path: root/arch/powerpc/mm/numa.c
2009-06-09powerpc: Set init_bootmem_done on NUMA platforms as wellBenjamin Herrenschmidt
For some obscure reason, we only set init_bootmem_done after initializing bootmem when NUMA isn't enabled. We even document this next to the declaration of that global in system.h which of course I didn't read before I had to debug why some WIP code wasn't working properly... This patch changes it so that we always set it after bootmem is initialized which should have always been the case... go figure ! Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc/numa: Cleanup hot_add_scn_to_nidNathan Fontenot
This patch reworks the hot_add_scn_to_nid and its supporting functions to make them easier to understand. There are no functional changes in this patch and has been tested on machine with memory represented in the device tree as memory nodes and in the ibm,dynamic-memory property. My previous patch that introduced support for hotplug memory add on systems whose memory was represented by the ibm,dynamic-memory property of the device tree only left the code more unintelligible. This will hopefully makes things easier to understand. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-18Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/pgtable-ppc32.h
2009-02-13powerpc/mm: Fix numa reserve bootmem page selectionDave Hansen
Fix the powerpc NUMA reserve bootmem page selection logic. commit 8f64e1f2d1e09267ac926e15090fd505c1c0cbcb (powerpc: Reserve in bootmem lmb reserved regions that cross NUMA nodes) changed the logic for how the powerpc LMB reserved regions were converted to bootmen reserved regions. As the folowing discussion reports, the new logic was not correct. mark_reserved_regions_for_nid() goes through each LMB on the system that specifies a reserved area. It searches for active regions that intersect with that LMB and are on the specified node. It attempts to bootmem-reserve only the area where the active region and the reserved LMB intersect. We can not reserve things on other nodes as they may not have bootmem structures allocated, yet. We base the size of the bootmem reservation on two possible things. Normally, we just make the reservation start and stop exactly at the start and end of the LMB. However, the LMB reservations are not aware of NUMA nodes and on occasion a single LMB may cross into several adjacent active regions. Those may even be on different NUMA nodes and will require separate calls to the bootmem reserve functions. So, the bootmem reservation must be trimmed to fit inside the current active region. That's all fine and dandy, but we trim the reservation in a page-aligned fashion. That's bad because we start the reservation at a non-page-aligned address: physbase. The reservation may only span 2 bytes, but that those bytes may span two pfns and cause a reserve_size of 2*PAGE_SIZE. Take the case where you reserve 0x2 bytes at 0x0fff and where the active region ends at 0x1000. You'll jump into that if() statment, but node_ar.end_pfn=0x1 and start_pfn=0x0. You'll end up with a reserve_size=0x1000, and then call reserve_bootmem_node(node, physbase=0xfff, size=0x1000); 0x1000 may not be on the same node as 0xfff. Oops. In almost all the vm code, end_<anything> is not inclusive. If you have an end_pfn of 0x1234, page 0x1234 is not included in the range. Using PFN_UP instead of the (>> >> PAGE_SHIFT) will make this consistent with the other VM code. We also need to do math for the reserved size with physbase instead of start_pfn. node_ar.end_pfn << PAGE_SHIFT is *precisely* the end of the node. However, (start_pfn << PAGE_SHIFT) is *NOT* precisely the beginning of the reserved area. That is, of course, physbase. If we don't use physbase here, the reserve_size can be made too large. From: Dave Hansen <dave@linux.vnet.ibm.com> Tested-by: Geoff Levand <geoffrey.levand@am.sony.com> Tested on PS3. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-11powerpc/numa: Remove redundant find_cpu_node()Milton Miller
Use of_get_cpu_node, which is a superset of numa.c's find_cpu_node in a less restrictive section (text vs cpuinit). Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-11powerpc/numa: Avoid possible reference beyond prop. length in ↵Milton Miller
find_min_common_depth() find_min_common_depth() was checking the property length incorrectly. The value is in bytes not cells, and it is using the second entry. Signed-off-By: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-08powerpc/mm: Cleanup careful_allocation(): consolidate memset()Dave Hansen
Both users of careful_allocation() immediately memset() the result. So, just do it in one place. Also give careful_allocation() a 'z' prefix to bring it in line with kzmalloc() and friends. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-08powerpc/mm: Make careful_allocation() return virtual addrsDave Hansen
Since we memset() the result in both of the uses here, just make careful_alloc() return a virtual address. Also, add a separate variable to store the physial address that comes back from the lmb_alloc() functions. This makes it less likely that someone will screw it up forgetting to convert before returning since the vaddr is always in a void* and the paddr is always in an unsigned long. I admit this is arbitrary since one of its users needs a paddr and one a vaddr, but it does remove a good number of casts. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-08powerpc/mm:: Cleanup careful_allocation(): bootmem already panicsDave Hansen
