path: root/arch/powerpc/kernel/asm-offsets.c
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
2011-05-22KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0)Scott Wood
Linux doesn't use USPRG0 (now renamed VRSAVE in the architecture, even when Altivec isn't involved), but a guest might. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-04-27powerpc: Per process DSCR + some fixes (try#4)Alexey Kardashevskiy
The DSCR (aka Data Stream Control Register) is supported on some server PowerPC chips and allow some control over the prefetch of data streams. This patch allows the value to be specified per thread by emulating the corresponding mfspr and mtspr instructions. Children of such threads inherit the value. Other threads use a default value that can be specified in sysfs - /sys/devices/system/cpu/dscr_default. If a thread starts with non default value in the sysfs entry, all children threads inherit this non default value even if the sysfs value is changed later. Signed-off-by: Alexey Kardashevskiy <aik@au1.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-29powerpc: Remove second definition of STACK_FRAME_OVERHEADStephen Rothwell
Since STACK_FRAME_OVERHEAD is defined in asm/ptrace.h and that is ASSEMBER safe, we can just include that instead of going via asm-offsets.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-10-24Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits) KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages KVM: Fix signature of kvm_iommu_map_pages stub KVM: MCE: Send SRAR SIGBUS directly KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED KVM: fix typo in copyright notice KVM: Disable interrupts around get_kernel_ns() KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address KVM: MMU: move access code parsing to FNAME(walk_addr) function KVM: MMU: audit: check whether have unsync sps after root sync KVM: MMU: audit: introduce audit_printk to cleanup audit code KVM: MMU: audit: unregister audit tracepoints before module unloaded KVM: MMU: audit: fix vcpu's spte walking KVM: MMU: set access bit for direct mapping KVM: MMU: cleanup for error mask set while walk guest page table KVM: MMU: update 'root_hpa' out of loop in PAE shadow path KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn() KVM: x86: Fix constant type in kvm_get_time_scale KVM: VMX: Add AX to list of registers clobbered by guest switch KVM guest: Move a printk that's using the clock before it's ready KVM: x86: TSC catchup mode ...
2010-10-24KVM: PPC: Add mtsrin PV codeAlexander Graf
This is the guest side of the mtsr acceleration. Using this a guest can now call mtsrin with almost no overhead as long as it ensures that it only uses it with (MSR_IR|MSR_DR) == 0. Linux does that, so we're good. Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Fix CONFIG_KVM_GUEST && !CONFIG_KVM caseAlexander Graf
When CONFIG_KVM_GUEST is selected, but CONFIG_KVM is not, we were missing some defines in asm-offsets.c and included too many headers at other places. This patch makes above configuration work. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Generic KVM PV guest supportAlexander Graf
We have all the hypervisor pieces in place now, but the guest parts are still missing. This patch implements basic awareness of KVM when running Linux as guest. It doesn't do anything with it yet though. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Convert MSR to shared pageAlexander Graf
One of the most obvious registers to share with the guest directly is the MSR. The MSR contains the "interrupts enabled" flag which the guest has to toggle in critical sections. So in order to bring the overhead of interrupt en- and disabling down, let's put msr into the shared page. Keep in mind that even though you can fully read its contents, writing to it doesn't always update all state. There are a few safe fields that don't require hypervisor interaction. See the documentation for a list of MSR bits that are safe to be set from inside the guest. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Introduce shared pageAlexander Graf
For transparent variable sharing between the hypervisor and guest, I introduce a shared page. This shared page will contain all the registers the guest can read and write safely without exiting guest context. This patch only implements the stubs required for the basic structure of the shared page. The actual register moving follows. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-14powerpc/fsl-booke64: Use TLB CAMs to cover linear mapping on FSL 64-bit chipsKumar Gala
