path: root/arch/powerpc/kernel/machine_kexec_32.c
2006-06-26Storage class should be firstTobias Klauser
Storage class should be before const Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-09[PATCH] powerpc: Merge kexecMichael Ellerman
This patch merges, to some extent, the PPC32 and PPC64 kexec implementations. We adopt the PPC32 approach of having ppc_md callbacks for the kexec functions. The current PPC64 implementation becomes the "default" implementation for PPC64 which platforms can select if they need no special treatment. I've added these default callbacks to pseries/maple/cell/powermac, this means iSeries no longer supports kexec - but it never worked anyway. I've renamed PPC32's machine_kexec_simple to default_machine_kexec, inline with PPC64. Judging by the comments it might be better named machine_kexec_non_of, or something, but at the moment it's the only implementation for PPC32 so it's the "default". Kexec requires machine_shutdown(), which is in machine_kexec.c on PPC32, but we already have in setup-common.c on powerpc. All this does is call ppc_md.nvram_sync, which only powermac implements, so instead make machine_shutdown a ppc_md member and have it call core99_nvram_sync directly on powermac. I've also stuck relocate_kernel.S into misc_32.S for powerpc. Built for ARCH=ppc, and 32 & 64 bit ARCH=powerpc, with KEXEC=y/n. Booted on P5 LPAR and successfully kexec'ed. Should apply on top of 493f25ef4087395891c99fcfe2c72e62e293e89f. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