If we fail a bootmem allocation, the bootmem code itself panics. No need to redo it here. Also change the wording of the other panic. We don't strictly have to allocate memory on the specified node. It is just a hint and that node may not even *have* any memory on it. In that case we can and do fall back to other nodes. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-08powerpc/mm: Add better comment on careful_allocation()Dave Hansen
The behavior in careful_allocation() really confused me at first. Add a comment to hopefully make it easier on the next doofus that looks at it. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-16powerpc: Fix bootmem reservation on uninitialized nodeDave Hansen
careful_allocation() was calling into the bootmem allocator for nodes which had not been fully initialized and caused a previous bug: http://patchwork.ozlabs.org/patch/10528/ So, I merged a few broken out loops in do_init_bootmem() to fix it. That changed the code ordering. I think this bug is triggered by having reserved areas for a node which are spanned by another node's contents. In the mark_reserved_regions_for_nid() code, we attempt to reserve the area for a node before we have allocated the NODE_DATA() for that nid. We do this since I reordered that loop. I suck. This is causing crashes at bootup on some systems, as reported by Jon Tollefson. This may only present on some systems that have 16GB pages reserved. But, it can probably happen on any system that is trying to reserve large swaths of memory that happen to span other nodes' contents. This commit ensures that we do not touch bootmem for any node which has not been initialized, and also removes a compile warning about an unused variable. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-01powerpc: Fix boot freeze on machine with empty memory nodeDave Hansen
I got a bug report about a distro kernel not booting on a particular machine. It would freeze during boot: > ... > Could not find start_pfn for node 1 > [boot]0015 Setup Done > Built 2 zonelists in Node order, mobility grouping on. Total pages: 123783 > Policy zone: DMA > Kernel command line: > [boot]0020 XICS Init > [boot]0021 XICS Done > PID hash table entries: 4096 (order: 12, 32768 bytes) > clocksource: timebase mult[7d0000] shift[22] registered > Console: colour dummy device 80x25 > console handover: boot [udbg0] -> real [hvc0] > Dentry cache hash table entries: 1048576 (order: 7, 8388608 bytes) > Inode-cache hash table entries: 524288 (order: 6, 4194304 bytes) > freeing bootmem node 0 I've reproduced this on 2.6.27.7. It is caused by commit 8f64e1f2d1e09267ac926e15090fd505c1c0cbcb ("powerpc: Reserve in bootmem lmb reserved regions that cross NUMA nodes"). The problem is that Jon took a loop which was (in pseudocode): for_each_node(nid) NODE_DATA(nid) = careful_alloc(nid); setup_bootmem(nid); reserve_node_bootmem(nid); and broke it up into: for_each_node(nid) NODE_DATA(nid) = careful_alloc(nid); setup_bootmem(nid); for_each_node(nid) reserve_node_bootmem(nid); The issue comes in when the 'careful_alloc()' is called on a node with no memory. It falls back to using bootmem from a previously-initialized node. But, bootmem has not yet been reserved when Jon's patch is applied. It gives back bogus memory (0xc000000000000000) and pukes later in boot. The following patch collapses the loop back together. It also breaks the mark_reserved_regions_for_nid() code out into a function and adds some comments. I think a huge part of introducing this bug is because for loop was too long and hard to read. The actual bug fix here is the: + if (end_pfn <= node->node_start_pfn || + start_pfn >= node_end_pfn) + continue; Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-21powerpc: Always trim numa memory to lmb_end_of_DRAM()Milton Miller
numa_enforce_memory_limit tried to be smart and only call lmb_end_of_DRAM when a memory limit was set via mem= on the command line. However, the early boot code will also limit memory added to the lmb system when iommu=off is specified. When this happens, the page allocator is given pages not in the linear mapping and this results in a fatal data reference to the unmapped page. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-21powerpc/numa: Make memory reserve code more robustJon Tollefson
Adjust amount to reserve based on previous nodes for reserves spanning multiple nodes. Check if the node active range is empty before attempting to pass the reserve to bootmem. In practice the range shouldn't be empty, but to be sure we check. Signed-off-by: Jon Tollefson <kniht@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-10powerpc: Reserve in bootmem lmb reserved regions that cross NUMA nodesJon Tollefson
