path: root/arch/powerpc/kernel/btext.c
2016-05-01powerpc/mm: Use a helper for finding pte bits mapping I/O areaAneesh Kumar K.V
Use a helper instead of open coding with constants. A later patch will drop the WIMG bits and use PowerISA 3.0 defines. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2013-08-27powerpc/btext: Fix CONFIG_PPC_EARLY_DEBUG_BOOTX on ppc32Benjamin Herrenschmidt
The "rmci" stuff only exists on 64-bit Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc/pmac: Early debug output on screen on 64-bit macsBenjamin Herrenschmidt
We have a bunch of CONFIG_PPC_EARLY_DEBUG_* options that are intended for bringup/debug only. They hard wire a machine specific udbg backend very early on (before we even probe the platform), and use whatever tricks are available on each machine/cpu to be able to get some kind of output out there early on. So far, on powermac with no serial ports, we have CONFIG_PPC_EARLY_DEBUG_BOOTX to use the low-level btext engine on the screen, but it doesn't do much, at least on 64-bit. It only really gets enabled after the platform has been probed and the MMU enabled. This adds a way to enable it much earlier. From prom_init.c (while still running with Open Firmware), we grab the screen details and set things up using the physical address of the frame buffer. Then btext itself uses the "rm_ci" feature of the 970 processor (Real Mode Cache Inhibited) to access it while in real mode. We need to do a little bit of reorg of the btext code to inline things better, in order to limit how much we touch memory while in this mode as the consequences might be ... interesting. This successfully allowed me to debug problems early on with the G5 (related to gold being broken vs. ppc64 kernels). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-10-31powerpc: various straight conversions from module.h --> export.hPaul Gortmaker
All these files were including module.h just for the basic EXPORT_SYMBOL infrastructure. We can shift them off to the export.h header which is a way smaller footprint and thus realize some compile time gains. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-08-20powerpc: Use the common ascii hex helpersHarvey Harrison
[akpm@linux-foundation.org: exclude prom_init.c] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-09[POWERPC] Remove duplicate #includeHuang Weiyi
Remove duplicate #include of <asm/prom.h> in arch/powerpc/kernel/btext.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-01-17[POWERPC] Use for_each macros in arch/powerpc/kernelCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-13[POWERPC] Fix early btext debug on PowerMacBenjamin Herrenschmidt
The early btext debug wouldn't work on PowerMac when booted from BootX due to the code looking for the wrong property name. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] Clean out a bunch of duplicate includesJesper Juhl
This removes several duplicate includes from arch/powerpc/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: arch/powerpcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Use udbg_early_init() on ppc32David Gibson
udbg_early_init() is a function used on 64 bit systems, which initializes whichever early udbg backend is configured. This function is not called on 32-bit, however if btext early debug is enabled it does have an explicit, inline, #ifdef-ed assignment performing analagous initialization. This patch makes things more uniform by folding the btext initialization as an option into udbg_early_init() and calling that from the 32-bit setup path. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix various offb issuesBenjamin Herrenschmidt
This patch fixes a few issues in offb: - A test was inverted causing the palette hack to never work (no device node was passed down to the init function) - Some cards seem to have their assigned-addresses property in a random order, thus we need to try using of_get_pci_address() first, which will fail if it's not a PCI device, and fallback to of_get_address() in that case. of_get_pci_address() properly parsees assigned-addresses to test the BAR number and thus will get it right whatever the order is. - Some cards (like GXT4500) provide a linebytes of 0xffffffff in the device-tree which does no good. This patch handles that by using the screen width when that happens. (Also fixes btext.c while at it). - Add detection of the GXT4500 in addition to the GXT2000 for the palette hacks (we use the same hack, palette is linear in register space at offset 0x6000). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-31[POWERPC] Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powerpc core changes. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-03[POWERPC] Fix various offb and BootX-related issuesBenjamin Herrenschmidt
This patch fixes various issues with offb (the default fbdev used on powerpc when no proper fbdev is supported). It was broken when using BootX under some circumstances and would fail to properly get the framebuffer base address in others. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Remove device_node addrs/n_addrBenjamin Herrenschmidt
The pre-parsed addrs/n_addrs fields in struct device_node are finally gone. Remove the dodgy heuristics that did that parsing at boot and remove the fields themselves since we now have a good replacement with the new OF parsing code. This patch also fixes a bunch of drivers to use the new code instead, so that at least pmac32, pseries, iseries and g5 defconfigs build. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Separate usage of KERNELBASE and PAGE_OFFSETMichael Ellerman
This patch separates usage of KERNELBASE and PAGE_OFFSET. I haven't looked at any of the PPC32 code, if we ever want to support Kdump on PPC we'll have to do another audit, ditto for iSeries. This patch makes PAGE_OFFSET the constant, it'll always be 0xC * 1 gazillion for 64-bit. To get a physical address from a virtual one you subtract PAGE_OFFSET, _not_ KERNELBASE. KERNELBASE is the virtual address of the start of the kernel, it's often the same as PAGE_OFFSET, but _might not be_. If you want to know something's offset from the start of the kernel you should subtract KERNELBASE. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Unify udbg (#2)Benjamin Herrenschmidt
This patch unifies udbg for both ppc32 and ppc64 when building the merged achitecture. xmon now has a single "back end". The powermac udbg stuff gets enriched with some ADB capabilities and btext output. In addition, the early_init callback is now called on ppc32 as well, approx. in the same order as ppc64 regarding device-tree manipulations. The init sequences of ppc32 and ppc64 are getting closer, I'll unify them in a later patch. For now, you can force udbg to the scc using "sccdbg" or to btext using "btextdbg" on powermacs. I'll implement a cleaner way of forcing udbg output to something else than the autodetected OF output device in a later patch. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-10powerpc: Get 64-bit configs to compile with ARCH=powerpcPaul Mackerras
This is a bunch of mostly small fixes that are needed to get ARCH=powerpc to compile for 64-bit. This adds setup_64.c from arch/ppc64/kernel/setup.c and locks.c from arch/ppc64/lib/locks.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-06powerpc: Merge in the ppc64 version of the prom code.Paul Mackerras
This brings in the ppc64 version of prom_init.c, prom.c and btext.c and makes them work for ppc32. This also brings in the new calling convention, where the first entry to the kernel (with r5 != 0) goes to the prom_init code, which then restarts from the beginning (with r5 == 0) after it has done its stuff. For now this also brings in the ppc32 version of setup.c. It also merges lmb.h. Signed-off-by: Paul Mackerras <paulus@samba.org>
