path: root/arch/powerpc/kernel/dma.c
2015-10-28powerpc/dma: dma_set_coherent_mask() should not be GPL onlyBenjamin Herrenschmidt
When turning this from inline to an exported function I was a bit over-eager and made it GPL only. This prevents the use of pretty much all non-GPL PCI driver which is a bit over the top. Let's bring it back in line with other architecture. Fixes: 817820b0226a ("powerpc/iommu: Support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask") Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-18powerpc/powernv: move dma_get_required_mask from pnv_phb to pci_controller_opsAndrew Donnellan
Simplify the dma_get_required_mask call chain by moving it from pnv_phb to pci_controller_ops, similar to commit 763d2d8df1ee ("powerpc/powernv: Move dma_set_mask from pnv_phb to pci_controller_ops"). Previous call chain: 0) call dma_get_required_mask() (kernel/dma.c) 1) call ppc_md.dma_get_required_mask, if it exists. On powernv, that points to pnv_dma_get_required_mask() (platforms/powernv/setup.c) 2) device is PCI, therefore call pnv_pci_dma_get_required_mask() (platforms/powernv/pci.c) 3) call phb->dma_get_required_mask if it exists 4) it only exists in the ioda case, where it points to pnv_pci_ioda_dma_get_required_mask() (platforms/powernv/pci-ioda.c) New call chain: 0) call dma_get_required_mask() (kernel/dma.c) 1) device is PCI, therefore call pci_controller_ops.dma_get_required_mask if it exists 2) in the ioda case, that points to pnv_pci_ioda_dma_get_required_mask() (platforms/powernv/pci-ioda.c) In the p5ioc2 case, the call chain remains the same - dma_get_required_mask() does not find either a ppc_md call or pci_controller_ops call, so it calls __dma_get_required_mask(). Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Reviewed-by: Daniel Axtens <dja@axtens.net> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-07-13powerpc/iommu: Support "hybrid" iommu/direct DMA ops for coherent_mask < ↵Benjamin Herrenschmidt
dma_mask This patch adds the ability to the DMA direct ops to fallback to the IOMMU ops for coherent alloc/free if the coherent mask of the device isn't suitable for accessing the direct DMA space and the device also happens to have an active IOMMU table. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-02powerpc/pci: add dma_set_mask to pci_controller_opsDaniel Axtens
Some systems only need to deal with DMA masks for PCI devices. For these systems, we can avoid the need for a platform hook and instead use a pci controller based hook. Signed-off-by: Daniel Axtens <dja@axtens.net> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-17powerpc: Only do dynamic DMA zone limits on platforms that need itMichael Ellerman
Scott's patch 1c98025c6c95 "Dynamic DMA zone limits" changed dma_direct_alloc_coherent() to start using dev->coherent_dma_mask. That seems fair enough, but it exposes the fact that some of the drivers we care about on IBM platforms aren't setting the coherent mask. The proper fix is to have drivers set the coherent mask and also have the platform code honor it. For now, just restrict the dynamic DMA zone limits to the platforms that need it. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Acked-by: Scott Wood <scottwood@freescale.com>
2014-10-04Merge branch 'next' of ↵Michael Ellerman
git://git.kernel.org/pub/scm/linux/kernel/git/scottwood/linux.git Freescale updates from Scott (27 commits): "Highlights include DMA32 zone support (SATA, USB, etc now works on 64-bit FSL kernels), MSI changes, 8xx optimizations and cleanup, t104x board support, and PrPMC PCI enumeration."