On Freescale parts typically have TLB array for large mappings that we can bolt the linear mapping into. We utilize the code that already exists on PPC32 on the 64-bit side to setup the linear mapping to be cover by bolted TLB entries. We utilize a quarter of the variable size TLB array for this purpose. Additionally, we limit the amount of memory to what we can cover via bolted entries so we don't get secondary faults in the TLB miss handlers. We should fix this limitation in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-02powerpc: Account time using timebase rather than PURRPaul Mackerras
Currently, when CONFIG_VIRT_CPU_ACCOUNTING is enabled, we use the PURR register for measuring the user and system time used by processes, as well as other related times such as hardirq and softirq times. This turns out to be quite confusing for users because it means that a program will often be measured as taking less time when run on a multi-threaded processor (SMT2 or SMT4 mode) than it does when run on a single-threaded processor (ST mode), even though the program takes longer to finish. The discrepancy is accounted for as stolen time, which is also confusing, particularly when there are no other partitions running. This changes the accounting to use the timebase instead, meaning that the reported user and system times are the actual number of real-time seconds that the program was executing on the processor thread, regardless of which SMT mode the processor is in. Thus a program will generally show greater user and system times when run on a multi-threaded processor than on a single-threaded processor. On pSeries systems on POWER5 or later processors, we measure the stolen time (time when this partition wasn't running) using the hypervisor dispatch trace log. We check for new entries in the log on every entry from user mode and on every transition from kernel process context to soft or hard IRQ context (i.e. when account_system_vtime() gets called). So that we can correctly distinguish time stolen from user time and time stolen from system time, without having to check the log on every exit to user mode, we store separate timestamps for exit to user mode and entry from user mode. On systems that have a SPURR (POWER6 and POWER7), we read the SPURR in account_system_vtime() (as before), and then apportion the SPURR ticks since the last time we read it between scaled user time and scaled system time according to the relative proportions of user time and system time over the same interval. This avoids having to read the SPURR on every kernel entry and exit. On systems that have PURR but not SPURR (i.e., POWER5), we do the same using the PURR rather than the SPURR. This disables the DTL user interface in /sys/debug/kernel/powerpc/dtl for now since it conflicts with the use of the dispatch trace log by the time accounting code. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-09powerpc: Optimise per cpu accesses on 64bitAnton Blanchard
Now we dynamically allocate the paca array, it takes an extra load whenever we want to access another cpu's paca. One place we do that a lot is per cpu variables. A simple example: DEFINE_PER_CPU(unsigned long, vara); unsigned long test4(int cpu) { return per_cpu(vara, cpu); } This takes 4 loads, 5 if you include the actual load of the per cpu variable: ld r11,-32760(r30) # load address of paca pointer ld r9,-32768(r30) # load link address of percpu variable sldi r3,r29,9 # get offset into paca (each entry is 512 bytes) ld r0,0(r11) # load paca pointer add r3,r0,r3 # paca + offset ld r11,64(r3) # load paca[cpu].data_offset ldx r3,r9,r11 # load per cpu variable If we remove the ppc64 specific per_cpu_offset(), we get the generic one which indexes into a statically allocated array. This removes one load and one add: ld r11,-32760(r30) # load address of __per_cpu_offset ld r9,-32768(r30) # load link address of percpu variable sldi r3,r29,3 # get offset into __per_cpu_offset (each entry 8 bytes) ldx r11,r11,r3 # load __per_cpu_offset[cpu] ldx r3,r9,r11 # load per cpu variable Having all the offsets in one array also helps when iterating over a per cpu variable across a number of cpus, such as in the scheduler. Before we would need to load one paca cacheline when calculating each per cpu offset. Now we have 16 (128 / sizeof(long)) per cpu offsets in each cacheline. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-09powerpc: Rework VDSO gettimeofday to prevent time going backwardsPaul Mackerras
