path: root/arch/powerpc/kernel/crash.c
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-01-25[POWERPC] kdump shutdown hook supportMichael Neuling
This adds hooks into the default_machine_crash_shutdown so drivers can register a function to be run in the first kernel before we hand off to the second kernel. This should only be used in exceptional circumstances, like where the device can't be reset in the second kernel alone (as is the case with eHEA). To emphasize this, the number of handles allowed to be registered is currently #def to 1. This uses the setjmp/longjmp code around the call out to the registered hooks, so any bogus exceptions we encounter will hopefully be recoverable. Tested with bogus data and instruction exceptions. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] Clean out a bunch of duplicate includesJesper Juhl
This removes several duplicate includes from arch/powerpc/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-20[CELL] saving spus information for kexec crashAndre Detsch
This patch adds support for investigating spus information after a kernel crash event, through kdump vmcore file. Implementation is based on xmon code, but the new functionality was kept independent from xmon. Signed-off-by: Lucio Jose Herculano Correia <luciojhc@br.ibm.com> Signed-off-by: Andre Detsch <adetsch@br.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-12-07[PATCH] Kexec / Kdump: Unify elf note codeMagnus Damm
The elf note saving code is currently duplicated over several architectures. This cleanup patch simply adds code to a common file and then replaces the arch-specific code with calls to the newly added code. The only drawback with this approach is that s390 doesn't fully support kexec-on-panic which for that arch leads to introduction of unused code. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-16[POWERPC] Lazy interrupt disabling for 64-bit machinesPaul Mackerras
This implements a lazy strategy for disabling interrupts. This means that local_irq_disable() et al. just clear the 'interrupts are enabled' flag in the paca. If an interrupt comes along, the interrupt entry code notices that interrupts are supposed to be disabled, and clears the EE bit in SRR1, clears the 'interrupts are hard-enabled' flag in the paca, and returns. This means that interrupts only actually get disabled in the processor when an interrupt comes along. When interrupts are enabled by local_irq_enable() et al., the code sets the interrupts-enabled flag in the paca, and then checks whether interrupts got hard-disabled. If so, it also sets the EE bit in the MSR to hard-enable the interrupts. This has the potential to improve performance, and also makes it easier to make a kernel that can boot on iSeries and on other 64-bit machines, since this lazy-disable strategy is very similar to the soft-disable strategy that iSeries already uses. This version renames paca->proc_enabled to paca->soft_enabled, and changes a couple of soft-disables in the kexec code to hard-disables, which should fix the crash that Michael Ellerman saw. This doesn't yet use a reserved CR field for the soft_enabled and hard_enabled flags. This applies on top of Stephen Rothwell's patches to make it possible to build a combined iSeries/other kernel. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] Fix interrupt clearing in kdump shutdown sequenceMohan Kumar M
Call chip->eoi(irq) to clear any pending interrupt in case of kdump shutdown sequence. chip->end(irq) does not serve this purpose. Signed-off-by: Mohan Kumar M <mohan@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-08-17[POWERPC] Make crash.c work on 32-bit and 64-bitMichael Ellerman
To compile kexec on 32-bit we need a few more bits and pieces. Rather than add empty definitions, we can make crash.c work on 32-bit, with only a couple of kludges. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (43 commits) [POWERPC] Use little-endian bit from firmware ibm,pa-features property [POWERPC] Make sure smp_processor_id works very early in boot [POWERPC] U4 DART improvements [POWERPC] todc: add support for Time-Of-Day-Clock [POWERPC] Make lparcfg.c work when both iseries and pseries are selected [POWERPC] Fix idr locking in init_new_context [POWERPC] mpc7448hpc2 (taiga) board config file [POWERPC] Add tsi108 pci and platform device data register function [POWERPC] Add general support for mpc7448hpc2 (Taiga) platform [POWERPC] Correct the MAX_CONTEXT definition powerpc: minor cleanups for mpc86xx [POWERPC] Make sure we select CONFIG_NEW_LEDS if ADB_PMU_LED is set [POWERPC] Simplify the code defining the 64-bit CPU features [POWERPC] powerpc: kconfig warning fix [POWERPC] Consolidate some of kernel/misc*.S [POWERPC] Remove unused function call_with_mmu_off [POWERPC] update asm-powerpc/time.h [POWERPC] Clean up it_lp_queue.h [POWERPC] Skip the "copy down" of the kernel if it is already at zero. [POWERPC] Add the use of the firmware soft-reset-nmi to kdump. ...
