path: root/arch/powerpc/kernel/pci_64.c
2009-06-09powerpc: Fix warning when printing a resource_size_tStephen Rothwell
resource_size_t is 64 bits on PowerPC 64. Gets rid of this warning: arch/powerpc/kernel/pci_64.c: In function 'pcibios_map_io_space': arch/powerpc/kernel/pci_64.c:504: warning: format '%016lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-09powerpc: Shield code specific to 64-bit server processorsBenjamin Herrenschmidt
This is a random collection of added ifdef's around portions of code that only mak sense on server processors. Using either CONFIG_PPC_STD_MMU_64 or CONFIG_PPC_BOOK3S as seems appropriate. This is meant to make the future merging of Book3E 64-bit support easier. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-21powerpc/pci: Remove redundant pcnet32 fixupKumar Gala
The pcnet32 driver has had in its device id table for some time a match against the "broken" vendor ID. No need to fake out the vendor ID with an explicit fixup. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-15powerpc: Fix PCI ROM accessBenjamin Herrenschmidt
A couple of issues crept in since about 2.6.27 related to accessing PCI device ROMs on various powerpc machines. First, historically, we don't allocate the ROM resource in the resource tree. I'm not entirely certain of why, I susepct they often contained garbage on x86 but it's hard to tell. This causes the current generic code to always call pci_assign_resource() when trying to access the said ROM from sysfs, which will try to re-assign some new address regardless of what the ROM BAR was already set to at boot time. This can be a problem on hypervisor platforms like pSeries where we aren't supposed to move PCI devices around (and in fact probably can't). Second, our code that generates the PCI tree from the OF device-tree (instead of doing config space probing) which we mostly use on pseries at the moment, didn't set the (new) flag IORESOURCE_SIZEALIGN on any resource. That means that any attempt at re-assigning such a resource with pci_assign_resource() would fail due to resource_alignment() returning 0. This fixes this by doing these two things: - The code that calculates resource flags based on the OF device-node is improved to set IORESOURCE_SIZEALIGN on any valid BAR, and while at it also set IORESOURCE_READONLY for ROMs since we were lacking that too - We now allocate ROM resources as part of the resource tree. However to limit the chances of nasty conflicts due to busted firmwares, we only do it on the second pass of our two-passes allocation scheme, so that all valid and enabled BARs get precedence. This brings pSeries back the ability to access PCI ROMs via sysfs (and thus initialize various video cards from X etc...). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-11powerpc/pci: Move hose_list and pci_address_to_pio to pci-commonMilton Miller
move the definition of hose_list next to its hotplug spinlock. create pcibios_io_size to encapsulate ifdef in existing pci-common function pcibios_vaddr_is_ioport move pci_address_to_pio to pci-common, using new pcibios_io_size, and protect this GPL exported function against concurrent hotplug removal Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-13powerpc: Cleanup from l64 to ll64 change: arch codeStephen Rothwell
2009-01-08powerpc: Fix pciconfig_iobase system call on PCI-Express powermacPaul Mackerras
X has been failing to start on my quad G5 powermac since commit 1fd0f52583a85b21a394201b007bc1ee104b235d ("powerpc: Fix domain numbers in /proc on 64-bit") went in. The reason is that the change allows X to see the PCI-PCI bridge above the video card (previously it was obscured by the fact that there were two "00" directories in /proc/bus/pci), and the pciconfig_iobase system call on the bridge is failing because of a hack that we have to return information about the AGP bus when X asks about bus 0. This machine doesn't have an AGP bus (it has PCI Express) and so the pciconfig_iobase call is returning -1, which ultimately causes X to fail to start. This fixes it by checking that we have an AGP bridge before redirecting the pciconfig_iobase call to return information about the AGP bus. With this, X starts successfully both on a quad G5 with PCI Express and on an older dual G5 with AGP. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-11-06powerpc/pci: Split pcibios_fixup_bus() into bus setup and device setupBenjamin Herrenschmidt
Currently, our PCI code uses the pcibios_fixup_bus() callback, which is called by the generic code when probing PCI buses, for two different things. One is to set up things related to the bus itself, such as reading bridge resources for P2P bridges, fixing them up, or setting up the iommu's associated with bridges on some platforms. The other is some setup for each individual device under that bridge, mostly setting up DMA mappings and interrupts. The problem is that this approach doesn't work well with PCI hotplug when an existing bus is re-probed for new children. We fix this problem by splitting pcibios_fixup_bus into two routines: pcibios_setup_bus_self() is now called to setup the bus itself pcibios_setup_bus_devices() is now called to setup devices pcibios_fixup_bus() is then modified to call these two after reading the bridge bases, and the OF based PCI probe is modified to avoid calling into the first one when rescanning an existing bridge. [paulus@samba.org - fixed eeh.h for 32-bit compile now that pci-common.c is including it unconditionally.] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/pci: Remove pcibios_do_bus_setup()Benjamin Herrenschmidt
