When the PE's config space is marked as blocked, PCI config read
requests always return 0xFF's. It's pointless to collect logs in
this case.
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
The flag EEH_PE_RESET indicates blocking config space of the PE
during reset time. We potentially need block PE's config space
other than reset time. So it's reasonable to replace it with
EEH_PE_CFG_BLOCKED to indicate its usage.
There are no substantial code or logic changes in this patch.
The PEs can be organized as nested. Current implementation doesn't
dump PCI config space for subordinate devices of child PEs. However,
the frozen PE could be caused by those subordinate devices of its
child PEs.
The patch dumps PCI config space for all subordinate devices of the
problematic PE.
When enabling EEH functionality on passed through devices (PE)
with VFIO, the devices in the PE would be removed permanently
from guest side. In that case, the PE remains frozen state.
When returning PE to host, or restarting the guest again, we
had mechanism unfreezing the PE by clearing PESTA/B frozen
bits. However, that's not enough for some adapters, which are
indicated as following "lspci" shows. Those adapters require
hot reset on the parent bus to bring their firmware back to
workable state. Otherwise, those adaptrs won't be operative
and the host (for returning case) or the guest will fail to
load the drivers for those adapters without exception.
0000:01:00.0 Ethernet controller: Emulex Corporation OneConnect \
10Gb NIC (be3) (rev 02)
0000:01:00.0 0200: 19a2:0710 (rev 02)
0001:03:00.0 Ethernet controller: Emulex Corporation OneConnect \
NIC (Lancer) (rev 10)
0001:03:00.0 0200: 10df:e220 (rev 10)
The patch adds mechanism to emulate EEH recovery (for hot reset
on parent PCI bus) on 3 gates to fix the issue: open/release one
adapter of the PE, enable EEH functionality on one adapter of the
PE.
Reported-by: Murilo Fossa Vicentini <muvic@br.ibm.com>
PE would be owned by userland, which probably request PE reset
done in host side. During the reset, we should drop the PCI
config accesses to the PE with help of flag EEH_PE_RESET.
Function pcibios_set_pcie_reset_state() can be used to do PCI
reset. PCI config access during the reset usually causes EEH
errors unexpectedly. In order to avoid the EEH error, the patch
blocks PCI config access during reset with the help of flag
EEH_PE_RESET, which is similar to what we did in EEH PE reset
path.
The patch uses eeh_unfreeze_pe() to replace the logic clearing
frozen IO and DMA, in order to simplify the code.
When passing through PE to guest, that's possibly in frozen
state. The driver for the pass-through devices on guest side
can't be loaded successfully as reported. We already had one
gate in eeh_dev_open() to clear PE frozen state accordingly,
but that's not enough because the function is only called at
QEMU startup for once.
The patch adds another gate in eeh_pe_set_option() so that the
PE frozen state can be cleared at QEMU restart time.
The function eeh_pci_enable() is called to apply various requests
to one particular PE: Enabling EEH, Disabling EEH, Enabling IO,
Enabling DMA, Freezing PE. When enabling IO or DMA on one specific
PE, we need check that IO or DMA isn't enabled previously. But
the condition used to do the check isn't completely correct because
one PE would be in DMA frozen state with workable IO path, or vice
versa.
The patch fixes the improper condition.
When passing through device, its PE might have been put into frozen
state. One obvious example would be: the passed PE is forced to be
offline because of hitting maximal allowed EEH errors in userland.
In that case, the frozen state won't be cleared and then the PE is
returned back to host, which might not have chance detecting and
recovering from it.
The patch adds more check when passing through device and clear the
PE frozen state if necessary.
The PCI devices that have been passed through are enabled before
reset, we need restore to the enabled state after reset. Otherwise,
MMIO access might be issued to disabled devices after reset and
causes exceptional recursive EEH error.
The patch adds one more option (EEH_OPT_FREEZE_PE) to set_option()
method to proactively freeze PE, which will be issued before resetting
pass-throughed PE to drop MMIO access during reset because it's
always contributing to recursive EEH error.
eeh_check_failure() is used to check frozen state of the PE which
owns the indicated I/O address. The argument "val" of the function
isn't used. The patch drops it and return the frozen state of the
PE as expected.