Currently it is possible for userspace to see the result of gettimeofday() going backwards by 1 microsecond, assuming that userspace is using the gettimeofday() in the VDSO. The VDSO gettimeofday() algorithm computes the time in "xsecs", which are units of 2^-20 seconds, or approximately 0.954 microseconds, using the algorithm now = (timebase - tb_orig_stamp) * tb_to_xs + stamp_xsec and then converts the time in xsecs to seconds and microseconds. The kernel updates the tb_orig_stamp and stamp_xsec values every tick in update_vsyscall(). If the length of the tick is not an integer number of xsecs, then some precision is lost in converting the current time to xsecs. For example, with CONFIG_HZ=1000, the tick is 1ms long, which is 1048.576 xsecs. That means that stamp_xsec will advance by either 1048 or 1049 on each tick. With the right conditions, it is possible for userspace to get (timebase - tb_orig_stamp) * tb_to_xs being 1049 if the kernel is slightly late in updating the vdso_datapage, and then for stamp_xsec to advance by 1048 when the kernel does update it, and for userspace to then see (timebase - tb_orig_stamp) * tb_to_xs being zero due to integer truncation. The result is that time appears to go backwards by 1 microsecond. To fix this we change the VDSO gettimeofday to use a new field in the VDSO datapage which stores the nanoseconds part of the time as a fractional number of seconds in a 0.32 binary fraction format. (Or put another way, as a 32-bit number in units of 0.23283 ns.) This is convenient because we can use the mulhwu instruction to convert it to either microseconds or nanoseconds. Since it turns out that computing the time of day using this new field is simpler than either using stamp_xsec (as gettimeofday does) or stamp_xtime.tv_nsec (as clock_gettime does), this converts both gettimeofday and clock_gettime to use the new field. The existing __do_get_tspec function is converted to use the new field and take a parameter in r7 that indicates the desired resolution, 1,000,000 for microseconds or 1,000,000,000 for nanoseconds. The __do_get_xsec function is then unused and is deleted. The new algorithm is now = ((timebase - tb_orig_stamp) << 12) * tb_to_xs + (stamp_xtime_seconds << 32) + stamp_sec_fraction with 'now' in units of 2^-32 seconds. That is then converted to seconds and either microseconds or nanoseconds with seconds = now >> 32 partseconds = ((now & 0xffffffff) * resolution) >> 32 The 32-bit VDSO code also makes a further simplification: it ignores the bottom 32 bits of the tb_to_xs value, which is a 0.64 format binary fraction. Doing so gets rid of 4 multiply instructions. Assuming a timebase frequency of 1GHz or less and an update interval of no more than 10ms, the upper 32 bits of tb_to_xs will be at least 4503599, so the error from ignoring the low 32 bits will be at most 2.2ns, which is more than an order of magnitude less than the time taken to do gettimeofday or clock_gettime on our fastest processors, so there is no possibility of seeing inconsistent values due to this. This also moves update_gtod() down next to its only caller, and makes update_vsyscall use the time passed in via the wall_time argument rather than accessing xtime directly. At present, wall_time always points to xtime, but that could change in future. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-21Merge branch 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (269 commits) KVM: x86: Add missing locking to arch specific vcpu ioctls KVM: PPC: Add missing vcpu_load()/vcpu_put() in vcpu ioctls KVM: MMU: Segregate shadow pages with different cr0.wp KVM: x86: Check LMA bit before set_efer KVM: Don't allow lmsw to clear cr0.pe KVM: Add cpuid.txt file KVM: x86: Tell the guest we'll warn it about tsc stability x86, paravirt: don't compute pvclock adjustments if we trust the tsc x86: KVM guest: Try using new kvm clock msrs KVM: x86: export paravirtual cpuid flags in KVM_GET_SUPPORTED_CPUID KVM: x86: add new KVMCLOCK cpuid feature KVM: x86: change msr numbers for kvmclock x86, paravirt: Add a global synchronization point for pvclock x86, paravirt: Enable pvclock flags in vcpu_time_info structure KVM: x86: Inject #GP with the right rip on efer writes KVM: SVM: Don't allow nested guest to VMMCALL into host KVM: x86: Fix exception reinjection forced to true KVM: Fix wallclock version writing race KVM: MMU: Don't read pdptrs with mmu spinlock held in mmu_alloc_roots KVM: VMX: enable VMXON check with SMX enabled (Intel TXT) ...