2014-09-30powerpc/powernv: Override dma_get_required_mask()Gavin Shan
The dma_get_required_mask() function is used by some drivers to query the platform about what DMA mask is needed to cover all of memory. This is a bit of a strange semantic when we have to choose between IOMMU translation or bypass, but essentially what it means is "what DMA mask will give best performances". Currently, our IOMMU backend always returns a 32-bit mask here, we don't do anything special to it when we have bypass available. This causes some drivers to choose a 32-bit mask, thus losing the ability to use the bypass window, thinking this is more efficient. The problem was reported from the driver of following device: 0004:03:00.0 0107: 1000:0087 (rev 05) 0004:03:00.0 Serial Attached SCSI controller: LSI Logic / Symbios \ Logic SAS2308 PCI-Express Fusion-MPT SAS-2 (rev 05) This patch adds an override of that function in order to, instead, return a 64-bit mask whenever a bypass window is available in order for drivers to prefer this configuration. Reported-by: Murali N. Iyer <mniyer@us.ibm.com> Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-09-03powerpc/64: Honor swiotlb limit in coherent allocationsScott Wood
FSL PCI cannot directly address the whole lower 4 GiB due to conflicts with PCICSRBAR and outbound windows, and thus max_direct_dma_addr is less than 4GiB. Honor that limit in dma_direct_alloc_coherent(). Note that setting the DMA mask to 31 bits is not an option, since many PCI drivers would fail if we reject 32-bit DMA in dma_supported(), and we have no control over the setting of coherent_dma_mask if dma_supported() returns true. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
2014-09-03powerpc: Dynamic DMA zone limitsScott Wood
Platform code can call limit_zone_pfn() to set appropriate limits for ZONE_DMA and ZONE_DMA32, and dma_direct_alloc_coherent() will select a suitable zone based on a device's mask and the pfn limits that platform code has configured. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
2014-02-11powerpc/powernv: Add iommu DMA bypass support for IODA2Benjamin Herrenschmidt
This patch adds the support for to create a direct iommu "bypass" window on IODA2 bridges (such as Power8) allowing to bypass iommu page translation completely for 64-bit DMA capable devices, thus significantly improving DMA performances. Additionally, this adds a hook to the struct iommu_table so that the IOMMU API / VFIO can disable the bypass when external ownership is requested, since in that case, the device will be used by an environment such as userspace or a KVM guest which must not be allowed to bypass translations. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc/kernel: Remove uses of abs_to_virt() and virt_to_abs()Michael Ellerman
These days they are just __va() and __pa() respectively. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-30Merge branch 'for-linus-for-3.6-rc1' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA-mapping updates from Marek Szyprowski: "Those patches are continuation of my earlier work. They contains extensions to DMA-mapping framework to remove limitation of the current ARM implementation (like limited total size of DMA coherent/write combine buffers), improve performance of buffer sharing between devices (attributes to skip cpu cache operations or creation of additional kernel mapping for some specific use cases) as well as some unification of the common code for dma_mmap_attrs() and dma_mmap_coherent() functions. All extensions have been implemented and tested for ARM architecture." * 'for-linus-for-3.6-rc1' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: dma-mapping: add support for DMA_ATTR_SKIP_CPU_SYNC attribute common: DMA-mapping: add DMA_ATTR_SKIP_CPU_SYNC attribute ARM: dma-mapping: add support for dma_get_sgtable() common: dma-mapping: introduce dma_get_sgtable() function ARM: dma-mapping: add support for DMA_ATTR_NO_KERNEL_MAPPING attribute common: DMA-mapping: add DMA_ATTR_NO_KERNEL_MAPPING attribute common: dma-mapping: add support for generic dma_mmap_* calls ARM: dma-mapping: fix error path for memory allocation failure ARM: dma-mapping: add more sanity checks in arm_dma_mmap() ARM: dma-mapping: remove custom consistent dma region mm: vmalloc: use const void * for caller argument scatterlist: add sg_alloc_table_from_pages function
2012-07-30common: dma-mapping: add support for generic dma_mmap_* callsMarek Szyprowski
Commit 9adc5374 ('common: dma-mapping: introduce mmap method') added a generic method for implementing mmap user call to dma_map_ops structure. This patch converts ARM and PowerPC architectures (the only providers of dma_mmap_coherent/dma_mmap_writecombine calls) to use this generic dma_map_ops based call and adds a generic cross architecture definition for dma_mmap_attrs, dma_mmap_coherent, dma_mmap_writecombine functions. The generic mmap virt_to_page-based fallback implementation is provided for architectures which don't provide their own implementation for mmap method. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-07-10powerpc: Call dma_debug_add_bus for PCI and VIO busesAnton Blanchard
