path: root/arch/powerpc/kernel/vector.S
2006-06-15[POWERPC] 64bit FPSCR supportAnton Blanchard
Forthcoming machines will extend the FPSCR to 64 bits. We already had a 64-bit save area for the FPSCR, but we need to use a new form of the mtfsf instruction. Fortunately this new form is decoded as an ordinary mtfsf by existing 64-bit processors. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-10powerpc: Use reg.h instead of processor.h when we just want reg namesPaul Mackerras
Now that the register names and bit definitions are all in reg.h, use that instead of processor.h in assembly code in a few places. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-26powerpc: Merge enough to start building in arch/powerpc.Paul Mackerras
This creates the directory structure under arch/powerpc and a bunch of Kconfig files. It does a first-cut merge of arch/powerpc/mm, arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough to build a 32-bit powermac kernel with ARCH=powerpc. For now we are getting some unmerged files from arch/ppc/kernel and arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes to files in those directories and files outside arch/powerpc. The boot directory is still not merged. That's going to be interesting. Signed-off-by: Paul Mackerras <paulus@samba.org>
