path: root/arch/powerpc/platforms/44x
2008-04-16[POWERPC] 4xx: Add idle wait support for 44x platformsJerone Young
This changes the cpu_idle loop for 44x platforms to utilize the Wait Enable feature of the CPU. This helps virtulization solutions know when the guest Linux kernel is in an idle state. A command line option called "idle" is also added to allow people to change the idle loop back to the original variation. This is done by setting "idle=spin" on the kernel command line. Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-05[POWERPC] 4xx: Use machine_device_initcall() for warp_nandValentine Barshak
With a multiplatform kernel, once built we always have warp_setup_nand_flash() called and NDFC probed, no matter what machine we actually run on. This potentially can cause problems (such as kernel crash), since NDFC is probed at a warp-predefined address. Using machine_device_initcall() NAND devices are registered if we run on a warp only. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-02[POWERPC] 4xx: Create common ppc4xx_reset_system() in ppc4xx_soc.cStefan Roese
This patch creates a common system reset routine for all 40x and 44x systems. Previously only a 44x routine existed. But since this system reset via the debug control register is common for 40x and 44x let's share this code for all those platforms in ppc4xx_soc.c. This patch also enables CONFIG_4xx_SOC for all 40x and 44x platforms. Tested on Kilauea (405EX) and Canyonlands (440EX). Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-03-26[POWERPC] 4xx: Add PPC4xx L2-cache support (440GX)Stefan Roese
This patch adds support for the 256k L2 cache found on some IBM/AMCC 4xx PPC's. It introduces a common 4xx SoC file (sysdev/ppc4xx_soc.c) which currently "only" adds the L2 cache init code. Other common 4xx stuff can be added later here. The L2 cache handling code is a copy of Eugene's code in arch/ppc with small modifications. Tested on AMCC Taishan 440GX. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-03-26[POWERPC] 4xx: Add platform support for the AMCC Yosemite boardJosh Boyer
The AMCC 440EP Yosemite board is very similar to the original AMCC Bamboo board. This adds a YOSEMITE option to Kconfig, and reuses the existing bamboo board support in the kernel. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-03-26[POWERPC] 4xx: Add AMCC Canyonlands 460EX eval board support to platforms/44xStefan Roese
Canyonlands is the AMCC 460EX eval board, featuring nearly all of the 460EX interfaces: - 1 * PCI (max 66MHz), 2 * PCIe (one 4-lane, one 1-lane) - 2 * GBit Ethernet with TCP/IP acceleration - USB 2.0 Host/Device OTG and Host interface - SATA port Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-02-15[POWERPC] 44x: Fix Kconfig formattingJosh Boyer
Clean up some whitespace issues in the 44x Kconfig file. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-02-06[POWERPC] 4xx: Fix offset value on Warp boardSean MacLennan
While merging, I found a small bug that I forgot to send. I add an offset to a value twice. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-01-25[POWERPC] 4xx: PIKA Warp base platformSean MacLennan
Add the base platform support for the PIKA Warp boards. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-01-25[POWERPC] Enable RTC for Ebony and Walnut (v2)David Gibson
This patch extends the Ebony and Walnut platform code to instantiate the existing ds1742 RTC class driver for the DS1743 RTC/NVRAM chip found on both those boards. The patch uses a helper function to scan the device tree and instantiate the appropriate platform_device based on it, so it should be easy to extend for other boards which have mmio mapped RTC chips. Along with this, the device tree binding for the ds1743 chips is tweaked, based on the existing DS1385 OF binding found at: http://playground.sun.com/1275/proposals/Closed/Remanded/Accepted/346-it.txt Although that document covers the NVRAM portion of the chip, whereas here we're interested in the RTC portion, so it's not entirely clear if that's a good model. This implements only RTC class driver support - that is /dev/rtc0, not /dev/rtc, and the low-level get/set time callbacks remain unimplemented. That means in order to get at the clock you will either need a modified version of hwclock which will look at /dev/rtc0, or you'll need to configure udev to symlink rtc0 to rtc. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-01-17[POWERPC] Use <linux/of_{platform, device}.h> and not <asm/...> variants.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-02[POWERPC] 4xx: typo in calling machine_device_initcall() for Sequoia boardGrant Likely
Fix an obvious typo. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-24[POWERPC] 4xx: Use machine_device_initcall for bus probeJosh Boyer
Some machine_xx_initcall macros were recently added that check for the machine type before calling the function. This converts the 4xx platforms to use those for bus probing. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-24[POWERPC] 4xx: Mark of_bus structures as __initdataJosh Boyer
