path: root/arch/powerpc/kernel/dma-iommu.c
2010-12-09powerpc/iommu: Use coherent_dma_mask for alloc_coherentNishanth Aravamudan
The IOMMU code has been passing the dma-mask instead of the coherent_dma_mask to the iommu allocator. Coherent allocations should be made using the coherent_dma_mask. Also update the vio code to ensure the coherent_dma_mask is set. Without this change drivers, such as ibmvscsi, fail to load with the corrected dma_iommu_alloc_coherent(). Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-10-13powerpc/dma: Fix dma_iommu_dma_supported compareNishanth Aravamudan
The table offset is in entries, each of which imply a dma address of an IOMMU page. Also, we should check the device can reach the whole IOMMU table. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-24powerpc: Change archdata dma_data to a unionBecky Bruce
Sometimes this is used to hold a simple offset, and sometimes it is used to hold a pointer. This patch changes it to a union containing void * and dma_addr_t. get/set accessors are also provided, because it was getting a bit ugly to get to the actual data. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc: use dma_map_ops structFUJITA Tomonori
This converts uses dma_map_ops struct (in include/linux/dma-mapping.h) instead of POWERPC homegrown dma_mapping_ops. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-13powerpc: Change u64/s64 to a long long integer typeIngo Molnar
Convert arch/powerpc/ over to long long based u64: -#ifdef __powerpc64__ -# include <asm-generic/int-l64.h> -#else -# include <asm-generic/int-ll64.h> -#endif +#include <asm-generic/int-ll64.h> This will avoid reoccuring spurious warnings in core kernel code that comes when people test on their own hardware. (i.e. x86 in ~98% of the cases) This is what x86 uses and it generally helps keep 64-bit code 32-bit clean too. [Adjusted to not impact user mode (from paulus) - sfr] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-31powerpc: Update remaining dma_mapping_ops to use map/unmap_pageMark Nelson
After the merge of the 32 and 64bit DMA code, dma_direct_ops lost their map/unmap_single() functions but gained map/unmap_page(). This caused a problem for Cell because Cell's dma_iommu_fixed_ops called the dma_direct_ops if the fixed linear mapping was to be used or the iommu ops if the dynamic window was to be used. So in order to fix this problem we need to update the 64bit DMA code to use map/unmap_page. First, we update the generic IOMMU code so that iommu_map_single() becomes iommu_map_page() and iommu_unmap_single() becomes iommu_unmap_page(). Then we propagate these changes up through all the callers of these two functions and in the process update all the dma_mapping_ops so that they have map/unmap_page rahter than map/unmap_single. We can do this because on 64bit there is no HIGHMEM memory so map/unmap_page ends up performing exactly the same function as map/unmap_single, just taking different arguments. This has no affect on drivers because the dma_map_single_attrs() just ends up calling the map_page() function of the appropriate dma_mapping_ops and similarly the dma_unmap_single_attrs() calls unmap_page(). This fixes an oops on Cell blades, which oops on boot without this because they call dma_direct_ops.map_single, which is NULL. Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-24powerpc: Drop archdata numa_nodeBecky Bruce
Use the struct device's numa_node instead; use accessor functions to get/set numa_node. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-24powerpc: Move iommu dma ops from dma.c to dma-iommu.cBecky Bruce
32-bit platforms are about to start using dma.c; move the iommu dma ops into their own file to make this a bit cleaner. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