Cc: Vishal Mansur <vmansur@linux.vnet.ibm.com>
When doing vfio passthrough a VF, the kernel will crash with following
message:
[ 442.656459] Unable to handle kernel paging request for data at address 0x00000060
[ 442.656593] Faulting instruction address: 0xc000000000038b88
[ 442.656706] Oops: Kernel access of bad area, sig: 11 [#1]
[ 442.656798] SMP NR_CPUS=1024 NUMA PowerNV
[ 442.656890] Modules linked in: vfio_pci mlx4_core nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6t_REJECT xt_conntrack bnep bluetooth rfkill ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw tg3 nfsd be2net nfs_acl ses lockd ptp enclosure pps_core kvm_hv kvm_pr shpchp binfmt_misc kvm sunrpc uinput lpfc scsi_transport_fc ipr scsi_tgt [last unloaded: mlx4_core]
[ 442.658152] CPU: 40 PID: 14948 Comm: qemu-system-ppc Not tainted 3.10.42yw-pkvm+ #37
[ 442.658219] task: c000000f7e2a9a00 ti: c000000f6dc3c000 task.ti: c000000f6dc3c000
[ 442.658287] NIP: c000000000038b88 LR: c0000000004435a8 CTR: c000000000455bc0
[ 442.658352] REGS: c000000f6dc3f580 TRAP: 0300 Not tainted (3.10.42yw-pkvm+)
[ 442.658419] MSR: 9000000000009032 <SF,HV,EE,ME,IR,DR,RI> CR: 28004882 XER: 20000000
[ 442.658577] CFAR: c00000000000908c DAR: 0000000000000060 DSISR: 40000000 SOFTE: 1
GPR00: c0000000004435a8 c000000f6dc3f800 c0000000012b1c10 c00000000da24000
GPR04: 0000000000000003 0000000000001004 00000000000015b3 000000000000ffff
GPR08: c00000000127f5d8 0000000000000000 000000000000ffff 0000000000000000
GPR12: c000000000068078 c00000000fdd6800 000001003c320c80 000001003c3607f0
GPR16: 0000000000000001 00000000105480c8 000000001055aaa8 000001003c31ab18
GPR20: 000001003c10fb40 000001003c360ae8 000000001063bcf0 000000001063bdb0
GPR24: 000001003c15ed70 0000000010548f40 c000001fe5514c88 c000001fe5514cb0
GPR28: c00000000da24000 0000000000000000 c00000000da24000 0000000000000003
[ 442.659471] NIP [c000000000038b88] .pcibios_set_pcie_reset_state+0x28/0x130
[ 442.659530] LR [c0000000004435a8] .pci_set_pcie_reset_state+0x28/0x40
[ 442.659585] Call Trace:
[ 442.659610] [c000000f6dc3f800] [00000000000719e0] 0x719e0 (unreliable)
[ 442.659677] [c000000f6dc3f880] [c0000000004435a8] .pci_set_pcie_reset_state+0x28/0x40
[ 442.659757] [c000000f6dc3f900] [c000000000455bf8] .reset_fundamental+0x38/0x80
[ 442.659835] [c000000f6dc3f980] [c0000000004562a8] .pci_dev_specific_reset+0xa8/0xf0
[ 442.659913] [c000000f6dc3fa00] [c0000000004448c4] .__pci_dev_reset+0x44/0x430
[ 442.659980] [c000000f6dc3fab0] [c000000000444d5c] .pci_reset_function+0x7c/0xc0
[ 442.660059] [c000000f6dc3fb30] [d00000001c141ab8] .vfio_pci_open+0xe8/0x2b0 [vfio_pci]
[ 442.660139] [c000000f6dc3fbd0] [c000000000586c30] .vfio_group_fops_unl_ioctl+0x3a0/0x630
[ 442.660219] [c000000f6dc3fc90] [c000000000255fbc] .do_vfs_ioctl+0x4ec/0x7c0
[ 442.660286] [c000000f6dc3fd80] [c000000000256364] .SyS_ioctl+0xd4/0xf0
[ 442.660354] [c000000f6dc3fe30] [c000000000009e54] syscall_exit+0x0/0x98
[ 442.660420] Instruction dump:
[ 442.660454] 4bfffce9 4bfffee4 7c0802a6 fbc1fff0 fbe1fff8 f8010010 f821ff81 7c7e1b78
[ 442.660566] 7c9f2378 60000000 60000000 e93e02c8 <e8690060> 2fa30000 41de00c4 2b9f0002
[ 442.660679] ---[ end trace a64ac9546bcf0328 ]---
[ 442.660724]
The reason is current VF is not EEH enabled.
