path: root/arch/powerpc/kernel/setup_32.c
2015-09-17powerpc32: memset: only use dcbz once cache is enabledLEROY Christophe
memset() uses instruction dcbz to speed up clearing by not wasting time loading cache line with data that will be overwritten. Some platform like mpc52xx do no have cache active at startup and can therefore not use memset(). Allthough no part of the code explicitly uses memset(), GCC may make calls to it. This patch modifies memset() such that at startup, memset() unconditionally skip the optimised bloc that uses dcbz instruction. Once the initial MMU is set up, in machine_init() we patch memset() by replacing this inconditional jump by a NOP Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-17powerpc32: memcpy: only use dcbz once cache is enabledLEROY Christophe
memcpy() uses instruction dcbz to speed up copy by not wasting time loading cache line with data that will be overwritten. Some platform like mpc52xx do no have cache active at startup and can therefore not use memcpy(). Allthough no part of the code explicitly uses memcpy(), GCC makes calls to it. This patch modifies memcpy() such that at startup, memcpy() unconditionally jumps to generic_memcpy() which doesn't use the dcbz instruction. Once the initial MMU is set up, in machine_init() we patch memcpy() by replacing this inconditional jump by a NOP Reported-by: Michal Sojka <sojkam1@fel.cvut.cz> Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-11-10powerpc: Remove unused vgacon_remap_base & fix build breakMichael Ellerman
The build is broken with CONFIG_PPC32=y, CONFIG_FB_VGA16=y and CONFIG_VGA_CONSOLE=n. The problem is that vgacon_remap_base is not defined. It's used in: #define VGA_MAP_MEM(x,s) (x + vgacon_remap_base) Which is used in the vga16fb.c code. Digging down it seems vgacon_remap_base is never initialised. It used to be, back in arch/ppc (pplus.c and prep_setup.c), but none of that code ever made it to arch/powerpc. So given it's been unused for >6 years, remove it. Whether vga16fb.c works on 32-bit is another question, but this patch shouldn't affect it. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-11-10powerpc: Remove superfluous bootmem includesAnton Blanchard
Lots of places included bootmem.h even when not using bootmem. Signed-off-by: Anton Blanchard <anton@samba.org> Tested-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-11-10powerpc: Remove bootmem allocatorAnton Blanchard
At the moment we transition from the memblock alloctor to the bootmem allocator. Gitting rid of the bootmem allocator removes a bunch of complicated code (most of which I owe the dubious honour of being responsible for writing). Signed-off-by: Anton Blanchard <anton@samba.org> Tested-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-02powerpc: Remove powerpc specific cmd_lineAnton Blanchard
There is no need for yet another copy of the command line, just use boot_command_line like everyone else. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-04-07powerpc: Make boot_cpuid common between 32 and 64-bitBenjamin Herrenschmidt
Move the definition to setup-common.c and set the init value to -1 on both 32 and 64-bit (it was 0 on 64-bit). Additionally add a check to prom.c to garantee that the init value has been udpated after the DT scan. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-02-11powerpc/ppc32: Fix the bug in the init of non-base exception stack for UPKevin Hao
We would allocate one specific exception stack for each kind of non-base exceptions for every CPU. For ppc32 the CPU hard ID is used as the subscript to get the specific exception stack for one CPU. But for an UP kernel, there is only one element in the each kind of exception stack array. We would get stuck if the CPU hard ID is not equal to '0'. So in this case we should use the subscript '0' no matter what the CPU hard ID is. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-26powerpc: Clean up panic_timeout usageJason Baron
Default CONFIG_PANIC_TIMEOUT to 180 seconds on powerpc. The pSeries continue to set the timeout to 10 seconds at run-time. Thus, there's a small window where we don't have the correct value on pSeries, but if this is only run-time discoverable we don't have a better option. In any case, if the user changes the default setting of 180 seconds, we honor that user setting. Signed-off-by: Jason Baron <jbaron@akamai.com> Cc: benh@kernel.crashing.org Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: mpe@ellerman.id.au Cc: felipe.contreras@gmail.com Cc: linuxppc-dev@lists.ozlabs.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/705bbe0f70fb20759151642ba0176a6414ec9f7a.1385418410.git.jbaron@akamai.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-30powerpc: Move local setup.h declarations to arch includesRobert Jennings
