path: root/arch/powerpc/kernel/kprobes.c
2010-06-02powerpc/kprobes: Remove resume_execution() in kprobesAnanth N Mavinakayanahalli
emulate_step() in kprobe_handler() would've already determined if the probed instruction can be emulated. We single-step in hardware only if the instruction couldn't be emulated. resume_execution() therefore is superfluous -- all we need is to fix up the instruction pointer after single-stepping. Thanks to Paul Mackerras for catching this. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-05powerpc/476: Add isync after loading mmu and debug spr'sDave Kleikamp
476 requires an isync after loading MMU and debug related SPR's. Some of these are in performance-critical paths and may need to be optimized, but initially, we're playing it safe. Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-17powerpc/booke: Introduce new CONFIG options for advanced debug registersDave Kleikamp
powerpc/booke: Introduce new CONFIG options for advanced debug registers From: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Introduce new config options to simplify the ifdefs pertaining to the advanced debug registers for booke and 40x processors: CONFIG_PPC_ADV_DEBUG_REGS - boolean: true for dac-based processors CONFIG_PPC_ADV_DEBUG_IACS - number of IAC registers CONFIG_PPC_ADV_DEBUG_DACS - number of DAC registers CONFIG_PPC_ADV_DEBUG_DVCS - number of DVC registers CONFIG_PPC_ADV_DEBUG_DAC_RANGE - DAC ranges supported Beginning conservatively, since I only have the facilities to test 440 hardware. I believe all 40x and booke platforms support at least 2 IAC and 2 DAC registers. For 440, 4 IAC and 2 DVC registers are enabled, as well as the DAC ranges. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-06kprobes: add kprobe_insn_mutex and cleanup arch_remove_kprobe()Masami Hiramatsu
Add kprobe_insn_mutex for protecting kprobe_insn_pages hlist, and remove kprobe_mutex from architecture dependent code. This allows us to call arch_remove_kprobe() (and free_insn_slot) while holding kprobe_mutex. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-25kprobes: improve kretprobe scalability with hashed lockingSrinivasa D S
Currently list of kretprobe instances are stored in kretprobe object (as used_instances,free_instances) and in kretprobe hash table. We have one global kretprobe lock to serialise the access to these lists. This causes only one kretprobe handler to execute at a time. Hence affects system performance, particularly on SMP systems and when return probe is set on lot of functions (like on all systemcalls). Solution proposed here gives fine-grain locks that performs better on SMP system compared to present kretprobe implementation. Solution: 1) Instead of having one global lock to protect kretprobe instances present in kretprobe object and kretprobe hash table. We will have two locks, one lock for protecting kretprobe hash table and another lock for kretporbe object. 2) We hold lock present in kretprobe object while we modify kretprobe instance in kretprobe object and we hold per-hash-list lock while modifying kretprobe instances present in that hash list. To prevent deadlock, we never grab a per-hash-list lock while holding a kretprobe lock. 3) We can remove used_instances from struct kretprobe, as we can track used instances of kretprobe instances using kretprobe hash table. Time duration for kernel compilation ("make -j 8") on a 8-way ppc64 system with return probes set on all systemcalls looks like this. cacheline non-cacheline Un-patched kernel aligned patch aligned patch =============================================================================== real 9m46.784s 9m54.412s 10m2.450s user 40m5.715s 40m7.142s 40m4.273s sys 2m57.754s 2m58.583s 3m17.430s =========================================================== Time duration for kernel compilation ("make -j 8) on the same system, when kernel is not probed. ========================= real 9m26.389s user 40m8.775s sys 2m7.283s ========================= Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26powerpc/booke: Add kprobes support for booke style processorsKumar Gala
This patch is based on work done by Madhvesh. R. Sulibhavi back in March 2007. We refactor some of the single step handling since it differs between "classic" and "booke" powerpc cores. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-26powerpc/kprobes: Some minor fixesKumar Gala
* Mark __flush_icache_range as a function that can't be probed since its used by the kprobe code. * Fix an issue with single stepping and async exceptions. We need to ensure that we dont get an async exception (external, decrementer, etc) while we are attempting to single step the probe point. Added a check to ensure we only handle a single step if its really intended for the instruction in question. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-05-23[POWERPC] Remove unnecessary cast in arch_deref_entry_point()Michael Ellerman
func_descr_t->entry is already an unsigned long. Mea culpa. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-20[POWERPC] Kill sparse warnings in kprobesAnanth N Mavinakayanahalli
Fix sparse warnings in powerpc kprobes: CHECK arch/powerpc/kernel/kprobes.c arch/powerpc/kernel/kprobes.c:277:6: warning: symbol 'kretprobe_trampoline_holder' was not declared. Should it be static? arch/powerpc/kernel/kprobes.c:287:15: warning: symbol 'trampoline_probe_handler' was not declared. Should it be static? arch/powerpc/kernel/kprobes.c:525:16: warning: symbol 'jprobe_return_end' was not declared. Should it be static? Fix along the same lines as http://lkml.org/lkml/2008/2/13/642 Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-16kprobes: support kretprobe blacklistMasami Hiramatsu
Introduce architecture dependent kretprobe blacklists to prohibit users from inserting return probes on the function in which kprobes can be inserted but kretprobes can not. This patch also removes "__kprobes" mark from "__switch_to" on x86_64 and registers "__switch_to" to the blacklist on x86-64, because that mark is to prohibit user from inserting only kretprobe. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19jprobes: make jprobes a little safer for usersMichael Ellerman