Mark the of_device_id structures used to probe the various busses on 4xx as __initdata. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: Update Kilauea, Rainier, and Walnut defconfigsJosh Boyer
Enable PCI support for these eval boards among other things. Also selects PCI for Rainier in the Kconfig file. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: libfdt and pci fixes for RainierJosh Boyer
Update the Rainier wrapper for the libfdt merge and add the pci flags to the platform file. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: Include missing headerJosh Boyer
A small error caused a header file to be removed making sequoia support no longer compile. Fix it. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: 440GRx Rainier board support.Valentine Barshak
PowerPC 440GRx Rainier board support. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] pci32: 4xx embedded platforms want to reassign all PCI resourcesBenjamin Herrenschmidt
This makes 4xx embedded platforms re-assign all PCI resources as we pretty much never care about what the various firmwares have done on these, it's generally not compatible with the way the kernel will map the bridges. We still need to also enable bus renumbering on some of them, but I will do that from a separate patch after I've fixed 4xx PCIe to handle all bus numbers. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: Base support for 440SPe "Katmai" eval boardBenjamin Herrenschmidt
This adds base support for the Katmai board, including PCI-X and PCI-Express (but no RTC, nvram, etc... yet). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: Wire up PCI on Bamboo boardBenjamin Herrenschmidt
This adds the device-tree bits & call to ppc4xx_pci_find_bridges() to make PCI work on the Bamboo board Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: Base support for 440GX Taishan eval boardHugh Blemings
This patch adds base support for the AMCC Taishan 440GX evaluation board. Signed-off-by: Hugh Blemings <hugh@blemings.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: PCI support for Ebony boardBenjamin Herrenschmidt
This wires up the 4xx PCI support & device tree bits for 440GP based Ebony platform. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] Reworking machine check handling and Fix 440/440ABenjamin Herrenschmidt
This adds a cputable function pointer for the CPU-side machine check handling. The semantic is still the same as the old one, the one in ppc_md. overrides the one in cputable, though ultimately we'll want to change that so the CPU gets first. This removes CONFIG_440A which was a problem for multiplatform kernels and instead fixes up the IVOR at runtime from a setup_cpu function. The "A" version of the machine check also tweaks the regs->trap value to differenciate the 2 versions at the C level. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-19[POWERPC] 4xx: Replace #includes of asm/of_platform.h with linux/of_platform.h.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-19[POWERPC] 4xx: Enable EMAC on Bamboo boardJosh Boyer
Fix some device tree omissions that prevented the new EMAC driver from setting up ethernet on the Bamboo board correctly and update the Bamboo defconfig. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-19[POWERPC] 4xx: Enable NEW EMAC support for Sequoia 440EPx.Valentine Barshak
This patch enables NEW EMAC support for PowerPC 440EPx Sequoia board. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-19[POWERPC] 4xx: Add RGMII support for Sequoia 440EPxValentine Barshak
This adds RGMII support to Sequoia DTS and sets correct phy-mode for EMACs. According to Sequoia datasheet, both ethernet ports are connected to RGMII interface, while ZMII is used only for MDIO. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (408 commits) [POWERPC] Add memchr() to the bootwrapper [POWERPC] Implement logging of unhandled signals [POWERPC] Add legacy serial support for OPB with flattened device tree [POWERPC] Use 1TB segments [POWERPC] XilinxFB: Allow fixed framebuffer base address [POWERPC] XilinxFB: Add support for custom screen resolution [POWERPC] XilinxFB: Use pdata to pass around framebuffer parameters [POWERPC] PCI: Add 64-bit physical address support to setup_indirect_pci [POWERPC] 4xx: Kilauea defconfig file [POWERPC] 4xx: Kilauea DTS [POWERPC] 4xx: Add AMCC Kilauea eval board support to platforms/40x [POWERPC] 4xx: Add AMCC 405EX support to cputable.c [POWERPC] Adjust TASK_SIZE on ppc32 systems to 3GB that are capable [POWERPC] Use PAGE_OFFSET to tell if an address is user/kernel in SW TLB handlers [POWERPC] 85xx: Enable FP emulation in MPC8560 ADS defconfig [POWERPC] 85xx: Killed <asm/mpc85xx.h> [POWERPC] 85xx: Add cpm nodes for 8541/8555 CDS [POWERPC] 85xx: Convert mpc8560ads to the new CPM binding. [POWERPC] mpc8272ads: Remove muram from the CPM reg property. [POWERPC] Make clockevents work on PPC601 processors ... Fixed up conflict in Documentation/powerpc/booting-without-of.txt manually.
