This patch adds full support for ftrace for PowerPC (both 64 and 32 bit).
This includes dynamic tracing and function filtering.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
This moves lockdep_init() to before udbg_early_init() as the later
can call things that acquire spinlocks etc... This also makes printk
safer to use earlier.
When debugging early boot problems, it's common to sprinkle printk's
all over the place. However, on 64-bit powerpc, this can lead to
memory corruption if done too early due to the PACA pointer and
lockdep core not being initialized.
This adds some comments to early_setup() that document when it is
safe to do so in order to save time for whoever has to debug that
stuff next.
The current_thread_info() macro, used by preempt_count(), assumes the
base address and size of the stack are THREAD_SIZE aligned.
The emergency stack currently isn't either of these things, which
could potentially cause problems anytime we're running on the
emergency stack. That includes when we detect a bad kernel stack
pointer, and also during early_setup_secondary().
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
This adds the required functionality to fill in all pacas at runtime.
With NR_CPUS=1024
137 1704032 0 1704169 1a00e9 arch/powerpc/kernel/paca.o :Before
121 1179744 524288 1704153 1a00d9 arch/powerpc/kernel/paca.o :After
Also remove unneeded #includes from arch/powerpc/kernel/paca.c
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Added support to allow an 85xx kernel to be run from a non-zero physical
address (useful for cooperative asymmetric multiprocessing situations and
kdump). The support can be configured at compile time by setting
CONFIG_PAGE_OFFSET, CONFIG_KERNEL_START, and CONFIG_PHYSICAL_START as
desired.
Alternatively, the kernel build can set CONFIG_RELOCATABLE. Setting this
config option causes the kernel to determine at runtime the physical
addresses of CONFIG_PAGE_OFFSET and CONFIG_KERNEL_START. If
CONFIG_RELOCATABLE is set, then CONFIG_PHYSICAL_START has no meaning.
However, CONFIG_PHYSICAL_START will always be used to set the LOAD program
header physical address field in the resulting ELF image.
Currently we are limited to running at a physical address that is a
multiple of 256M. This is due to how we map TLBs to cover
lowmem. This should be fixed to allow 64M or maybe even 16M alignment
in the future. It is considered an error to try and run a kernel at a
non-aligned physical address.
All the magic for this support is accomplished by proper initialization
of the kernel memory subsystem and use of ARCH_PFN_OFFSET.
The use of ARCH_PFN_OFFSET only affects normal memory and not IO mappings.
ioremap uses map_page and isn't affected by ARCH_PFN_OFFSET.
/dev/mem continues to allow access to any physical address in the system
regardless of how CONFIG_PHYSICAL_START is set.
This adds the low level irq tracing hooks to the powerpc architecture
needed to enable full lockdep functionality.
This is partly based on Johannes Berg's initial version. I removed
the asm trampoline that isn't needed (thus improving performance) and
modified all sorts of bits and pieces, reworking most of the assembly,
etc...
* PAGE_OFFSET is not always the start of code, use _stext instead.
* grab PAGE_SIZE and KERNELBASE from asm/page.h like ppc64 does. Makes the
code a bit more common and provide a single place to manipulate the
defines for things like kdump.
We had an historical confusion in the kernel between cache line
and cache block size. The former is an implementation detail of
the L1 cache which can be useful for performance optimisations,
the later is the actual size on which the cache control
instructions operate, which can be different.
For some reason, we had a weird hack reading the right property
on powermac and the wrong one on any other 64 bits (32 bits is
unaffected as it only uses the cputable for cache block size
infos at this stage).
This fixes the booting-without-of.txt documentation to mention
the right properties, and fixes the 64 bits initialization code
to look for the block size first, with a fallback to the line
size if the property is missing.
After 6 years the ppc64 kernel still thinks its important to tell me my
cache line size is 0x80 bytes. I think most people who care know that by
now. The rest probably cant even understand the hex output.
Since we might have misconfigured firmware or cpus that have a linesize
that isnt 128 bytes, I still print it out for those cases. If people
would prefer to remove it completely, lets do it.
Also for lpar remove the htab_address printout since its not used.
Anton
ppc64 boot log usability expert
Convert cpu_sibling_map from a static array sized by NR_CPUS to a per_cpu
variable. This saves sizeof(cpumask_t) * NR unused cpus. Access is mostly
from startup and CPU HOTPLUG functions.
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
This allows platforms which don't have anything to do at setup_arch time
(like a bunch of the 4xx platforms) to eliminate an empty setup_arch hook.