I realise jprobes are a razor-blades-included type of interface, but that doesn't mean we can't try and make them safer to use. This guy I know once wrote code like this: struct jprobe jp = { .kp.symbol_name = "foo", .entry = "jprobe_foo" }; And then his kernel exploded. Oops. This patch adds an arch hook, arch_deref_entry_point() (I don't like it either) which takes the void * in a struct jprobe, and gives back the text address that it represents. We can then use that in register_jprobe() to check that the entry point we're passed is actually in the kernel text, rather than just some random value. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: The ON/OFF knob thru debugfsAnanth N Mavinakayanahalli
This patch provides a debugfs knob to turn kprobes on/off o A new file /debug/kprobes/enabled indicates if kprobes is enabled or not (default enabled) o Echoing 0 to this file will disarm all installed probes o Any new probe registration when disabled will register the probe but not arm it. A message will be printed out in such a case. o When a value 1 is echoed to the file, all probes (including ones registered in the intervening period) will be enabled o Unregistration will happen irrespective of whether probes are globally enabled or not. o Update Documentation/kprobes.txt to reflect these changes. While there also update the doc to make it current. We are also looking at providing sysrq key support to tie to the disabling feature provided by this patch. [akpm@linux-foundation.org: Use bool like a bool!] [akpm@linux-foundation.org: add printk facility levels] [cornelia.huck@de.ibm.com: Add the missing arch_trampoline_kprobe() for s390] Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: kretprobes simplificationsChristoph Hellwig
- consolidate duplicate code in all arch_prepare_kretprobe instances into common code - replace various odd helpers that use hlist_for_each_entry to get the first elemenet of a list with either a hlist_for_each_entry_save or an opencoded access to the first element in the caller - inline add_rp_inst into it's only remaining caller - use kretprobe_inst_table_head instead of opencoding it Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: print details of kretprobe on assertion failureAnanth N Mavinakayanahalli
In certain cases like when the real return address can't be found or when the number of tracked calls to a kretprobed function is less than the number of returns, we may not be able to find the correct return address after processing a kretprobe. Currently we just do a BUG_ON, but no information is provided about the actual failing kretprobe. Print out details of the kretprobe before calling BUG(). Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[POWERPC] Minor fault path optimizationChristoph Hellwig
Call the kprobes pagefault handler directly instead of going through the complex notifier chain. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] kprobes: Eliminate sstep exception if instruction can be emulatedAnanth N Mavinakayanahalli
For cases when probes are placed on instructions that can be emulated, don't take the single-step exception. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-06[POWERPC] Added kprobes support to ppc32Kumar Gala
Added kprobes to ppc32 platforms that have use single_step_exception. This excludes 4xx and anything Book-E since their debug mechanisms for single stepping are completely different. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-12-07[PATCH] kprobes: enable booster on the preemptible kernelMasami Hiramatsu
When we are unregistering a kprobe-booster, we can't release its instruction buffer immediately on the preemptive kernel, because some processes might be preempted on the buffer. The freeze_processes() and thaw_processes() functions can clean most of processes up from the buffer. There are still some non-frozen threads who have the PF_NOFREEZE flag. If those threads are sleeping (not preempted) at the known place outside the buffer, we can ensure safety of freeing. However, the processing of this check routine takes a long time. So, this patch introduces the garbage collection mechanism of insn_slot. It also introduces the "dirty" flag to free_insn_slot because of efficiency. The "clean" instruction slots (dirty flag is cleared) are released immediately. But the "dirty" slots which are used by boosted kprobes, are marked as garbages. collect_garbage_slots() will be invoked to release "dirty" slots if there are more than INSNS_PER_PAGE garbage slots or if there are no unused slots. Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "bibo,mao" <bibo.mao@intel.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Yumiko Sugita <yumiko.sugita.yf@hitachi.com> Cc: Satoshi Oshima <soshima@redhat.com> Cc: Hideo Aoki <haoki@redhat.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] kretprobe spinlock deadlock patchbibo,mao
kprobe_flush_task() possibly calls kfree function during holding kretprobe_lock spinlock, if kfree function is probed by kretprobe that will incur spinlock deadlock. This patch moves kfree function out scope of kretprobe_lock. Signed-off-by: bibo, mao <bibo.mao@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] kprobe whitespace cleanupbibo,mao
Whitespace is used to indent, this patch cleans up these sentences by kernel coding style. Signed-off-by: bibo, mao <bibo.mao@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-17[POWERPC] kprobes: Fix possible system crash during out-of-line single-steppingAnanth N Mavinakayanahalli
