Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
We shouldn't directly access sysdata to get the device node to just
go get the pci_controller. We can call pci_bus_to_host() for this
purpose.
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER
architecture does:
This enables us to cleanly fix the Calgary IOMMU issue that some devices
are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423).
I think that per-device dma_mapping_ops support would be also helpful for
KVM people to support PCI passthrough but Andi thinks that this makes it
difficult to support the PCI passthrough (see the above thread). So I
CC'ed this to KVM camp. Comments are appreciated.
A pointer to dma_mapping_ops to struct dev_archdata is added. If the
pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's
NULL, the system-wide dma_ops pointer is used as before.
If it's useful for KVM people, I plan to implement a mechanism to register
a hook called when a new pci (or dma capable) device is created (it works
with hot plugging). It enables IOMMUs to set up an appropriate
dma_mapping_ops per device.
The major obstacle is that dma_mapping_error doesn't take a pointer to the
device unlike other DMA operations. So x86 can't have dma_mapping_ops per
device. Note all the POWER IOMMUs use the same dma_mapping_error function
so this is not a problem for POWER but x86 IOMMUs use different
dma_mapping_error functions.
The first patch adds the device argument to dma_mapping_error. The patch
is trivial but large since it touches lots of drivers and dma-mapping.h in
all the architecture.
This patch:
dma_mapping_error() doesn't take a pointer to the device unlike other DMA
operations. So we can't have dma_mapping_ops per device.
Note that POWER already has dma_mapping_ops per device but all the POWER
IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device
argument.
[akpm@linux-foundation.org: fix sge]
[akpm@linux-foundation.org: fix svc_rdma]
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix bnx2x]
[akpm@linux-foundation.org: fix s2io]
[akpm@linux-foundation.org: fix pasemi_mac]
[akpm@linux-foundation.org: fix sdhci]
[akpm@linux-foundation.org: fix sparc]
[akpm@linux-foundation.org: fix ibmvscsi]
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
Cc: Avi Kivity <avi@qumranet.com>
This adds support for PCI Express port on Celleb. I/O space of this
PCI Express port is not mapped in memory space. So we use the
io-workaround mechanism to make accesses indirect.
Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
