path: root/arch/powerpc/platforms/amigaone
2011-06-09pcspkr: Cleanup Kconfig dependenciesRalf Baechle
Lenghty lists of the kind "depends on ARCH1 || ARCH2 ... || ARCH123" are usually either wrong or too coarse grained. Or plain an ugly sin. [ tglx: Fixed up amigaone ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: linux-alpha@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linuxppc-dev@lists.ozlabs.org Cc: Gerhard Pircher <gerhard_pircher@gmx.net> Link: http://lkml.kernel.org/r/20110601180610.984881988@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-08-01of/address: Clean up function declarationsGrant Likely
This patch moves the declaration of of_get_address(), of_get_pci_address(), and of_pci_address_to_resource() out of arch code and into the common linux/of_address header file. This patch also fixes some of the asm/prom.h ordering issues. It still includes some header files that it ideally shouldn't be, but at least the ordering is consistent now so that of_* overrides work. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-08-20powerpc/amigaone: Convert amigaone_init() to a machine_device_initcall()Gerhard Pircher
This allows to remove the ppc_md.init() hook in the setup code. Signed-off-by: Gerhard Pircher <gerhard_pircher@gmx.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-11powerpc/kconfig: Kill PPC_MULTIPLATFORMBenjamin Herrenschmidt
CONFIG_PPC_MULTIPLATFORM is a remain of the pre-powerpc days and isn't really meaningful anymore. It was basically equivalent to PPC64 || 6xx. This removes it along with the following changes: - 32-bit platforms that relied on PPC32 && PPC_MULTIPLATFORM now rely on 6xx which is what they want anyway. - A new symbol, PPC_BOOK3S, is defined that represent compliance with the "Server" variant of the architecture. This is set when either 6xx or PPC64 is set and open the door for future BOOK3E 64-bit. - 64-bit platforms that relied on PPC64 && PPC_MULTIPLATFORM now use PPC64 && PPC_BOOK3S - A separate and selectable CONFIG_PPC_OF_BOOT_TRAMPOLINE option is now used to control the use of prom_init.c Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-11powerpc/amigaone: Add platform support for AmigaOneGerhard Pircher
This commit adds the setup code for booting Linux on AmigaOne G3SE (G3 only), AmigaOne XE and uA1 (G3/G4) desktop computers. These boards were sold by Eyetech and are based on MAI Logic's Teron boards and its Articia S northbridge. The AmigaOne uses U-boot as firmware, which doesn't support a flattened device tree yet. The northbridge has some design flaws, which makes it necessary to use non cacheable memory for DMA operations (CONFIG_NOT_COHERENT_CACHE) and to avoid setting the coherence (M) flag for memory pages. Signed-off-by: Gerhard Pircher <gerhard_pircher@gmx.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