2010-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (92 commits) powerpc: Remove unused 'protect4gb' boot parameter powerpc: Build-in e1000e for pseries & ppc64_defconfig powerpc/pseries: Make request_ras_irqs() available to other pseries code powerpc/numa: Use ibm,architecture-vec-5 to detect form 1 affinity powerpc/numa: Set a smaller value for RECLAIM_DISTANCE to enable zone reclaim powerpc: Use smt_snooze_delay=-1 to always busy loop powerpc: Remove check of ibm,smt-snooze-delay OF property powerpc/kdump: Fix race in kdump shutdown powerpc/kexec: Fix race in kexec shutdown powerpc/kexec: Speedup kexec hash PTE tear down powerpc/pseries: Add hcall to read 4 ptes at a time in real mode powerpc: Use more accurate limit for first segment memory allocations powerpc/kdump: Use chip->shutdown to disable IRQs powerpc/kdump: CPUs assume the context of the oopsing CPU powerpc/crashdump: Do not fail on NULL pointer dereferencing powerpc/eeh: Fix oops when probing in early boot powerpc/pci: Check devices status property when scanning OF tree powerpc/vio: Switch VIO Bus PM to use generic helpers powerpc: Avoid bad relocations in iSeries code powerpc: Use common cpu_die (fixes SMP+SUSPEND build) ...
2010-05-21powerpc/kexec: Fix race in kexec shutdownMichael Neuling
In kexec_prepare_cpus, the primary CPU IPIs the secondary CPUs to kexec_smp_down(). kexec_smp_down() calls kexec_smp_wait() which sets the hw_cpu_id() to -1. The primary does this while leaving IRQs on which means the primary can take a timer interrupt which can lead to the IPIing one of the secondary CPUs (say, for a scheduler re-balance) but since the secondary CPU now has a hw_cpu_id = -1, we IPI CPU -1... Kaboom! We are hitting this case regularly on POWER7 machines. There is also a second race, where the primary will tear down the MMU mappings before knowing the secondaries have entered real mode. Also, the secondaries are clearing out any pending IPIs before guaranteeing that no more will be received. This changes kexec_prepare_cpus() so that we turn off IRQs in the primary CPU much earlier. It adds a paca flag to say that the secondaries have entered the kexec_smp_down() IPI and turned off IRQs, rather than overloading hw_cpu_id with -1. This new paca flag is again used to in indicate when the secondaries has entered real mode. It also ensures that all CPUs have their IRQs off before we clear out any pending IPI requests (in kexec_cpu_down()) to ensure there are no trailing IPIs left unacknowledged. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-17powerpc/fsl-booke: Move loadcam_entry back to asm code to fix SMP ftraceKumar Gala
When we build with ftrace enabled its possible that loadcam_entry would have used the stack pointer (even though the code doesn't need it). We call loadcam_entry in __secondary_start before the stack is setup. To ensure that loadcam_entry doesn't use the stack pointer the easiest solution is to just have it in asm code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-05-17PPC: Export SWITCH_FRAME_SIZEAlexander Graf
We need the SWITCH_FRAME_SIZE define on Book3S_32 now too. So let's export it unconditionally. CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Add SVCPU to Book3S_32Alexander Graf
We need to keep the pointer to the shadow vcpu somewhere accessible from within really early interrupt code. The best fit I found was the thread struct, as that resides in an SPRG. So let's put a pointer to the shadow vcpu in the thread struct and add an asm-offset so we can find it. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Use now shadowed vcpu fieldsAlexander Graf
The shadow vcpu now contains some fields we don't use from the vcpu anymore. Access to them happens using inline functions that happily use the shadow vcpu fields. So let's now ifdef them out to booke only and add asm-offsets. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Use CONFIG_PPC_BOOK3S defineAlexander Graf
Upstream recently added a new name for PPC64: Book3S_64. So instead of using CONFIG_PPC64 we should use CONFIG_PPC_BOOK3S consotently. That makes understanding the code easier (I hope). Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-12powerpc/perf_event: Fix oops due to perf_event_do_pending callPaul Mackerras