If there are multiple reserved memory blocks via lmb_reserve() that are contiguous addresses and on different NUMA nodes we are losing track of which address ranges to reserve in bootmem on which node. I discovered this when I recently got to try 16GB huge pages on a system with more then 2 nodes. When scanning the device tree in early boot we call lmb_reserve() with the addresses of the 16G pages that we find so that the memory doesn't get used for something else. For example the addresses for the pages could be 4000000000, 4400000000, 4800000000, 4C00000000, etc - 8 pages, one on each of eight nodes. In the lmb after all the pages have been reserved it will look something like the following: lmb_dump_all: memory.cnt = 0x2 memory.size = 0x3e80000000 memory.region[0x0].base = 0x0 .size = 0x1e80000000 memory.region[0x1].base = 0x4000000000 .size = 0x2000000000 reserved.cnt = 0x5 reserved.size = 0x3e80000000 reserved.region[0x0].base = 0x0 .size = 0x7b5000 reserved.region[0x1].base = 0x2a00000 .size = 0x78c000 reserved.region[0x2].base = 0x328c000 .size = 0x43000 reserved.region[0x3].base = 0xf4e8000 .size = 0xb18000 reserved.region[0x4].base = 0x4000000000 .size = 0x2000000000 The reserved.region[0x4] contains the 16G pages. In arch/powerpc/mm/num.c: do_init_bootmem() we loop through each of the node numbers looking for the reserved regions that belong to the particular node. It is not able to identify region 0x4 as being a part of each of the 8 nodes. It is assuming that a reserved region is only on a single node. This patch takes out the reserved region loop from inside the loop that goes over each node. It looks up the active region containing the start of the reserved region. If it extends past that active region then it adjusts the size and gets the next active region containing it. Signed-off-by: Jon Tollefson <kniht@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-09-15powerpc: Add support for dynamic reconfiguration memory in kexec/kdump kernelsChandru
Kdump kernel needs to use only those memory regions that it is allowed to use (crashkernel, rtas, tce, etc.). Each of these regions have their own sizes and are currently added under 'linux,usable-memory' property under each memory@xxx node of the device tree. The ibm,dynamic-memory property of ibm,dynamic-reconfiguration-memory node (on POWER6) now stores in it the representation for most of the logical memory blocks with the size of each memory block being a constant (lmb_size). If one or more or part of the above mentioned regions lie under one of the lmb from ibm,dynamic-memory property, there is a need to identify those regions within the given lmb. This makes the kernel recognize a new 'linux,drconf-usable-memory' property added by kexec-tools. Each entry in this property is of the form of a count followed by that many (base, size) pairs for the above mentioned regions. The number of cells in the count value is given by the #size-cells property of the root node. Signed-off-by: Chandru Siddalingappa <chandru@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-24mm: move bootmem descriptors definition to a single placeJohannes Weiner
There are a lot of places that define either a single bootmem descriptor or an array of them. Use only one central array with MAX_NUMNODES items instead. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03powerpc/pseries: Update numa association of hotplug memory add for drconf memoryNathan Fontenot
Update the association of a memory section with a numa node that occurs during hotplug add of a memory section. This adds a check in the hot_add_scn_to_nid() routine for the ibm,dynamic-reconfiguration-memory node in the device tree. If present the new hot_add_drconf_scn_to_nid() routine is invoked, which can properly parse the ibm,dynamic-reconfiguration-memory node of the device tree and make the proper numa node associations. This also introduces the valid_hot_add_scn() routine as a helper function for code that is common to the hot_add_scn_to_nid() and hot_add_drconf_scn_to_nid() routines. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-03powerpc/pseries: Split code into helper routines for drconf memoryNathan Fontenot
This splits off several pieces of code that parse the ibm,dynamic-reconfiguration-memory node of the device tree into separate helper routines. This is in preparation for the next commit that will use these helper routines. There are no functional changes in this patch. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-24[POWERPC] Add include of linux/of.h to numa.cMichael Ellerman
numa.c requires routines declared in linux/of.h, so should include it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-02-07Merge branch 'for-2.6.25' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (69 commits) [POWERPC] Add SPE registers to core dumps [POWERPC] Use regset code for compat PTRACE_*REGS* calls [POWERPC] Use generic compat_sys_ptrace [POWERPC] Use generic compat_ptrace_request [POWERPC] Use generic ptrace peekdata/pokedata [POWERPC] Use regset code for PTRACE_*REGS* requests [POWERPC] Switch to generic compat_binfmt_elf code [POWERPC] Switch to using user_regset-based core dumps [POWERPC] Add user_regset compat support [POWERPC] Add user_regset_view definitions [POWERPC] Use user_regset accessors for GPRs [POWERPC] ptrace accessors for special regs MSR and TRAP [POWERPC] Use user_regset accessors for SPE regs [POWERPC] Use user_regset accessors for altivec regs [POWERPC] Use user_regset accessors for FP regs [POWERPC] mpc52xx: fix compile error introduce when rebasing patch [POWERPC] 4xx: PCIe indirect DCR spinlock fix. [POWERPC] Add missing native dcr dcr_ind_lock spinlock [POWERPC] 4xx: Fix offset value on Warp board [POWERPC] 4xx: Add 440EPx Sequoia ehci dts entry ...
