dma_mask
This patch adds the ability to the DMA direct ops to fallback to the IOMMU
ops for coherent alloc/free if the coherent mask of the device isn't
suitable for accessing the direct DMA space and the device also happens
to have an active IOMMU table.
Move the installation of DMA operations out of swiotlb's subsys
initcall, and into the generic PCI controller operations struct.
These ops are installed conditionally, based on the ppc_swiotlb_enable
global. The global can be set in two places:
- swiotlb_detect_4g, which is always called at the arch initcall level
- setup_pci_atmu, which is called as part of the fsl_add_bridge and
fsl_pci_syscore_do_resume.
fsl_pci_syscore_do_resume is called late enough that any changes as a
result of that call will have no effect.
As such, if we test the global and set the operations as part of
fsl_add_bridge, after the call to setup_pci_atmu, we can be confident
that it will cover all the PCI implementations affected by the changes
to dma-swiotlb.c.
Signed-off-by: Daniel Axtens <dja@axtens.net>
Acked-by: Scott Wood <scottwood@freescale.com>
A DMA zone is still needed with swiotlb, for coherent allocations.
This doesn't affect platforms that don't use swiotlb or that don't call
swiotlb_detect_4g().
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Remove the dependency on PCI initialization for SWIOTLB initialization.
So that PCI can be initialized at proper time.
SWIOTLB is partly determined by PCI inbound/outbound map which is assigned
in PCI initialization. But swiotlb_init() should be done at the stage of
mem_init() which is much earlier than PCI initialization. So we reserve the
memory for SWIOTLB first and free it if not necessary.
All boards are converted to fit this change.
Signed-off-by: Jia Hongtao <B38951@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Acked-by: Tony Breeds <tony@bakeyournoodle.com>
It's empty now, apart from other includes.
Fixup a few files that were getting things via this header.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Commit 9adc5374 ('common: dma-mapping: introduce mmap method') added a
generic method for implementing mmap user call to dma_map_ops structure.
This patch converts ARM and PowerPC architectures (the only providers of
dma_mmap_coherent/dma_mmap_writecombine calls) to use this generic
dma_map_ops based call and adds a generic cross architecture
definition for dma_mmap_attrs, dma_mmap_coherent, dma_mmap_writecombine
functions.
The generic mmap virt_to_page-based fallback implementation is provided for
architectures which don't provide their own implementation for mmap method.
Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com>
Adapt core PowerPC architecture code for dma_map_ops changes: replace
alloc/free_coherent with generic alloc/free methods.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
[added missing changes to arch/powerpc/kernel/vio.c]
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Now that the generic code has dma_map_ops set, instead of having a
messy ifdef & if block in the base dma_get_required_mask hook push
the computation into the dma ops.
If the ops fails to set the get_required_mask hook default to the
width of dma_addr_t.
This also corrects ibmbus ibmebus_dma_supported to require a 64
bit mask. I doubt anything is checking or setting the dma mask on
that bus.
Signed-off-by: Milton Miller <miltonm@bga.com>
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: benh@kernel.crashing.org
of_platform_bus was being used in the same manner as the platform_bus.
The only difference being that of_platform_bus devices are generated
from data in the device tree, and platform_bus devices are usually
statically allocated in platform code. Having them separate causes
the problem of device drivers having to be registered twice if it
was possible for the same device to appear on either bus.
This patch removes of_platform_bus_type and registers all of_platform
bus devices and drivers on the platform bus instead. A previous patch
made the of_device structure an alias for the platform_device structure,
and a shim is used to adapt of_platform_drivers to the platform bus.
After all of of_platform_bus drivers are converted to be normal platform
drivers, the shim code can be removed.
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
sync_single_range_for_cpu and sync_single_range_for_device hooks in
swiotlb_dma_ops are unnecessary because sync_single_for_cpu and
sync_single_for_device are used there.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Becky Bruce <beckyb@kernel.crashing.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
When we compare the devices DMA mask to the amount of memory we need to
make sure we treat the DMA mask as an address boundary. For example if
the DMA_MASK(32) and we have 4G of memory we'd incorrectly set the dma
ops to swiotlb. We need to add one to the dma mask when we convert it.
We can kill unused swiotlb variable.
This converts uses dma_map_ops struct (in include/linux/dma-mapping.h)
instead of POWERPC homegrown dma_mapping_ops.
Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
Now swiotlb_pci_dma_ops is identical to swiotlb_dma_ops; we can use
swiotlb_dma_ops with any devices. This removes swiotlb_pci_dma_ops.
This patch adds max_direct_dma_addr to struct dev_archdata to remove
addr_needs_map in struct dma_mapping_ops. It also converts
dma_capable() to use max_direct_dma_addr.
max_direct_dma_addr is initialized in pci_dma_dev_setup_swiotlb(),
called via ppc_md.pci_dma_dev_setup hook.
For further information:
http://marc.info/?t=124719060200001&r=1&w=2
phys_to_dma() and dma_to_phys() are used instead of
swiotlb_phys_to_bus() and swiotlb_bus_to_phys().
swiotlb doesn't use swiotlb_arch_address_needs_mapping(); it uses
dma_capalbe(). We can remove unnecessary
swiotlb_arch_address_needs_mapping().
We can remove swiotlb_addr_needs_map() and is_buffer_dma_capable() in
swiotlb_pci_addr_needs_map() too; dma_capable() handles the features
that both provide.
swiotlb_bus_to_virt is unncessary; we can use swiotlb_bus_to_phys and
phys_to_virt instead.
This patch includes the basic infrastructure to use swiotlb
bounce buffering on 32-bit powerpc. It is not yet enabled on
any platforms. Probably the most interesting bit is the
addition of addr_needs_map to dma_ops - we need this as
a dma_op because the decision of whether or not an addr
can be mapped by a device is device-specific.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