- On archs that have no-exec support, we vmalloc() a executable scratch area of PAGE_SIZE and divide it up into an array of slots of maximum instruction size for that arch - On a kprobe registration, the original instruction is copied to the first available free slot, so if multiple kprobes are registered, chances are, they get contiguous slots - On POWER4, due to not having coherent icaches, we could hit a situation where a probe that is registered on one processor, is hit immediately on another. This second processor could have fetched the stream of text from the out-of-line single-stepping area *before* the probe registration completed, possibly due to an earlier (and a different) kprobe hit and hence would see stale data at the slot. Executing such an arbitrary instruction lead to a problem as reported in LTC bugzilla 23555. The correct solution is to call flush_icache_range() as soon as the instruction is copied for out-of-line single-stepping, so the correct instruction is seen on all processors. Thanks to Will Schmidt who tracked this down. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-03[PATCH] powerpc/kprobes: fix singlestep out-of-lineAnanth N Mavinakayanahalli
We currently single-step inline if the instruction on which a kprobe is inserted is a trap variant. - variants (such as tdnei, used by BUG()) typically evaluate a condition and cause a trap only if the condition is satisfied. - kprobes uses the unconditional "trap" (0x7fe00008) and single-stepping again on this instruction, resulting in another trap without evaluating the condition is obviously incorrect. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-19[PATCH] Switch Kprobes inline functions to __kprobes for ppc64Prasanna S Panchamukhi
Andrew Morton pointed out that compiler might not inline the functions marked for inline in kprobes. There-by allowing the insertion of probes on these kprobes routines, which might cause recursion. This patch removes all such inline and adds them to kprobes section there by disallowing probes on all such routines. Some of the routines can even still be inlined, since these routines gets executed after the kprobes had done necessay setup for reentrancy. Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] kprobes: fix broken fault handling for powerpc64Prasanna S Panchamukhi
Provide proper kprobes fault handling, if a user-specified pre/post handlers tries to access user address space, through copy_from_user(), get_user() etc. The user-specified fault handler gets called only if the fault occurs while executing user-specified handlers. In such a case user-specified handler is allowed to fix it first, later if the user-specifed fault handler does not fix it, we try to fix it by calling fix_exception(). The user-specified handler will not be called if the fault happens when single stepping the original instruction, instead we reset the current probe and allow the system page fault handler to fix it up. Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] kprobe handler: discard user space trapbibo,mao
Currently kprobe handler traps only happen in kernel space, so function kprobe_exceptions_notify should skip traps which happen in user space. This patch modifies this, and it is based on 2.6.16-rc4. Signed-off-by: bibo mao <bibo.mao@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com> Cc: <hiramatu@sdl.hitachi.co.jp> Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: kprobesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-11[PATCH] kprobes: fix race in recovery of reentrant probeKeshavamurthy Anil S
There is a window where a probe gets removed right after the probe is hit on some different cpu. In this case probe handlers can't find a matching probe instance related to break address. In this case we need to read the original instruction at break address to see if that is not a break/int3 instruction and recover safely. Previous code had a bug where we were not checking for the above race in case of reentrant probes and the below patch fixes this race. Tested on IA64, Powerpc, x86_64. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: fix build breakageAnanth N Mavinakayanahalli
The following patch (against 2.6.15-rc5-mm3) fixes a kprobes build break due to changes introduced in the kprobe locking in 2.6.15-rc5-mm3. In addition, the patch reverts back the open-coding of kprobe_mutex. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: arch_remove_kprobeAnil S Keshavamurthy
Currently arch_remove_kprobes() is only implemented/required for x86_64 and powerpc. All other architecture like IA64, i386 and sparc64 implementes a dummy function which is being called from arch independent kprobes.c file. This patch removes the dummy functions and replaces it with #define arch_remove_kprobe(p, s) do { } while(0) Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes-changed-from-using-spinlock-to-mutex fixKeshavamurthy Anil S
Based on some feedback from Oleg Nesterov, I have made few changes to previously posted patch. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] kprobes: changed from using spinlock to mutexAnil S Keshavamurthy
Since Kprobes runtime exception handlers is now lock free as this code path is now using RCU to walk through the list, there is no need for the register/unregister{_kprobe} to use spin_{lock/unlock}_isr{save/restore}. The serialization during registration/unregistration is now possible using just a mutex. In the above process, this patch also fixes a minor memory leak for x86_64 and powerpc. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] kprobes: increment kprobe missed count for multiprobesKeshavamurthy Anil S
When multiple probes are registered at the same address and if due to some recursion (probe getting triggered within a probe handler), we skip calling pre_handlers and just increment nmissed field. The below patch make sure it walks the list for multiple probes case. Without the below patch we get incorrect results of nmissed count for multiple probe case. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14powerpc: Move most remaining ppc64 files over to arch/powerpcPaul Mackerras
Also deletes files in arch/ppc64 that are no longer used now that we don't compile with ARCH=ppc64 any more. Signed-off-by: Paul Mackerras <paulus@samba.org>
