commit a11940978bd598e65996b4f807cf4904793f7025 upstream.
If we echo an address the hypervisor doesn't like to
/sys/devices/system/memory/probe we oops the box:
# echo 0x10000000000 > /sys/devices/system/memory/probe
kernel BUG at arch/powerpc/mm/hash_utils_64.c:541!
The backtrace is:
create_section_mapping
arch_add_memory
add_memory
memory_probe_store
sysdev_class_store
sysfs_write_file
vfs_write
SyS_write
In create_section_mapping we BUG if htab_bolt_mapping returned
an error. A better approach is to return an error which will
propagate back to userspace.
Rerunning the test with this patch applied:
-bash: echo: write error: Invalid argument
When using 64K pages with a separate cpio rootfs, U-Boot will align
the rootfs on a 4K page boundary. When the memory is reserved, and
subsequent early memblock_alloc is called, it will allocate memory
between the 64K page alignment and reserved memory. When the reserved
memory is subsequently freed, it is done so by pages, causing the
early memblock_alloc requests to be re-used, which in my case, caused
the device-tree to be clobbered.
This patch forces the reserved memory for initrd to be kernel page
aligned, and will move the device tree if it overlaps with the range
extension of initrd. This patch will also consolidate the identical
function free_initrd_mem() from mm/init_32.c, init_64.c to mm/mem.c,
and adds the same range extension when freeing initrd. free_initrd_mem()
is also moved to the __init section.
Many thanks to Milton Miller for his input on this patch.
[BenH: Fixed build without CONFIG_BLK_DEV_INITRD]
Signed-off-by: Dave Carroll <dcarroll@astekcorp.com>
We need to round memory regions correctly -- specifically, we need to
round reserved region in the more expansive direction (lower limit
down, upper limit up) whereas usable memory regions need to be rounded
in the more restrictive direction (lower limit up, upper limit down).
This introduces two set of inlines:
memblock_region_memory_base_pfn()
memblock_region_memory_end_pfn()
memblock_region_reserved_base_pfn()
memblock_region_reserved_end_pfn()
Although they are antisymmetric (and therefore are technically
duplicates) the use of the different inlines explicitly documents the
programmer's intention.
The lack of proper rounding caused a bug on ARM, which was then found
to also affect other architectures.
Reported-by: Russell King <rmk@arm.linux.org.uk>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4CB4CDFD.4020105@kernel.org>
Right now, both the "memory" and "reserved" memblock_type structures have
a "size" member. It represents the calculated memory size in the former
case and is unused in the latter.
This moves it out to the main memblock structure instead
memblock_region
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
powerpc initializes swiotlb before parsing the kernel boot options so
swiotlb options (e.g. specifying the swiotlb buffer size) are ignored.
Any time before freeing bootmem works for swiotlb so this patch moves
powerpc's swiotlb initialization after parsing the kernel boot
options, mem_init (as x86 does).
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Tested-by: Becky Bruce <beckyb@kernel.crashing.org>
Tested-by: Albert Herranz <albert_herranz@yahoo.es>
On VIVT ARM, when we have multiple shared mappings of the same file
in the same MM, we need to ensure that we have coherency across all
copies. We do this via make_coherent() by making the pages
uncacheable.
This used to work fine, until we allowed highmem with highpte - we
now have a page table which is mapped as required, and is not available
for modification via update_mmu_cache().
Ralf Beache suggested getting rid of the PTE value passed to
update_mmu_cache():
On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables
to construct a pointer to the pte again. Passing a pte_t * is much
more elegant. Maybe we might even replace the pte argument with the
pte_t?
Ben Herrenschmidt would also like the pte pointer for PowerPC:
Passing the ptep in there is exactly what I want. I want that
-instead- of the PTE value, because I have issue on some ppc cases,
for I$/D$ coherency, where set_pte_at() may decide to mask out the
_PAGE_EXEC.
So, pass in the mapped page table pointer into update_mmu_cache(), and
remove the PTE value, updating all implementations and call sites to
suit.
Includes a fix from Stephen Rothwell:
sparc: fix fallout from update_mmu_cache API change
accessors
The hugepage arch code provides a number of hook functions/macros
which mirror the functionality of various normal page pte access
functions. Various changes in the normal page accessors (in
particular BenH's recent changes to the handling of lazy icache
flushing and PAGE_EXEC) have caused the hugepage versions to get out
of sync with the originals. In some cases, this is a bug, at least on
some MMU types.
