This processor/memory module was mostly used on ATCA blades and
before that, on cPCI blades. It wasn't really user friendly, with
custom non u-boot bootloaders (powerboot/motload) and no real way
to recover corrupted boot flash (which was a common problem).
As such, it had its day back before the big ppc --> powerpc move
to device trees, and that was largely through commercial BSPs that
started to dry up around 2007.
Systems using one were largely in a "deploy and sustain" mode,
so interest in upgrading to new kernels in the field was nil.
Also, requiring 50A, 48V power supplies and a 2'x2'x2' ATCA
chassis largely rules out any hobbyist/enthusiast interest.
The point of all this, is that we might as well delete the in
kernel files relating to this platform. No point in continuing
to build it via walking the defconfigs or via linux-next testing.
Cc: linuxppc-dev@lists.ozlabs.org
Add support for the Motorola/Emerson MVME5100 Single Board Computer.
The MVME5100 is a 6U form factor VME64 computer with:
- A single MPC7410 or MPC750 CPU
- A HAWK Processor Host Bridge (CPU to PCI) and
MultiProcessor Interrupt Controller (MPIC)
- Up to 500Mb of onboard memory
- A M48T37 Real Time Clock (RTC) and Non-Volatile Memory chip
- Two 16550 compatible UARTS
- Two Intel E100 Fast Ethernets
- Two PCI Mezzanine Card (PMC) Slots
- PPCBug Firmware
The HAWK PHB/MPIC is compatible with the MPC10x devices.
There is no onboard disk support. This is usually provided by installing a PMC
in first PMC slot.
This patch revives the board support, it was present in early 2.6
series kernels. The board support in those days was by Matt Porter of
MontaVista Software.
CSC Australia has around 31 of these boards in service. The kernel in use
for the boards is based on 2.6.31. The boards are operated without disks
from a file server.
This patch is based on linux-3.13-rc2 and has been boot tested.
Only boards with 512 Mb of memory are known to work.
Signed-off-by: Stephen Chivers <schivers@csc.com>
Tested-by: Alessio Igor Bogani <alessio.bogani@elettra.eu>
Add platform support for the Nintendo Wii video game console.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Segher Boessenkool <segher@kernel.crashing.org>
Add support for the dual interrupt controller included in the "Hollywood"
chipset of the Nintendo Wii video game console.
This interrupt controller serves both the Broadway processor (as a cascade)
and the Starlet processor, and is used to manage interrupts for the
non-classic hardware.
Add platform support for the Nintendo GameCube video game console.
Add support for the interrupt controller included in the "Flipper"
chipset of the Nintendo GameCube video game console.
The same interrupt controller is also present in the "Hollywood" chipset
of the Nintendo Wii.
Add support for using the USB Gecko adapter via the udbg facility on
the Nintendo GameCube and Wii video game consoles.
The USB Gecko is a 3rd party memory card interface adapter that provides
a EXI (External Interface) to USB serial converter.
Support for the C2K cPCI Single Board Computer from GEFanuc
(PowerPC MPC7448 with a Marvell MV64460 chipset).
All features of the board are not supported yet, but the board
boots, flash works, all Ethernet ports are working and PCI
devices are all found (USB and SATA on PCI1 do not work yet).
Part 3 of 5: driver for the board. At this time it is very generic
and similar to its original, the driver for the prpmc2800.
Signed-off-by: Remi Machet <rmachet@slac.stanford.edu>
Use cuImage bootwrapper until U-Boot port is completed.
Derived heavily from Linkstation port.
Acked-by: Andy Wilcox <andy@protium.com>
This finally adds the PPC_PRPMC2800 Kconfig option, the board setup
code (the setup and reset functions) and the defconfig, to support the
Motorola PrPMC2800 platform.
Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
Add PowerPC 750 Holly/Hickory platform support
Signed-off-by: Stephen Winiecki <stevewin@us.ibm.com>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Acked-by: Olof Johansson <olof@lixom.net>
Support for the Kurobox(HG)/LinkStation-I NAS systems by Buffalo
Technology, should be also applicable to the PPC TeraStation family.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Add support for Freescale mpc7448 (Taiga) board support
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