Move the few declarations from arch/powerpc/kernel/setup.h into arch/powerpc/include/asm/setup.h. This resolves a sparse warning for arch/powerpc/mm/numa.c which defines do_init_bootmem() but can't include the setup.h header in the prior path. Resolves: arch/powerpc/mm/numa.c:998:13: warning: symbol 'do_init_bootmem' was not declared. Should it be static? Signed-off-by: Robert C Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-07powerpc/85xx: Move ePAPR paravirt initialization earlierLaurentiu TUDOR
At console init, when the kernel tries to flush the log buffer the ePAPR byte-channel based console write fails silently, losing the buffered messages. This happens because The ePAPR para-virtualization init isn't done early enough so that the hcall instruction to be set, causing the byte-channel write hcall to be a nop. To fix, change the ePAPR para-virt init to use early device tree functions and move it in early init. Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-07-11powerpc/watchdog: move booke watchdog param related code to setup-common.cShaohui Xie
Currently, BOOKE watchdog code for checking "wdt" and "wdt_period" is in setup_32.c, it cannot be used in 64-bit, so move it to a common place setup-common.c, which will be shared by 32-bit and 64-bit. Also, replace the simple_strtoul with kstrtol. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-04-19powerpc: fix build when CONFIG_BOOKE_WDT is enabledBaruch Siach
Commit ae3a197e (Disintegrate asm/system.h for PowerPC) broke build of assembly files when CONFIG_BOOKE_WDT is enabled as follows: AS arch/powerpc/lib/string.o /home/baruch/git/stable/arch/powerpc/include/asm/reg_booke.h: Assembler messages: /home/baruch/git/stable/arch/powerpc/include/asm/reg_booke.h:19: Error: Unrecognized opcode: `extern' /home/baruch/git/stable/arch/powerpc/include/asm/reg_booke.h:20: Error: Unrecognized opcode: `extern' Since setup_32.c is the only user of the booke_wdt configuration variables, move the declarations there. Cc: David Howells <dhowells@redhat.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-28Disintegrate asm/system.h for PowerPCDavid Howells
Disintegrate asm/system.h for PowerPC. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> cc: linuxppc-dev@lists.ozlabs.org
2011-11-16powerpc: Copy down exception vectors after feature fixupsAnton Blanchard
kdump fails because we try to execute an HV only instruction. Feature fixups are being applied after we copy the exception vectors down to 0 so they miss out on any updates. We have always had this issue but it only became critical in v3.0 when we added CFAR support (breaks POWER5) and v3.1 when we added POWERNV (breaks everyone). Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> [v3.0+] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-09-20powerpc/32: Pass device tree address as u64 to machine_initScott Wood
u64 is used rather than phys_addr_t to keep things simple, as this is called from assembly code. Update callers to pass a 64-bit address in r3/r4. Other unused register assignments that were once parameters to machine_init are dropped. For FSL BookE, look up the physical address of the device tree from the effective address passed in r3 by the loader. This is required for situations where memory does not start at zero (due to AMP or IOMMU-less virtualization), and thus the IMA doesn't start at zero, and thus the device tree effective address does not equal the physical address. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-22Merge remote-tracking branch 'jwb/next' into nextBenjamin Herrenschmidt
2011-07-19powerpc: Exporting boot_cpuid_physAndrew Gabbasov
Kernel loadable module can use hard_smp_processor_id() if building with SMP kernel. In order to make it work for UP kernels too, boot_cpuid_phys symbol (which is what hard_smp_processor_id() macro resolves to in non-SMP configuration) must be exported. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-12powerpc/44x: don't use tlbivax on AMP systemsDave Kleikamp
Since other OS's may be running on the other cores don't use tlbivax Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2011-06-17powerpc: Fix early boot accounting of CPUsMatt Evans
smp_release_cpus() waits for all cpus (including the bootcpu) due to an off-by-one count on boot_cpu_count (which is all CPUs). This patch replaces that with spinning_secondaries (which is all secondary CPUs). Signed-off-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc: Properly handshake CPUs going out of boot spin loopBenjamin Herrenschmidt