Grammatical corrections to comments.
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
This reverts commit 5a26f6bbb767d7ad23311a1e81cfdd2bebefb855.
The original patch causes boot failures when built with ppc64_defconfig. The
quickest fix is to revert it while alterates are investigated.
On pSeries the firmware features are not setup until ppc_md.init_early,
so we can't do the firmware feature sections fixups till after this.
Currently firmware feature sections is only used on iSeries which inits
the firmware features much earlier. This is a bug in waiting on
pSeries.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and
Ingo suggested KVM as well).
Because larger alignments can use more room, we increase the max per-cpu
memory to 64k rather than 32k: it's getting a little tight.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Remove unneeded inclusion of linux/ide.h
It does not compile with CONFIG_BLOCK=n.
Remove asm/ide.h from ksyms file, it gets included earlier via
linux/ide.h.
Compile tested with all defconfig files.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
This adds code to look at the properties firmware puts in the device
tree to determine what compatibility mode the partition is in on
POWER6 machines, and set the ELF aux vector AT_HWCAP and AT_PLATFORM
entries appropriately.
Specifically, we look at the cpu-version property in the cpu node(s).
If that contains a "logical" PVR value (of the form 0x0f00000x), we
call identify_cpu again with this PVR value. A value of 0x0f000001
indicates the partition is in POWER5+ compatibility mode, and a value
of 0x0f000002 indicates "POWER6 architected" mode, with various
extensions disabled. We also look for various other properties:
ibm,dfp, ibm,purr and ibm,spurr.
This patch reworks the way iSeries hooks on PCI IO operations (both MMIO
and PIO) and provides a generic way for other platforms to do so (we
have need to do that for various other platforms).
While reworking the IO ops, I ended up doing some spring cleaning in
io.h and eeh.h which I might want to split into 2 or 3 patches (among
others, eeh.h had a lot of useless stuff in it).
A side effect is that EEH for PIO should work now (it used to pass IO
ports down to the eeh address check functions which is bogus).
Also, new are MMIO "repeat" ops, which other archs like ARM already had,
and that we have too now: readsb, readsw, readsl, writesb, writesw,
writesl.
In the long run, I might also make EEH use the hooks instead
of wrapping at the toplevel, which would make things even cleaner and
relegate EEH completely in platforms/iseries, but we have to measure the
performance impact there (though it's really only on MMIO reads)
Since I also need to hook on ioremap, I shuffled the functions a bit
there. I introduced ioremap_flags() to use by drivers who want to pass
explicit flags to ioremap (and it can be hooked). The old __ioremap() is
still there as a low level and cannot be hooked, thus drivers who use it
should migrate unless they know they want the low level version.
The patch "arch provides generic iomap missing accessors" (should be
number 4 in this series) is a pre-requisite to provide full iomap
API support with this patch.
This patch completely refactors DMA operations for 64 bits powerpc. 32 bits
is untouched for now.
We use the new dev_archdata structure to add the dma operations pointer
and associated data to struct device. While at it, we also add the OF node
pointer and numa node. In the future, we might want to look into merging
that with pci_dn as well.
The old vio, pci-iommu and pci-direct DMA ops are gone. They are now replaced
by a set of generic iommu and direct DMA ops (non PCI specific) that can be
used by bus types. The toplevel implementation is now inline.
Add a check for a null ppc_md.init_early to allow platforms that
don't require an init_early routine to just set this member to null.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
dev_t boot_dev is declared in arch/powerpc/kernel/setup_32.c
and in arch/powerpc/kernel/setup_64.c but not used in these files.
It is only used in arch/powerpc/platforms/powermac/setup.c, so make
it static in this file.
This patch reworks the feature fixup mecanism so vdso's can be fixed up.
The main issue was that the construct:
.long label (or .llong on 64 bits)
will not work in the case of a shared library like the vdso. It will
generate an empty placeholder in the fixup table along with a reloc,
which is not something we can deal with in the vdso.
The idea here (thanks Alan Modra !) is to instead use something like:
1:
.long label - 1b
That is, the feature fixup tables no longer contain addresses of bits of
code to patch, but offsets of such code from the fixup table entry
itself. That is properly resolved by ld when building the .so's. I've
modified the fixup mecanism generically to use that method for the rest
of the kernel as well.