This patch introduces a macro to convert eeh_dev to eeh_pe. By doing so, it
will prevent converting with NULL pointer.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
CC: Michael Ellerman <mpe@ellerman.id.au>
V3 -> V4:
1. move the macro definition from include/linux/pci.h to
arch/powerpc/include/asm/eeh.h
V2 -> V3:
1. rebased on 3.17-rc4
2. introduce a macro
3. use this macro in several other places
V1 -> V2:
1. code style and patch subject adjustment
The function is used by VFIO driver, which might be built as a
dynamic module. So it should be exported.
Some new functions are exposed for use by the IOMMU code but
won't build when CONFIG_IOMMU_API isn't set, so shield them
appropriately.
pr_warn() is equal to pr_warning(), but the former is a bit more
formal according to commit fc62f2f ("kernel.h: add pr_warn for
symmetry to dev_warn, netdev_warn").
The patch replaces pr_warning() with pr_warn().
The patch prints 4 PCIE or AER config registers each line, which
is part of the EEH log so that it looks a bit more compact.
Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
According to the experiment I did, PCI config access is blocked
on P7IOC frozen PE by hardware, but PHB3 doesn't do that. That
means we always get 0xFF's while dumping PCI config space of the
frozen PE on P7IOC. We don't have the problem on PHB3. So we have
to enable I/O prioir to collecting error log. Otherwise, meaningless
0xFF's are always returned.
The patch fixes it by EEH flag (EEH_ENABLE_IO_FOR_LOG), which is
selectively set to indicate the case for: P7IOC on PowerNV platform,
pSeries platform.
There are multiple global EEH flags. Almost each flag has its own
accessor, which doesn't make sense. The patch refactors EEH flag
accessors so that they look unified:
eeh_add_flag(): Add EEH flag
eeh_clear_flag(): Clear EEH flag
eeh_has_flag(): Check if one specific flag has been set
eeh_enabled(): Check if EEH functionality has been enabled
Function eeh_iommu_group_to_pe() iterates each PCI device to check
the binding IOMMU group with get_iommu_table_base(), which possibly
fetches pdev->dev.archdata.dma_data.dma_offset. It's (0x1 << 59)
for "bypass" cases.
The patch fixes the issue by iterating devices hooked to the IOMMU
group and fetch IOMMU table there.
The patch exports functions to be used by new VFIO ioctl command,
which will be introduced in subsequent patch, to support EEH
functinality for VFIO PCI devices.
Acked-by: Alexander Graf <agraf@suse.de>
We must not handle EEH error on devices which are passed to somebody
else. Instead, we expect that the frozen device owner detects an EEH
error and recovers from it.
This avoids EEH error handling on passed through devices so the device
owner gets a chance to handle them.
As Ben suggested, it's meaningful to dump PE's location code
for site engineers when hitting EEH errors. The patch introduces
function eeh_pe_loc_get() to retireve the location code from
dev-tree so that we can output it when hitting EEH errors.
If primary PE bus is root bus, the PHB's dev-node would be tried
prior to root port's dev-node. Otherwise, the upstream bridge's
dev-node of the primary PE bus will be check for the location code
directly.
When we have the corner case of frozen parent and child PE at the
same time, we have to handle the frozen parent PE prior to the
child. Without clearning the frozen state on parent PE, the child
PE can't be recovered successfully.
The patch searches the EEH PE hierarchy tree and returns the toppest
frozen PE to be handled. It ensures the frozen parent PE will be
handled prior to child PE.
