Fallback gracefully when reading /proc/ppc64/lparcfg when the /rtas
device node can't be found.
At present the lppaca - the structure shared with the iSeries
hypervisor and phyp - is contained within the PACA, our own low-level
per-cpu structure. This doesn't have to be so, the patch below
removes it, making a separate array of lppaca structures.
This saves approximately 500*NR_CPUS bytes of image size and kernel
memory, because we don't need aligning gap between the Linux and
hypervisor portions of every PACA. On the other hand it means an
extra level of dereference in many accesses to the lppaca.
The patch also gets rid of several places where we assign the paca
address to a local variable for no particular reason.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
log_plpar_hcall_return is only used on PPC_PSERIES, so move
it closer to its users and inside ifdef CONFIG_PPC_PSERIES.
remove the last vestiges of systemcfg in iSeries.
We needed the VDSO symbols in the arch/ppc asm-offsets.c, and there
were a few usages of _systemcfg still left lying around.
If we dont have permission to read some information from the hypervisor,
lparcfg outputs a warning on the console. Now that lparcfg is world
readable this is a problem.
Dont warn in the case of H_Authority, remove some unnecessary function
prototypes and fix whitespace damage in a structure as well.
This patch moves a bunch more files from arch/ppc64 and
include/asm-ppc64 which have no equivalents in ppc32 code into
arch/powerpc and include/asm-powerpc. The file affected are:
hvcall.h
proc_ppc64.c
sysfs.c
lparcfg.c
rtas_pci.c
The only changes apart from the move and corresponding Makefile
changes are:
- #ifndef/#define in includes updated to _ASM_POWERPC_ form
- trailing whitespace removed
- comments giving full paths removed
Built and booted on POWER5 LPAR (ARCH=powerpc and ARCH=ppc64), built
for 32-bit powermac (ARCH=powerpc).
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