Another trick is that the 32 bits vDSO included in the 64 bits kernel
need to have a table in the 64 bits format. However, gas does not
support 32 bits code with a statement of the form:
.llong label - 1b (Or even just .llong label)
That is, it cannot emit the right fixup/relocation for the linker to use
to assign a 32 bits address to an .llong field. Thus, in the specific
case of the 32 bits vdso built as part of the 64 bits kernel, we are
using a modified macro that generates:
.long 0xffffffff
.llong label - 1b
Note that is assumes that the value is negative which is enforced by
the .lds (those offsets are always negative as the .text is always
before the fixup table and gas doesn't support emiting the reloc the
other way around).
There are currently two versions of the functions for applying the
feature fixups, one for CPU features and one for firmware features. In
addition, they are both in assembly and with separate implementations
for 32 and 64 bits. identify_cpu() is also implemented in assembly and
separately for 32 and 64 bits.
This patch replaces them with a pair of C functions. The call sites are
slightly moved on ppc64 as well to be called from C instead of from
assembly, though it's a very small change, and thus shouldn't cause any
problem.
Acked-by: Olof Johansson <olof@lixom.net>
This implements a lazy strategy for disabling interrupts. This means
that local_irq_disable() et al. just clear the 'interrupts are
enabled' flag in the paca. If an interrupt comes along, the interrupt
entry code notices that interrupts are supposed to be disabled, and
clears the EE bit in SRR1, clears the 'interrupts are hard-enabled'
flag in the paca, and returns. This means that interrupts only
actually get disabled in the processor when an interrupt comes along.
When interrupts are enabled by local_irq_enable() et al., the code
sets the interrupts-enabled flag in the paca, and then checks whether
interrupts got hard-disabled. If so, it also sets the EE bit in the
MSR to hard-enable the interrupts.
This has the potential to improve performance, and also makes it
easier to make a kernel that can boot on iSeries and on other 64-bit
machines, since this lazy-disable strategy is very similar to the
soft-disable strategy that iSeries already uses.
This version renames paca->proc_enabled to paca->soft_enabled, and
changes a couple of soft-disables in the kexec code to hard-disables,
which should fix the crash that Michael Ellerman saw. This doesn't
yet use a reserved CR field for the soft_enabled and hard_enabled
flags. This applies on top of Stephen Rothwell's patches to make it
possible to build a combined iSeries/other kernel.
My patch to make the early xmon logic work with earlier early param
parsing (480f6f35a149802a94ad5c1a2673ed6ec8d2c158) breaks xmon=off.
No one does this obviously as xmon rocks, but it should really work
as documented.
While fixing that it struck me that we could move the xmon param
handling into xmon.c, and also consolidate the
xmon_init()/do_early_xmon logic into xmon_setup(). This means
xmon=early drops into xmon a little earlier on 32-bit, but it
seems to work just fine.
Tested on PSERIES and CLASSIC32.
In some places, particularly drivers and __init code, the init utsns is the
appropriate one to use. This patch replaces those with a the init_utsname
helper.
Changes: Removed several uses of init_utsname(). Hope I picked all the
right ones in net/ipv4/ipconfig.c. These are now changed to
utsname() (the per-process namespace utsname) in the previous
patch (2/7)
[akpm@osdl.org: CIFS fix]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
Cc: Serge Hallyn <serue@us.ibm.com>
Remove unused global SYSRQ_KEY from ppc and powerpc
Remove unused define SYSRQ_KEY from sh/sh64 and h8300
Remove unused pckbd_sysrq_xlate and kbd_sysrq_xlate usage
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Reduce default cacheline size on 64-bit powerpc from 128 bytes to 64.
This is the architected minimum. In most cases we'll still end up using
cache line information from the device tree, but defaults are used during
early boot and doing a few dcbst/icbi's too many there won't do any harm.
Now that get_property() returns a void *, there's no need to cast its
return value. Also, treat the return value as const, so we can
constify get_property later.
powerpc core changes.
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
Move ItLpNaca into platforms/iseries now that it's not used elsewhere.
This adds the new irq remapper core and removes the old one. Because
there are some fundamental conflicts with the old code, like the value
of NO_IRQ which I'm now setting to 0 (as per discussions with Linus),
etc..., this commit also changes the relevant platform and driver code
over to use the new remapper (so as not to cause difficulties later
in bisecting).
This patch removes the old pre-parsing of the open firmware interrupt
tree along with all the bogus assumptions it made to try to renumber
interrupts according to the platform. This is all to be handled by the
new code now.
