path: root/arch/powerpc/oprofile/op_model_power4.c
2015-07-13powerpc: Remove mtmsrd(), use existing mtmsr()Anton Blanchard
mtmsr() does the right thing on 32bit and 64bit, so use it everywhere. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-01-15powerpc: Delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. The one instance where we add an include for init.h covers off a case where that file was implicitly getting it from another header which itself didn't need it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-29powerpc/oprofile: Fix error in oprofile power7_marked_instr_event() functionCarl E. Love
The calculation for the left shift of the mask OPROFILE_PM_PMCSEL_MSK has an error. The calculation is should be to shift left by (max_cntrs - cntr) times the width of the pmsel field width. However, the #define OPROFILE_MAX_PMC_NUM was used instead of OPROFILE_PMSEL_FIELD_WIDTH. This patch fixes the calculation. Signed-off-by: Carl Love <cel@us.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-07powerpc/oprofile: Fix marked events support on Power7+ not set.Carl E. Love
Starting with Power 7+ we need to check for marked events if the SIAR register is valid, i.e. it contains the correct address of the instruction at the time the performance counter overflowed. The mmcra register on Power 7+, contains a new bit to indicate that the contents of the SIAR is valid. If the event is not marked, then the sample is recorded independently of the SIAR valid bit setting. For older processors, there is no SIAR valid bit to check so the samples are always recorded. This is done by forcing the cntr_marked_events bit mask to zero. The code will always record the sample in this case since the bit mask says the event is not a marked event even if it really is a marked event. Signed-off-by: Carl Love <cel@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05powerpc: Rename 64-bit PVR constants to PVR_fooMichael Ellerman
We have an old FIXME in reg.h which points out that we should standardise on PVR_foo for our PVR #defines. Currently we use PVR_ on 32-bit and PV_ on 64-bit. So do that rename and remove the FIXME. Seeing as we're touching all but one usage of __is_processor(), rename it to something less ugly and more indicative of what it does, which is simply to check the PVR version. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-28Disintegrate asm/system.h for PowerPCDavid Howells
Disintegrate asm/system.h for PowerPC. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> cc: linuxppc-dev@lists.ozlabs.org
2011-05-26powerpc/oprofile: Handle events that raise an exception without overflowingEric B Munson
Commit 0837e3242c73566fc1c0196b4ec61779c25ffc93 fixes a situation on POWER7 where events can roll back if a specualtive event doesn't actually complete. This can raise a performance monitor exception. We need to catch this to ensure that we reset the PMC. In all cases the PMC will be less than 256 cycles from overflow. This patch lifts Anton's fix for the problem in perf and applies it to oprofile as well. Signed-off-by: Eric B Munson <emunson@mgebm.net> Cc: <stable@kernel.org> # as far back as it applies cleanly Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-15powerpc: Fix oprofile sampling of marked events on POWER7Maynard Johnson
Description ----------- Change ppc64 oprofile kernel driver to use the SLOT bits (MMCRA[37:39]only on older processors where those bits are defined. Background ---------- The performance monitor unit of the 64-bit POWER processor family has the ability to collect accurate instruction-level samples when profiling on marked events (i.e., "PM_MRK_<event-name>"). In processors prior to POWER6, the MMCRA register contained "slot information" that the oprofile kernel driver used to adjust the value latched in the SIAR at the time of a PMU interrupt. But as of POWER6, these slot bits in MMCRA are no longer necessary for oprofile to use, since the SIAR itself holds the accurate sampled instruction address. With POWER6, these MMCRA slot bits were zero'ed out by hardware so oprofile's use of these slot bits was, in effect, a NOP. But with POWER7, these bits are no longer zero'ed out; however, they serve some other purpose rather than slot information. Thus, using these bits on POWER7 to adjust the SIAR value results in samples being attributed to the wrong instructions. The attached patch changes the oprofile kernel driver to ignore these slot bits on all newer processors starting with POWER6. Signed-off-by: Maynard Johnson <maynardj@us.ibm.com> Signed-off-by: Michael Wolf <mjw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-08-20powerpc: Expose PMCs & cache topology in sysfs on 32-bitBenjamin Herrenschmidt
The file arch/powerpc/kernel/sysfs.c is currently only compiled for 64-bit kernels. It contain code to register CPU sysdevs in sysfs and add various properties such as cache topology and raw access by root to performance monitor counters (PMCs). A lot of that can be re-used as is on 32-bits. This makes the file be built for both, with appropriate ifdef'ing for the few bits that are really 64-bit specific, and adds some support for the raw PMCs for 75x and 74xx processors. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-20[CELL] oprofile: add support to OProfile for profiling CELL BE SPUsBob Nelson
From: Maynard Johnson <mpjohn@us.ibm.com> This patch updates the existing arch/powerpc/oprofile/op_model_cell.c to add in the SPU profiling capabilities. In addition, a 'cell' subdirectory was added to arch/powerpc/oprofile to hold Cell-specific SPU profiling code. Exports spu_set_profile_private_kref and spu_get_profile_private_kref which are used by OProfile to store private profile information in spufs data structures. Also incorporated several fixes from other patches (rrn). Check pointer returned from kzalloc. Eliminated unnecessary cast. Better error handling and cleanup in the related area. 64-bit unsigned long parameter was being demoted to 32-bit unsigned int and eventually promoted back to unsigned long. Signed-off-by: Carl Love <carll@us.ibm.com> Signed-off-by: Maynard Johnson <mpjohn@us.ibm.com> Signed-off-by: Bob Nelson <rrnelson@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org>
