path: root/arch/powerpc/platforms/82xx
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-17[POWERPC] CPM: Always use new binding.Scott Wood
The kconfig entry can go away once arch/ppc and references to the config in drivers are removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-06[POWERPC] arch/powerpc/platforms/82xx: Add missing of_node_putJulia Lawall
Of_get_parent and of_find_compatible_node do a of_node_get, and thus a corresponding of_code_put is needed in both the error case and the normal return case. The problem was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T,T1,T2; identifier E; statement S; expression x1,x2,x3; int ret; @@ T E; ... * E = \(of_get_parent\|of_find_compatible_node\)(...); if (E == NULL) S ... when != of_node_put(...,(T1)E,...) when != if (E != NULL) { ... of_node_put(...,(T1)E,...); ...} when != x1 = (T1)E when != E = x3; when any if (...) { ... when != of_node_put(...,(T2)E,...) when != if (E != NULL) { ... of_node_put(...,(T2)E,...); ...} when != x2 = (T2)E ( * return; | * return ret; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-28[POWERPC] 82xx and embedded6xx: Use machine_*_initcall() hooks in platform codeGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] 82xx: Embedded Planet EP8248E supportScott Wood
This board is also resold by Freescale under the names "QUICCStart MPC8248 Evaluation System" and "CWH-PPC-8248N-VE". Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-20[POWERPC] pci32: Add flags modifying the PCI code behaviourBenjamin Herrenschmidt
This adds to the 32 bits PCI code some flags, replacing the old pci_assign_all_busses global, that allow us to control various aspects of the PCI probing, such as whether to re-assign all resources or not, or to not try to assign anything at all. This also adds the flag x86 already has to avoid ISA alignment on bridges that don't have ISA forwarding enabled (no legacy devices on the top level bus) and sets it for PowerMacs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-11[POWERPC] 8xxx: Convert #include of asm/of_{platform, device}.h into ↵Jon Loeliger
linux/of_{platform, device}.h. Signed-off-by: Jon Loeliger <jdl@freescale.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11[POWERPC] pci_controller->arch_data really is a struct device_node *Stephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-04[POWERPC] mpc82xx: Add pq2fads board support.Scott Wood
2007-10-04[POWERPC] mpc82xx: Update mpc8272ads, and factor out PCI and reset.Scott Wood
1. PCI and reset are factored out into pq2.c. I renamed them from m82xx to pq2 because they won't work on the Integrated Host Processor line of 82xx chips (i.e. 8240, 8245, and such). 2. The PCI PIC, which is nominally board-specific, is used on multiple boards, and thus is used into pq2ads-pci-pic.c. 3. The new CPM binding is used. 4. General cleanup. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] mpc8272ads: Change references from 82xx_ADS to 8272_ADS.Scott Wood
2007-10-04[POWERPC] mpc82xx: Rename mpc82xx_ads to mpc8272_ads.Scott Wood
This is just a rename patch; internal references to mpc82xx_ads will be changed in the next one. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-04[POWERPC] mpc82xx: Remove a bunch of cruft that duplicates generic ↵Scott Wood
functionality. m82xx_calibrate_decr(), mpc82xx_ads_show_cpuinfo(), and mpc82xx_halt() do anything useful beyond what the generic code does. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] Provide a default irq_host match, which matches on an exact of_nodeMichael Ellerman
The most common match semantic is an exact match based on the device node. So provide a default implementation that does this, and hook it up if no match routine is specified. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-14[POWERPC] Add an optional device_node pointer to the irq_hostMichael Ellerman
The majority of irq_host implementations (3 out of 4) are associated with a device_node, and need to stash it somewhere. Rather than having it somewhere different for each host, add an optional device_node pointer to the irq_host structure. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-22[POWERPC] Remove old includes from arch/ppcKumar Gala
Remove includes of files that existed in arch/ppc that we dont need in arch/powerpc anymore. The following includes were removed: <asm/amigappc.h> <asm/bootinfo.h> <asm/ppcboot.h> <asm/ppc_sys.h> <asm/residual.h> <asm/m8260_pci.h> This also caused platforms/embedded6xx/mpc7448_hpc2.h to no longer be needed and thus removed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-23[POWERPC] Make endianess of cfg_addr for indirect pci ops runtimeKumar Gala
Make it so we do a runtime check to know if we need to write cfg_addr as big or little endian. This is needed if we want to allow 86xx support to co-exist in the same kernel as other 6xx PPCs. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Merge ppc32 and ppc64 pcibios_alloc_controller() prototypesKumar Gala
Make the ppc32 pcibios_alloc_controller take a device node to match the ppc64 prototypes and have it set arch_data. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Remove bus_offset in places its not really usedKumar Gala
The user of the fsl_pcie code doesn't set bus_offset and 82xx doesn't require it either. Remove the places in the code that reference it so we can remove it all together. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Pass the pci_controller into pci_exclude_deviceKumar Gala
