path: root/arch/powerpc/lib/crtsavres.S
2010-07-08powerpc: Fix module building for gcc 4.5 and 64 bitStephen Rothwell
Gcc 4.5 is now generating out of line register save and restore in the function prefix and postfix when we use -Os. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-06-16[POWERPC] Fix -Os kernel builds with newer gcc versionsKumar Gala
GCC 4.4.x looks to be adding support for generating out-of-line register saves/restores based on: http://gcc.gnu.org/ml/gcc-patches/2008-04/msg01678.html This breaks the kernel if we enable CONFIG_CC_OPTIMIZE_FOR_SIZE. To fix this we add the use the save/restore code from gcc and simplified it down for our needs (integer only). Additionally, we have to link this code into each module. The other solution was to add EXPORT_SYMBOL() which meant going through the trampoline which seemed nonsensical for these out-of-line routines. Finally, we add some checks to prom_init_check.sh to ignore the out-of-line save/restore functions. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