For the pSeries XICS interrupt controller, a single remapper host is
created for the whole machine regardless of how many interrupt
presentation and source controllers are found, and it's set to match
any device node that isn't a 8259. That works fine on pSeries and
avoids having to deal with some of the complexities of split source
controllers vs. presentation controllers in the pSeries device trees.
The powerpc i8259 PIC driver now always requests the legacy interrupt
range. It also has the feature of being able to match any device node
(including NULL) if passed no device node as an input. That will help
porting over platforms with broken device-trees like Pegasos who don't
have a proper interrupt tree.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
There's a small period early in boot where we don't know which cpu we're
running on. That's ok, except that it means we have no paca, or more
correctly that our paca pointer points somewhere random.
So that we can safely call things like smp_processor_id(), we need a paca,
so just assume we're on cpu 0. No code should _write_ to the paca before
we've set the correct one up.
We setup the proper paca after we've scanned the flat device tree in
early_setup(), so there's no need to do it again in start_here_common.
There's no need to set the boot cpu paca in asm, so do it in C so us
mere mortals can understand it.
There's no reason kexec_setup() needs to be called explicitly from
setup_system(), it can just be a regular initcall.
Initialise the ppc_md htab callbacks earlier, in the probe routines. This
allows us to call htab_finish_init() from htab_initialize(), and makes it
private to hash_utils_64.c. Move htab_finish_init() and make_bl() above
htab_initialize() to avoid forward declarations.
We need to know the base address of the kdump kernel even when we're not a
kdump kernel, so add a #define for it. Move the logic that sets the kdump
kernelbase into kdump.h instead of page.h.
Rename kdump_setup() to setup_kdump_trampoline() to make it clearer what it's
doing, and add an empty definition for the !CRASH_DUMP case to avoid a
We currently do mem= handling in three seperate places. And as benh pointed out
I wrote two of them. Now that we parse command line parameters earlier we can
clean this mess up.
Moving the parsing out of prom_init means the device tree might be allocated
above the memory limit. If that happens we'd have to move it. As it happens
we already have logic to do that for kdump, so just genericise it.
This also means we might have reserved regions above the memory limit, if we
do the bootmem allocator will blow up, so we have to modify
lmb_enforce_memory_limit() to truncate the reserves as well.
Tested on P5 LPAR, iSeries, F50, 44p. Tested moving device tree on P5 and
44p and F50.
Currently we have call parse_early_param() earliyish, but not really very
early. In particular, it's not early enough to do things like mem=x or
crashkernel=blah, which is annoying.
So do it earlier. I've checked all the early param handlers, and none of them
look like they should have any trouble with this. I haven't tested the
booke_wdt ones though.
On 32-bit we were doing the CONFIG_CMDLINE logic twice, so don't.
Currently early_xmon() calls directly into debugger() if xmon=early is passed.
This ties the invocation of early xmon to the location of parse_early_param(),
which might change.
Tested on P5 LPAR and F50.
Allow boards to provide a panic callback on ppc32. Moved the code to sets
this up into setup-common.c so its shared between ppc32 & ppc64. Also moved
do_init_bootmem prototype into setup.h.
Some people report that we die on some Macs when we are expecting to
catch machine checks after poking at some random I/O address. I'd seen
it happen on my dual G4 with serial ports until we fixed those to use
OF, but now other users are reporting it with i8042.
This expands the use of check_legacy_ioport() to avoid that situation
even on 32-bit kernels.
Since the powerpc 64k pages patch went in, systems that have SLBs
(like Power4 iSeries) needed to have slb_initialize called to set up
some variables for the SLB miss handler. This was not being called
on the boot processor on iSeries, so on single cpu iSeries machines,
we would get apparent memory curruption as soon as we entered user mode.
This patch fixes that by calling slb_initialize on the boot cpu if the
processor has an SLB.
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes
in the past where people were using for_each_cpu() where they should have been
iterating across only online or present CPUs. This is inefficient and
possibly buggy.
We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the
future.
This patch replaces for_each_cpu with for_each_possible_cpu.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This removes statically assigned platform numbers and reworks the
powerpc platform probe code to use a better mechanism. With this,
board support files can simply declare a new machine type with a
macro, and implement a probe() function that uses the flattened
device-tree to detect if they apply for a given machine.
We now have a machine_is() macro that replaces the comparisons of
_machine with the various PLATFORM_* constants. This commit also
changes various drivers to use the new macro instead of looking at
_machine.
