Return the actual host SVR for now, as we already do for PVR. Eventually
we may support Qemu overriding PVR/SVR if the situation is appropriate,
once we implement KVM_SET_SREGS on e500.
The VCPU uninit calls some TLB functions, and the TLB uninit function
frees the memory used by them.
Acked-by: Liu Yu <yu.liu@freescale.com>
For transparent variable sharing between the hypervisor and guest, I introduce
a shared page. This shared page will contain all the registers the guest can
read and write safely without exiting guest context.
This patch only implements the stubs required for the basic structure of the
shared page. The actual register moving follows.
Signed-off-by: Avi Kivity <avi@redhat.com>
kvmppc_e500_exit() is a module_exit function, so it should be tagged
with __exit, not __init. The incorrect annotation was added by commit
2986b8c72c272ea58edd37903b042c6da985627d.
Cc: stable@kernel.org
vmx and svm vcpus have different contents and therefore may have different
alignmment requirements. Let each specify its required alignment.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
commit 513579e3a391a3874c478a8493080822069976e8 change the way
we emulate PVR/PIR,
which left PVR/PIR uninitialized on E500, and make guest puzzled.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
Acked-by: Alexander Graf <agraf@suse.de>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Fixes a couple of warnings like this one:
WARNING: arch/powerpc/kvm/kvm-440.o(.text+0x1e8c): Section mismatch in reference from the function kvmppc_44x_exit() to the function .exit.text:kvmppc_booke_exit()
The function kvmppc_44x_exit() references a function in an exit section.
Often the function kvmppc_booke_exit() has valid usage outside the exit section
and the fix is to remove the __exit annotation of kvmppc_booke_exit.
Also add some __init annotations on obvious routines.
e500 has additional interrupt vectors (and corresponding IVORs) for SPE and
performance monitoring interrupts.
Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com>