The function pcibios_do_bus_setup() was used by pcibios_fixup_bus() to perform setup that is different between the 32-bit and 64-bit code. This difference no longer exists, thus the function is removed and the setup now done directly from pci-common.c. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/pci: Use common PHB resource hookupBenjamin Herrenschmidt
The 32-bit and 64-bit powerpc PCI code used to set up the resource pointers of the root bus of a given PHB in completely different places. This unifies this in large part, by making 32-bit use a routine very similar to what 64-bit does when initially scanning the PCI busses. The actual setup of the PHB resources itself is then moved to a common function in pci-common.c. This should cause no functional change on 64-bit. On 32-bit, the effect is that the PHB resources are going to be setup a bit earlier, instead of being setup from pcibios_fixup_bus(). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/pci: Cleanup debug printk'sBenjamin Herrenschmidt
This removes the various DBG() macro from the powerpc PCI code and makes it use the standard pr_debug instead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc: Fix domain numbers in /proc on 64-bitBenjamin Herrenschmidt
The code to properly expose domain numbers in /proc is somewhat bogus on ppc64 as it depends on the "buid" field being non-0, but that field is really pseries specific. This removes that code and makes ppc64 use the same code as 32-bit which effectively decides whether to expose domains based on ppc_pci_flags set by the platform, and sets the default for 64-bit to enable domains and enable compatibility for domain 0 (which strips the domain number for domain 0 to help with X servers). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-31powerpc/pci: Fix unmapping of IO space on 64-bitBenjamin Herrenschmidt
A typo/thinko made us pass the wrong argument to __flush_hash_table_range when unplugging bridges, thus not flushing all the translations for the IO space on unplug. The third parameter to __flush_hash_table_range is `end', not `size'. This causes the hypervisor to refuse unplugging slots. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-24powerpc: Merge 32 and 64-bit dma codeBecky Bruce
We essentially adopt the 64-bit dma code, with some changes to support 32-bit systems, including HIGHMEM. dma functions on 32-bit are now invoked via accessor functions which call the correct op for a device based on archdata dma_ops. If there is no archdata dma_ops, this defaults to dma_direct_ops. In addition, the dma_map/unmap_page functions are added to dma_ops because we can't just fall back on map/unmap_single when HIGHMEM is enabled. In the case of dma_direct_*, we stop using map/unmap_single and just use the page version - this saves a lot of ugly ifdeffing. We leave map/unmap_single in the dma_ops definition, though, because they are needed by the iommu code, which does not implement map/unmap_page. Ideally, going forward, we will completely eliminate map/unmap_single and just have map/unmap_page, if it's workable for 64-bit. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-24powerpc: Drop archdata numa_nodeBecky Bruce
Use the struct device's numa_node instead; use accessor functions to get/set numa_node. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09[POWERPC] Use dev_set_name in pci_64.cStephen Rothwell
During the next merge window, pci_name()'s return value will become const, so use the new dev_set_name() instead to avoid the warning (from linux-next): arch/powerpc/kernel/pci_64.c: In function 'of_create_pci_dev': arch/powerpc/kernel/pci_64.c:193: warning: passing argument 1 of 'sprintf' discards qualifiers from pointer target type Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-25[POWERPC] Always hookup PHB IO resource even when emptyBenjamin Herrenschmidt
We must always hookup the pci_bus resource 0 to the PHB io_resource even if the latter is empty (the bus has no IO support). Otherwise, some other code will end up hooking it up to something bogus and the resource tree will end up being broken. This fixes boot on QS20 Cell blades where the IDE driver failed to allocate the IO resources due to breakage of the resource tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-17[POWERPC] arch/powerpc/kernel: Use for_each_child_of_nodeStephen Rothwell
2007-12-20[POWERPC] Merge 32 and 64 bits pcibios_enable_deviceBenjamin Herrenschmidt
This merge the two implementations, based on the previously fixed up 32 bits one. The pcibios_enable_device_hook in ppc_md is now available for ppc64 use. Also remove the new unused "initial" parameter from it and fixup users. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] fix iSeries PCI resource managementBenjamin Herrenschmidt