2007-07-10[POWERPC] Oprofile enhanced instruction sampling supportwill schmidt
Oprofile enhanced instruction sampling support. When performing instruction sampling, the mmcra[SLOT] field can be used to more accurately identify the address of the sampled instruction. Tested on power4, js20, power5 and power5+. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> cc: Maynard Johnson <maynardj@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] Oprofile cleanupOlof Johansson
Clean up the ctr_read/write a bit. It's currently defined in the include but only used in one C file each. The only exception is the classic version, so keep that in the include and define in the C file as appropriate. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-01[POWERPC] Fix oprofile support for e500 in arch/powerpcAndy Fleming
Fixed a compile error in building the 85xx support with oprofile, and in the process cleaned up some issues with the fsl_booke performance monitor code. * Reorganized FSL Book-E performance monitoring code so that the 7450 wouldn't be built if the e500 was, and cleaned it up so it was more self-contained. * Added a cpu_setup function for FSL Book-E. The original cpu_setup function prototype had no arguments, assuming that the reg_setup function would copy the required information into variables which represented the registers. This was silly for e500, since it has 1 register per counter (rather than 3 for all counters), so the code has been restructured to have cpu_setup take the current counter config array as an argument, with op_powerpc_setup() invoking op_powerpc_cpu_setup() through on_each_cpu(), and op_powerpc_cpu_setup() invoking the model-specific cpu_setup function with an argument. The argument is ignored on all other platforms at present. * Fixed a confusing line where a trinary operator only had two arguments Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-23[POWERPC] Add 970GX cputable entryJake Moilanen
970GX cputable entry from Steve Winiecki. Signed-off-by: Jake Moilanen <moilanen@austin.ibm.com> arch/powerpc/kernel/cputable.c | 15 +++++++++++++++ arch/powerpc/oprofile/op_model_power4.c | 2 +- include/asm-powerpc/reg.h | 1 + 3 files changed, 17 insertions(+), 1 deletion(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-09[PATCH] powerpc: oprofile support for POWER6Michael Neuling
POWER6 moves some of the MMCRA bits and also requires some bits to be cleared each PMU interrupt. Signed-off-by: Michael Neuling <mikey@neuling.org> Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29[PATCH] powerpc: Remove oprofile spinlock backtrace codeAnton Blanchard
Remove oprofile spinlock backtrace code now we have proper calltrace support. Also make MMCRA sihv and sipr bits a variable since they may change in future cpus. Finally, MMCRA should be a 64bit quantity. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-29[PATCH] powerpc: Add oprofile calltrace supportBrian Rogan
Add oprofile calltrace support to powerpc. Disable spinlock backtracing now we can use calltrace info. (Updated to work on both 32bit and 64bit by me). Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc: Replace platform_is_lpar() with a firmware featureMichael Ellerman
It has been decreed that platform numbers are evil, so as a step in that direction, replace platform_is_lpar() with a FW_FEATURE_LPAR bit. Currently FW_FEATURE_LPAR really means i/pSeries LPAR, in the future we might have to clean that up if we need to be more specific about what LPAR actually means. But that's another patch ... Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Add a is_kernel_addr() macroMichael Ellerman
There's a bunch of code that compares an address with KERNELBASE to see if it's a "kernel address", ie. >= KERNELBASE. The proper test is actually to compare with PAGE_OFFSET, since we're going to change KERNELBASE soon. So replace all of them with an is_kernel_addr() macro that does that. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-11[PATCH] powerpc: Merge vdso's and add vdso support to 32 bits kernelBenjamin Herrenschmidt
This patch moves the vdso's to arch/powerpc, adds support for the 32 bits vdso to the 32 bits kernel, rename systemcfg (finally !), and adds some new (still untested) routines to both vdso's: clock_gettime() with support for CLOCK_REALTIME and CLOCK_MONOTONIC, clock_getres() (same clocks) and get_tbfreq() for glibc to retreive the timebase frequency. Tom,Steve: The implementation of get_tbfreq() I've done for 32 bits returns a long long (r3, r4) not a long. This is such that if we ever add support for >4Ghz timebases on ppc32, the userland interface won't have to change. I have tested gettimeofday() using some glibc patches in both ppc32 and ppc64 kernels using 32 bits userland (I haven't had a chance to test a 64 bits userland yet, but the implementation didn't change and was tested earlier). I haven't tested yet the new functions. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-10[PATCH] powerpc: merge code values for identifying platformsPaul Mackerras
This patch merges platform codes. systemcfg->platform is no longer used, systemcfg use in general is deprecated as much as possible (and renamed _systemcfg before it gets completely moved elsewhere in a future patch), _machine is now used on ppc64 along as ppc32. Platform codes aren't gone yet but we are getting a step closer. A bunch of asm code in head[_64].S is also turned into C code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: fix oprofile sample bit handlingAnton Blanchard
Oprofile was hardwiring the MMCRA sample bit to 1 but on newer cpus (eg POWER5) we want to vary it based on the group being sampled. Add a temporary workaround until people update their oprofile userspace. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-21[PATCH] powerpc: merge the rest of arch/ppc*/oprofileStephen Rothwell
- merge common.c - move model specific files - remove stub Makefiles - clean up arch/ppc*/Makefile Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