Anton Blanchard found that large POWER systems would occasionally crash in the exception exit path when profiling with perf_events. The symptom was that an interrupt would occur late in the exit path when the MSR[RI] (recoverable interrupt) bit was clear. Interrupts should be hard-disabled at this point but they were enabled. Because the interrupt was not recoverable the system panicked. The reason is that the exception exit path was calling perf_event_do_pending after hard-disabling interrupts, and perf_event_do_pending will re-enable interrupts. The simplest and cleanest fix for this is to use the same mechanism that 32-bit powerpc does, namely to cause a self-IPI by setting the decrementer to 1. This means we can remove the tests in the exception exit path and raw_local_irq_restore. This also makes sure that the call to perf_event_do_pending from timer_interrupt() happens within irq_enter/irq_exit. (Note that calling perf_event_do_pending from timer_interrupt does not mean that there is a possible 1/HZ latency; setting the decrementer to 1 ensures that the timer interrupt will happen immediately, i.e. within one timebase tick, which is a few nanoseconds or 10s of nanoseconds.) Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: stable@kernel.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-03-01KVM: PPC: Keep SRR1 flags around in shadow_msrAlexander Graf
SRR1 stores more information that just the MSR value. It also stores valuable information about the type of interrupt we received, for example whether the storage interrupt we just got was because of a missing htab entry or not. We use that information to speed up the exit path. Now if we get preempted before we can interpret the shadow_msr values, we get into vcpu_put which then calls the MSR handler, which then sets all the SRR1 information bits in shadow_msr to 0. Great. So let's preserve the SRR1 specific bits in shadow_msr whenever we set the MSR. They don't hurt. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: PPC: Call SLB patching code in interrupt safe mannerAlexander Graf
Currently we're racy when doing the transition from IR=1 to IR=0, from the module memory entry code to the real mode SLB switching code. To work around that I took a look at the RTAS entry code which is faced with a similar problem and did the same thing: A small helper in linear mapped memory that does mtmsr with IR=0 and then RFIs info the actual handler. Thanks to that trick we can safely take page faults in the entry code and only need to be really wary of what to do as of the SLB switching part. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: PPC: Use PACA backed shadow vcpuAlexander Graf
We're being horribly racy right now. All the entry and exit code hijacks random fields from the PACA that could easily be used by different code in case we get interrupted, for example by a #MC or even page fault. After discussing this with Ben, we figured it's best to reserve some more space in the PACA and just shove off some vcpu state to there. That way we can drastically improve the readability of the code, make it less racy and less complex. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-11-20powerpc/fsl-booke: Rework TLB CAM codeKumar Gala
Re-write the code so its more standalone and fixed some issues: * Bump'd # of CAM entries to 64 to support e500mc * Make the code handle MAS7 properly * Use pr_cont instead of creating a string as we go Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-05Export new PACA constants in asm-offsetsAlexander Graf
In order to access fields in the PACA from assembly code, we need to generate offsets using asm-offsets.c. So let's add the new PACA related bits, we just introduced! Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-05Add Book3s_64 offsets to asm-offsets.cAlexander Graf
We need to access some VCPU fields from assembly code. In order to get the proper offsets, we have to define them in asm-offsets.c. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-20Merge commit 'paulus-perf/master' into nextBenjamin Herrenschmidt
2009-08-20powerpc: Add PACA fields specific to 64-bit Book3E processorsBenjamin Herrenschmidt
This adds various fields in the PACA that are for use specifically by Book3E processors, such as exception save areas, current pgd pointer, special exceptions kernel stacks etc... Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc: Add memory management headers for new 64-bit BookEBenjamin Herrenschmidt
This adds the PTE and pgtable format definitions, along with changes to the kernel memory map and other definitions related to implementing support for 64-bit Book3E. This also shields some asm-offset bits that are currently only relevant on 32-bit We also move the definition of the "linux" page size constants to the common mmu.h file and add a few sizes that are relevant to embedded processors. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-18powerpc: Allow perf_counters to access user memory at interrupt timePaul Mackerras