The way iSeries manages PCI IO and Memory resources is a bit strange and is based on overriding the content of those resources with home cooked ones afterward. This changes it a bit to better integrate with the new resource handling so that the "virtual" tokens that iSeries replaces resources with are done from the proper per-device fixup hook, and bridge resources are set to enclose that token space. This fixes various things such as the output of /proc/iomem & ioports, among others. This also fixes up various boot messages as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] Merge PCI resource allocation & assignmentBenjamin Herrenschmidt
The 32 bits PCI code now uses the generic code for assigning unassigned resources and an algorithm similar to x86 for claiming existing ones. This works far better than the 64 bits code which basically can only claim existing ones (pci_probe_only=1) or would fall apart completely. This merges them so that the new 32 bits implementation is used for both. 64 bits now gets the new PCI flags for controlling the behaviour, though the old pci_probe_only global is still there for now to be cleared if you want to. I kept a pcibios_claim_one_bus() function mostly based on the old 64 bits code for use by the DLPAR hotplug. This will have to be cleaned up, thought I hope it will work in the meantime. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] Merge PCI resource fixupsBenjamin Herrenschmidt
The PCI code in 32 and 64 bits fixes up resources differently. 32 bits uses a header quirk plus handles bridges in pcibios_fixup_bus() while 64 bits does things in various places depending on whether you are using OF probing, using PCI hotplug, etc... This merges those by basically using the 32 bits approach for both, with various tweaks to make 64 bits work with the new approach. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] Merge pcibios_resource_to_bus/bus_to_resourceBenjamin Herrenschmidt
This merges the PowerPC 32 and 64 bits version of pcibios_resource_to_bus and pcibios_bus_to_resource(). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] pci32: Add platform option to enable /proc PCI domainsBenjamin Herrenschmidt
This adds flags the platforms can use to enable domain numbers in /proc/bus/pci. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] pci32: Add flags modifying the PCI code behaviourBenjamin Herrenschmidt
This adds to the 32 bits PCI code some flags, replacing the old pci_assign_all_busses global, that allow us to control various aspects of the PCI probing, such as whether to re-assign all resources or not, or to not try to assign anything at all. This also adds the flag x86 already has to avoid ISA alignment on bridges that don't have ISA forwarding enabled (no legacy devices on the top level bus) and sets it for PowerMacs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] Implement pci_set_dma_mask() in terms of the dma_opsMichael Ellerman
PowerPC currently doesn't implement pci_set_dma_mask(), which means drivers calling it will get the generic version in drivers/pci/pci.c. The powerpc dma mapping ops include a dma_set_mask() hook, which luckily is not implemented by anyone - so there is no bug in the fact that the hook is currently never called. However in future we'll add implementation(s) of dma_set_mask(), and so we need pci_set_dma_mask() to call the hook. To save adding a hook to the dma mapping ops, pci-set_consistent_dma_mask() simply calls the dma_set_mask() hook and then copies the new mask into dev.coherenet_dma_mask. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-11[POWERPC] Merge pci_process_bridge_OF_ranges()Benjamin Herrenschmidt
This merges the 32-bit and 64-bit implementations of pci_process_bridge_OF_ranges(). The new function is cleaner than both the old ones, and supports 64 bits ranges on ppc32 which is necessary for the 4xx port. It also adds some better (hopefully) output to the kernel log which should help diagnose problems and makes better use of existing OF parsing helpers (avoiding a few bugs of both implementations along the way). There are still a few unfortunate ifdef's but there is no way around these for now at least not until some other bits of the PCI code are made common. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-11[POWERPC] pci_controller->arch_data really is a struct device_node *Stephen Rothwell
2007-12-11[POWERPC] Remove some iSeries platform checks from the PCI codeStephen Rothwell
2007-12-11[POWERPC] iSeries: hose->buid is always zero for iSeriesStephen Rothwell
so remove a firmware feature test. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-11[POWERPC] iSeries: Call iSeries_pcibios_init from setup_archStephen Rothwell
2007-10-03[POWERPC] Fix pci domain detectionArnd Bergmann
The /proc/bus/pci/* files list PCI domain numbers only for devices that claim to be on a multi-domain system. The check for this is broken on powerpc, because the buid value is truncated to 32 bits. There is at least one machine (IBM QS21) that only uses the high-order bits of the buid, so the return value of pci_proc_domain() ends up being always zero, which makes /proc/bus/pci useless. Change the logic to always return '1' for a nonzero buid value. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-10[POWERPC] Fix initialization and usage of dma_maskBenjamin Herrenschmidt