One of the reasons that some hooks were not identical to the normal
page versions, is that the fact we're dealing with a hugepage needed
to be passed down do use the correct dcache-icache flush function.
This patch makes the main flush_dcache_icache_page() function hugepage
aware (by checking for the PageCompound flag). That in turn means we
can make set_huge_pte_at() just a call to set_pte_at() bringing it
back into sync. As a bonus, this lets us remove the
hash_huge_page_do_lazy_icache() function, replacing it with a call to
the hash_page_do_lazy_icache() function it was based on.
Some other hugepage pte access hooks - huge_ptep_get_and_clear() and
huge_ptep_clear_flush() - are not so easily unified, but this patch at
least brings them back into sync with the current versions of the
corresponding normal page functions.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
Originally, walk_memory_resource() was introduced to traverse all memory
of "System RAM" for detecting memory hotplug/unplug range. For doing so,
flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for
memory hotplug.
But for using other purpose, /proc/kcore, this may includes some firmware
area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the
check strict to find out busy "System RAM".
Note: PPC64 keeps their own walk_memory_resouce(), which walk through
ppc64's lmb informaton. Because old kclist_add() is called per lmb, this
patch makes no difference in behavior, finally.
And this patch removes CONFIG_MEMORY_HOTPLUG check from this function.
Because pfn_valid() just show "there is memmap or not* and cannot be used
for "there is physical memory or not", this function is useful in generic
to scan physical memory range.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chris Zankel <zankel@tensilica.com>
The implementation we just revived has issues, such as using a
Kconfig-defined virtual address area in kernel space that nothing
actually carves out (and thus will overlap whatever is there),
or having some dependencies on being self contained in a single
PTE page which adds unnecessary constraints on the kernel virtual
address space.
This fixes it by using more classic PTE accessors and automatically
locating the area for consistent memory, carving an appropriate hole
in the kernel virtual address space, leaving only the size of that
area as a Kconfig option. It also brings some dma-mask related fixes
from the ARM implementation which was almost identical initially but
grew its own fixes.
Make FIXADDR_TOP a compile time constant and cleanup a
couple of definitions relative to the layout of the kernel
address space on ppc32. We also print out that layout at
boot time for debugging purposes.
This is a pre-requisite for properly fixing non-coherent
DMA allocactions.
We're currently choking on mem=4g (and above) due to memory_limit
being specified as an unsigned long. Make memory_limit
phys_addr_t to fix this.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
This patch reworks the way we do I and D cache coherency on PowerPC.
The "old" way was split in 3 different parts depending on the processor type:
- Hash with per-page exec support (64-bit and >= POWER4 only) does it
at hashing time, by preventing exec on unclean pages and cleaning pages
on exec faults.
- Everything without per-page exec support (32-bit hash, 8xx, and
64-bit < POWER4) does it for all page going to user space in update_mmu_cache().
- Embedded with per-page exec support does it from do_page_fault() on
exec faults, in a way similar to what the hash code does.
That leads to confusion, and bugs. For example, the method using update_mmu_cache()
is racy on SMP where another processor can see the new PTE and hash it in before
we have cleaned the cache, and then blow trying to execute. This is hard to hit but
I think it has bitten us in the past.
Also, it's inefficient for embedded where we always end up having to do at least
one more page fault.
This reworks the whole thing by moving the cache sync into two main call sites,
though we keep different behaviours depending on the HW capability. The call
sites are set_pte_at() which is now made out of line, and ptep_set_access_flags()
which joins the former in pgtable.c
The base idea for Embedded with per-page exec support, is that we now do the
flush at set_pte_at() time when coming from an exec fault, which allows us
to avoid the double fault problem completely (we can even improve the situation
more by implementing TLB preload in update_mmu_cache() but that's for later).
If for some reason we didn't do it there and we try to execute, we'll hit
the page fault, which will do a minor fault, which will hit ptep_set_access_flags()
to do things like update _PAGE_ACCESSED or _PAGE_DIRTY if needed, we just make
this guys also perform the I/D cache sync for exec faults now. This second path
is the catch all for things that weren't cleaned at set_pte_at() time.
For cpus without per-pag exec support, we always do the sync at set_pte_at(),
thus guaranteeing that when the PTE is visible to other processors, the cache
is clean.