We need to wait a bit for them to have done their CPU setup or we might end up with translation and EE on with different LPCR values between threads Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-10-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (71 commits) powerpc/44x: Update ppc44x_defconfig powerpc/watchdog: Make default timeout for Book-E watchdog a Kconfig option fsl_rio: Add comments for sRIO registers. powerpc/fsl-booke: Add e55xx (64-bit) smp defconfig powerpc/fsl-booke: Add p5020 DS board support powerpc/fsl-booke64: Use TLB CAMs to cover linear mapping on FSL 64-bit chips powerpc/fsl-booke: Add support for FSL Arch v1.0 MMU in setup_page_sizes powerpc/fsl-booke: Add support for FSL 64-bit e5500 core powerpc/85xx: add cache-sram support powerpc/85xx: add ngPIXIS FPGA device tree node to the P1022DS board powerpc: Fix compile error with paca code on ppc64e powerpc/fsl-booke: Add p3041 DS board support oprofile/fsl emb: Don't set MSR[PMM] until after clearing the interrupt. powerpc/fsl-booke: Add PCI device ids for P2040/P3041/P5010/P5020 QoirQ chips powerpc/mpc8xxx_gpio: Add support for 'qoriq-gpio' controllers powerpc/fsl_booke: Add support to boot from core other than 0 powerpc/p1022: Add probing for individual DMA channels powerpc/fsl_soc: Search all global-utilities nodes for rstccr powerpc: Fix invalid page flags in create TLB CAM path for PTE_64BIT powerpc/mpc83xx: Support for MPC8308 P1M board ... Fix up conflict with the generic irq_work changes in arch/powerpc/kernel/time.c
2010-10-14powerpc/fsl_booke: Add support to boot from core other than 0Matthew McClintock
First we check to see if we are the first core booting up. This is accomplished by comparing the boot_cpuid with -1, if it is we assume this is the first core coming up. Secondly, we need to update the initial thread info structure to reflect the actual cpu we are running on otherwise smp_processor_id() and related functions will return the default initialization value of the struct or 0. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-31Merge commit 'v2.6.36-rc3' into x86/memblockIngo Molnar
Conflicts: arch/x86/kernel/trampoline.c mm/memblock.c Merge reason: Resolve the conflicts, update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-23powerpc/4xx: Index interrupt stacks by physical cpuDave Kleikamp
The interrupt stacks need to be indexed by the physical cpu since the critical, debug and machine check handlers use the contents of SPRN_PIR to index the critirq_ctx, dbgirq_ctx, and mcheckirq_ctx arrays. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-08-05memblock: Introduce default allocation limit and use it to replace explicit onesBenjamin Herrenschmidt
This introduce memblock.current_limit which is used to limit allocations from memblock_alloc() or memblock_alloc_base(..., MEMBLOCK_ALLOC_ACCESSIBLE). The old MEMBLOCK_ALLOC_ANYWHERE changes value from 0 to ~(u64)0 and can still be used with memblock_alloc_base() to allocate really anywhere. It is -no-longer- cropped to MEMBLOCK_REAL_LIMIT which disappears. Note to archs: I'm leaving the default limit to MEMBLOCK_ALLOC_ANYWHERE. I strongly recommend that you ensure that you set an appropriate limit during boot in order to guarantee that an memblock_alloc() at any time results in something that is accessible with a simple __va(). The reason is that a subsequent patch will introduce the ability for the array to resize itself by reallocating itself. The MEMBLOCK core will honor the current limit when performing those allocations. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-15powerpc: Unconditionally enabled irq stacksChristoph Hellwig
Irq stacks provide an essential protection from stack overflows through external interrupts, at the cost of two additionals stacks per CPU. Enable them unconditionally to simplify the kernel build and prevent people from accidentally disabling them. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-03-19powerpc: Fix swiotlb to respect the boot optionFUJITA Tomonori
powerpc initializes swiotlb before parsing the kernel boot options so swiotlb options (e.g. specifying the swiotlb buffer size) are ignored. Any time before freeing bootmem works for swiotlb so this patch moves powerpc's swiotlb initialization after parsing the kernel boot options, mem_init (as x86 does). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Albert Herranz <albert_herranz@yahoo.es> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-10swiotlb: Defer swiotlb init printing, export swiotlb_print_info()FUJITA Tomonori