powerpc has a couple of bugs in the usage of dma_masks that tend to break when drivers explicitly try to set a 32-bit mask for example. First, the code that generates the pci devices from the OF device-tree doesn't initialize the mask properly, then our implementation of set_dma_mask() was trying to validate the -previous- mask value, not the one passed in as an argument. This fixes these problems. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-16Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (209 commits) [POWERPC] Create add_rtc() function to enable the RTC CMOS driver [POWERPC] Add H_ILLAN_ATTRIBUTES hcall number [POWERPC] xilinxfb: Parameterize xilinxfb platform device registration [POWERPC] Oprofile support for Power 5++ [POWERPC] Enable arbitary speed tty ioctls and split input/output speed [POWERPC] Make drivers/char/hvc_console.c:khvcd() static [POWERPC] Remove dead code for preventing pread() and pwrite() calls [POWERPC] Remove unnecessary #undef printk from prom.c [POWERPC] Fix typo in Ebony default DTS [POWERPC] Check for NULL ppc_md.init_IRQ() before calling [POWERPC] Remove extra return statement [POWERPC] pasemi: Don't auto-select CONFIG_EMBEDDED [POWERPC] pasemi: Rename platform [POWERPC] arch/powerpc/kernel/sysfs.c: Move NUMA exports [POWERPC] Add __read_mostly support for powerpc [POWERPC] Modify sched_clock() to make CONFIG_PRINTK_TIME more sane [POWERPC] Create a dummy zImage if no valid platform has been selected [POWERPC] PS3: Bootwrapper support. [POWERPC] powermac i2c: Use mutex [POWERPC] Schedule removal of arch/ppc ... Fixed up conflicts manually in: Documentation/feature-removal-schedule.txt arch/powerpc/kernel/pci_32.c arch/powerpc/kernel/pci_64.c include/asm-powerpc/pci.h and asked the powerpc people to double-check the result..
2007-07-11PCI: read revision ID by defaultAuke Kok
Currently there are 97 occurrences where drivers need the pci revision ID. We can do this once for all devices. Even the pci subsystem needs the revision several times for quirks. The extra u8 member pads out nicely in the pci_dev struct. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Make pcibios_add_platform_entries() return errorsMichael Ellerman
Currently pcibios_add_platform_entries() returns void, but could fail, so instead have it return an int and propagate errors up to pci_create_sysfs_dev_files(). Fixes: arch/powerpc/kernel/pci_64.c: In function 'pcibios_add_platform_entries': arch/powerpc/kernel/pci_64.c:878: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result arch/powerpc/kernel/pci_32.c: In function 'pcibios_add_platform_entries': arch/powerpc/kernel/pci_32.c:1043: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-03[POWERPC] Replace use of GET_64BIT(prop, i) with of_read_number().Jon Loeliger
Remove uses of hack GET_64BIT() property macro and use the more general of_read_number() function from prom.h as suggested by Milton. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Use ppc64 style list management for pci_controller on ppc32Kumar Gala
Use the ppc64 style list management and allocation functions for pci_controllers. This makes the pci_controller structs just a bit more common between ppc32 & ppc64. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Move common PCI code out of pci_32/pci_64Kumar Gala
Moved the low hanging fruit that was either identical or close to it between ppc32 & ppc64 for PCI into pci-common.c Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Use global_number in ppc32 pci_controllerKumar Gala
Make the pci_controller struct use global_number for the PHB domain number instead of index to match what ppc64 does and reuse its pci_domain_nr code. Introduced a pci-common.c to handle shared code between ppc32 & ppc64. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-28[POWERPC] Turn off debugging in arch/powerpc/kernel/pci_64.cMichael Ellerman
Commit 3d5134ee8341bffc4f539049abb9e90d469b448d left debugging turned on in arch/powerpc/kernel/pci_64.c. This turns it off again. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Rewrite IO allocation & mapping on powerpc64Benjamin Herrenschmidt