For the 64-bit hash with per-page exec support case, we keep the old mechanism
for now. I'll look into changing it later, once I've reworked a bit how we
use _PAGE_EXEC.
This is also a first step for adding _PAGE_EXEC support for embedded platforms
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Currently, we never set _PAGE_COHERENT in the PTEs, we just OR it in
in the hash code based on some CPU feature bit. We also manipulate
_PAGE_NO_CACHE and _PAGE_GUARDED by hand in all sorts of places.
This changes the logic so that instead, the PTE now contains
_PAGE_COHERENT for all normal RAM pages thay have I = 0 on platforms
that need it. The hash code clears it if the feature bit is not set.
It also adds some clean accessors to setup various valid combinations
of access flags and change various bits of code to use them instead.
This should help having the PTE actually containing the bit
combinations that we really want.
I also removed _PAGE_GUARDED from _PAGE_BASE on 44x and instead
set it explicitely from the TLB miss. I will ultimately remove it
completely as it appears that it might not be needed after all
but in the meantime, having it in the TLB miss makes things a
lot easier.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This commit moves the whole no-hash TLB handling out of line into a
new tlb_nohash.c file, and implements some basic SMP support using
IPIs and/or broadcast tlbivax instructions.
Note that I'm using local invalidations for D->I cache coherency.
At worst, if another processor is trying to execute the same and
has the old entry in its TLB, it will just take a fault and re-do
the TLB flush locally (it won't re-do the cache flush in any case).
There is nothing architecture specific about remove_memory().
remove_memory() function is common for all architectures which support
hotplug memory remove. Instead of duplicating it in every architecture,
collapse them into arch neutral function.
[akpm@linux-foundation.org: fix the export]
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Gary Hade <garyhade@us.ibm.com>
Commit 8b150478 ("ppc: make phys_mem_access_prot() work with pfns
instead of addresses") fixed page_is_ram() in arch/ppc to avoid overflow
for addresses above 4G on 32-bit kernels. However arch/powerpc's
page_is_ram() is missing the same fix -- it computes a physical address
by doing pfn << PAGE_SHIFT, which overflows if pfn corresponds to a page
above 4G.
In particular this causes pages above 4G to be mapped with the wrong
caching attribute; for example many ppc440-based SoCs have PCI space
above 4G, and mmap()ing MMIO space may end up with a mapping that has
caching enabled.
Fix this by working with the pfn and avoiding the conversion to
physical address that causes the overflow. This patch compares the
pfn to max_pfn, which is a semantic change from the old code -- that
code compared the physical address to high_memory, which corresponds
to max_low_pfn. However, I think that was is another bug, since
highmem pages are still RAM.
Reported-by: vb <vb@vsbe.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Explicitly cast to unsigned long long, rather than u64.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Remove arch-specific show_mem() in favor of the generic version.
This also removes the following redundant information display:
- pages in swapcache, printed by show_swap_cache_info()
where show_mem() calls show_free_areas(), which calls
show_swap_cache_info().
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
This patch enables 32bit PPC's (with 36bit physical address space, e.g.
IBM/AMCC PPC44x) to run with >= 4GB of RAM. Mostly its just replacing types
(unsigned long -> phys_addr_t).
Tested on an AMCC Katmai with 4GB of DDR2.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
SPARSEMEM=n
Currently the kernel fails to build with the above config options with:
CC arch/powerpc/mm/mem.o
arch/powerpc/mm/mem.c: In function 'arch_add_memory':
arch/powerpc/mm/mem.c:130: error: implicit declaration of function 'create_section_mapping'
This explicitly includes asm/sparsemem.h in arch/powerpc/mm/mem.c and
moves the guards in include/asm-powerpc/sparsemem.h to protect the
SPARSEMEM specific portions only.
The ehea driver was recently changed[1] to use walk_memory_resource() to
detect the system's memory layout. However, walk_memory_resource() is
available only when memory hotplug is enabled. So CONFIG_EHEA was
made to depend on MEMORY_HOTPLUG [2], but it is inappropriate for a
network driver to have such a dependency.
Make the declaration of walk_memory_resource() and its powerpc
implementation (ehea is powerpc-specific) unconditionally available.