This provides a mechanism to allow the perf_counters code to access user memory in a PMU interrupt routine. Such an access can cause various kinds of interrupt: SLB miss, MMU hash table miss, segment table miss, or TLB miss, depending on the processor. This commit only deals with 64-bit classic/server processors, which use an MMU hash table. 32-bit processors are already able to access user memory at interrupt time. Since we don't soft-disable on 32-bit, we avoid the possibility of reentering hash_page or the TLB miss handlers, since they run with interrupts disabled. On 64-bit processors, an SLB miss interrupt on a user address will update the slb_cache and slb_cache_ptr fields in the paca. This is OK except in the case where a PMU interrupt occurs in switch_slb, which also accesses those fields. To prevent this, we hard-disable interrupts in switch_slb. Interrupts are already soft-disabled at this point, and will get hard-enabled when they get soft-enabled later. This also reworks slb_flush_and_rebolt: to avoid hard-disabling twice, and to make sure that it clears the slb_cache_ptr when called from other callers than switch_slb, the existing routine is renamed to __slb_flush_and_rebolt, which is called by switch_slb and the new version of slb_flush_and_rebolt. Similarly, switch_stab (used on POWER3 and RS64 processors) gets a hard_irq_disable() to protect the per-cpu variables used there and in ste_allocate. If a MMU hashtable miss interrupt occurs, normally we would call hash_page to look up the Linux PTE for the address and create a HPTE. However, hash_page is fairly complex and takes some locks, so to avoid the possibility of deadlock, we check the preemption count to see if we are in a (pseudo-)NMI handler, and if so, we don't call hash_page but instead treat it like a bad access that will get reported up through the exception table mechanism. An interrupt whose handler runs even though the interrupt occurred when soft-disabled (such as the PMU interrupt) is considered a pseudo-NMI handler, which should use nmi_enter()/nmi_exit() rather than irq_enter()/irq_exit(). Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-06-12Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/kernel/asm-offsets.c
2009-06-09powerpc: Separate PACA fields for server CPUsBenjamin Herrenschmidt
This patch has no effect other than re-ordering PACA fields on current server CPUs. It however is a pre-requisite for future support of BookE 64-bit processors. Various parts of the PACA struct are now moved under some ifdef's, either the new CONFIG_PPC_BOOK3S or CONFIG_PPC_STD_MMU_64, whatever seems more appropriate. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.craashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-06Merge branch 'linus' into perfcounters/core-v2Ingo Molnar
Merge reason: we have gathered quite a few conflicts, need to merge upstream Conflicts: arch/powerpc/kernel/Makefile arch/x86/ia32/ia32entry.S arch/x86/include/asm/hardirq.h arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/cpu/common.c arch/x86/kernel/irq.c arch/x86/kernel/syscall_table_32.S arch/x86/mm/iomap_32.c include/linux/sched.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-30Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/elf.h drivers/i2c/busses/i2c-mpc.c
2009-03-24KVM: ppc: No need to include core-header for KVM in asm-offsets.c currentlyHollis Blanchard
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-11powerpc: Remove unused asm-offsets entries for cpu_specMichael Ellerman
Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-21Merge commit 'v2.6.29-rc2' into perfcounters/coreIngo Molnar
Conflicts: include/linux/syscalls.h
2009-01-13Merge commit 'kumar/kumar-next' into nextBenjamin Herrenschmidt
2009-01-11Merge branch 'master' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/perfcounters into perfcounters/core
2009-01-09powerpc: Provide a way to defer perf counter work until interrupts are enabledPaul Mackerras