Commit 7f52a526f ("powerpc/eeh: Allow to disable EEH") caused
following build error with "celleb_defconfig" as being catched
by Mikey on linux-next.
arch/powerpc/kernel/eeh.c: In function 'eeh_init_proc':
arch/powerpc/kernel/eeh.c:1173:37: error: 'powerpc_debugfs_root' \
undeclared (first use in this function)
arch/powerpc/kernel/eeh.c:1173:37: note: each undeclared identifier \
is reported only once for each function it appears in
Reported-by: Michael Neuling <mikey@neuling.org>
Basically, we have 3 types of resets to fulfil PE reset: fundamental,
hot and PHB reset. For the later 2 cases, we need PCI bus reset hold
and settlement delay as specified by PCI spec. PowerNV and pSeries
platforms are running on top of different firmware and some of the
delays have been covered by underly firmware (PowerNV).
The patch makes the delays unified to be done in backend, instead of
EEH core.
The patch introduces bootarg "eeh=off" to disable EEH functinality.
Also, it creates /sys/kerenl/debug/powerpc/eeh_enable to disable
or enable EEH functionality. By default, we have the functionality
enabled.
For PowerNV platform, we will restore to have the conventional
mechanism of clearing frozen PE during PCI config access if we're
going to disable EEH functionality. Conversely, we will rely on
EEH for error recovery.
The patch also fixes the issue that we missed to cover the case
of disabled EEH functionality in function ioda_eeh_event(). Those
events driven by interrupt should be cleared to avoid endless
reporting.
There're 2 EEH subsystem variables: eeh_subsystem_enabled and
eeh_probe_mode. We needn't maintain 2 variables and we can just
have one variable and introduce different flags. The patch also
introduces additional flag EEH_FORCE_DISABLE, which will be used
to disable EEH subsystem via boot parameter ("eeh=off") in future.
Besides, the patch also introduces flag EEH_ENABLED, which is
changed to disable or enable EEH functionality on the fly through
debugfs entry in future.
With the patch applied, the creteria to check the enabled EEH
functionality is changed to:
!EEH_FORCE_DISABLED && EEH_ENABLED : Enabled
Other cases : Disabled
When calling into eeh_gather_pci_data() on pSeries platform, we
possiblly don't have pci_dev instance yet, but eeh_dev is always
ready. So we use cached capability from eeh_dev instead of pci_dev
for log dump there. In order to keep things unified, we also cache
PCI capability positions to eeh_dev for PowerNV as well.
The patch replaces printk(KERN_WARNING ...) with pr_warn() in the
function eeh_gather_pci_data().
We have suffered recrusive frozen PE a lot, which was caused
by IO accesses during the PE reset. Ben came up with the good
idea to keep frozen PE until recovery (BAR restore) gets done.
With that, IO accesses during PE reset are dropped by hardware
and wouldn't incur the recrusive frozen PE any more.
The patch implements the idea. We don't clear the frozen state
until PE reset is done completely. During the period, the EEH
core expects unfrozen state from backend to keep going. So we
have to reuse EEH_PE_RESET flag, which has been set during PE
reset, to return normal state from backend. The side effect is
we have to clear frozen state for towice (PE reset and clear it
explicitly), but that's harmless.
We have some limitations on pHyp. pHyp doesn't allow to enable
IO or DMA for unfrozen PE. So we don't enable them on unfrozen PE
in eeh_pci_enable(). We have to enable IO before grabbing logs on
pHyp. Otherwise, 0xFF's is always returned from PCI config space.
Also, we had wrong return value from eeh_pci_enable() for
EEH_OPT_THAW_DMA case. The patch fixes it too.
When doing PE reset, EEH_PE_ISOLATED is cleared unconditionally.
However, We should remove that if the PE reset has cleared the
frozen state successfully. Otherwise, the flag should be kept.
The patch fixes the issue.
The PE state (for eeh_pe instance) EEH_PE_PHB_DEAD is duplicate to
EEH_PE_ISOLATED. Originally, those PHBs (PHB PE) with EEH_PE_PHB_DEAD
would be removed from the system. However, it's safe to replace
that with EEH_PE_ISOLATED.
The patch also clear EEH_PE_RECOVERING after fenced PHB has been handled,
either failure or success. It makes the PHB PE state consistent with:
PHB functions normally NONE
PHB has been removed EEH_PE_ISOLATED
PHB fenced, recovery in progress EEH_PE_ISOLATED | RECOVERING
We possiblly detect EEH errors during reboot, particularly in kexec
path, but it's impossible for device drivers and EEH core to handle
or recover them properly.