[1] 48cfb14f8b89d4d5b3df6c16f08b258686fb12ad
"ehea: Add DLPAR memory remove support"
[2] fb7b6ca2b6b7c23b52be143bdd5f55a23b9780c8
"ehea: Add dependency to Kconfig"
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Badari Pulavarty <pbadari@us.ibm.com>
Provide walk_memory_resource() for 64-bit powerpc. PowerPC maintains
logical memory region mapping in the lmb.memory structure. Walk
through these structures and do the callbacks for the contiguous
chunks.
All architectures use an effectively identical definition of online_page(), so
just make it common code. x86-64, ia64, powerpc and sh are actually
identical; x86-32 is slightly different.
x86-32's differences arise because it puts its hotplug pages in the highmem
zone. We can handle this in the generic code by inspecting the page to see if
its in highmem, and update the totalhigh_pages count appropriately. This
leaves init_32.c:free_new_highpage with a single caller, so I folded it into
add_one_highpage_init.
I also removed an incorrect comment referring to the NUMA case; any NUMA
details have already been dealt with by the time online_page() is called.
[akpm@linux-foundation.org: fix indenting]
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com>
Tested-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com>
Cc: Christoph Lameter <clameter@sgi.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
The fixmap code from x86 allows us to have compile time virtual addresses
that we change the physical addresses of at run time.
This is useful for applications like kmap_atomic, PCI config that is done
via direct memory map, kexec/kdump.
We got ride of CONFIG_HIGHMEM_START as we can now determine a more optimal
location for PKMAP_BASE based on where the fixmap addresses start and
working back from there.
Additionally, the kmap code in asm-powerpc/highmem.h always had debug
enabled. Moved to using CONFIG_DEBUG_HIGHMEM to determine if we should
have the extra debug checking.
Added support to allow an 85xx kernel to be run from a non-zero physical
address (useful for cooperative asymmetric multiprocessing situations and
kdump). The support can be configured at compile time by setting
CONFIG_PAGE_OFFSET, CONFIG_KERNEL_START, and CONFIG_PHYSICAL_START as
desired.
Alternatively, the kernel build can set CONFIG_RELOCATABLE. Setting this
config option causes the kernel to determine at runtime the physical
addresses of CONFIG_PAGE_OFFSET and CONFIG_KERNEL_START. If
CONFIG_RELOCATABLE is set, then CONFIG_PHYSICAL_START has no meaning.
However, CONFIG_PHYSICAL_START will always be used to set the LOAD program
header physical address field in the resulting ELF image.
Currently we are limited to running at a physical address that is a
multiple of 256M. This is due to how we map TLBs to cover
lowmem. This should be fixed to allow 64M or maybe even 16M alignment
in the future. It is considered an error to try and run a kernel at a
non-aligned physical address.
All the magic for this support is accomplished by proper initialization
of the kernel memory subsystem and use of ARCH_PFN_OFFSET.
The use of ARCH_PFN_OFFSET only affects normal memory and not IO mappings.
ioremap uses map_page and isn't affected by ARCH_PFN_OFFSET.
/dev/mem continues to allow access to any physical address in the system
regardless of how CONFIG_PHYSICAL_START is set.
total_lowmem represents the amount of low memory, not the physical
address that low memory ends at. If the start of memory is at 0 it
happens that total_lowmem can be used as both the size and the address
that lowmem ends at (or more specifically one byte beyond the end).
To make the code a bit more clear and deal with the case when the start of
memory isn't at physical 0, we introduce lowmem_end_addr that represents
one byte beyond the last physical address in the lowmem region.
show_mem() has no need to print the amount of free swap space manually
because show_free_areas() does this already and is called by the
former.
The two outputs only differ in text formatting:
printk("Free swap = %lukB\n", ...);
printk("Free swap: %6ldkB\n", ...);
WARNING: vmlinux.o(.text+0xb41b0): Section mismatch in reference from the
function .add_memory() to the function .devinit.text:.arch_add_memory()
The function .add_memory() references
the function __devinit .arch_add_memory().
This is often because .add_memory lacks a __devinit
annotation or the annotation of .arch_add_memory is wrong.
arch_add_memory() is also not __devinit on other architectures
walk_memory_resource() verifies if there are holes in a given memory
range, by checking against /proc/iomem. On x86/ia64 system memory is
represented in /proc/iomem. On powerpc, we don't show system memory as
IO resource in /proc/iomem - instead it's maintained in
/proc/device-tree.
