path: root/arch/powerpc/platforms/cell/cbe_cpufreq.c
2007-12-19[POWERPC] cell: Convert #include of asm/of_{platform, device}.h into ↵Jon Loeliger
linux/of_{platform, device}.h. Signed-off-by: Jon Loeliger <jdl@freescale.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2007-10-16Convert cpu_sibling_map to be a per cpu variableMike Travis
Convert cpu_sibling_map from a static array sized by NR_CPUS to a per_cpu variable. This saves sizeof(cpumask_t) * NR unused cpus. Access is mostly from startup and CPU HOTPLUG functions. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Don't take semaphore in cpufreq_quick_get() [CPUFREQ] Support different families in fid/did to frequency conversion [CPUFREQ] cpufreq_stats: misc cpuinit section annotations [CPUFREQ] implement !CONFIG_CPU_FREQ stub for cpufreq_unregister_notifier() [CPUFREQ] mark hotplug notifier callback as __cpuinit [CPUFREQ] Only check for transition latency on problematic governors (kconfig fix) [CPUFREQ] allow ondemand and conservative cpufreq governors to be used as default [CPUFREQ] move policy's governor initialisation out of low-level drivers into cpufreq core [CPUFREQ] Longhaul - Add support for PM133 northbridge [CPUFREQ] x86: use num_online_nodes to get physical cpus numbers for
2007-10-09[POWERPC] cell: Move cbe_regs.h to include/asm-powerpc/cell-regs.hBenjamin Herrenschmidt
The new Cell EDAC driver needs that file, oprofile also does ugly path tricks to get to it, it's time to move it to asm-powerpc. While at it, rename it to be consistent with cell-pmu.h (and dashes look nicer than underscores anyway). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-04[CPUFREQ] move policy's governor initialisation out of low-level drivers ↵Thomas Renninger
into cpufreq core Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-07-20[CELL] fix cbe_cpufreq for legacy SLOF tree.Jean-Christophe DUBOIS
Previous patch changed based on Christian Krafft's comment. On some legacy SLOF tree the generic code is unable to ioremap some Cell BE registers. Therefore the "generic" functions are returning a NULL pointer, triggering a crash on such platforms. Let's handle this more gracefully. Signed-off-by: Jean-Christophe DUBOIS <jcd@tribudubois.net> Acked-by: Christian Kraff <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-07-20[CELL] cbe_cpufreq: reorganize codeChristian Krafft
This patch reorganizes the code of the driver into three files. Two cbe_cpufreq_pmi.c and cbe_cpufreq_pervasive.c care about hardware. cbe_cpufreq.c contains the logic. There is no changed behaviour, except that the PMI related function is now located in a seperate module cbe_cpufreq_pmi. This module will be required by cbe_cpufreq, if CONFIG_CBE_CPUFREQ_PMI has been set. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-07-20[CELL] cbe_cpufreq: fix minor issuesChristian Krafft
Minor issues have been fixed: * added a missing call to of_node_put() * signedness of a function parameter * added some line breaks * changed global pmi_frequency_limit to a per node pmi_slow_mode_limit array Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-07-20[CELL] cbe_cpufreq: fix initializationChristian Krafft
This patch fixes the initialization of the cbe_cpufreq driver. The code that initializes the PMI related functions was called per cpu: * registering cpufreq notifier block * registering a pmi handler This ends in a bug that the notifier block gets called in an endless loop. The initialization code is being put to the module init code path by this patch. This way it only gets called once. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-07-20[CELL] cbe_cpufreq: fix latency measurementChristian Krafft
This patch fixes the debug code that calculates the transition time when changing the slow modes on a Cell BE cpu. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-07-20[CELL] pmi: remove support for mutiple devices.Christian Krafft
The pmi driver got simplified by removing support for multiple devices. As there is no more than one pmi device per maschine, there is no need to specify the device for listening and sending messages. This way the caller (cbe_cpufreq) doesn't need to scan the device tree. When registering the handler on a board without a pmi interface, pmi.c will just return -ENODEV. The patch that fixed the breakage of cell_defconfig has been broken out of the earlier version of this patch. So this is the version that applies cleanly on top of it. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-07-02[POWERPC] Fix PMI breakage in cbe_cbufreq driverChristian Krafft
The recent change to cell_defconfig to enable cpufreq on Cell exposed the fact that the cbe_cpufreq driver currently needs the PMI interface code to compile, but Kconfig doesn't make sure that the PMI interface code gets built if cbe_cpufreq is enabled. In fact cbe_cpufreq can work without PMI, so this ifdefs out the code that deals with PMI. This is a minimal solution for 2.6.22; a more comprehensive solution will be merged for 2.6.23. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-07[POWERPC] cbe_cpufreq: Limit frequency via cpufreq notifier chainThomas Renninger
... and get rid of cpufreq_set_policy call that caused a build failure due interfering commits. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30[POWERPC] cell: cbe_cpufreq cleanup and crash fixOlof Johansson
cbe_cpufreq cleanups: * comment format * whitespace * don't init on non-cell platforms Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-23[POWERPC] cell: use pmi in cpufreq driverChristian Krafft
The new PMI driver was added in order to support cpufreq on blades that require the frequency to be controlled by the service processor, so use it on those. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-04-13[POWERPC] Rename get_property to of_get_property: the last oneStephen Rothwell
This also fixes a bug where a property value was being modified in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] cell: add cpufreq driver for Cell BE processorChristian Krafft
This patch adds a cpufreq backend driver to enable frequency scaling on cell. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