The patch registers one reboot notifier for EEH and disable EEH
subsystem during reboot. That means the EEH errors is going to be
cleared by hardware reset or second kernel during early stage of
PCI probe.
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
The patch cleans up variable eeh_subsystem_enabled so that we needn't
refer the variable directly from external. Instead, we will use
function eeh_enabled() and eeh_set_enable() to operate the variable.
When EEH error comes to one specific PCI device before its driver
is loaded, we will apply hotplug to recover the error. During the
plug time, the PCI device will be probed and its driver is loaded.
Then we wrongly calls to the error handlers if the driver supports
EEH explicitly.
The patch intends to fix by introducing flag EEH_DEV_NO_HANDLER and
set it before we remove the PCI device. In turn, we can avoid wrongly
calls the error handlers of the PCI device after its driver loaded.
In order to support concurrent adapter firmware download
to SR-IOV adapters on pSeries, each VF will see an EEH event
where the slot will remain in the unavailable state for
the duration of the adapter firmware update, which can take
as long as 5 minutes. Extend the EEH recovery timeout to
account for this.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Acked-by: Gavin Shan <shangw@linux.vnet.ibm.com>
On PHB3, we will fail to fetch IODA tables without PCI_COMMAND_MASTER
on PCI bridges. According to one experiment I had, the MSIx interrupts
didn't raise from the adapter without the bit applied to all upstream
PCI bridges including root port of the adapter. The patch forces to
have that bit enabled accordingly.
CC: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Resource management
- Fix host bridge window coalescing (Alexey Neyman)
- Pass type, width, and prefetchability for window alignment (Wei Yang)
PCI device hotplug
- Convert acpiphp, acpiphp_ibm to dynamic debug (Lan Tianyu)
Power management
- Remove pci_pm_complete() (Liu Chuansheng)
MSI
- Fail initialization if device is not in PCI_D0 (Yijing Wang)
MPS (Max Payload Size)
- Use pcie_get_mps() and pcie_set_mps() to simplify code (Yijing Wang)
- Use pcie_set_readrq() to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_mpss to simplify code (Yijing Wang)
SR-IOV
- Enable upstream bridges even for VFs on virtual buses (Bjorn Helgaas)
- Use pci_is_root_bus() to avoid catching virtual buses (Wei Yang)
Virtualization
- Add x86 MSI masking ops (Konrad Rzeszutek Wilk)
Freescale i.MX6
- Support i.MX6 PCIe controller (Sean Cross)
- Increase link startup timeout (Marek Vasut)
- Probe PCIe in fs_initcall() (Marek Vasut)
- Fix imprecise abort handler (Tim Harvey)
- Remove redundant of_match_ptr (Sachin Kamat)
Renesas R-Car
- Support Gen2 internal PCIe controller (Valentine Barshak)
Samsung Exynos
- Add MSI support (Jingoo Han)
- Turn off power when link fails (Jingoo Han)
- Add Jingoo Han as maintainer (Jingoo Han)
- Add clk_disable_unprepare() on error path (Wei Yongjun)
Synopsys DesignWare
- Add irq_create_mapping() (Pratyush Anand)
- Add header guards (Seungwon Jeon)
Miscellaneous
- Enable native PCIe services by default on non-ACPI (Andrew Murray)
- Cleanup _OSC usage and messages (Bjorn Helgaas)
- Remove pcibios_last_bus boot option on non-x86 (Bjorn Helgaas)
- Convert bus code to use bus_, drv_, and dev_groups (Greg Kroah-Hartman)
- Remove unused pci_mem_start (Myron Stowe)
- Make sysfs functions static (Sachin Kamat)
- Warn on invalid return from driver probe (Stephen M. Cameron)
- Remove Intel Haswell D3 delays (Todd E Brandt)
- Call pci_set_master() in core if driver doesn't do it (Yinghai Lu)
- Use pci_is_pcie() to simplify code (Yijing Wang)
- Use PCIe capability accessors to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_cap to simplify code (Yijing Wang)
- Removed unused "is_pcie" from struct pci_dev (Yijing Wang)
- Simplify sysfs CPU affinity implementation (Yijing Wang)"
* tag 'pci-v3.13-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (79 commits)
PCI: Enable upstream bridges even for VFs on virtual buses