The DMA API debug code has hooks to verify all DMA entries have been freed at time of hot unplug. We need to call dma_debug_add_bus for this to work. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-28PowerPC: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core PowerPC architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> [added missing changes to arch/powerpc/kernel/vio.c] Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31powerpc: add export.h to files making use of EXPORT_SYMBOLPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-20powerpc: Tidy up dma_map_ops after adding new hookMilton Miller
The new get_required_mask hook name is longer than many of but not all of the prior ops. Tidy the struct initializers to align the equal signs using the local whitespace. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-kernel@vger.kernel.org Cc: benh@kernel.crashing.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-09-20powerpc: Use the newly added get_required_mask dma_map_ops hookMilton Miller
Now that the generic code has dma_map_ops set, instead of having a messy ifdef & if block in the base dma_get_required_mask hook push the computation into the dma ops. If the ops fails to set the get_required_mask hook default to the width of dma_addr_t. This also corrects ibmbus ibmebus_dma_supported to require a 64 bit mask. I doubt anything is checking or setting the dma mask on that bus. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-kernel@vger.kernel.org Cc: benh@kernel.crashing.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-09-01powerpc: Override dma_get_required_mask by platform hook and opsMilton Miller
The hook dma_get_required_mask is supposed to return the mask required by the platform to operate efficently. The generic version of dma_get_required_mask in driver/base/platform.c returns a mask based only on max_pfn. However, this is likely too big for iommu systems and could be too small for platforms that require a dma offset or have a secondary window at a high offset. Override the default, provide a hook in ppc_md used by pseries lpar and cell, and provide the default answer based on memblock_end_of_DRAM(), with hooks for get_dma_offset, and provide an implementation for iommu that looks at the defined table size. Coverting from the end address to the required bit mask is based on the generic implementation. The need for this was discovered when the qla2xxx driver switched to 64 bit dma then reverted to 32 bit when dma_get_required_mask said 32 bits was sufficient. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-kernel@vger.kernel.org Cc: benh@kernel.crashing.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-08powerpc: Dont require a dma_ops struct to set dma maskKumar Gala
The only reason to require a dma_ops struct is to see if it has implemented set_dma_mask. If not we can fall back to setting the mask directly. This resolves an issue with how to sequence the setting of a DMA mask for platform devices. Before we had an issue in that we have no way of setting the DMA mask before the various low level bus notifiers get called that might check it (swiotlb). So now we can do: pdev = platform_device_alloc("foobar", 0); dma_set_mask(&pdev->dev, DMA_BIT_MASK(37)); platform_device_add(pdev); And expect the right thing to happen with the bus notifiers get called via platform_device_add. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-30powerpc: Implement dma_mmap_coherent()Benjamin Herrenschmidt
This is used by Alsa to mmap buffers allocated with dma_alloc_coherent() into userspace. We need a special variant to handle machines with non-coherent DMAs as those buffers have "special" virt addresses and require non-cachable mappings Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-10-13powerpc/dma: Fix check for direct DMA supportNishanth Aravamudan
The current check is wrong because it does not take the DMA offset intot account, and in the case of a driver which doesn't actually support 64bits would falsely report that device as working. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-09-02powerpc/dma: Add optional platform override of dma_set_mask()Benjamin Herrenschmidt
Some platforms may want to override dma_set_mask() to take into account some specific "features" such as the availability of a direct-map window in addition to an iommu. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-27powerpc: remove unnecessary sync_single_range_* in swiotlb_dma_opsFUJITA Tomonori
sync_single_range_for_cpu and sync_single_range_for_device hooks in swiotlb_dma_ops are unnecessary because sync_single_for_cpu and sync_single_for_device are used there. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Becky Bruce <beckyb@kernel.crashing.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-24powerpc: Rename get_dma_direct_offset get_dma_offsetBecky Bruce
The former is no longer really accurate with the swiotlb case now a possibility. I also move it into dma-mapping.h - it no longer needs to be in dma.c, and there are about to be some more accessors that should all end up in the same place. A comment is added to indicate that this function is not used in configs where there is no simple dma offset, such as the iommu case. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc: Add CONFIG_DMA_API_DEBUG supportFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc: use dma_map_ops structFUJITA Tomonori