There are times that we need to know which controller we are on to decide how to exclude devices properly. We now pass the pci_controller that we are going to use down to the pci_exclude_device function. This will greatly simplify being able to exclude the PHBs in multiple controller setups. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] Remove set_cfg_type for PCI indirect users that don't need itKumar Gala
The Freescale and Marvell PCI controllers dont require explicit setting for type 1 config cycles. They handle producing them by implicitly looking at the bus, devfn. The TSI108 and 52xx don't use the generic PCI indirect code and thus don't bother with set_cfg_type. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-29[POWERPC] mpc82xx_ads build fixArnd Bergmann
needed for 6xx allyesconfig Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2007-06-29[POWERPC] rename add_bridge to avoid namespace clashesArnd Bergmann
Many platforms currently define their own add_bridge function, some of them globally. This breaks some multiplatform configurations. Prefixing each of these functions with the platform name avoids this problem. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2007-06-29[POWERPC] move 82xx/83xx/86xx Kconfig options to platform selectionArnd Bergmann
The cores used in the MPC82xx/83xx/86xx embedded controllers are very similar to those in the 32 bit general-purpose processors, so it makes sense to treat them as the same CPU family. Choosing between the embedded platforms and the multiplatform code is now done in the platform menu, but functionally everything stays the same. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2007-04-24Merge branch 'kconfig' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into for-2.6.22
2007-04-12[POWERPC] Convert 82xx platform to unified platform KconfigKumar Gala
Moved 82xx platform Kconfig over to being sourced by the unified arch/powerpc/platforms/Kconfig. Also, cleaned up whitespace issues in 82xx Kconfig. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: arch/powerpcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-22[POWERPC] Removed config options that we don't support in embedded6xxKumar Gala
When we started arch/powerpc we duplicated a number of config options from arch/ppc for various platforms that are supported. Now that we actually support a few platforms, remove all the ones that haven't been moved over. Additionally, this cleanup moved the 82xx/PQ2 options over into arch/powerpc/platforms/82xx/Kconfig where they belong. It also killed GEN550 which doesn't exist in arch/powerpc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-07[POWERPC] Fix kernel build errors for mpc8272ads and mpc8560adsVitaly Bordug
Recent update of asm-powerpc/io.h caused cpm-related stuff to break in the current kernel. Current patch fixes it, as well as other inconsistencies expressed, that do not permit targets from working properly: - Updated dts with a chosen node with interrupt controller, - fixed messed device IDs among CPM2 SoC devices, - corrected odd header name and fixed type in defines, - Added 82xx subdir to the powerpc/platforms Makefile, missed during initial commit, - new solely-powerpc header file for 8260 family (was using one from arch/ppc, this one cleaned up from the extra stuff), in fact for now a placeholder to get the board-specific includes for stuff not yet capable to live with devicetree peeks only - Fixed couple of misprints in reference mpc8272 dts. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Make pci_read_irq_line the defaultBenjamin Herrenschmidt
This patch reworks the way IRQs are fixed up on PCI for arch powerpc. It makes pci_read_irq_line() called by default in the PCI code for devices that are probed, and add an optional per-device fixup in ppc_md for platforms that really need to correct what they obtain from pci_read_irq_line(). It also removes ppc_md.irq_bus_setup which was only used by pSeries and should not be needed anymore. I've also removed the pSeries s7a workaround as it can't work with the current interrupt code anyway. I'm trying to get one of these machines working so I can test a proper fix for that problem. I also haven't updated the old-style fixup code from 85xx_cds.c because it's actually buggy :) It assigns pci_dev->irq hard coded numbers which is no good with the new IRQ mapping code. It should at least use irq_create_mapping(NULL, hard_coded_number); and possibly also set_irq_type() to set them as level low. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-09[HEADERS] Put linux/config.h out of its misery.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-07[POWERPC] Fix up after irq changesOlaf Hering
Remove struct pt_regs * from all handlers. Also remove the regs argument from get_irq() functions. Compile tested with arch/powerpc/config/* and arch/ppc/configs/prep_defconfig Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-03POWERPC: mpc82xx merge: board-specific/platform stuff(resend)Vitaly Bordug
This intruduces 82xx family in arch/powerpc/platforms, and has all the board-specific code to represent regression-less transaction from ppc. The functionality is apparently the same, including PCI controller. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