PCI: Add pci_upstream_bridge()
PCI: Add x86_msi.msi_mask_irq() and msix_mask_irq()
PCI: Warn on driver probe return value greater than zero
PCI: Drop warning about drivers that don't use pci_set_master()
PCI: Workaround missing pci_set_master in pci drivers
powerpc/pci: Use pci_is_pcie() to simplify code [fix]
PCI: Update pcie_ports 'auto' behavior for non-ACPI platforms
PCI: imx6: Probe the PCIe in fs_initcall()
PCI: Add R-Car Gen2 internal PCI support
PCI: imx6: Remove redundant of_match_ptr
PCI: Report pci_pme_active() kmalloc failure
mn10300/PCI: Remove useless pcibios_last_bus
frv/PCI: Remove pcibios_last_bus
PCI: imx6: Increase link startup timeout
PCI: exynos: Remove redundant of_match_ptr
PCI: imx6: Fix imprecise abort handler
PCI: Fail MSI/MSI-X initialization if device is not in PCI_D0
PCI: imx6: Remove redundant dev_err() in imx6_pcie_probe()
x86/PCI: Coalesce multiple overlapping host bridge windows
Fix f0308261b1 ("powerpc/pci: Use pci_is_pcie() to simplify code"). I
accidentally merged v2 instead of v3, so this adds the difference. Without
this, "cap" is the left-over PCI-X capability offset, and we're using it as
the PCIe capability offset.
[bhelgaas: extracted v2->v3 diff]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
We already had some output messages from EEH core. Occasionally,
we can see the output messages from EEH core before the stack
dump. That's not what we expected. The patch fixes that and shows
the stack dump prior to output messages from EEH core.
Use pci_is_pcie() to simplify code.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Reviewed-by: Gavin Shan <shangw@linux.vnet.ibm.com>
Cc: Gavin Shan <shangw@linux.vnet.ibm.com>
The procfs entry for global statistics has been missed on PowerNV
platform and the patch is going to add that.
Signed-off-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
The patch introduces flag EEH_DEV_SYSFS to keep track that the sysfs
entries for the corresponding EEH device (then PCI device) has been
added or removed, in order to avoid race condition.
When EEH error happens to one specific PE, some devices with drivers
supporting EEH won't except hotplug on the device. However, there
might have other deivces without driver, or with driver without EEH
support. For the case, we need do partial hotplug in order to make
sure that the PE becomes absolutely quite during reset. Otherise,
the PE reset might fail and leads to failure of error recovery.
The current code doesn't handle that 'mixed' case properly, it either
uses the error callbacks to the drivers, or tries hotplug, but doesn't
handle a PE (EEH domain) composed of a combination of the two.
The patch intends to support so-called "partial" hotplug for EEH:
Before we do reset, we stop and remove those PCI devices without
EEH sensitive driver. The corresponding EEH devices are not detached
from its PE, but with special flag. After the reset is done, those
EEH devices with the special flag will be scanned one by one.
Currently, we're trasversing the EEH devices list using list_for_each_entry().
That's not safe enough because the EEH devices might be removed from
its parent PE while doing iteration. The patch replaces that with
list_for_each_entry_safe().
When we do normal hotplug, the PE (shadow EEH structure) shouldn't be
kept around.
However, we need to keep it if the hotplug an artifial one caused by
EEH errors recovery.
Since we remove EEH device through the PCI hook pcibios_release_device(),
the flag "purge_pe" passed to various functions is meaningless. So the patch
removes the meaningless flag and introduce new flag "EEH_PE_KEEP"
to save the PE while doing hotplug during EEH error recovery.
Make some functions public in order to support hotplug on either specific
PCI bus or PCI device in future.
We will rely on pcibios_release_device() to remove the EEH cache
and unbind EEH device for the specific PCI device. So we shouldn't
hold the reference to the PCI device from EEH cache and EEH device.
Otherwise, pcibios_release_device() won't be called as we expected.
The patch removes the reference to the PCI device in EEH core.