This converts uses dma_map_ops struct (in include/linux/dma-mapping.h) instead of POWERPC homegrown dma_mapping_ops. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-10powerpc/dma: pci_set_dma_mask() shouldn't fail if mask fits in RAMBenjamin Herrenschmidt
On an iMac G5, the b43 driver is failing to initialise because trying to set the dma mask to 30-bit fails. Even though there's only 512MiB of RAM in the machine anyway: https://bugzilla.redhat.com/show_bug.cgi?id=514787 We should probably let it succeed if the available RAM in the system doesn't exceed the requested limit. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-09powerpc: Add support for swiotlb on 32-bitBecky Bruce
This patch includes the basic infrastructure to use swiotlb bounce buffering on 32-bit powerpc. It is not yet enabled on any platforms. Probably the most interesting bit is the addition of addr_needs_map to dma_ops - we need this as a dma_op because the decision of whether or not an addr can be mapped by a device is device-specific. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-27powerpc: Fix up dma_alloc_coherent() on platforms without cache coherency.Benjamin Herrenschmidt
The implementation we just revived has issues, such as using a Kconfig-defined virtual address area in kernel space that nothing actually carves out (and thus will overlap whatever is there), or having some dependencies on being self contained in a single PTE page which adds unnecessary constraints on the kernel virtual address space. This fixes it by using more classic PTE accessors and automatically locating the area for consistent memory, carving an appropriate hole in the kernel virtual address space, leaving only the size of that area as a Kconfig option. It also brings some dma-mask related fixes from the ARM implementation which was almost identical initially but grew its own fixes. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-03powerpc: Add sync_*_for_* to dma_opsBecky Bruce
We need to swap these out once we start using swiotlb, so add them to dma_ops. Create CONFIG_PPC_NEED_DMA_SYNC_OPS Kconfig option; this is currently enabled automatically if we're CONFIG_NOT_COHERENT_CACHE. In the future, this will also be enabled for builds that need swiotlb. If PPC_NEED_DMA_SYNC_OPS is not defined, the dma_sync_*_for_* ops compile to nothing. Otherwise, they access the dma_ops pointers for the sync ops. This patch also changes dma_sync_single_range_* to actually sync the range - previously it was using a generous dma_sync_single. dma_sync_single_* is now implemented as a dma_sync_single_range with an offset of 0. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-03powerpc: Fix dma_map_sg() cache flushing on non coherent platformsBenjamin Herrenschmidt
On PowerPC 4xx or other non cache-coherent platforms, we lost the appropriate cache flushing in dma_map_sg() when merging the 32 and 64-bit DMA code (commit 4fc665b88a79a45bae8bbf3a05563c27c7337c3d, "powerpc: Merge 32 and 64-bit dma code"). This restores it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-14powerpc: Fix DMA offset for non-coherent DMABenjamin Herrenschmidt
After Becky's work we can almost have different DMA offsets between on-chip devices and PCI. Almost because there's a problem with the non-coherent DMA code that basically ignores the programmed offset to use the global one for everything. This fixes it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-09-24powerpc: Merge 32 and 64-bit dma codeBecky Bruce
We essentially adopt the 64-bit dma code, with some changes to support 32-bit systems, including HIGHMEM. dma functions on 32-bit are now invoked via accessor functions which call the correct op for a device based on archdata dma_ops. If there is no archdata dma_ops, this defaults to dma_direct_ops. In addition, the dma_map/unmap_page functions are added to dma_ops because we can't just fall back on map/unmap_single when HIGHMEM is enabled. In the case of dma_direct_*, we stop using map/unmap_single and just use the page version - this saves a lot of ugly ifdeffing. We leave map/unmap_single in the dma_ops definition, though, because they are needed by the iommu code, which does not implement map/unmap_page. Ideally, going forward, we will completely eliminate map/unmap_single and just have map/unmap_page, if it's workable for 64-bit. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-24powerpc: Drop archdata numa_nodeBecky Bruce
Use the struct device's numa_node instead; use accessor functions to get/set numa_node. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-24powerpc: Move iommu dma ops from dma.c to dma-iommu.cBecky Bruce
32-bit platforms are about to start using dma.c; move the iommu dma ops into their own file to make this a bit cleaner. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-24powerpc: Rename dma_64.c to dma.cBecky Bruce
This is in preparation for the merge of the 32 and 64-bit dma code in arch/powerpc. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