2006-06-29[PATCH] genirq: cleanup: remove irq_descp()Ingo Molnar
Cleanup: remove irq_descp() - explicit use of irq_desc[] is shorter and more readable. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[POWERPC] Add the use of the firmware soft-reset-nmi to kdump.David Wilder
With this patch, kdump uses the firmware soft-reset NMI for two purposes: 1) Initiate the kdump (take a crash dump) by issuing a soft-reset. 2) Break a CPU out of a deadlock condition that is detected during kdump processing. When a soft-reset is initiated each CPU will enter system_reset_exception() and set its corresponding bit in the global bit-array cpus_in_sr then call die(). When die() finds the CPU's bit set in cpu_in_sr crash_kexec() is called to initiate a crash dump. The first CPU to enter crash_kexec() is called the "crashing CPU". All other CPUs are "secondary CPUs". The secondary CPU's pass through to crash_kexec_secondary() and sleep. The crashing CPU waits for all CPUs to enter via soft-reset then boots the kdump kernel (see crash_soft_reset_check()) When the system crashes due to a panic or exception, crash_kexec() is called by panic() or die(). The crashing CPU sends an IPI to all other CPUs to notify them of the pending shutdown. If a CPU is in a deadlock or hung state with interrupts disabled, the IPI will not be delivered. The result being, that the kdump kernel is not booted. This problem is solved with the use of a firmware generated soft-reset. After the crashing_cpu has issued the IPI, it waits for 10 sec for all CPUs to enter crash_ipi_callback(). A CPU signifies its entry to crash_ipi_callback() by setting its corresponding bit in the cpus_in_crash bit array. After 10 sec, if one or more CPUs have not set their bit in cpus_in_crash we assume that the CPU(s) is deadlocked. The operator is then prompted to generate a soft-reset to break the deadlock. Each CPU enters the soft reset handler as described above. Two conditions must be handled at this point: 1) The system crashed because the operator generated a soft-reset. See 2) The system had crashed before the soft-reset was generated ( in the case of a Panic or oops). The first CPU to enter crash_kexec() uses the state of the kexec_lock to determine this state. If kexec_lock is already held then condition 2 is true and crash_kexec_secondary() is called, else; this CPU is flagged as the crashing CPU, the kexec_lock is acquired and crash_kexec() proceeds as described above. Each additional CPUs responding to the soft-reset will pass through crash_kexec() to kexec_secondary(). All secondary CPUs call crash_ipi_callback() readying them self's for the shutdown. When ready they clear their bit in cpus_in_sr. The crashing CPU waits in kexec_secondary() until all other CPUs have cleared their bits in cpus_in_sr. The kexec kernel boot is then started. Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: David Wilder <dwilder@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-26fix paniced->panicked typosLee Revell
In a testament to the utter simplicity and logic of the English language ;-), I found a single correct use - in kernel/panic.c - and 10-15 incorrect ones. Signed-Off-By: Lee Revell <rlrevell@joe-job.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-22[PATCH] powerpc: Disable and EOI interrupts in machine_crash_shutdown()Michael Ellerman
We've seen several bugs caused by interrupt weirdness in the kdump kernel. Panicking from an interrupt handler means we fail to EOI the interrupt, and so the second kernel never gets that interrupt ever again. We also see hangs on JS20 where we take interrupts in the second kernel early during boot. This patch fixes both those problems, and although it adds more code to the crash path I think it is the best solution. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc: Trivial fix to set the proper timeout value for kdumpHaren Myneni
The panic CPU is waiting forever due to some large timeout value if some CPU is not responding to an IPI. This patch fixes the problem - the maximum waiting period will be 10 seconds and then the kdump boot will go ahead. Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-15[PATCH] powerpc: Fix kdump copy regs and dynamic allocate per-cpu crash notesHaren Myneni
- This contains the arch specific changes for the following the kdump generic fixes which were already accepted in the upstream. . Capturing CPU registers (for the case of 'panic' and invoking the dump using 'sysrq-trigger') from a function (stack frame) which will be not be available during the kdump boot. Hence, might result in invalid stack trace. . Dynamically allocating per cpu ELF notes section instead of statically for NR_CPUS. - Fix the compiler warning in prom_init.c. Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] powerpc: fix for compile problem in kdump code when SMP disabledHaren Myneni
This patch fixes the compilation error (shown below) when CONFIG_SMP=n. arch/powerpc/kernel/crash.c: In function `crash_kexec_prepare_cpus': arch/powerpc/kernel/crash.c:236: error: implicit declaration of function `smp_release_cpus' Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Add arch dependent basic infrastructure for Kdump.Michael Ellerman
Implementing the machine_crash_shutdown which will be called by crash_kexec (called in case of a panic, sysrq etc.). Disable the interrupts, shootdown cpus using debugger IPI and collect regs for all CPUs. elfcorehdr= specifies the location of elf core header stored by the crashed kernel. This command line option will be passed by the kexec-tools to capture kernel. savemaxmem= specifies the actual memory size that the first kernel has and this value will be used for dumping in the capture kernel. This command line option will be passed by the kexec-tools to capture kernel. Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