Because 64-bit powerpc uses lazy (soft) interrupt disabling, it is possible for a performance monitor exception to come in when the kernel thinks interrupts are disabled (i.e. when they are soft-disabled but hard-enabled). In such a situation the performance monitor exception handler might have some processing to do (such as process wakeups) which can't be done in what is effectively an NMI handler. This provides a way to defer that work until interrupts get enabled, either in raw_local_irq_restore() or by returning from an interrupt handler to code that had interrupts enabled. We have a per-processor flag that indicates that there is work pending to do when interrupts subsequently get re-enabled. This flag is checked in the interrupt return path and in raw_local_irq_restore(), and if it is set, perf_counter_do_pending() is called to do the pending work. Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-01-07powerpc/fsl-booke: Don't hard-code size of struct tlbcamTrent Piepho
Some assembly code in head_fsl_booke.S hard-coded the size of struct tlbcam to 20 when it indexed the TLBCAM table. Anyone changing the size of struct tlbcam would not know to expect that. The kernel already has a system to get the size of C structures into assembly language files, asm-offsets, so let's use it. The definition of the struct gets moved to a header, so that asm-offsets.c can include it. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-31KVM: ppc: Implement in-kernel exit timing statisticsHollis Blanchard
Existing KVM statistics are either just counters (kvm_stat) reported for KVM generally or trace based aproaches like kvm_trace. For KVM on powerpc we had the need to track the timings of the different exit types. While this could be achieved parsing data created with a kvm_trace extension this adds too much overhead (at least on embedded PowerPC) slowing down the workloads we wanted to measure. Therefore this patch adds a in-kernel exit timing statistic to the powerpc kvm code. These statistic is available per vm&vcpu under the kvm debugfs directory. As this statistic is low, but still some overhead it can be enabled via a .config entry and should be off by default. Since this patch touched all powerpc kvm_stat code anyway this code is now merged and simplified together with the exit timing statistic code (still working with exit timing disabled in .config). Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: ppc: directly insert shadow mappings into the hardware TLBHollis Blanchard
Formerly, we used to maintain a per-vcpu shadow TLB and on every entry to the guest would load this array into the hardware TLB. This consumed 1280 bytes of memory (64 entries of 16 bytes plus a struct page pointer each), and also required some assembly to loop over the array on every entry. Instead of saving a copy in memory, we can just store shadow mappings directly into the hardware TLB, accepting that the host kernel will clobber these as part of the normal 440 TLB round robin. When we do that we need less than half the memory, and we have decreased the exit handling time for all guest exits, at the cost of increased number of TLB misses because the host overwrites some guest entries. These savings will be increased on processors with larger TLBs or which implement intelligent flush instructions like tlbivax (which will avoid the need to walk arrays in software). In addition to that and to the code simplification, we have a greater chance of leaving other host userspace mappings in the TLB, instead of forcing all subsequent tasks to re-fault all their mappings. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: ppc: create struct kvm_vcpu_44x and introduce container_of() accessorHollis Blanchard
This patch doesn't yet move all 44x-specific data into the new structure, but is the first step down that path. In the future we may also want to create a struct kvm_vcpu_booke. Based on patch from Liu Yu <yu.liu@freescale.com>. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: ppc: Rename "struct tlbe" to "struct kvmppc_44x_tlbe"Hollis Blanchard
This will ease ports to other cores. Also remove unused "struct kvm_tlb" while we're at it. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-29powerpc/44x: Support 16K/64K base page sizes on 44xIlya Yanok
This adds support for 16k and 64k page sizes on PowerPC 44x processors. The PGDIR table is much smaller than a page when using 16k or 64k pages (512 and 32 bytes respectively) so we allocate the PGDIR with kzalloc() instead of __get_free_pages(). One PTE table covers rather a large memory area when using 16k or 64k pages (32MB or 512MB respectively), so we can easily put FIXMAP and PKMAP in the area covered by one PTE table. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Vladimir Panfilov <pvr@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
