can access the VMX registers and the FP registers as well
as the extra VSX registers, we have to load up the FP and VMX registers
before we can turn on the MSR_VSX bit for the guest. Conversely, if
we save away any of the VSX or FP registers, we have to turn off MSR_VSX
for the guest.
To handle all this, it is more convenient for a single call to
kvmppc_giveup_ext() to handle all the state saving that needs to be done,
so we make it take a set of MSR bits rather than just one, and the switch
statement becomes a series of if statements. Similarly kvmppc_handle_ext
needs to be able to load up more than one set of registers.
This adds basic emulation of the PURR and SPURR registers. We assume
we are emulating a single-threaded core, so these advance at the same
rate as the timebase. A Linux kernel running on a POWER7 expects to
be able to access these registers and is not prepared to handle a
program interrupt on accessing them.
This also adds a very minimal emulation of the DSCR (data stream
control register). Writes are ignored and reads return zero.
A new ioctl, KVM_PPC_GET_HTAB_FD, returns a file descriptor. Reads on
this fd return the contents of the HPT (hashed page table), writes
create and/or remove entries in the HPT. There is a new capability,
KVM_CAP_PPC_HTAB_FD, to indicate the presence of the ioctl. The ioctl
takes an argument structure with the index of the first HPT entry to
read out and a set of flags. The flags indicate whether the user is
intending to read or write the HPT, and whether to return all entries
or only the "bolted" entries (those with the bolted bit, 0x10, set in
the first doubleword).
This is intended for use in implementing qemu's savevm/loadvm and for
live migration. Therefore, on reads, the first pass returns information
about all HPTEs (or all bolted HPTEs). When the first pass reaches the
end of the HPT, it returns from the read. Subsequent reads only return
information about HPTEs that have changed since they were last read.
A read that finds no changed HPTEs in the HPT following where the last
read finished will return 0 bytes.
The format of the data provides a simple run-length compression of the
invalid entries. Each block of data starts with a header that indicates
the index (position in the HPT, which is just an array), the number of
valid entries starting at that index (may be zero), and the number of
invalid entries following those valid entries. The valid entries, 16
bytes each, follow the header. The invalid entries are not explicitly
represented.
[agraf: fix documentation]
This makes a HPTE removal function, kvmppc_do_h_remove(), available
outside book3s_hv_rm_mmu.c. This will be used by the HPT writing
code.
This uses a bit in our record of the guest view of the HPTE to record
when the HPTE gets modified. We use a reserved bit for this, and ensure
that this bit is always cleared in HPTE values returned to the guest.
The recording of modified HPTEs is only done if other code indicates
its interest by setting kvm->arch.hpte_mod_interest to a non-zero value.
The reason for this is that when later commits add facilities for
userspace to read the HPT, the first pass of reading the HPT will be
quicker if there are no (or very few) HPTEs marked as modified,
rather than having most HPTEs marked as modified.
This restructures the code that creates HPT (hashed page table)
entries so that it can be called in situations where we don't have a
struct vcpu pointer, only a struct kvm pointer. It also fixes a bug
where kvmppc_map_vrma() would corrupt the guest R4 value.
Most of the work of kvmppc_virtmode_h_enter is now done by a new
function, kvmppc_virtmode_do_h_enter, which itself calls another new
function, kvmppc_do_h_enter, which contains most of the old
kvmppc_h_enter. The new kvmppc_do_h_enter takes explicit arguments
for the place to return the HPTE index, the Linux page tables to use,
and whether it is being called in real mode, thus removing the need
for it to have the vcpu as an argument.
Currently kvmppc_map_vrma creates the VRMA (virtual real mode area)
HPTEs by calling kvmppc_virtmode_h_enter, which is designed primarily
to handle H_ENTER hcalls from the guest that need to pin a page of
memory. Since H_ENTER returns the index of the created HPTE in R4,
kvmppc_virtmode_h_enter updates the guest R4, corrupting the guest R4
in the case when it gets called from kvmppc_map_vrma on the first
VCPU_RUN ioctl. With this, kvmppc_map_vrma instead calls
kvmppc_virtmode_do_h_enter with the address of a dummy word as the
place to store the HPTE index, thus avoiding corrupting the guest R4.
'arch-h8300', 'arch-m32r', 'arch-mn10300', 'arch-score', 'arch-sh' and 'arch-powerpc' into for-next
Add dma-debug interface debug_dma_mapping_error() to debug drivers that fail
to check dma mapping errors on addresses returned by dma_map_single() and
dma_map_page() interfaces.
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
PAMU bypass enable register added to the ccsr_guts structure.
Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com>
On ia64 and powerpc, vtime context switch only consists
in flushing system and user pending time, plus a few
arch housekeeping.
Consolidate that into a generic implementation. s390 is
a special case because pending user and system time accounting
there is hard to dissociate. So it's keeping its own implementation.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
This patch is a follow-up for patch "filter: add XOR instruction for use
with X/K" that implements BPF PowerPC JIT parts for the BPF XOR operation.
Signed-off-by: Daniel Borkmann <daniel.borkmann@tik.ee.ethz.ch>
Cc: Matt Evans <matt@ozlabs.org>
Acked-by: Matt Evans <matt@ozlabs.org>
I am going to use this in the next patch, better to have this code in
one place rather than three.
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
Signed-off-by: Michael Neuling <mikey@neuling.org>
This new hcall in POWER8 is used to set various resource mode registers.
eg. it can set address translation mode on interrupt (note: partition wide
scope)
This turns on MMU on execptions via AIL field in the LPCR.
Signed-off-by: Matt Evans <matt@ozlabs.org>
POWER8/v2.07 allows exceptions to be taken with the MMU still on.
A new set of exception vectors is added at 0xc000_0000_0000_4xxx. When the HW
takes us here, MSR IR/DR will be set already and we no longer need a costly
RFID to turn the MMU back on again.
The original 0x0 based exception vectors remain for when the HW can't leave the
MMU on. Examples of this are when we can't trust the current MMU mappings,
like when we are changing from guest to hypervisor (HV 0 -> 1) or when the MMU
was off already. In these cases the HW will take us to the original 0x0 based
exception vectors with the MMU off as before.
This uses the new macros added previously too implement these new execption
vectors at 0xc000_0000_0000_4xxx. We exit these exception vectors using
mflr/blr (rather than mtspr SSR0/RFID), since we don't need the costly MMU
switch anymore.
This moves the __end_interrupts marker down past these new 0x4000 vectors since
they will need to be copied down to 0x0 when the kernel is not at 0x0.
MMU on. Examples of this are when we can't trust the current the MMU mappings,
The below macros are copies of the macros used at the 0x0 offset but modified
to handle the MMU being on. In these macros we use the link register to jump
to the secondary handlers rather than using RFID (RFID was also use to turn on
the MMU).
If we change load_hander() to use an ori instead of addi, we can load handlers
upto 64k away provided we are still 64k aligned.
The only difference between powerpc and asm-generic le-bitops is
test_bit_le(). Usually all bitops require a long aligned bitmap.
But powerpc test_bit_le() can take an unaligned address.
There is no special callsite of test_bit_le() that needs unaligned
access in powerpc as far as I can see. So convert to use
asm-generic/bitops/le.h for powerpc.
Cc: linuxppc-dev@lists.ozlabs.org
Replace BITOP_MASK and BITOP_WORD with BIT_MASK and BIT_WORD defined
in linux/bitops.h and remove BITOP_* which are not used anymore.