2007-10-11[POWERPC] Remove empty ppc_md.setup_arch hooksGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-10Device tree aware EMAC driverDavid Gibson
Based on BenH's earlier work, this is a new version of the EMAC driver for the built-in ethernet found on PowerPC 4xx embedded CPUs. The same ASIC is also found in the Axon bridge chip. This new version is designed to work in the arch/powerpc tree, using the device tree to probe the device, rather than the old and ugly arch/ppc OCP layer. This driver is designed to sit alongside the old driver (that lies in drivers/net/ibm_emac and this one in drivers/net/ibm_newemac). The old driver is left in place to support arch/ppc until arch/ppc itself reaches its final demise (not too long now, with luck). This driver still has a number of things that could do with cleaning up, but I think they can be fixed up after merging. Specifically: - Should be adjusted to properly use the dma mapping API. Axon needs this. - Probe logic needs reworking, in conjuction with the general probing code for of_platform devices. The dependencies here between EMAC, MAL, ZMII etc. make this complicated. At present, it usually works, because we initialize and register the sub-drivers before the EMAC driver itself, and (being in driver code) runs after the devices themselves have been instantiated from the device tree. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-07[POWERPC] Fix bus probe on Bamboo boardJosh Boyer
Commit 804ace8881d21 changed the behavior of how compatible nodes are found. This highlighted a bug on the Bamboo board where it wasn't probing the bus specified in the DTS file. We fix it by being explicit about which bus to probe. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: David Gibson <david@gibson.dropbvear.id.au>
2007-09-07[POWERPC] PowerPC 440EPx: Sequoia board supportValentine Barshak
AMCC PPC440EPx Sequoia board support. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-08-20[POWERPC] Bamboo board supportJosh Boyer
Add support for the AMCC Bamboo board Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au>
2007-05-17[POWERPC] Small fixes for the Ebony device treeDavid Gibson
This patch corrects a number of minor errors in the Ebony device tree: - Missing (given as 0) cache sizes are added to the CPU node - device_type properties are removed from nodes which don't have a reasonably well defined device_type binding. This does require a very small code change to locate the busses to be probed for of_platform devices by 'compatible' instead of 'device_type'. - A node is added for the SRAM controller - The unit address of the small-flash node is adjusted to correctly reflect the reg property. - device_type values for the MAL and ZMII are updated to reflected more up-to-date versions of the binding. - An incorrect offset in the partition map for the large-flash node is corrected. - Some redundant values, already commented out are removed entirely. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-17[POWERPC] Fix Kconfig undefined symbol 'IBM_NEW_EMAC_ZMII'Tony Breeds
An allmodconfig on the current powerpc tree yields: arch/powerpc/platforms/44x/Kconfig:41:warning: 'select' used by config symbol '440GP' refers to undefined symbol 'IBM_NEW_EMAC_ZMII' Hide the select until the driver exists. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Early serial debug support for PPC44xDavid Gibson
This adds support for early serial debugging via the built in port on IBM/AMCC PowerPC 44x CPUs. It uses a bolted TLB entry in address space 1 for the UART's mapping, allowing robust debugging both before and after the initialization of the MMU. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Support for the Ebony 440GP reference board in arch/powerpcDavid Gibson
This adds platform support code for the Ebony (440GP) evaluation board. This includes both code in arch/powerpc/platforms/44x for board initialization, and zImage wrapper code to correctly tweak the flattened device tree based on information from the firmware. The zImage supports both IBM OpenBIOS (aka "treeboot") and old versions of uboot which don't support a flattened device tree. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for nowDavid Gibson
This prepares for Ebony/440 support by creating an arch/powerpc/platforms/44x directory. It is populated with a single misc_44x.S file, into which is moved the 44x specific reset code from head_44x.S (on the grounds that we should really stop clogging up the head_* files with random asm helper routines). At the same time, we disable the (empty save Kconfig and Makefile) arch/powerpc/platforms/4xx directory from the arch/powerpc/platforms Makefile. Contrary to the comment in arch/powerpc/platforms/4xx/Makefile, attempting to build such an empty Makefile will fail, thus breaking compile for the 44x platforms we're about to add. It can go back in once we start porting some of the 40x platforms (and thus it becomes non-empty). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