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[POWERPC] Fake NUMA emulation for PowerPCBalbir Singh
Here's a dumb simple implementation of fake NUMA nodes for PowerPC. Fake NUMA nodes can be specified using the following command line option numa=fake=<node range> node range is of the format <range1>,<range2>,...<rangeN> Each of the rangeX parameters is passed using memparse(). I find the patch useful for fake NUMA emulation on my simple PowerPC machine. I've tested it on a numa box with the following arguments numa=fake=512M numa=fake=512M,768M numa=fake=256M,512M mem=512M numa=fake=1G mem=768M numa=fake= without any numa= argument The other side-effect introduced by this patch is that; in the case where we don't have NUMA information, we now set a node online after adding each LMB. This node could very well be node 0, but in the case that we enable fake NUMA nodes, when we cross node boundaries, we need to set the new node online. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-03[POWERPC] Fix parse_drconf_memory() for 64-bit start addressesMichael Ellerman
Some new machines use the "ibm,dynamic-reconfiguration-memory" property to provide memory layout information, rather than via memory nodes. There is a bug in the code to parse this property for start addresses over 4GB; we store the start address in an unsigned int, which means we throw away the high bits and add apparently duplicate regions. This results in a BUG() in free_bootmem_core(). This fixes it by using an unsigned long instead. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: arch/powerpcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename prom_n_size_cells to of_n_size_cellsStephen Rothwell
This is more consistent and gets us closer to the Sparc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename prom_n_addr_cells to of_n_addr_cellsStephen Rothwell
2007-02-17Fix typos concerning hierarchyUwe Kleine-König
heirarchical, hierachical -> hierarchical heirarchy, hierachy -> hierarchy Signed-off-by: Uwe Kleine-König <zeisberg@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-11[POWERPC] Support ibm,dynamic-reconfiguration-memory nodesPaul Mackerras
For PAPR partitions with large amounts of memory, the firmware has an alternative, more compact representation for the information about the memory in the partition and its NUMA associativity information. This adds the code to the kernel to parse this alternative representation. The other part of this patch is telling the firmware that we can handle the alternative representation. There is however a subtlety here, because the firmware will invoke a reboot if the memory representation we request is different from the representation that firmware is currently using. This is because firmware can't change the representation on the fly. Further, some firmware versions used on POWER5+ machines have a bug where this reboot leaves the machine with an altered value of load-base, which will prevent any kernel booting until it is reset to the normal value (0x4000). Because of this bug, we do NOT set fake_elf.rpanote.new_mem_def = 1, and thus we do not request the new representation on POWER5+ and earlier machines. We do request the new representation on POWER6, which uses the ibm,client-architecture-support call. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-11[PATCH] mm: use symbolic names instead of indices for zone initialisationMel Gorman
Arch-independent zone-sizing is using indices instead of symbolic names to offset within an array related to zones (max_zone_pfns). The unintended impact is that ZONE_DMA and ZONE_NORMAL is initialised on powerpc instead of ZONE_DMA and ZONE_HIGHMEM when CONFIG_HIGHMEM is set. As a result, the the machine fails to boot but will boot with CONFIG_HIGHMEM turned off. The following patch properly initialises the max_zone_pfns[] array and uses symbolic names instead of indices in each architecture using arch-independent zone-sizing. Two users have successfully booted their powerpcs with it (one an ibook G4). It has also been boot tested on x86, x86_64, ppc64 and ia64. Please merge for 2.6.19-rc2. Credit to Benjamin Herrenschmidt for identifying the bug and rolling the first fix. Additional credit to Johannes Berg and Andreas Schwab for reporting the problem and testing on powerpc. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Have Power use add_active_range() and free_area_init_nodes()Mel Gorman
Size zones and holes in an architecture independent manner for Power. [judith@osdl.org: build fix] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[POWERPC] Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powerpc core changes. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-27[PATCH] cpu hotplug: make cpu_notifier related notifier blocks __cpuinit onlyChandra Seetharaman
Make notifier_blocks associated with cpu_notifier as __cpuinitdata. __cpuinitdata makes sure that the data is init time only unless CONFIG_HOTPLUG_CPU is defined. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-05Merge ../linux-2.6Paul Mackerras
2006-05-01[PATCH] powerpc: Allow devices to register with numa topologyJeremy Kerr
