This moves the base code for celleb support into platforms/cell/.
All files in this patch are used by celleb-beat and celleb-native
commonly.
Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
This adds markers two important points in the spufs code and a new
module (sputrace.ko) that allows reading these out through a proc file.
Long-term I'd rather see something like lttng extended to use the spufs
instrumentation, but for now I think this is a good enough quick
solution. We'll probably want to add various addition event in addition
to that ones I have already.
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
This removes an OProfile dependency on the spufs module. This
dependency was causing a problem for multiplatform systems that are
built with support for Oprofile on Cell but try to load the oprofile
module on a non-Cell system.
Signed-off-by: Bob Nelson <rrnelson@us.ibm.com>
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Acked-by: Jeremy Kerr <jk@ozlabs.org>
Based on BenH's earlier work, this is a new version of the EMAC driver
for the built-in ethernet found on PowerPC 4xx embedded CPUs. The
same ASIC is also found in the Axon bridge chip. This new version is
designed to work in the arch/powerpc tree, using the device tree to
probe the device, rather than the old and ugly arch/ppc OCP layer.
This driver is designed to sit alongside the old driver (that lies in
drivers/net/ibm_emac and this one in drivers/net/ibm_newemac). The
old driver is left in place to support arch/ppc until arch/ppc itself
reaches its final demise (not too long now, with luck).
This driver still has a number of things that could do with cleaning
up, but I think they can be fixed up after merging. Specifically:
- Should be adjusted to properly use the dma mapping API.
Axon needs this.
- Probe logic needs reworking, in conjuction with the general
probing code for of_platform devices. The dependencies here between
EMAC, MAL, ZMII etc. make this complicated. At present, it usually
works, because we initialize and register the sub-drivers before the
EMAC driver itself, and (being in driver code) runs after the devices
themselves have been instantiated from the device tree.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This patch reorganizes the code of the driver into three files.
Two cbe_cpufreq_pmi.c and cbe_cpufreq_pervasive.c care about hardware.
cbe_cpufreq.c contains the logic.
There is no changed behaviour, except that the PMI related function
is now located in a seperate module cbe_cpufreq_pmi. This module
will be required by cbe_cpufreq, if CONFIG_CBE_CPUFREQ_PMI has been set.
Signed-off-by: Christian Krafft <krafft@de.ibm.com>
This adds an option to spufs when the kernel is configured for
4K page to give it the ability to use 64K pages for SPE local store
mappings.
Currently, we are optimistic and try order 4 allocations when creating
contexts. If that fails, the code will fallback to 4K automatically.
I wanted to enable CBE_THERM on PS3. So I had to enable CBE_RAS first.
But the resulting kernel doesn't link, as cbe_regs.c isn't compiled for
non-PPC_CELL_NATIVE.
CBE_RAS should depend on PPC_CELL_NATIVE; this makes it so.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cleaning up arch/powerpc/Kconfig platform support.
This patch adds a cpufreq backend driver to enable frequency scaling on cell.
This patch adds a module that registers sysfs attributes to CPU and SPU
containing the temperature of the CBE.
They can be found under
/sys/devices/system/spu/cpuX/thermal/temperature[0|1]
/sys/devices/system/spu/spuX/thermal/temperature
The temperature is read from the on-chip temperature sensors.
This patch adds a new "psmap" file to spufs that allows mmap of all of
the problem state mapping of SPEs. It is compatible with 64k pages. In
addition, it removes mmap ability of individual files when using 64k
pages, with the exception of signal1 and signal2 which will both map the
entire 64k page holding both registers. It also removes
CONFIG_SPUFS_MMAP as there is no point in not building mmap support in
spufs.
It goes along a separate patch to libspe implementing usage of that new
file to access problem state registers.
Another patch will follow up to fix races opened up by accessing
the 'runcntl' register directly, which is made possible with this
patch.
spufs_base.c calls __add_pages, which depends on CONFIG_MEMORY_HOTPLUG.
Moved the selection of CONFIG_MEMORY_HOTPLUG from CONFIG_SPUFS_MMAP
to CONFIG_SPU_FS.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
dependant parts
Creates new config variables PPC_CELL_NATIVE and PPC_IBM_CELL_BLADE.
The existing CONFIG_PPC_CELL is now used to denote the generic
Cell processor support.
PPC_CELL = make descends into platforms/cell
PPC_CELL_NATIVE = add bare metal support
PPC_IBM_CELL_BLADE = add blade device drivers, etc.
Also renames spu_priv1.c to spu_priv1_mmio.c.
This is a first version of support for the Cell BE "Reliability,
Availability and Serviceability" features.
It doesn't yet handle some of the RAS interrupts (the ones described in
iic_is/iic_irr), I'm still working on a proper way to expose these. They
are essentially a cascaded controller by themselves (sic !) though I may
just handle them locally to the iic driver. I need also to sync with
David Erb on the way he hooked in the performance monitor interrupt.
So that's all for 2.6.17 and I'll do more work on that with my rework of
the powerpc interrupt layer that I'm hacking on at the moment.
Based on an older patch from Mike Kravetz <kravetz@us.ibm.com>
We need to have a mem_map for high addresses in order to make fops->no_page
work on spufs mem and register files. So far, we have used the
memory_present() function during early bootup, but that did not work when
CONFIG_NUMA was enabled.
We now use the __add_pages() function to add the mem_map when loading the
spufs module, which is a lot nicer.
This patch is layered on top of CONFIG_SPARSEMEM
and is patterned after direct mapping of LS.
This patch allows mmap() of the following regions:
"mfc", which represents the area from [0x3000 - 0x3fff];
"cntl", which represents the area from [0x4000 - 0x4fff];
"signal1" which begins at offset 0x14000; "signal2" which
begins at offset 0x1c000.
The signal1 & signal2 files may be mmap()'d by regular user
processes. The cntl and mfc file, on the other hand, may
only be accessed if the owning process has CAP_SYS_RAWIO,
because they have the potential to confuse the kernel
with regard to parallel access to the same files with
regular file operations: the kernel always holds a spinlock
when accessing registers in these areas to serialize them,
which can not be guaranteed with user mmaps,
This is the current version of the spu file system, used
for driving SPEs on the Cell Broadband Engine.
This release is almost identical to the version for the
2.6.14 kernel posted earlier, which is available as part
of the Cell BE Linux distribution from
http://www.bsc.es/projects/deepcomputing/linuxoncell/.
The first patch provides all the interfaces for running
spu application, but does not have any support for
debugging SPU tasks or for scheduling. Both these
functionalities are added in the subsequent patches.
See Documentation/filesystems/spufs.txt on how to use
spufs.
Signed-off-by: Arnd Bergmann <arndb@de.ibm.com>