This enables us to avoid printing swiotlb memory info when we initialize swiotlb. After swiotlb initialization, we could find that we don't need swiotlb. This patch removes the code to print swiotlb memory info in swiotlb_init() and exports the function to do that. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com Cc: tony.luck@intel.com Cc: benh@kernel.crashing.org LKML-Reference: <1257849980-22640-9-git-send-email-fujita.tomonori@lab.ntt.co.jp> [ -v2: merge up conflict ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-11powerpc/nvram: Enable use Generic NVRAM driver for different size chipsMartyn Welch
Remove the reliance on a staticly defined NVRAM size, allowing platforms to support NVRAMs with sizes differing from the standard. A fall back value is provided for platforms not supporting this extension. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc: Add irqtrace support for 32-bit powerpcBenjamin Herrenschmidt
Based on initial work from: Dale Farnsworth <dale@farnsworth.org> Add the low level irq tracing hooks for 32-bit powerpc needed to enable full lockdep functionality. The approach taken to deal with the code in entry_32.S is that we don't trace all the transitions of MSR:EE when we just turn it off to peek at TI_FLAGS without races. Only when we are calling into C code or returning from exceptions with a state that have changed from what lockdep thinks. There's a little bugger though: If we take an exception that keeps interrupts enabled (such as an alignment exception) while interrupts are enabled, we will call trace_hardirqs_on() on the way back spurriously. Not a big deal, but to get rid of it would require remembering in pt_regs that the exception was one of the type that kept interrupts enabled which we don't know at this stage. (Well, we could test all cases for regs->trap but that sucks too much). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-09powerpc: Add support for swiotlb on 32-bitBecky Bruce
This patch includes the basic infrastructure to use swiotlb bounce buffering on 32-bit powerpc. It is not yet enabled on any platforms. Probably the most interesting bit is the addition of addr_needs_map to dma_ops - we need this as a dma_op because the decision of whether or not an addr can be mapped by a device is device-specific. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-23powerpc/32: Wire up the trampoline code for kdumpDale Farnsworth
Wire up the trampoline code for ppc32 to relay exceptions from the vectors at address 0 to vectors at address 32MB, and modify Kconfig to enable Kdump support for all classic powerpcs. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-21powerpc/mm: Runtime allocation of mmu context maps for nohash CPUsBenjamin Herrenschmidt
This makes the MMU context code used for CPUs with no hash table (except 603) dynamically allocate the various maps used to track the state of contexts. Only the main free map and CPU 0 stale map are allocated at boot time. Other CPU maps are allocated when those CPUs are brought up and freed if they are unplugged. This also moves the initialization of the MMU context management slightly later during the boot process, which should be fine as it's really only needed when userland if first started anyways. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-21powerpc/mm: Introduce MMU featuresBenjamin Herrenschmidt
We're soon running out of CPU features and I need to add some new ones for various MMU related bits, so this patch separates the MMU features from the CPU features. I moved over the 32-bit MMU related ones, added base features for MMU type families, but didn't move over any 64-bit only feature yet. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-16powerpc: Move smp_hw_index to 32-bit codeNathan Lynch
smp_hw_index isn't used on 64-bit, so move it from smp.c to setup_32.c. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-16powerpc: Remove `have_of' global variableAnton Vorontsov
The `have_of' variable is a relic from the arch/ppc time, it isn't useful nowadays. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-14powerpc: Reflect the used arguments in machine_init() prototypeSebastian Andrzej Siewior
The "phys" argument to machine_init() isn't used and isn't likely to ever be so let's remove it. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-08-20powerpc: Expose PMCs & cache topology in sysfs on 32-bitBenjamin Herrenschmidt