Change of_node_to_nid() to traverse the device tree, looking for a numa id. Cell uses this to assign ids to SPUs, which are children of the CPU node. Existing users of of_node_to_nid() are altered to use of_node_to_nid_single(), which doesn't do the traversal. Export an attach_sysdev_to_node() function, allowing system devices (eg. SPUs) to link themselves into the numa topology in sysfs. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] powerpc: Less verbose mem configuration outputOlof Johansson
Quieten some of the debug ram config output. we already print out available memory at KERN_INFO level. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] powerpc: hot_add_scn_to_nid() build fixAndrew Morton
The return statement is to prevent `warning: 'nid' might be used uninitialized in this function'. Cc: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: Consolidate assignment of cpus to nodesNathan Lynch
We can plug the boot cpu into its node independently of whether numa topology is detected. And numa_setup_cpu does the right thing for all cases now, so remove special-casing for non-numa from the cpu hotplug callback. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: Support sparse online node mapNathan Lynch
The powerpc numa code unconditionally onlines all nodes from 0 to the highest node id found, regardless of whether cpus or memory are present in the nodes. This wastes 8K per node and complicates some cpu and memory hotplug situations, such as adding a resource that doesn't map to one of the nodes discovered at boot. Set nodes online as resources are scanned. Fall back to node 0 only when we're sure this isn't a NUMA machine. Instead of defaulting to node 0 for cases of hot-adding a resource which doesn't belong to any initialized node, assign it to the first online node. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: Consolidate handling of Power4 special caseNathan Lynch
Code to handle Power4's invalid node id (0xffff) is duplicated for cpu and memory. Better to handle this case in one place -- of_node_to_nid. Overall behavior should be unchanged. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: Get rid of "numa domain" terminologyNathan Lynch
Since we effectively treat the domain ids given to us by firmare as logical node ids, make this explicit (basically s/numa_domain/nid/). No functional changes, only variable and function names are modified. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: Minor cpu hotplug-related cleanupsNathan Lynch
map_cpu_to_node does not need to be inline, it is never called in a hot path. map_cpu_to_node, numa_setup_cpu, and find_cpu_node can be marked __cpuinit, as they are never used after boot if CONFIG_HOTPLUG_CPU=n. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: Minor debugging code changesNathan Lynch
Add debug statement for map_cpu_to_node; it's useful for cpu hotplug. Clarify debug statement about not finding the numa reference points property. Don't print a meaningless associativity depth (-1) on non-numa systems. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc numa: fix boot_cpuid always assigned to node 0Nathan Lynch
At boot, the numa code is assigning boot_cpuid to node 0 unconditionally. Basically, numa_setup_cpu is being stupid about it, but this is the minimal fix -- just call numa_setup_cpu(boot_cpuid) later, after all nodes have been set online. Signed-off-by: Nathan Lynch <nathanl@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: Always panic if lmb_alloc() failsMichael Ellerman
Currently most callers of lmb_alloc() don't check if it worked or not, if it ever does weird bad things will probably happen. The few callers who do check just panic or BUG_ON. So make lmb_alloc() panic internally, to catch bugs at the source. The few callers who did check the result no longer need to. The only caller that did anything interesting with the return result was careful_allocation(). For it we create __lmb_alloc_base() which _doesn't_ panic automatically, a little messy, but passable. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: don't add memory to empty node/zoneMike Kravetz
The system will oops if an attempt is made to add memory to an empty node/zone. This patch prevents adding memory to an empty node. The code to dynamically add a node/zone is non-trivial. This patch is temporary and will be removed when the ability to dynamically add a node/zone is complete. Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Remove device_node addrs/n_addrBenjamin Herrenschmidt
The pre-parsed addrs/n_addrs fields in struct device_node are finally gone. Remove the dodgy heuristics that did that parsing at boot and remove the fields themselves since we now have a good replacement with the new OF parsing code. This patch also fixes a bunch of drivers to use the new code instead, so that at least pmac32, pseries, iseries and g5 defconfigs build. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] ppc64: Add NUMA cpu summary at bootAnton Blanchard
We used to print a NUMA cpu summary at boot before the hotplug cpu code was added. This has been useful for catching machine configuration as well as firmware bugs in the past. This patch restores that functionality. An example of the output is: Node 0 CPUs: 0-7 Node 1 CPUs: 8-15 Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
