path: root/arch/powerpc/platforms/cell/Kconfig
2008-04-24[POWERPC] celleb: Move the files for celleb base supportIshizaki Kou
This moves the base code for celleb support into platforms/cell/. All files in this patch are used by celleb-beat and celleb-native commonly. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-06[POWERPC] spufs: Add marker-based tracing facilityChristoph Hellwig
This adds markers two important points in the spufs code and a new module (sputrace.ko) that allows reading these out through a proc file. Long-term I'd rather see something like lttng extended to use the spufs instrumentation, but for now I think this is a good enough quick solution. We'll probably want to add various addition event in addition to that ones I have already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-28[POWERPC] Oprofile: Remove dependency on spufs moduleBob Nelson
This removes an OProfile dependency on the spufs module. This dependency was causing a problem for multiplatform systems that are built with support for Oprofile on Cell but try to load the oprofile module on a non-Cell system. Signed-off-by: Bob Nelson <rrnelson@us.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-10Device tree aware EMAC driverDavid Gibson
Based on BenH's earlier work, this is a new version of the EMAC driver for the built-in ethernet found on PowerPC 4xx embedded CPUs. The same ASIC is also found in the Axon bridge chip. This new version is designed to work in the arch/powerpc tree, using the device tree to probe the device, rather than the old and ugly arch/ppc OCP layer. This driver is designed to sit alongside the old driver (that lies in drivers/net/ibm_emac and this one in drivers/net/ibm_newemac). The old driver is left in place to support arch/ppc until arch/ppc itself reaches its final demise (not too long now, with luck). This driver still has a number of things that could do with cleaning up, but I think they can be fixed up after merging. Specifically: - Should be adjusted to properly use the dma mapping API. Axon needs this. - Probe logic needs reworking, in conjuction with the general probing code for of_platform devices. The dependencies here between EMAC, MAL, ZMII etc. make this complicated. At present, it usually works, because we initialize and register the sub-drivers before the EMAC driver itself, and (being in driver code) runs after the devices themselves have been instantiated from the device tree. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20[CELL] cbe_cpufreq: reorganize codeChristian Krafft
This patch reorganizes the code of the driver into three files. Two cbe_cpufreq_pmi.c and cbe_cpufreq_pervasive.c care about hardware. cbe_cpufreq.c contains the logic. There is no changed behaviour, except that the PMI related function is now located in a seperate module cbe_cpufreq_pmi. This module will be required by cbe_cpufreq, if CONFIG_CBE_CPUFREQ_PMI has been set. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-05-09[POWERPC] Spufs support for 64K LS mappings on 4K kernelsBenjamin Herrenschmidt
This adds an option to spufs when the kernel is configured for 4K page to give it the ability to use 64K pages for SPE local store mappings. Currently, we are optimistic and try order 4 allocations when creating contexts. If that fails, the code will fallback to 4K automatically. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] CBE thermal support on PS3Geert Uytterhoeven
I wanted to enable CBE_THERM on PS3. So I had to enable CBE_RAS first. But the resulting kernel doesn't link, as cbe_regs.c isn't compiled for non-PPC_CELL_NATIVE. CBE_RAS should depend on PPC_CELL_NATIVE; this makes it so. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-22[POWERPC] Split cell platforms into their respective Kconfig fileKumar Gala
Cleaning up arch/powerpc/Kconfig platform support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-25[POWERPC] cell: add cpufreq driver for Cell BE processorChristian Krafft
This patch adds a cpufreq backend driver to enable frequency scaling on cell. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] cell: add temperature to SPU and CPU sysfs entriesChristian Krafft
This patch adds a module that registers sysfs attributes to CPU and SPU containing the temperature of the CBE. They can be found under /sys/devices/system/spu/cpuX/thermal/temperature[0|1] /sys/devices/system/spu/spuX/thermal/temperature The temperature is read from the on-chip temperature sensors. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-05[POWERPC] spufs: cell spu problem state mapping updatesBenjamin Herrenschmidt
This patch adds a new "psmap" file to spufs that allows mmap of all of the problem state mapping of SPEs. It is compatible with 64k pages. In addition, it removes mmap ability of individual files when using 64k pages, with the exception of signal1 and signal2 which will both map the entire 64k page holding both registers. It also removes CONFIG_SPUFS_MMAP as there is no point in not building mmap support in spufs. It goes along a separate patch to libspe implementing usage of that new file to access problem state registers. Another patch will follow up to fix races opened up by accessing the 'runcntl' register directly, which is made possible with this patch. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-28[POWERPC] spufs: fix memory hotplug dependencyGeoff Levand
spufs_base.c calls __add_pages, which depends on CONFIG_MEMORY_HOTPLUG. Moved the selection of CONFIG_MEMORY_HOTPLUG from CONFIG_SPUFS_MMAP to CONFIG_SPU_FS. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-21[POWERPC] spufs: split the Cell BE support into generic and platform ↵Geoff Levand
dependant parts Creates new config variables PPC_CELL_NATIVE and PPC_IBM_CELL_BLADE. The existing CONFIG_PPC_CELL is now used to denote the generic Cell processor support. PPC_CELL = make descends into platforms/cell PPC_CELL_NATIVE = add bare metal support PPC_IBM_CELL_BLADE = add blade device drivers, etc. Also renames spu_priv1.c to spu_priv1_mmio.c. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-21[POWERPC] cell: add RAS supportBenjamin Herrenschmidt
This is a first version of support for the Cell BE "Reliability, Availability and Serviceability" features. It doesn't yet handle some of the RAS interrupts (the ones described in iic_is/iic_irr), I'm still working on a proper way to expose these. They are essentially a cascaded controller by themselves (sic !) though I may just handle them locally to the iic driver. I need also to sync with David Erb on the way he hooked in the performance monitor interrupt. So that's all for 2.6.17 and I'll do more work on that with my rework of the powerpc interrupt layer that I'm hacking on at the moment. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-01[PATCH] spufs: fix for CONFIG_NUMAJoel H Schopp
Based on an older patch from Mike Kravetz <kravetz@us.ibm.com> We need to have a mem_map for high addresses in order to make fops->no_page work on spufs mem and register files. So far, we have used the memory_present() function during early bootup, but that did not work when CONFIG_NUMA was enabled. We now use the __add_pages() function to add the mem_map when loading the spufs module, which is a lot nicer. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] spufs: enable SPE problem state MMIO access.Mark Nutter
This patch is layered on top of CONFIG_SPARSEMEM and is patterned after direct mapping of LS. This patch allows mmap() of the following regions: "mfc", which represents the area from [0x3000 - 0x3fff]; "cntl", which represents the area from [0x4000 - 0x4fff]; "signal1" which begins at offset 0x14000; "signal2" which begins at offset 0x1c000. The signal1 & signal2 files may be mmap()'d by regular user processes. The cntl and mfc file, on the other hand, may only be accessed if the owning process has CAP_SYS_RAWIO, because they have the potential to confuse the kernel with regard to parallel access to the same files with regular file operations: the kernel always holds a spinlock when accessing registers in these areas to serialize them, which can not be guaranteed with user mmaps, Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] spufs: The SPU file system, baseArnd Bergmann
This is the current version of the spu file system, used for driving SPEs on the Cell Broadband Engine. This release is almost identical to the version for the 2.6.14 kernel posted earlier, which is available as part of the Cell BE Linux distribution from http://www.bsc.es/projects/deepcomputing/linuxoncell/. The first patch provides all the interfaces for running spu application, but does not have any support for debugging SPU tasks or for scheduling. Both these functionalities are added in the subsequent patches. See Documentation/filesystems/spufs.txt on how to use spufs. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