The file arch/powerpc/kernel/sysfs.c is currently only compiled for 64-bit kernels. It contain code to register CPU sysdevs in sysfs and add various properties such as cache topology and raw access by root to performance monitor counters (PMCs). A lot of that can be re-used as is on 32-bits. This makes the file be built for both, with appropriate ifdef'ing for the few bits that are really 64-bit specific, and adds some support for the raw PMCs for 75x and 74xx processors. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-23kgdb, powerpc: arch specific powerpc kgdb supportJason Wessel
This patch removes the old kgdb reminants from ARCH=powerpc and implements the new style arch specific stub for the common kgdb core interface. It is possible to have xmon and kgdb in the same kernel, but you cannot use both at the same time because there is only one set of debug hooks. The arch specific kgdb implementation saves the previous state of the debug hooks and restores them if you unconfigure the kgdb I/O driver. Kgdb should have no impact on a kernel that has no kgdb I/O driver configured. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-07-15Merge commit '85082fd7cbe3173198aac0eb5e85ab1edcc6352c' into test-buildBenjamin Herrenschmidt
Manual fixup of: arch/powerpc/Kconfig
2008-07-03powerpc: Fixup lwsync at runtimeKumar Gala
To allow for a single kernel image on e500 v1/v2/mc we need to fixup lwsync at runtime. On e500v1/v2 lwsync causes an illop so we need to patch up the code. We default to 'sync' since that is always safe and if the cpu is capable we will replace 'sync' with 'lwsync'. We introduce CPU_FTR_LWSYNC as a way to determine at runtime if this is needed. This flag could be moved elsewhere since we dont really use it for the normal CPU_FTR purpose. Finally we only store the relative offset in the fixup section to keep it as small as possible rather than using a full fixup_entry. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-26powerpc/85xx: add DOZE/NAP support for e500 coreKumar Gala
The e500 core enter DOZE/NAP power-saving modes when the core go to cpu_idle routine. The power management default running mode is DOZE, If the user echo 1 > /proc/sys/kernel/powersave-nap the system will change to NAP running mode. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-02[POWERPC] Move to runtime allocated exception stacksKumar Gala
For the additonal exception levels (critical, debug, machine check) on 40x/book-e we were using "static" allocations of the stack in the associated head.S. Move to a runtime allocation to make the code a bit easier to read as we mimic how we handle IRQ stacks. Its also a bit easier to setup the stack with a "dummy" thread_info in C code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Paul Mackerras <paulus@samba.org>
2008-05-26ftrace: powerpc clean upsSteven Rostedt
This patch cleans up the ftrace code in PowerPC based on the comments from Michael Ellerman. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: proski@gnu.org Cc: a.p.zijlstra@chello.nl Cc: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linuxppc-dev@ozlabs.org Cc: Soeren Sandmann Pedersen <sandmann@redhat.com> Cc: paulus@samba.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: support for PowerPCSteven Rostedt
This patch adds full support for ftrace for PowerPC (both 64 and 32 bit). This includes dynamic tracing and function filtering. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-29[POWERPC] Add IRQSTACKS support on ppc32Kumar Gala
This makes it possible to use separate stacks for hard and soft IRQs on 32-bit powerpc as well as on 64-bit. The code for 32-bit is just the 32-bit analog of the 64-bit code. * Added allocation and initialization of the irq stacks. We limit the stacks to be in lowmem for ppc32. * Implemented ppc32 versions of call_do_softirq() and call_handle_irq() to switch the stack pointers * Reworked how we do stack overflow detection. We now keep around the limit of the stack in the thread_struct and compare against the limit to see if we've overflowed. We can now use this on ppc64 if desired. [ paulus@samba.org: Fixed bug on 6xx where we need to reload r9 with the thread_info pointer. ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-18ppc: remove ppc_ide_mdBartlomiej Zolnierkiewicz
* Add special cases for pplus and prep to ide_default_{irq,io_base}() (+ FIXMEs about the need to use IDE platform host driver instead). * Remove no longer needed ppc_ide_md and struct ide_machdep_calls. * Then remove <linux/ide.h> include from: - arch/powerpc/kernel/setup_32.c - arch/ppc/kernel/ppc_ksyms.c - arch/ppc/kernel/setup.c - arch/ppc/platforms/pplus.c - arch/ppc/platforms/prep_setup.c There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