This rewrites pretty much from scratch the handling of MMIO and PIO space allocations on powerpc64. The main goals are: - Get rid of imalloc and use more common code where possible - Simplify the current mess so that PIO space is allocated and mapped in a single place for PCI bridges - Handle allocation constraints of PIO for all bridges including hot plugged ones within the 2GB space reserved for IO ports, so that devices on hotplugged busses will now work with drivers that assume IO ports fit in an int. - Cleanup and separate tracking of the ISA space in the reserved low 64K of IO space. No ISA -> Nothing mapped there. I booted a cell blade with IDE on PIO and MMIO and a dual G5 so far, that's it :-) With this patch, all allocations are done using the code in mm/vmalloc.c, though we use the low level __get_vm_area with explicit start/stop constraints in order to manage separate areas for vmalloc/vmap, ioremap, and PCI IOs. This greatly simplifies a lot of things, as you can see in the diffstat of that patch :-) A new pair of functions pcibios_map/unmap_io_space() now replace all of the previous code that used to manipulate PCI IOs space. The allocation is done at mapping time, which is now called from scan_phb's, just before the devices are probed (instead of after, which is by itself a bug fix). The only other caller is the PCI hotplug code for hot adding PCI-PCI bridges (slots). imalloc is gone, as is the "sub-allocation" thing, but I do beleive that hotplug should still work in the sense that the space allocation is always done by the PHB, but if you unmap a child bus of this PHB (which seems to be possible), then the code should properly tear down all the HPTE mappings for that area of the PHB allocated IO space. I now always reserve the first 64K of IO space for the bridge with the ISA bus on it. I have moved the code for tracking ISA in a separate file which should also make it smarter if we ever are capable of hot unplugging or re-plugging an ISA bridge. This should have a side effect on platforms like powermac where VGA IOs will no longer work. This is done on purpose though as they would have worked semi-randomly before. The idea at this point is to isolate drivers that might need to access those and fix them by providing a proper function to obtain an offset to the legacy IOs of a given bus. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-17[POWERPC] Fix IO space on PCI buses created from of_platformBenjamin Herrenschmidt
This changes the way of_platform_pci creates PCI host bridges such that it uses request_phb_iospace() for mapping the IO ports, instead of using the dynamic hotplug stuff. That guarantees the IO space stays within the 2GB limit and thus doesn't break half of the legacy drivers around. Fixes a couple of warnings due to missing IO space while at it. This patch is a temporary workaround for 2.6.22 before a more complete rewrite of IO mappings is merged in 2.6.23 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-10[POWERPC] Fix incorrect calculation of I/O window addressesPaul Mackerras
My patch "Cope with PCI host bridge I/O window not starting at 0" introduced a bug in the calculation of the virtual addresses for the I/O windows of PCI host bridges other than the first, because it didn't account for the fact that hose->io_resource gets offset so that it reflects the range of global I/O port numbers assigned to the bridge. This fixes it and simplifies get_bus_io_range() in the process. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08Merge branch 'linux-2.6'Paul Mackerras
2007-05-08[POWERPC] Cope with PCI host bridge I/O window not starting at 0Paul Mackerras
Currently our code to set up the data structures for a PCI host bridge and create the mapping for its I/O window assumes that the window starts at I/O port 0 on the PCI side. If this is not true, we can end up with I/O port numbers in the resources for PCI devices which will cause an oops if a driver tries to access them via inb/outb etc., because there is no mapping for the corresponding addresses. Normally the I/O window starts at 0, but there are some situations on partitioned machines with a hypervisor where the window may not start at 0. This fixes the problem by allocating space for the range from 0 to the end of the I/O window. That is, hose->io_base_virt contains the virtual address for I/O port 0 on the PCI bus, and thus the assumption that hose->io_base_virt - pci_io_base is the offset between the "global" I/O port numbers (those in the PCI device resources) and the I/O port numbers on the PCI bus is maintained. For PCI host bridges that are present at boot, we only map the portion of that range that correspond to the bridge's I/O window. For bridges added after boot we ioremap the range from 0 to the end of the I/O window, for now; in fact hot-added bridges should be using reserve_phb_iospace() and __ioremap_explicit (so they get sensible global port numbers), but we don't have the infrastructure yet to do that (basically a free_phb_iospace() routine plus appropriate locking). Interestingly, this makes the two arms of the if statement in get_bus_io_range do almost exactly the same thing; that function could now be simplified in a further patch. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02PCI: Convert to alloc_pci_dev()Michael Ellerman
Convert code that allocs a struct pci_dev to use alloc_pci_dev(). Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-13[POWERPC] Rename get_property to of_get_property: arch/powerpcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename prom_n_addr_cells to of_n_addr_cellsStephen Rothwell
This is more consistent and gets us closer to the Sparc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-09[POWERPC] Create and use get_pci_dma_ops()Stephen Rothwell
This allows us to hide pci_dma_ops. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
