Initial splitoff of the low-level stuff; taken to fdtable.h
At present, ppu-gdb can't trace spu infomation with coredump generated
by the kernel. While the core dumps notes have correct contents, they
have the wrong names, as the file descriptors used to generate the note
names are off-by-one. An application that opens a SPE context as fd 3,
the current core dump code will generate notes like:
SPU/4/mem
SPU/4/regs
etc.
This confuses GDB, which knows it is looking for SPE context 3 (from
parsing the spu_context_run system call arguments), and cannot find
any notes that match context 3.
This change corrects the file descriptor counting, to only increment
the fd until after we've written the note name.
Signed-off-by: Gerhard Stenzel <stenzel@de.ibm.com>
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
Make most places that use spu_acquire/spu_acquire_saved interruptible,
this allows getting out of the spufs code when e.g. pressing ctrl+c.
There are a few places where we get called e.g. from spufs teardown
routines were we can't simply err out so these are left with a comment.
For now I've also not touched the poll routines because it's open what
libspe would expect in terms of interrupted system calls.
Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Currently the spu coredump code doesn't respect the ulimit, it should.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
a pipe
Rework spufs_coredump_extra_notes_write() to check for and return errors.
If we're coredumping to a pipe we can't trust file->f_pos, we need to
maintain the foffset value passed to us. The cleanest way to do this is
to have the low level write routine increment foffset when we've
successfully written.
Because spufs might be built as a module, we can't have other parts of the
kernel calling directly into it, we need stub routines that check first if the
module is loaded.
Currently we have two structures which hold callbacks for these stubs, the
syscalls are in spufs_calls and the coredump calls are in spufs_coredump_calls.
In both cases the logic for registering/unregistering is essentially the same,
so we can simplify things by combining the two.
NULL terminate
The spufs_coredump_read array is NULL terminated, and we also store the size.
We only need one or the other, and the other arrays in file.c are NULL
terminated, so do that.
The routine to dump the local store, __spufs_mem_read(), does not take the
spu_lslr_RW value into account - so we shouldn't check it when we're
calculating the size either.
Unfortunately GDB expects some of the SPU coredump values to be identical
in format to what is found in spufs. This means we need to dump some of
the values as ASCII strings, not the actual values.
Because we don't know what the values will be, we always print the values
with the format "0x%.16lx", that way we know the result will be 19 bytes.
do_coredump_read() doesn't take a __user buffer, so remove the annotation,
and because we know that it's safe to just snprintf() directly to it.
It makes sense to stop the SPU processes as soon as possible. Also if we
dont acquire_saved() I think there's a possibility that the value in
csa.priv2.spu_lslr_RW won't be accurate.
Remove the ctx_info struct entirely, and also the ctx_info_list. This
fixes a race where two processes can clobber each other's ctx_info structs.
Instead of using the list, we just repeat the search through the file
descriptor table.
Extract the logic for searching through the file descriptors for spu contexts
into a separate routine, coredump_next_context(), so we can use it elsewhere
in future. In the process we flatten the for loop, and move the NOSCHED test
into coredump_next_context().
Currently a process is removed from the physical spu when spu_acquire_saved
is saved but never put back. This patch adds a new spu_release_saved
that is to be paired with spu_acquire_saved and put the process back if
it has been in RUNNABLE state before.
Niether Jeremy not be are entirely happy about this exact patch because
it adds another spu_activate call outside of the owner thread, but I
feel this is the best short-term fix we can come up with.
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Dynamically allocated read/write buffer in spufs_arch_write_note() will
not be freed. Convert it to get_free_page at the same time.
Cc: Akinobu Mita <mita@fixstars.com>
Commit bbea9f69668a3d0cf9feba15a724cd02896f8675 removed the max_fdset
element of struct fdtable. It appears that checking max_fds is
sufficient now.
This patch adds SPU elf notes to the coredump. It creates a separate note
for each of /regs, /fpcr, /lslr, /decr, /decr_status, /mem, /signal1,
/signal1_type, /signal2, /signal2_type, /event_mask, /event_status,
/mbox_info, /ibox_info, /wbox_info, /dma_info, /proxydma_info, /object-id.
A new macro, ARCH_HAVE_EXTRA_NOTES, was created for architectures to
specify they have extra elf core notes.
A new macro, ELF_CORE_EXTRA_NOTES_SIZE, was created so the size of the
additional notes could be calculated and added to the notes phdr entry.
A new macro, ELF_CORE_WRITE_EXTRA_NOTES, was created so the new notes
would be written after the existing notes.
The SPU coredump code resides in spufs. Stub functions are provided in the
kernel which are hooked into the spufs code which does the actual work via
register_arch_coredump_calls().
A new set of __spufs_<file>_read/get() functions was provided to allow the
coredump code to read from the spufs files without having to lock the
SPU context for each file read from.
Cc: <linux-arch@vger.kernel.org>
Signed-off-by: Dwayne Grant McConnell <decimal@us.ibm.com>