This provides a way for an architecture to provide its own
walk_memory_resource() function. On powerpc, the memory region is
small (16MB), contiguous and non-overlapping. So extra checking
against the device-tree is not needed.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Kumar Gala <galak@gate.crashing.org>
Supply remove_memory() function for 64-bit powerpc. This is still
not quite complete as it needs to do some more arch-specific stuff,
which will be added in a later patch.
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (69 commits)
[POWERPC] Add SPE registers to core dumps
[POWERPC] Use regset code for compat PTRACE_*REGS* calls
[POWERPC] Use generic compat_sys_ptrace
[POWERPC] Use generic compat_ptrace_request
[POWERPC] Use generic ptrace peekdata/pokedata
[POWERPC] Use regset code for PTRACE_*REGS* requests
[POWERPC] Switch to generic compat_binfmt_elf code
[POWERPC] Switch to using user_regset-based core dumps
[POWERPC] Add user_regset compat support
[POWERPC] Add user_regset_view definitions
[POWERPC] Use user_regset accessors for GPRs
[POWERPC] ptrace accessors for special regs MSR and TRAP
[POWERPC] Use user_regset accessors for SPE regs
[POWERPC] Use user_regset accessors for altivec regs
[POWERPC] Use user_regset accessors for FP regs
[POWERPC] mpc52xx: fix compile error introduce when rebasing patch
[POWERPC] 4xx: PCIe indirect DCR spinlock fix.
[POWERPC] Add missing native dcr dcr_ind_lock spinlock
[POWERPC] 4xx: Fix offset value on Warp board
[POWERPC] 4xx: Add 440EPx Sequoia ehci dts entry
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Currently, update_mmu_cache will crash if given a no-access PTE.
There's no need to synchronize dcache/icache unless it's an exec
mapping -- however, due to the existence of older glibc versions that
execute out of a read-but-no-exec page, readability is tested instead.
This assumes no exec-only mappings; if such mappings become supported,
they will need to go through the kmap_atomic() version of
dcache/icache synchronization.
This fixes a bug reported by some users where the kernel would crash
while dumping core on a threaded program.
There were several issues if a memreserve range existed and happened
to be in highmem:
* The bootmem allocator is only aware of lowmem so calling
reserve_bootmem with a highmem address would cause a BUG_ON
* All highmem pages were provided to the buddy allocator
Added a lmb_is_reserved() api that we now use to determine if a highem
page should continue to be PageReserved or provided to the buddy
allocator.
Also, we incorrectly reported the amount of pages reserved since all
highmem pages are initally marked reserved and we clear the
PageReserved flag as we "free" up the highmem pages.
My changes to _tlbie to fix 4xx unfortunately broke 8xx build in a
couple of places. This fixes it.
Spotted by Olof Johansson.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
Now, arch dependent code around CONFIG_MEMORY_HOTREMOVE is a mess.
This patch cleans up them. This is against 2.6.23-rc6-mm1.
- fix compile failure on ia64/ CONFIG_MEMORY_HOTPLUG && !CONFIG_MEMORY_HOTREMOVE case.
- For !CONFIG_MEMORY_HOTREMOVE, add generic no-op remove_memory(),
which returns -EINVAL.
- removed remove_pages() only used in powerpc.
- removed no-op remove_memory() in i386, sh, sparc64, x86_64.
- only powerpc returns -ENOSYS at memory hot remove(no-op). changes it
to return -EINVAL.
Note:
Currently, only ia64 supports CONFIG_MEMORY_HOTREMOVE. I welcome other
archs if there are requirements and testers.
This removes several duplicate includes from arch/powerpc/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Found 2 instances of return one right after each other in
arch_add_memory(). This removes the superfluous one.
Signed-off-by: Manish Ahuja <mahuja@us.ibm.com>
APUS (the Amiga Power-Up System) is not supported under arch/powerpc
and it's unlikely it ever will be. Therefore, this patch removes the
fragments of APUS support code from arch/powerpc which have been
copied from arch/ppc.
A few APUS references are left in asm-powerpc in .h files which are
still used from arch/ppc.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Some missing fixup for the removal of 4 level fixup header.
On some powerpc architectures (notably 64-bit powermac) there is a memory
hole, for example on powermacs between 2G and 4G. Since we use the flat
memory model regardless, these pages must be marked as nosave (for suspend
to disk.)
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
arch/powerpc/mm/mem.c exports page_is_ram, which is not used anywhere
that could be modular.
